48 kbps AAC Encoders Test - Q1 2006 Edition
Ivan Dimkovic
post Dec 14 2005, 14:45
Nero MPEG4 developer
Hello,
This is the invitation for a discussion about 48 Kbps AAC test, that should be done before the next 48 kbps multiformat listening test.
Gabriel from LAME development team and myself decided to organize this test - there are few reasons why this test should be organized, and why it should be organized before the next 48 kbps multiformat test:
Reasons:
* Test the state-of-the-art HE-AAC v1 and HE-AAC v2 (Parametric Stereo) commercial encoders, as well as non-commercial 3GPP reference encoder
* Evaluate the usefullnes of Parametric Stereo tool at bit rate of 48 Kb/s
* Make the pre-selection of the best HE-AAC/HE-AAC v2 solutions for the multiformat listening test
* Compare all these solutions with the low-anchored Low Complexity (LC) AAC, in order to verify how the technology has improved over past few years
* Compare against higher bit rate MP3 to verify how much could state-of-the-art 48 kbps codec approach the good old MP3 technology at significantly higher bit rate.
Which high bit rate of MP3 should be used is debatable - should it be 80, 96 or 128 kbps - as stated above, this is open for debate.
Codecs
At this point (alphabetically):
- 3GPP Reference Encoder
- Coding Technologies aacPlus (HE-AAC)
- Coding Technologies Enhanced aacPlus (HE-AAC v2)
- Nero Digital HE-AAC v1
- Nero Digital HE-AAC v2
Anchors:
- LAME MP3 (high) - bit rate yet TBD / High Anchor
- QuickTime/iTunes LC-AAC @48 kbps / Low Anchor
Samples
My idea was to use combined sample set from multiformat 128 kbps listening test and previous Roberto's 64 kbps multiformat test - I thought of chosing several (5-6) samples from both of these two sets by using the worst scored samples.
Worst scored = Lowest average subjective difference grade (SDG) for all codecs in the particular set, except the low and (where applicable) high anchors.
Gabriel's addition was:
* 1 spoken (german male speech?)
* 1 with strong L/R differences, in order to know how PS fares in bad conditions. Something like some old Beatles songs, with singer on 1 channel and instruments on the other one.
When
Test should happen at the end of January - to make enough break after the current 128 kbps multiformat test.
Encoding Settings, Encoders, Bit Rates
Like with all other tests, we won't be testing closed or produced solutions - encoders used in the test will be widely available - as well as encoding settings and encoding material. Regarding the Coding Technologies' aacPlus encoder, my proposal is to use their imlpementation in the Winamp, which is widely available product.
Prior to the test, we will conduct public bit rate verification - in order to make sure codecs behave within the bitrate constraints.
NoXFeR
post Dec 15 2005, 18:51
The bitrates were examples, modify them to the 48kbps-range for direct relevance. For instance, it is possible that 40kbps VBR sounds better than 48kbps CBR and at the same time they require the same buffer.
And if everything above 48kbps skips, a buffer isn't used. And as has been said here earlier, it isn't reasonable to expect 56kbps modems to play 48kbps streams reliably. It can be done, but it isn't the scenario one would expect. When I had dial-up, I tried several times and failed 90% of the time.
Lastly, of course you can predict the upcoming bitrate; using some statistics on similar music, artists and masterings should give a reasonable estimate. But that wasn't what was questioned: The question was whether one could easily predict what buffer size would be needed. One way to do this would be to take the song with the highest average bitrate until now and use a buffer size which allows this song to be played smoothly. This isn't a good way to do it, but it is a way to do it, and shows that it is possible.
