Why 24bit/48kHz/96kHz/, If 16bit/44.1kHz is good enough?
William
post Dec 29 2005, 13:45
Yes, I have searched the forum.
Yes, maybe I am dumb.
But it seems I cannot find the answer.
Why do we need 24bit/48kHz/96kHz/192kHz if 16bit/44.1kHz is good enough? Are there any situations that 16bit/44.1kHz simply cannot satisfy? In other words, is there any real need for the higher bit depth and sampling rate?
Thanks for answering.
This post has been edited by William: Dec 29 2005, 13:47
singaiya
post Dec 29 2005, 18:44
QUOTE (William @ Dec 29 2005, 04:45 AM)
I have read that if you are recording music and performing several layers of edits and signal processing, that higher sampling and/or bit depth may be of actual value to the final mixdown. I don't do that kind of work, so that is hearsay pretty much. For simple audio playback you are correct, 16/44.1 is totally sufficient.
bug80
post Dec 29 2005, 22:16
QUOTE (singaiya @ Dec 29 2005, 07:44 PM)
Exactly. In the digital domain you make rounding errors due to the quantization. If an engineer does all the processing in the 16 bit domain, these rounding errors will build up and therefore decrease the signal to noise ratio. If all the processing is done in the 24 bit domain and the audio is quantized to 16 bits per sample afterwards, these rounding errors will be negligible.
A higher sampling rate is not really necessary.
I also think that's the case. I don't think many people are able to ABX 24 bit versus 16 bit audio, for example. Or 44.1 kHz versus 48 kHz.
edit: I can imagine that a higher sampling rate can be of use if multiple anti-aliasing filters exist in a recording chain. Each anti-aliasing filter will remove high frequencies, so multiple filters may remove too much energy from the high frequency bands. However, in most studios only one A/D converter with anti-aliasing filter is present in the chain (for example in the mixing desk).
This post has been edited by bug80: Dec 29 2005, 22:20
- William   Why 24bit/48kHz/96kHz/   Dec 29 2005, 13:45
- - Lyx   QUOTE (William @ Dec 29 2005, 01:45 PM)Why do...   Dec 29 2005, 13:53
|- - krabapple   QUOTE (Lyx @ Dec 29 2005, 07:53 AM)QUOTE (Wil...   Jan 6 2006, 20:04
- - William   I heard someone saying that increasing the samplin...   Dec 29 2005, 14:09
|- - Garf   QUOTE (William @ Dec 29 2005, 03:09 PM)I hear...   Dec 29 2005, 14:13
|- - William   QUOTE (Garf @ Dec 29 2005, 01:13 PM)Normally,...   Dec 29 2005, 14:22
|- - Garf   QUOTE (William @ Dec 29 2005, 03:22 PM)Would ...   Dec 29 2005, 14:45
- - bizangoin   I totally agree with you all. Increasing sample ra...   Dec 29 2005, 14:32
- - William   I am sorry. Thanks.   Dec 29 2005, 14:59
- - singaiya   QUOTE (William @ Dec 29 2005, 04:45 AM)Why do...   Dec 29 2005, 18:44
|- - bug80   QUOTE (singaiya @ Dec 29 2005, 07:44 PM)I hav...   Dec 29 2005, 22:16
- - rosshmusic   I agree that it makes no difference to end users.....   Dec 29 2005, 21:32
|- - Garf   QUOTE (rosshmusic @ Dec 29 2005, 10:32 PM)I a...   Dec 29 2005, 21:46
|- - listen   I had a thread here: http://www.hydrogenaudio.org/...   Dec 29 2005, 22:24
|- - rosshmusic   QUOTE (Garf @ Dec 29 2005, 04:46 PM)QUOTE (ro...   Dec 29 2005, 22:55
||- - Garf   QUOTE (rosshmusic @ Dec 29 2005, 11:55 PM)htt...   Dec 29 2005, 23:58
||- - rosshmusic   QUOTE (Garf @ Dec 29 2005, 06:58 PM)QUOTE (ro...   Dec 30 2005, 02:59
||- - bug80   QUOTE (rosshmusic @ Dec 30 2005, 03:59 AM)whe...   Dec 30 2005, 13:54
|- - krabapple   QUOTE (Garf @ Dec 29 2005, 03:46 PM)QUOTE (ro...   Jan 6 2006, 20:10
