Dolby Headphone Wrapper DSP, foo_dsp_dolbyhp
Chungalin
post Dec 4 2005, 13:08
I'd like to introduce a DSP I've been developing these weeks. It's a Dolby Headphone wrapper DSP. cool.gif
After some research on Lake DOLBYHPH.DLL bundled with software DVD players, I was able to find out its protocol used to interface with the client app. Then, why not make it work for myself?! And that was how foo_dsp_dolbyhp was originated. It wraps the functionality of the original DLL to be used under foobar2000. You just need to configure the plugin pointing out the location of that DLL in your system. Of course I'll NOT give any help about how to get that DLL.
foo_dsp_dolbyhp is available at the usual 3rd party component website. Any comments, criticisms, bug reports and legal issues unsure.gif are welcome (under this thread).
hushypushy
post Dec 5 2006, 10:01
Chungalin, could you please elaborate on what that fix does please? smile.gif
edit: Hancoque, I don't know if you noticed but you're losing a bit of dynamic range when you turn the plugin volume down to 50%. On that green wave, the highs are a bit lower, and the lows are a bit higher. Hmm...
edit2: Ok, I figured it out. Replaygain is the trick. I converted (from FLAC) two files: the first was just converted to 4 channels and then Dolby Headphones. Cooledit Pro reports 13990 and 13537 possibly clipped samples in the left and right channels, respectively. The other file was also 4 channels and Dolby Headphones, BUT I added replaygain (album mode). This file has 0 clipped samples (same as the original file). In the Dolby Headphone config, the volume was set to 100% at all times. This leads me to believe that Foobar applies RG then applies DSP. This might be common knowledge but it's the first I've heard of it. Anyway, since you're obviously having clipping problems, there is your solution wink.gif
This post has been edited by hushypushy: Dec 5 2006, 10:19
- Chungalin   Dolby Headphone Wrapper DSP   Dec 4 2005, 13:08
- - Stratman   QUOTE (Chungalin @ Dec 4 2005, 04:08 AM)I...   Dec 4 2005, 22:55
- - Chungalin   If the plugin is working fine and you have selecte...   Dec 5 2005, 00:24
|- - Stratman   QUOTE (Chungalin @ Dec 4 2005, 03:24 PM)If th...   Dec 5 2005, 22:04
- - Chungalin   Best results are obtained when a 5.1 signal is use...   Dec 6 2005, 01:57
- - kode54   Interesting limitation there. I always wondered wh...   Dec 6 2005, 02:22
|- - thegeek   Nice job, works quite well. There is no doubt that...   Dec 11 2005, 06:54
- - edwardar   Just wanted to say thanks for a really useful plug...   Dec 13 2005, 01:45
|- - GiGurra   QUOTE (edwardar @ Dec 12 2005, 06:45 PM)Just ...   Dec 14 2005, 20:06
- - Chungalin   I can't hardly do anything to improve DH sound...   Dec 15 2005, 00:19
|- - GiGurra   QUOTE (Chungalin @ Dec 14 2005, 05:19 PM)I ca...   Dec 15 2005, 15:38
- - Chungalin   Looks interesting. I've found the full specifi...   Dec 15 2005, 17:07
|- - GiGurra   QUOTE (Chungalin @ Dec 15 2005, 10:07 AM)Look...   Dec 15 2005, 21:40
- - ItsLateIMustSleep   Is it possible to use that Plugin in Winamp, too? ...   Jan 2 2006, 02:36
- - Chungalin   I had to choose between Winamp and foobar2000 when...   Jan 4 2006, 03:23
- - Dark_Angel   If you can find a way to do this but for the Dolby...   Jan 9 2006, 05:09
- - daveuu   Definately a worthwhile plugin! Thanks. I w...   Jan 9 2006, 14:18
|- - daveuu   QUOTE (daveuu @ Jan 9 2006, 02:18 PM)I was wo...   Jan 11 2006, 02:06
- - option1   Thank you for this great plugin!!! I...   Jan 16 2006, 14:59