- Ivan Dimkovic   48 kbps AAC Encoders Test - Q1 2006 Edition   Dec 14 2005, 14:45
- - elmar3rd   QUOTE Prior to the test, we will conduct public bi...   Dec 14 2005, 15:15
|- - guruboolez   QUOTE (elmar3rd @ Dec 14 2005, 03:15 PM)So th...   Dec 14 2005, 16:52
|- - IgorC   For many people here 48 kbit/s has sence. It was m...   Dec 14 2005, 17:07
||- - guruboolez   QUOTE (IgorC @ Dec 14 2005, 05:07 PM)For many...   Dec 14 2005, 17:19
||- - IgorC   Somebody want test at 32 kbps , another at 64 and ...   Dec 14 2005, 17:27
||- - guruboolez   QUOTE (IgorC @ Dec 14 2005, 05:27 PM)Somebody...   Dec 14 2005, 17:33
||- - dimzon   QUOTE (guruboolez @ Dec 14 2005, 08:33 PM)Why...   Dec 14 2005, 17:40
||- - Shade[ST]   QUOTE (guruboolez @ Dec 14 2005, 10:33 AM)If ...   Dec 14 2005, 17:41
|||- - guruboolez   QUOTE (Shade[ST] @ Dec 14 2005, 05:4...   Dec 14 2005, 17:53
||||- - Shade[ST]   QUOTE (guruboolez @ Dec 14 2005, 10:53 AM)QUO...   Dec 14 2005, 18:02
|||- - Atlantis   QUOTE (Shade[ST] @ Dec 14 2005, 06:4...   Dec 14 2005, 18:03
||- - IgorC   QUOTE (guruboolez @ Dec 14 2005, 08:33 AM)QUO...   Dec 14 2005, 17:42
||- - guruboolez   QUOTE (IgorC @ Dec 14 2005, 05:42 PM)I dont m...   Dec 14 2005, 18:00
||- - IgorC   QUOTE (guruboolez @ Dec 14 2005, 09:00 AM)QUO...   Dec 14 2005, 18:10
||- - dimzon   QUOTE (IgorC @ Dec 14 2005, 09:10 PM)Itīs not...   Dec 14 2005, 18:13
|||- - IgorC   QUOTE (dimzon @ Dec 14 2005, 09:13 AM)QUOTE (...   Dec 14 2005, 18:16
|||- - dimzon   QUOTE (IgorC @ Dec 14 2005, 09:16 PM)+/- 8 kb...   Dec 14 2005, 18:21
||- - guruboolez   QUOTE (IgorC @ Dec 14 2005, 06:10 PM)The idea...   Dec 14 2005, 18:56
||- - dimzon   QUOTE (guruboolez @ Dec 14 2005, 09:56 PM)QUO...   Dec 14 2005, 19:04
|- - Shade[ST]   QUOTE (guruboolez @ Dec 14 2005, 09:52 AM)I...   Dec 14 2005, 17:12
|- - Sebastian Mares   QUOTE (guruboolez @ Dec 14 2005, 04:52 PM)Are...   Dec 14 2005, 20:44
|- - Serge Smirnoff   QUOTE (Sebastian Mares @ Dec 14 2005, 10:44 P...   Dec 15 2005, 00:21
- - Shade[ST]   I have a few samples which you might like, and are...   Dec 14 2005, 15:21
|- - [JAZ]   About High Anchor: If MP3, then, a CBR (or ABR) 1...   Dec 14 2005, 16:22
- - dimzon   And please add avoTuVo Vorbis @ 48kbsp to - just t...   Dec 14 2005, 16:26
|- - Shade[ST]   QUOTE (dimzon @ Dec 14 2005, 09:26 AM)And ple...   Dec 14 2005, 16:28
|- - dimzon   QUOTE (Shade[ST] @ Dec 14 2005, 07:2...   Dec 14 2005, 16:30
|- - Shade[ST]   There are over 4 implementations of AAC-HE, and a ...   Dec 14 2005, 16:32
|- - dimzon   Oh! And don't forget - Coding Technologie...   Dec 14 2005, 16:37
- - Gabriel   QUOTE So this test will be a mix of CBR (aacPlus) ...   Dec 14 2005, 16:38
- - Ivan Dimkovic   QUOTE 48 kb/s ist very interesting for streaming i...   Dec 14 2005, 16:40
|- - dimzon   QUOTE (Ivan Dimkovic @ Dec 14 2005, 07:40 PM)...   Dec 14 2005, 17:02
- - Ivan Dimkovic   Hmm - nobody really tested WMA @48 kbps vs. anythi...   Dec 14 2005, 17:09
