Why 24bit/48kHz/96kHz/, If 16bit/44.1kHz is good enough?
William
post Dec 29 2005, 13:45
Yes, I have searched the forum.
Yes, maybe I am dumb.
But it seems I cannot find the answer.
Why do we need 24bit/48kHz/96kHz/192kHz if 16bit/44.1kHz is good enough? Are there any situations that 16bit/44.1kHz simply cannot satisfy? In other words, is there any real need for the higher bit depth and sampling rate?
Thanks for answering.
This post has been edited by William: Dec 29 2005, 13:47
Axon
post Dec 30 2005, 19:39
Group: Members (Donating)
Some DSP algorithms may benefit from a high sampling rate, but strictly speaking, they can all be written to work fine at 44.1, or else the algorithm itself will just include its own resampler to do what it needs to do. (A trivially naive example: suppose you want to make a comb filter in less than 10 taps with a starting freq of 12khz. AFAIK, you can't do that with a 44.1 sampling rate, or else you could do it more easily with 96 than you could with 44.1.)
Low integral resamples (88.2 -> 44.1) are quite a bit easier on the math compared to 96->44.1. It shouldn't make an audible difference but the filters need to be much much more complex for the 96 downsample to be legitimate.
The 44.1khz frequency was chosen because the first PCM machines used (drumroll) analog videotape as its media. The math worked out that at 16 bits of resolution you could cram enough samples into a video frame to get 44.1.
The really ironic thing about 192khz is that the SNR numbers are objectively worse compared to 96khz recording (to say nothing of 44.1). Virtually all ADCs are sigma-delta nowadays anyway, and one of their fundamental characteristics is that you can always trade off frequency for resolution. There are a couple hardware vendors who actively speak out against 192khz recording for this reason.
In fact I'd almost argue that 192khz was just as much driven by hardware vendors than audiophiles. They're already trying to cram DxD down studios' necks. 8 bits at 384khz... yuck.
- William   Why 24bit/48kHz/96kHz/   Dec 29 2005, 13:45
- - Lyx   QUOTE (William @ Dec 29 2005, 01:45 PM)Why do...   Dec 29 2005, 13:53
|- - krabapple   QUOTE (Lyx @ Dec 29 2005, 07:53 AM)QUOTE (Wil...   Jan 6 2006, 20:04
- - William   I heard someone saying that increasing the samplin...   Dec 29 2005, 14:09
|- - Garf   QUOTE (William @ Dec 29 2005, 03:09 PM)I hear...   Dec 29 2005, 14:13
|- - William   QUOTE (Garf @ Dec 29 2005, 01:13 PM)Normally,...   Dec 29 2005, 14:22
|- - Garf   QUOTE (William @ Dec 29 2005, 03:22 PM)Would ...   Dec 29 2005, 14:45
- - bizangoin   I totally agree with you all. Increasing sample ra...   Dec 29 2005, 14:32
- - William   I am sorry. Thanks.   Dec 29 2005, 14:59
- - singaiya   QUOTE (William @ Dec 29 2005, 04:45 AM)Why do...   Dec 29 2005, 18:44
|- - bug80   QUOTE (singaiya @ Dec 29 2005, 07:44 PM)I hav...   Dec 29 2005, 22:16
- - rosshmusic   I agree that it makes no difference to end users.....   Dec 29 2005, 21:32
|- - Garf   QUOTE (rosshmusic @ Dec 29 2005, 10:32 PM)I a...   Dec 29 2005, 21:46
|- - listen   I had a thread here: http://www.hydrogenaudio.org/...   Dec 29 2005, 22:24
|- - rosshmusic   QUOTE (Garf @ Dec 29 2005, 04:46 PM)QUOTE (ro...   Dec 29 2005, 22:55
||- - Garf   QUOTE (rosshmusic @ Dec 29 2005, 11:55 PM)htt...   Dec 29 2005, 23:58
||- - rosshmusic   QUOTE (Garf @ Dec 29 2005, 06:58 PM)QUOTE (ro...   Dec 30 2005, 02:59
||- - bug80   QUOTE (rosshmusic @ Dec 30 2005, 03:59 AM)whe...   Dec 30 2005, 13:54