- - Chungalin   Discussing technical details about how I did it is...   Jan 18 2006, 01:51
- - euphonic   I'd love to try out the plugin -- rock & r...   Feb 12 2006, 11:46
- - admiraljustin   I'm in love this, and I hope it's ported t...   Feb 12 2006, 19:29
- - Chungalin   Since there have been two folks asking me the same...   Feb 18 2006, 01:12
|- - iZenja   QUOTE (Chungalin @ Feb 17 2006, 06:12 PM)I ex...   Mar 28 2006, 09:27
- - ssamadhi97   The foobar2000 SDK provides plenty of help for han...   Feb 18 2006, 03:32
- - Audionut   I love this plugin. Produces very pleasing sound t...   Mar 28 2006, 12:36
- - Chungalin   There will be 0.9 version. I'm in the process ...   Mar 28 2006, 23:23
|- - iZenja   QUOTE (Chungalin @ Mar 28 2006, 04:23 PM)Ther...   Mar 29 2006, 23:14
|- - david_dl   QUOTE (iZenja @ Mar 30 2006, 11:14 AM)QUOTE (...   Apr 5 2006, 05:33
- - fred_frno   I love this plugin ! too bad I discovered it o...   Apr 2 2006, 17:36
- - broski   QUOTE (fred_frno @ Apr 2 2006, 08:36 AM)I lov...   Apr 5 2006, 03:08
- - falconfox   never knew about this plugin. i am excited to test...   Apr 5 2006, 04:33
- - Chungalin   Today I've started the port to 0.9. There...   Apr 23 2006, 00:55
- - Chungalin   Just uploaded the updated plugin for 0.9.x at 3rd ...   Apr 30 2006, 14:21
- - MrMuffin   Wow, I didn't realize the effect would be so d...   May 1 2006, 00:31
- - Chungalin   While testing this new version I tried to feed the...   May 1 2006, 12:39
|- - GeSomeone   QUOTE (Chungalin @ May 1 2006, 01:39 PM) ...   May 1 2006, 14:07
|- - prawns   I've just tried this plugin. Nice work, Chunga...   May 1 2006, 14:24
- - MrMuffin   After much work, I figured out how to encode my DT...   May 1 2006, 23:32
- - Hancoque   I have version 1.2.0.222 of DolbyHph.dll. I think ...   May 5 2006, 00:33
- - Rogacz   Will it be possible to do something similar, but f...   May 5 2006, 23:18
- - Chungalin   Haven't got into this CMSS-3D thing, first of ...   May 6 2006, 22:49
- - Rogacz   Ummm there is a Creative software bundled with the...   May 7 2006, 23:02
- - euphonic   Out of curiosity, does anyone know what ffdshow...   May 12 2006, 21:10
- - lextune   I am interested in trying this plugin out, but cal...   May 12 2006, 22:36
- - Hancoque   Just use your computer's local search function...   May 13 2006, 03:44
|- - lextune   QUOTE (Hancoque @ May 12 2006, 22:44) Jus...   May 13 2006, 16:22
|- - Spirit_of_the_ocean   QUOTE (lextune @ May 13 2006, 16:22) QUOT...   Dec 2 2006, 00:17
- - MrMuffin   Alright, I may have found some insight as to what ...   May 13 2006, 08:31
- - atjs   QUOTE (MrMuffin @ May 13 2006, 15:31) I a...   May 13 2006, 18:46
- - deadfones   Can someone please put the 0.8.3 version up somewh...   May 14 2006, 09:00
- - thuneau   I just wanted to express my gratitude to Chungalin...   Jul 3 2006, 05:20
- - Chungalin   Thanks thuneau for your feedback. Regarding the b...   Jul 4 2006, 02:44
- - Peter L   I am delighted to find this wrapper. For some tim...   Aug 15 2006, 14:16
- - Peter L   Same newbie again. I got it licked - apparantly, ...   Aug 16 2006, 03:07
- - mkeroppi   Thanks! This is great. Dolby Headphone is the ...   Sep 15 2006, 06:59
- - greekgoddj   Hello, Would like to say you have done a great jo...   Oct 27 2006, 11:34
- - Chungalin   For those who where asking here, a Dolby Headphone...   Nov 18 2006, 14:47
- - Hancoque   It doesn't work for me. In Cubase all it does ...   Nov 19 2006, 04:16
|- - greekgoddj   QUOTE (Hancoque @ Nov 19 2006, 04:16) It ...   Nov 19 2006, 14:00