|- - dimzon   QUOTE (Ivan Dimkovic @ Dec 14 2005, 08:09 PM)...   Dec 14 2005, 17:15
- - Ivan Dimkovic   I wouldn't go interpolating results that easil...   Dec 14 2005, 17:18
- - dimzon   I beleive it wood be much more usable to add old H...   Dec 14 2005, 17:18
- - stephanV   At the 32 kbps test WMA and Real were tied with Vo...   Dec 14 2005, 17:23
- - Ivan Dimkovic   QUOTE guruboolez Right. But if people have a 128 k...   Dec 14 2005, 17:33
|- - IgorC   QUOTE (Ivan Dimkovic @ Dec 14 2005, 08:33 AM)...   Dec 14 2005, 17:36
|- - dimzon   QUOTE (IgorC @ Dec 14 2005, 08:36 PM)Finally ...   Dec 14 2005, 17:43
- - Ivan Dimkovic   Well - theoretically we (Nero) could do CBR, quali...   Dec 14 2005, 17:43
|- - dimzon   QUOTE (Ivan Dimkovic @ Dec 14 2005, 08:43 PM)...   Dec 14 2005, 17:48
- - Ivan Dimkovic   QUOTE WOW!!!!!!!! ...   Dec 14 2005, 18:07
- - Gabriel   VBR/CBR issue: As you know, modern codecs are usin...   Dec 14 2005, 18:43
|- - guruboolez   QUOTE (Gabriel @ Dec 14 2005, 06:43 PM)CBR is...   Dec 14 2005, 18:51
|- - IgorC   QUOTE (Gabriel @ Dec 14 2005, 09:43 AM)The mp...   Dec 15 2005, 15:39
- - Ivan Dimkovic   QUOTE question: what is the typical aac buffer siz...   Dec 14 2005, 19:04
- - guruboolez   Something is worrying me. The purpose of this test...   Dec 14 2005, 19:14
|- - Shade[ST]   I don't mind preparing a Vorbis + MP3 test at ...   Dec 14 2005, 19:37
|- - [JAZ]   48kbps Streaming IS reasonable : http://www.polsk...   Dec 14 2005, 20:34
- - NoXFeR   Well, in my opinion, the test should be about how ...   Dec 15 2005, 02:00
- - guruboolez   [JAZ] & Serge Smirnoff> I know that 48 kbps...   Dec 15 2005, 10:35
|- - IgorC   So you are pruposing a 32 kbit/s test, right?   Dec 15 2005, 14:54
|- - guruboolez   QUOTE (IgorC @ Dec 15 2005, 02:54 PM)So you a...   Dec 15 2005, 15:01
|- - IgorC   It was mentioned 48 kbit/s is very interesting t...   Dec 15 2005, 15:09
||- - guruboolez   QUOTE (IgorC @ Dec 15 2005, 03:09 PM)It was m...   Dec 15 2005, 15:21
||- - IgorC   QUOTE (guruboolez @ Dec 15 2005, 06:21 AM)It ...   Dec 15 2005, 15:26
||- - IgorC   I don't agree to use VBR at least for high a...   Dec 15 2005, 15:33
|||- - guruboolez   QUOTE (IgorC @ Dec 15 2005, 03:33 PM)I don...   Dec 15 2005, 16:27
|||- - IgorC   QUOTE (guruboolez @ Dec 15 2005, 07:27 AM)Hig...   Dec 15 2005, 17:36
||- - ATWindsor   QUOTE (IgorC @ Dec 15 2005, 06:26 AM)QUOTE (g...   Dec 15 2005, 16:15
||- - guruboolez   QUOTE (IgorC @ Dec 15 2005, 03:26 PM)QUOTE (g...   Dec 15 2005, 16:24
|- - JohnV   QUOTE (guruboolez @ Dec 15 2005, 05:01 PM)QUO...   Dec 15 2005, 15:21
|- - guruboolez   QUOTE (JohnV @ Dec 15 2005, 03:21 PM)QUOTE (g...   Dec 15 2005, 15:22
|- - JohnV   QUOTE (guruboolez @ Dec 15 2005, 05:22 PM)Doe...   Dec 15 2005, 15:24
- - Gabriel   QUOTE So why we should give a prior for mp3? If mp...   Dec 15 2005, 16:20
|- - JohnV   QUOTE (Gabriel @ Dec 15 2005, 06:20 PM)To me ...   Dec 16 2005, 14:41