- - Tool462   ok, i'm a newb so don't give me some slack...   Dec 29 2005, 22:50
|- - Garf   QUOTE (Tool462 @ Dec 29 2005, 11:50 PM)ok, i...   Dec 30 2005, 00:01
- - Revliskciuq   I have to step out and disagree that there is no a...   Dec 30 2005, 03:11
|- - Garf   QUOTE (Revliskciuq @ Dec 30 2005, 04:11 AM)I ...   Dec 30 2005, 13:59
||- - jmvalin   QUOTE (Garf @ Dec 30 2005, 09:59 PM)Practise ...   Dec 31 2005, 16:22
||- - Garf   QUOTE (jmvalin @ Dec 31 2005, 05:22 PM)Actual...   Dec 31 2005, 16:31
||- - WmAx   QUOTE (jmvalin @ Dec 31 2005, 11:22 AM)but I...   Dec 31 2005, 16:33
||- - Shade[ST]   QUOTE (WmAx @ Dec 31 2005, 09:33 AM)Just to p...   Dec 31 2005, 19:25
||- - WmAx   QUOTE (Shade[ST),Dec 31 2005, 02:25 PM]QUOTE ...   Dec 31 2005, 20:52
||- - enry2k   First: What about ensuring extremely controlled li...   Jan 6 2006, 01:08
||- - Pio2001   QUOTE (William @ Dec 30 2005, 05:03 AM)And wh...   Jan 6 2006, 06:48
||- - krabapple   QUOTE (enry2k @ Jan 5 2006, 07:08 PM)First: W...   Jan 6 2006, 20:27
||- - enry2k   Thank you for quoting the thread, it is really i...   Jan 8 2006, 20:36
|- - crimsontide   QUOTE (Revliskciuq @ Dec 29 2005, 08:11 PM)I ...   Mar 13 2006, 14:36
|- - Cyaneyes   QUOTE (crimsontide @ Mar 13 2006, 08:36 AM)I ...   Mar 13 2006, 15:55
||- - crimsontide   QUOTE (Cyaneyes @ Mar 13 2006, 08:55 AM)QUOTE...   Mar 13 2006, 16:49
|- - Societal Eclipse   QUOTE (crimsontide @ Mar 13 2006, 09:36 AM)An...   Mar 13 2006, 17:40
- - William   OK, so here are some more technical questions I fo...   Dec 30 2005, 04:03
|- - probedb   QUOTE (William @ Dec 30 2005, 04:03 AM)1) The...   Jan 5 2006, 14:28
- - boombaard   so, on a slightly different note, would the 24/96 ...   Dec 30 2005, 14:24
|- - Garf   QUOTE (boombaard @ Dec 30 2005, 03:24 PM)so, ...   Dec 30 2005, 14:25
|- - boombaard   QUOTE (Garf @ Dec 30 2005, 02:25 PM)QUOTE (bo...   Dec 30 2005, 14:37
|- - Garf   QUOTE (boombaard @ Dec 30 2005, 03:37 PM)how ...   Dec 30 2005, 15:13
||- - boombaard   QUOTE (Garf @ Dec 30 2005, 03:13 PM)QUOTE (bo...   Dec 30 2005, 15:46
||- - jussi   well, and what about the HDCD (20bit) technology? ...   Dec 30 2005, 15:52
|||- - Garf   QUOTE (jussi @ Dec 30 2005, 04:52 PM)well, an...   Dec 30 2005, 16:00
||- - Garf   QUOTE (boombaard @ Dec 30 2005, 04:46 PM)QUOT...   Dec 30 2005, 15:56
|- - Crissaegrim   Definitive answer... Artists record at as high as ...   Dec 30 2005, 17:02
|- - bug80   QUOTE (Crissaegrim @ Dec 30 2005, 06:02 PM)De...   Dec 30 2005, 17:09
- - William   Well, it sounds like these 24bits / whatever kHz a...   Dec 30 2005, 15:54
- - Wintershade   Sorry for popping in like that, but here's my ...   Dec 30 2005, 16:04
|- - bug80   QUOTE (Wintershade @ Dec 30 2005, 05:04 PM)So...   Dec 30 2005, 16:25
||- - Wintershade   QUOTE (bug80 @ Dec 30 2005, 05:25 PM)Do you h...   Jan 2 2006, 12:45
|- - krabapple   QUOTE (Wintershade @ Dec 30 2005, 10:04 AM)So...   Jan 6 2006, 20:16
- - Axon   Some DSP algorithms may benefit from a high sampli...   Dec 30 2005, 19:39
- - Lyx   Regarding clipping and samplerate: according to a ...   Dec 30 2005, 19:58
|- - bug80   QUOTE (Lyx @ Dec 30 2005, 08:58 PM)Regarding ...   Dec 31 2005, 12:23
|- - Garf   QUOTE (Lyx @ Dec 30 2005, 08:58 PM)As you kno...   Dec 31 2005, 14:26
- - Raptus   >16bit would be necessary if someone wanted to ...   Dec 30 2005, 20:07
- - NoXFeR   On a sidenote; recorders may want higher frequenci...   Dec 31 2005, 00:05
|- - bug80   QUOTE (NoXFeR @ Dec 31 2005, 01:05 AM)On a si...   Dec 31 2005, 12:16