|- - krabapple   QUOTE (Garf @ Dec 29 2005, 03:46 PM)QUOTE (ro...   Jan 6 2006, 20:10
- - Tool462   ok, i'm a newb so don't give me some slack...   Dec 29 2005, 22:50
|- - Garf   QUOTE (Tool462 @ Dec 29 2005, 11:50 PM)ok, i...   Dec 30 2005, 00:01
- - Revliskciuq   I have to step out and disagree that there is no a...   Dec 30 2005, 03:11
|- - Garf   QUOTE (Revliskciuq @ Dec 30 2005, 04:11 AM)I ...   Dec 30 2005, 13:59
||- - jmvalin   QUOTE (Garf @ Dec 30 2005, 09:59 PM)Practise ...   Dec 31 2005, 16:22
||- - Garf   QUOTE (jmvalin @ Dec 31 2005, 05:22 PM)Actual...   Dec 31 2005, 16:31
||- - WmAx   QUOTE (jmvalin @ Dec 31 2005, 11:22 AM)but I...   Dec 31 2005, 16:33
||- - Shade[ST]   QUOTE (WmAx @ Dec 31 2005, 09:33 AM)Just to p...   Dec 31 2005, 19:25
||- - WmAx   QUOTE (Shade[ST),Dec 31 2005, 02:25 PM]QUOTE ...   Dec 31 2005, 20:52
||- - enry2k   First: What about ensuring extremely controlled li...   Jan 6 2006, 01:08
||- - Pio2001   QUOTE (William @ Dec 30 2005, 05:03 AM)And wh...   Jan 6 2006, 06:48
||- - krabapple   QUOTE (enry2k @ Jan 5 2006, 07:08 PM)First: W...   Jan 6 2006, 20:27
||- - enry2k   Thank you for quoting the thread, it is really i...   Jan 8 2006, 20:36
|- - crimsontide   QUOTE (Revliskciuq @ Dec 29 2005, 08:11 PM)I ...   Mar 13 2006, 14:36
|- - Cyaneyes   QUOTE (crimsontide @ Mar 13 2006, 08:36 AM)I ...   Mar 13 2006, 15:55
||- - crimsontide   QUOTE (Cyaneyes @ Mar 13 2006, 08:55 AM)QUOTE...   Mar 13 2006, 16:49
|- - Societal Eclipse   QUOTE (crimsontide @ Mar 13 2006, 09:36 AM)An...   Mar 13 2006, 17:40
- - William   OK, so here are some more technical questions I fo...   Dec 30 2005, 04:03
|- - probedb   QUOTE (William @ Dec 30 2005, 04:03 AM)1) The...   Jan 5 2006, 14:28
- - boombaard   so, on a slightly different note, would the 24/96 ...   Dec 30 2005, 14:24
|- - Garf   QUOTE (boombaard @ Dec 30 2005, 03:24 PM)so, ...   Dec 30 2005, 14:25
|- - boombaard   QUOTE (Garf @ Dec 30 2005, 02:25 PM)QUOTE (bo...   Dec 30 2005, 14:37
|- - Garf   QUOTE (boombaard @ Dec 30 2005, 03:37 PM)how ...   Dec 30 2005, 15:13
||- - boombaard   QUOTE (Garf @ Dec 30 2005, 03:13 PM)QUOTE (bo...   Dec 30 2005, 15:46
||- - jussi   well, and what about the HDCD (20bit) technology? ...   Dec 30 2005, 15:52
|||- - Garf   QUOTE (jussi @ Dec 30 2005, 04:52 PM)well, an...   Dec 30 2005, 16:00
||- - Garf   QUOTE (boombaard @ Dec 30 2005, 04:46 PM)QUOT...   Dec 30 2005, 15:56
|- - Crissaegrim   Definitive answer... Artists record at as high as ...   Dec 30 2005, 17:02
|- - bug80   QUOTE (Crissaegrim @ Dec 30 2005, 06:02 PM)De...   Dec 30 2005, 17:09
- - William   Well, it sounds like these 24bits / whatever kHz a...   Dec 30 2005, 15:54
- - Wintershade   Sorry for popping in like that, but here's my ...   Dec 30 2005, 16:04
|- - bug80   QUOTE (Wintershade @ Dec 30 2005, 05:04 PM)So...   Dec 30 2005, 16:25
||- - Wintershade   QUOTE (bug80 @ Dec 30 2005, 05:25 PM)Do you h...   Jan 2 2006, 12:45
|- - krabapple   QUOTE (Wintershade @ Dec 30 2005, 10:04 AM)So...   Jan 6 2006, 20:16
- - Axon   Some DSP algorithms may benefit from a high sampli...   Dec 30 2005, 19:39
- - Lyx   Regarding clipping and samplerate: according to a ...   Dec 30 2005, 19:58
|- - bug80   QUOTE (Lyx @ Dec 30 2005, 08:58 PM)Regarding ...   Dec 31 2005, 12:23
|- - Garf   QUOTE (Lyx @ Dec 30 2005, 08:58 PM)As you kno...   Dec 31 2005, 14:26
- - Raptus   >16bit would be necessary if someone wanted to ...   Dec 30 2005, 20:07
- - NoXFeR   On a sidenote; recorders may want higher frequenci...   Dec 31 2005, 00:05
