10 Pages V  « < 8 9 10
Closed TopicStart new topic
Multiformat Listening Test @ 128 kbps - OPEN
STL
post Jan 12 2006, 21:27
Post #226
I figured it out. I had to change my playback device setting.
kwanbis
post Jan 12 2006, 21:28
Post #227
Group: Developer (Donating)
options -> settings -> playback, and set it to "Primary Sound Driver".
edit: cool.
This post has been edited by kwanbis: Jan 12 2006, 21:29
MAREO: http://www.webearce.com.ar
Pio2001
post Jan 13 2006, 00:34
Post #228
Moderator
QUOTE (kwanbis @ Jan 12 2006, 10:10 PM)
i would check sample 12 right away. i suppose my cheap earphones could be the culprid also?
You should not send the results of sample 12, unless you send the results for every other sample also.
Choosing sample 12 on someone else's advice will bias your answers.
Even if you send every result, it will be somewhat biased, because you would have paid more attention to sample 12 than to the other samples, bit this problem is less important.
Cutter
post Jan 13 2006, 06:02
Post #229
QUOTE (Sebastian Mares @ Jan 12 2006, 08:32 PM)
Well, as I said in a previous post, I didn't receive a significant amount of new results which makes me feel a bit upset. It's not your fault, don't get me wrong. smile.gif
In that case why not extending the test until you get enough results? You're not in a hurry, are you? tongue.gif
Sebastian Mares
post Jan 13 2006, 07:03
Post #230
QUOTE (Cutter @ Jan 13 2006, 06:02 AM)
Because people really had enough time now. If they didn't test now, they won't test either.
I have to admit that the test is really hard and the actual bitrate for the encoded material is not 128 kbps, but 140 kbps. I think this makes people step back. smile.gif
Anyways, the test will end today, 23:59:59 GMT.
This post has been edited by Sebastian Mares: Jan 13 2006, 12:31
http://listening-tests.hydrogenaud.io/sebastian/
Synthetic Soul
post Jan 13 2006, 08:34
Post #231
I seem to remember reading about the Playback Device.
Try selecting "Options" > "Settings" > "Playback" and changing the selected device in the drop down.
I'm on a horse.
matthiasb
post Jan 13 2006, 08:42
Post #232
QUOTE (Sebastian Mares @ Jan 13 2006, 07:03 AM)
Anyways, the test will end today, 23:59:99 GMT.
23:59:59?
Mit freundlichen Grüßen aus Österreich, Matthias
Serge Smirnoff
post Jan 13 2006, 08:46
Post #233
QUOTE (Sebastian Mares @ Jan 13 2006, 09:03 AM)
Does this mean that we'll see the results at 24:00:00?
keeping audio clear together - soundexpert.org
Sebastian Mares
post Jan 13 2006, 12:32
Post #234
QUOTE (matthiasb @ Jan 13 2006, 08:42 AM)
23:59:59?
QUOTE (Serge Smirnoff @ Jan 13 2006, 08:46 AM)
Nope. What I wanted to say is that no results posted after that date are going to be accepted. I will do my best to post the results on Saturday afternoon.
This post has been edited by Sebastian Mares: Jan 13 2006, 12:33
eisa01
post Jan 13 2006, 12:37
Post #235
Looking forward to the results, it was very interesting for me to participate in this test. Didn't know my hearing was so bad tongue.gif
Sebastian Mares
post Jan 14 2006, 00:00
Post #236
BTW, results are most likely going to be published on Saturday around 2 PM GMT. Hope you understand that I am pretty busy with school. sad.gif
This post has been edited by Sebastian Mares: Jan 14 2006, 00:07
minisu
post Jan 14 2006, 00:55
Post #237
QUOTE (Sebastian Mares @ Jan 14 2006, 01:00 AM)
No problem. You've done a great job and it's a pity that so few did the test.
Opera bookmark synchronizer: http://osync.sf.net
Caroliano
post Jan 14 2006, 01:09
Post #238
I was late by 2min! Wondering what is the tolerance.... I tested 6 samples (12-18). Found some diferences between the main codecs (excluding the low-anchor) in two or three samples IIRC.
The longer time to test helped a bit: I tested 2~3 samples more than I would if the test ended in 25th. But after the extending I forgot about the test, and remembered only two days ago. That is the side efect.
Anyway: thanks for this oportunity!
Sebastian Mares
post Jan 14 2006, 10:07
Post #239
QUOTE (Caroliano @ Jan 14 2006, 01:09 AM)
According to the mail header, one minute too late. It's OK, I am not that anal about it. biggrin.gif Thanks for submitting.
Sebastian Mares
post Jan 14 2006, 17:04
Post #240
OK, finished school work. I now started working on the results and hope to be able to post them within the next one or two hours. Stay tuned. smile.gif
I think this thread can be closed now.
Garf
post Jan 14 2006, 17:59
Post #241
Server Admin
Group: Admin
Maybe it's better to close only after the results thread is up?
(Yes, I'm getting more careful with that now smile.gif)
This post has been edited by Garf: Jan 14 2006, 18:01
Sebastian Mares
post Jan 15 2006, 14:04
Post #242
RSS Lo-Fi Version Time is now: 3rd May 2015 - 17:35