|- - NoXFeR   QUOTE (bug80 @ Dec 31 2005, 12:16 PM)QUOTE (N...   Dec 31 2005, 15:18
|- - WmAx   QUOTE (NoXFeR @ Dec 31 2005, 10:18 AM)The poi...   Dec 31 2005, 15:29
- - Lyx   One more reason to instead simply use proper level...   Dec 31 2005, 12:33
|- - bug80   QUOTE (Lyx @ Dec 31 2005, 01:33 PM)One more r...   Dec 31 2005, 13:33
|- - Garf   QUOTE (bug80 @ Dec 31 2005, 02:33 PM)QUOTE (L...   Dec 31 2005, 14:20
|- - bug80   QUOTE (Garf @ Dec 31 2005, 03:20 PM)QUOTE (bu...   Dec 31 2005, 14:23
|- - Garf   QUOTE (bug80 @ Dec 31 2005, 03:23 PM)QUOTE (G...   Dec 31 2005, 14:31
- - kwwong   The main reason why sampling rates > 44.1Khz is...   Dec 31 2005, 14:30
|- - Garf   QUOTE (kwwong @ Dec 31 2005, 03:30 PM)The mai...   Dec 31 2005, 14:41
||- - kwwong   QUOTE (Garf @ Dec 31 2005, 07:41 AM)QUOTE (kw...   Jan 1 2006, 04:30
||- - kwwong   QUOTE (kwwong @ Dec 31 2005, 09:30 PM)QUOTE (...   Jan 1 2006, 04:39
|- - WmAx   QUOTE (kwwong @ Dec 31 2005, 09:30 AM)As for ...   Dec 31 2005, 15:39
- - Garf   Another thing to consider is that with proper dith...   Dec 31 2005, 14:51
|- - marcan   QUOTE (Garf @ Dec 31 2005, 05:51 AM)Another t...   Jan 5 2006, 15:57
|- - enry2k   QUOTE (marcan @ Jan 5 2006, 06:57 AM)QUOTE (G...   Jan 8 2006, 21:28
|- - Garf   QUOTE (marcan @ Jan 5 2006, 04:57 PM)QUOTE (G...   Jan 10 2006, 12:33
- - Garf   I think what he's trying to say is this: If y...   Dec 31 2005, 15:31
- - Lyx   I think he means playing 192khz sample at 44khz WI...   Dec 31 2005, 15:31
- - ivalladt   QUOTE (Garf @ Dec 29 2005, 03:13 PM)The quest...   Dec 31 2005, 19:13
- - dekkersj   QUOTE (Garf @ Dec 31 2005, 02:51 PM)Another t...   Jan 2 2006, 15:41
- - Qjimbo   Ok, back to the original question of the thread. T...   Jan 9 2006, 00:20
|- - Lyx   QUOTE (Qjimbo @ Jan 9 2006, 12:20 AM)Firstly ...   Jan 9 2006, 16:17
|- - marcan   QUOTE (Lyx @ Jan 9 2006, 07:17 AM)QUOTE (Qjim...   Jan 9 2006, 17:59
|- - Woodinville   QUOTE (Lyx @ Jan 9 2006, 07:17 AM)This thread...   Jan 10 2006, 00:38
|- - Garf   QUOTE (Woodinville @ Jan 10 2006, 01:38 AM)We...   Jan 10 2006, 12:42
|- - Woodinville   QUOTE (Garf @ Jan 10 2006, 03:42 AM)QUOTE (Wo...   Jan 10 2006, 23:41
- - CSMR   Somehow this question brings out all the know-alls...   Jan 9 2006, 01:52
- - AndyH-ha   The Sampling Theorem says that signals containing ...   Jan 9 2006, 08:28
|- - bug80   QUOTE (AndyH-ha @ Jan 9 2006, 09:28 AM)T...   Jan 9 2006, 10:19
|- - Woodinville   QUOTE (AndyH-ha @ Jan 8 2006, 11:28 PM)T...   Jan 10 2006, 00:41
- - AndyH-ha   My immediately available source is Principles of D...   Jan 9 2006, 18:02
|- - SebastianG   QUOTE (AndyH-ha @ Jan 9 2006, 06:02 PM)o...   Jan 9 2006, 18:30
- - stephanV   @crimsontide: You can never prove a negative. The...   Mar 13 2006, 17:49
|- - crimsontide   QUOTE (stephanV @ Mar 13 2006, 10:49 AM)@crim...   Mar 13 2006, 18:32
- - harlekeyn   16bit means 2^16 = 65536 possible values for each ...   Mar 19 2006, 06:58
|- - Pio2001   QUOTE (harlekeyn @ Mar 19 2006, 07:58 AM)If y...   Mar 19 2006, 22:07
|- - crimsontide   Well I agree with what Tristan said For example ...   Mar 20 2006, 11:03
|- - Woodinville   QUOTE (crimsontide @ Mar 20 2006, 02:03 AM)I ...   Mar 20 2006, 21:19
- - harlekeyn   WHEN COMPARING digital audio to digital photograph...   Apr 4 2006, 16:48
- - benski   With somewhat expensive studio equipment (RME Hamm...   Apr 4 2006, 16:56
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 27th April 2015 - 02:07
