foo_sid, Emulates the sound chips of Commodore's CBM-II, Commodore 64, C128
deus-ex
post Oct 11 2005, 20:13
Tried the Foo_Sid beta release with foobar v0.9 beta 10. It does'nt produce any soundoutput for me but runs through the modules silently instead (indicated by searchbar slider).
Foo_Sid/Foobar v0.8.3 works all fine with same modules though (with Kernelstreaming output).
Regards,
deus-ex
Best regards
deus-ex (MODLAND co-admin: ftp://ftp.modland.com)
kode54
post Feb 3 2011, 15:55
Group: Admin
Fixed and uploaded in the usual place. Debug version is in the same place as I linked above. You should be seeing "Attempting to use song length database: <path>" when you attempt to play SID files.
fuffi
post Feb 3 2011, 16:20
QUOTE (kode54 @ Feb 3 2011, 15:55) *
question:
if realize, that i update via the "get updates" button in foobar, my files (songlenght, stil, etc...) inside your plugin folder foo_sid are deleted. i not 100% sure, but i remember, that, while installing ohter plugins, no files (i.e. extended config files or notes.txt i created) were deleted.
is this from your plugin or from foobar?
- deus-ex   foo_sid   Oct 11 2005, 20:13
- - Wedge   I have a similar problem. When I try to play a sid...   Oct 12 2005, 18:51
- - Wedge   noticed that there was a new version posted at kod...   Oct 23 2005, 21:56
|- - deus-ex   QUOTE (Wedge @ Oct 23 2005, 09:56 PM)noticed ...   Oct 24 2005, 13:56
- - kode54   Can't reproduce. ( As in, this should be fixed...   Oct 24 2005, 13:25
- - Synthetic Soul   I get the same as Wedge I'm afraid. QUOTE (0.9...   Oct 24 2005, 13:56
- - kode54   Please upload the relevant files. ( The only known...   Oct 24 2005, 14:02
- - Synthetic Soul   http://www.neilpopham.pwp.blueyonder.co.uk/temp/Sa...   Oct 24 2005, 14:07
- - kode54   Bleh. libsidplay was breaking only in Release mode...   Oct 24 2005, 14:44
|- - deus-ex   Ok, fixed. Regards, deus-ex   Oct 24 2005, 14:59
- - Synthetic Soul   Confirmed. Thank you kode54. Gotta dig those old...   Oct 24 2005, 15:11
- - Wedge   Works for me too. Thanks kode! Another thing ...   Oct 24 2005, 16:59
|- - deus-ex   QUOTE (Wedge @ Oct 24 2005, 04:59 PM)Another ...   Oct 24 2005, 21:41
- - kode54   Nope, just requires brute force decoding to the bi...   Oct 26 2005, 15:54
|- - OpaJo0   Hi! First thanx for providing this foo_sid p...   Mar 12 2006, 17:46
|- - OpaJo0   QUOTE (OpaJo0 @ Mar 12 2006, 10:46 AM)So it l...   Mar 21 2006, 20:28
- - kode54   Are you sure your rip isn't broken? I thought ...   Mar 23 2006, 08:03
|- - OpaJo0   QUOTE (kode54 @ Mar 23 2006, 01:03 AM)Are you...   Mar 23 2006, 20:30
- - Arthur   Hi there, thanks for this sid plugin! Just a ...   Apr 17 2006, 22:01
|- - Zerp_Tren   QUOTE (Arthur @ Apr 17 2006, 16:01) 1. Th...   May 30 2011, 06:04
- - Arthur   Hi, an adendum to my last post. It would be usefu...   Apr 17 2006, 22:53
|- - deus-ex   Current version of foo_sid (v1.13, 23-03-2006) rep...   Jun 2 2006, 19:39
|- - kode54   QUOTE (deus-ex @ Jun 2 2006, 11:39) ...   Jun 2 2006, 22:14
- - deus-ex   Playing Once more.sid (RealSID by Reed) using the ...   May 28 2007, 19:32
- - iycgtptyarvg   I discovered 2 bugs in Foo_sid (30-Jun-2007) when ...   Aug 10 2007, 10:11