- - NoXFeR   Gabriel: Is there any reason why streaming must be...   Dec 15 2005, 17:40
|- - Shade[ST]   QUOTE (NoXFeR @ Dec 15 2005, 10:40 AM)Gabriel...   Dec 15 2005, 17:45
- - NoXFeR   Well... Lowering the average bitrate of the VBR to...   Dec 15 2005, 17:57
|- - Shade[ST]   QUOTE (NoXFeR @ Dec 15 2005, 10:57 AM)Well......   Dec 15 2005, 18:36
- - NoXFeR   The bitrates were examples, modify them to the 48k...   Dec 15 2005, 18:51
|- - Shade[ST]   If a 40kbps VBR never goes above 48 kbps, it will ...   Dec 15 2005, 20:06
- - Ivan Dimkovic   One thing which worries me here - if the part of t...   Dec 16 2005, 12:28
|- - IgorC   Coding Technologies Enhanced aacPlus (HE-AAC v2) ?...   Dec 16 2005, 14:01
|- - guruboolez   QUOTE (Ivan Dimkovic @ Dec 16 2005, 12:28 PM)...   Dec 22 2005, 14:59
- - Ivan Dimkovic   I think Winamp was the only software actually bein...   Dec 16 2005, 14:41
|- - IgorC   QUOTE (Ivan Dimkovic @ Dec 16 2005, 05:41 AM)...   Dec 16 2005, 14:45
|- - benski   QUOTE (IgorC @ Dec 16 2005, 09:45 AM)QUOTE (I...   Dec 19 2005, 17:11
- - Ivan Dimkovic   Can more people confirm this? We would use best w...   Dec 16 2005, 15:07
- - Gabriel   QUOTE I think Winamp was the only software actuall...   Dec 16 2005, 15:18
|- - IgorC   Does helix support HE-AAC2?   Dec 16 2005, 15:19
|- - IgorC   More probably itīs the same updated audio encoder ...   Dec 16 2005, 15:29
|- - kurtnoise   QUOTE (IgorC @ Dec 16 2005, 03:19 PM)Does hel...   Dec 16 2005, 18:33
- - ckjnigel   I wish very much that someone who can translate Ja...   Dec 16 2005, 19:43
- - PatchWorKs   Hey, guyz... be calm. In my opinion "legal...   Dec 19 2005, 12:20
- - stephanV   That are not multiples of 128, that's just 2^n...   Dec 19 2005, 12:59
- - Ivan Dimkovic   Okay, we will use whatever has the latest CT encod...   Dec 19 2005, 18:14
|- - IgorC   Winamp 5.12 has a newer version than previos 5.11...   Dec 19 2005, 22:54
- - Ivan Dimkovic   Test is anyway scheduled for the late January, so ...   Dec 20 2005, 01:16
- - rjamorim   QUOTE (JohnV @ Dec 15 2005, 12:21 PM)One area...   Dec 20 2005, 01:34
|- - JohnV   QUOTE (rjamorim @ Dec 20 2005, 03:34 AM)Isn...   Dec 20 2005, 14:16
|- - rjamorim   QUOTE (JohnV @ Dec 20 2005, 11:16 AM)That...   Dec 21 2005, 00:32
- - digitalradiotech   A good reason to use CBR is that the new mobile br...   Dec 21 2005, 12:48
- - Ivan Dimkovic   Basically it all goes down to three use models: 1...   Dec 21 2005, 12:55
- - JohnV   One issue is also that in principle we should test...   Dec 21 2005, 20:32
|- - IgorC   QUOTE (JohnV @ Dec 21 2005, 11:32 AM)One issu...   Dec 22 2005, 14:51
- - Ivan Dimkovic   Well I know for sure that Nero could supply a vari...   Dec 22 2005, 15:01
- - Ivan Dimkovic   Actually a smart idea will be to do a small pre-te...   Dec 22 2005, 16:59
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 6th May 2015 - 20:26