|- - bug80   QUOTE (NoXFeR @ Dec 31 2005, 01:05 AM)On a si...   Dec 31 2005, 12:16
|- - NoXFeR   QUOTE (bug80 @ Dec 31 2005, 12:16 PM)QUOTE (N...   Dec 31 2005, 15:18
|- - WmAx   QUOTE (NoXFeR @ Dec 31 2005, 10:18 AM)The poi...   Dec 31 2005, 15:29
- - Lyx   One more reason to instead simply use proper level...   Dec 31 2005, 12:33
|- - bug80   QUOTE (Lyx @ Dec 31 2005, 01:33 PM)One more r...   Dec 31 2005, 13:33
|- - Garf   QUOTE (bug80 @ Dec 31 2005, 02:33 PM)QUOTE (L...   Dec 31 2005, 14:20
|- - bug80   QUOTE (Garf @ Dec 31 2005, 03:20 PM)QUOTE (bu...   Dec 31 2005, 14:23
|- - Garf   QUOTE (bug80 @ Dec 31 2005, 03:23 PM)QUOTE (G...   Dec 31 2005, 14:31
- - kwwong   The main reason why sampling rates > 44.1Khz is...   Dec 31 2005, 14:30
|- - Garf   QUOTE (kwwong @ Dec 31 2005, 03:30 PM)The mai...   Dec 31 2005, 14:41
||- - kwwong   QUOTE (Garf @ Dec 31 2005, 07:41 AM)QUOTE (kw...   Jan 1 2006, 04:30
||- - kwwong   QUOTE (kwwong @ Dec 31 2005, 09:30 PM)QUOTE (...   Jan 1 2006, 04:39
|- - WmAx   QUOTE (kwwong @ Dec 31 2005, 09:30 AM)As for ...   Dec 31 2005, 15:39
- - Garf   Another thing to consider is that with proper dith...   Dec 31 2005, 14:51
|- - marcan   QUOTE (Garf @ Dec 31 2005, 05:51 AM)Another t...   Jan 5 2006, 15:57
|- - enry2k   QUOTE (marcan @ Jan 5 2006, 06:57 AM)QUOTE (G...   Jan 8 2006, 21:28
|- - Garf   QUOTE (marcan @ Jan 5 2006, 04:57 PM)QUOTE (G...   Jan 10 2006, 12:33
- - Garf   I think what he's trying to say is this: If y...   Dec 31 2005, 15:31
- - Lyx   I think he means playing 192khz sample at 44khz WI...   Dec 31 2005, 15:31
- - ivalladt   QUOTE (Garf @ Dec 29 2005, 03:13 PM)The quest...   Dec 31 2005, 19:13
- - dekkersj   QUOTE (Garf @ Dec 31 2005, 02:51 PM)Another t...   Jan 2 2006, 15:41
- - Qjimbo   Ok, back to the original question of the thread. T...   Jan 9 2006, 00:20
|- - Lyx   QUOTE (Qjimbo @ Jan 9 2006, 12:20 AM)Firstly ...   Jan 9 2006, 16:17
|- - marcan   QUOTE (Lyx @ Jan 9 2006, 07:17 AM)QUOTE (Qjim...   Jan 9 2006, 17:59
|- - Woodinville   QUOTE (Lyx @ Jan 9 2006, 07:17 AM)This thread...   Jan 10 2006, 00:38
|- - Garf   QUOTE (Woodinville @ Jan 10 2006, 01:38 AM)We...   Jan 10 2006, 12:42
|- - Woodinville   QUOTE (Garf @ Jan 10 2006, 03:42 AM)QUOTE (Wo...   Jan 10 2006, 23:41
- - CSMR   Somehow this question brings out all the know-alls...   Jan 9 2006, 01:52
- - AndyH-ha   The Sampling Theorem says that signals containing ...   Jan 9 2006, 08:28
|- - bug80   QUOTE (AndyH-ha @ Jan 9 2006, 09:28 AM)T...   Jan 9 2006, 10:19
|- - Woodinville   QUOTE (AndyH-ha @ Jan 8 2006, 11:28 PM)T...   Jan 10 2006, 00:41
- - AndyH-ha   My immediately available source is Principles of D...   Jan 9 2006, 18:02
|- - SebastianG   QUOTE (AndyH-ha @ Jan 9 2006, 06:02 PM)o...   Jan 9 2006, 18:30
- - stephanV   @crimsontide: You can never prove a negative. The...   Mar 13 2006, 17:49
|- - crimsontide   QUOTE (stephanV @ Mar 13 2006, 10:49 AM)@crim...   Mar 13 2006, 18:32
- - harlekeyn   16bit means 2^16 = 65536 possible values for each ...   Mar 19 2006, 06:58
|- - Pio2001   QUOTE (harlekeyn @ Mar 19 2006, 07:58 AM)If y...   Mar 19 2006, 22:07
|- - crimsontide   Well I agree with what Tristan said For example ...   Mar 20 2006, 11:03
|- - Woodinville   QUOTE (crimsontide @ Mar 20 2006, 02:03 AM)I ...   Mar 20 2006, 21:19
- - harlekeyn   WHEN COMPARING digital audio to digital photograph...   Apr 4 2006, 16:48
- - benski   With somewhat expensive studio equipment (RME Hamm...   Apr 4 2006, 16:56
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 26th April 2015 - 03:16