- - Hancoque   Yes, the file was already there. But I also tried ...   Nov 19 2006, 14:10
|- - greekgoddj   QUOTE (Hancoque @ Nov 19 2006, 14:10) Yes...   Nov 19 2006, 14:57
- - Kblood   Hello, The original website seems to be down (at ...   Nov 29 2006, 11:22
- - Chungalin   Kblood and all others, I've uploaded the lates...   Dec 1 2006, 02:01
- - Kblood   Thanks a lot!!!   Dec 1 2006, 06:21
- - saberrider   I use that component with version 1.2.0.222 of the...   Dec 1 2006, 23:38
- - Chungalin   Thanks saberrider. As always, 99% of the credit go...   Dec 2 2006, 14:27
- - hushypushy   Man, this is a great DSP. Any chance to get a wina...   Dec 3 2006, 02:43
- - Hancoque   You should upmix stereo material to at least 4 cha...   Dec 3 2006, 15:49
- - Chungalin   It has already been discused about the convenience...   Dec 3 2006, 19:53
- - hushypushy   I agree with Hancoque. Stereo to 4 channels --...   Dec 3 2006, 20:27
- - Hancoque   QUOTE (Chungalin @ Dec 3 2006, 19:53) I t...   Dec 4 2006, 01:44
- - Chungalin   Very interesting and clarifying experiment. The t...   Dec 4 2006, 03:19
|- - Hancoque   QUOTE (Chungalin @ Dec 4 2006, 03:19) Whi...   Dec 4 2006, 11:25
- - Andreasvb   For PL2XDLL.dll, you can download PowerDVD, it...   Dec 4 2006, 11:29
- - Hancoque   Thanks, that worked. PowerDVD also has an olderne...   Dec 4 2006, 14:51
- - Chungalin   OK, but have in mind that 1.10.0.270 is *not* olde...   Dec 4 2006, 19:35
- - Hancoque   Oh, you're right. Stupid me.   Dec 4 2006, 19:55
- - Chungalin   Hancoque, here you have a test version with checkb...   Dec 5 2006, 02:34
- - hushypushy   Chungalin, could you please elaborate on what that...   Dec 5 2006, 10:01
- - Hancoque   @Chungalin: I will check it out later today. @hus...   Dec 5 2006, 12:58
|- - hushypushy   QUOTE (Hancoque @ Dec 5 2006, 03:58) @hus...   Dec 6 2006, 00:41
- - Chungalin   This version is not a fix, it just shows a new con...   Dec 5 2006, 14:55
- - Morfeus   It produces some weird sound, but it doesn't m...   Dec 5 2006, 18:32
- - Hancoque   I have made a new graphical comparison. This time ...   Dec 6 2006, 04:29
|- - hushypushy   QUOTE (Hancoque @ Dec 5 2006, 19:29) But ...   Dec 6 2006, 08:08
- - pro_optimizer   QUOTE edit: Just did a couple of tests with PLII a...   Dec 6 2006, 11:35
|- - hushypushy   QUOTE (pro_optimizer @ Dec 6 2006, 02:35)...   Dec 6 2006, 20:18
- - Hancoque   QUOTE (hushypushy @ Dec 6 2006, 08:08) Ar...   Dec 6 2006, 15:00
- - Chungalin   Thanks Hancoque for taking your time to make these...   Dec 6 2006, 18:22
- - pro_optimizer   QUOTE Can it really? After all you only have two c...   Dec 6 2006, 21:40
|- - Hancoque   Okay, I think you're right about the "beh...   Dec 6 2006, 23:41
- - pro_optimizer   QUOTE Okay, I think you're right about the ...   Dec 7 2006, 00:21
- - hushypushy   Whoa whoa whoa, I'd love to see some source in...   Dec 7 2006, 03:07
|- - pro_optimizer   QUOTE (hushypushy @ Dec 7 2006, 03:07) Wh...   Dec 8 2006, 01:25
- - hushypushy   Very interesting...I will mess with this. By the ...   Dec 8 2006, 07:23
- - pro_optimizer   Hi folks, I was just thinking about how PL2 works...   Dec 9 2006, 01:25
- - hushypushy   I've been trying to understand how PL works fo...   Dec 9 2006, 05:54
- - pro_optimizer   QUOTE So let me ask you this: why do you think tha...   Dec 9 2006, 16:09
- - Nathan P   Wow, I am finding this plugin incredibly enjoyable...   Jan 2 2007, 01:07
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 5th May 2015 - 02:51