|- - iycgtptyarvg   More crashes with Foo_sid (30-Jun-2007). I now not...   Aug 24 2007, 10:25
- - kode54   I cannot reproduce the subsong length problem, as ...   Aug 24 2007, 23:42
|- - iycgtptyarvg   I just saw there was a new version (2008-01-20). C...   Feb 7 2008, 10:38
|- - deus-ex   QUOTE (iycgtptyarvg @ Feb 7 2008, 10:38) ...   Feb 7 2008, 13:01
|- - iycgtptyarvg   QUOTE (deus-ex @ Feb 7 2008, 13:01) ...   Feb 8 2008, 01:06
- - BokanoiD   Kode54, first of all - thank you very much for th...   Jun 17 2008, 08:41
- - kode54   I have no idea, it reports a "title" fie...   Jun 17 2008, 18:47
- - BokanoiD   Hello Kode54, It'll report a title field if a...   Jun 18 2008, 07:25
- - kode54   Ah, yes. It adds the title field as "album...   Jun 18 2008, 19:50
|- - casedawg   All my sid files only come through the left speake...   Oct 25 2008, 01:56
|- - kode54   QUOTE (casedawg @ Oct 24 2008, 17:56) All...   Oct 25 2008, 02:27
|- - mpz   kode54, can I interest you in incorporating the Re...   Nov 2 2008, 05:50
- - casedawg   That did the trick. Thanks for all your solid chip...   Oct 25 2008, 23:26
- - kode54   It will require significant work, since his patche...   Nov 2 2008, 07:18
- - fuffi   hello all, hello kode54, i used your plugin a lon...   Nov 8 2008, 16:01
- - fuffi   hi again, new post, new question :-) could it be ...   Nov 8 2008, 16:15
|- - musikdusche   QUOTE (fuffi @ Nov 8 2008, 17:15) i'd...   Aug 23 2009, 14:16
|- - fuffi   QUOTE (musikdusche @ Aug 23 2009, 14:16) ...   Sep 3 2009, 15:18
|- - fuffi   QUOTE (musikdusche @ Aug 23 2009, 14:16) ...   Feb 3 2011, 15:50
- - Cutter   Hi kode54, I have a strange problem when foo_sid ...   Mar 14 2009, 21:08
- - demalexx   Hello, I have a problem with this file. I can ope...   May 12 2010, 13:39
- - kode54   The song length database is only accurate to the s...   May 13 2010, 00:57
|- - demalexx   QUOTE (kode54 @ May 13 2010, 07:57) The s...   May 13 2010, 03:47
- - kode54   You need to configure the Song Length Database in ...   May 13 2010, 11:49
|- - demalexx   QUOTE (kode54 @ May 13 2010, 18:49) You n...   May 13 2010, 12:28
- - kode54   Sidplay2 does not specify a default length, so it ...   May 13 2010, 14:39
|- - demalexx   QUOTE (kode54 @ May 13 2010, 21:39) Sidpl...   May 13 2010, 14:42
- - migero   hi is there any chance for stereo ? and if not why...   Jun 29 2010, 17:14
- - kode54   It already does stereo for MUS/STR file pairs. It ...   Jun 29 2010, 21:04
- - alvaro84   Hi! Do you plan to incorporate reSIDfp and/or ...   Jul 19 2010, 22:36
- - kode54   I have switched over to sidplay-residfp, and you...   Jul 20 2010, 07:00
- - edwardar   Thanks so much for switching to residfp - I just t...   Jul 20 2010, 22:26
- - Arthur   Hi Kode, Again, excellent work on the plugin, agre...   Jul 22 2010, 14:47
- - kode54   Where is this sidplay 2.5? All I can find is some ...   Jul 23 2010, 01:10
- - Arthur   Hi, I know this won't help you much in terms o...   Jul 23 2010, 08:54
|- - kode54   QUOTE (Arthur @ Jul 23 2010, 00:54) And, ...   Jul 23 2010, 20:33
- - fuffi   hello kode54, is there a chance to make your plugi...   Jan 30 2011, 19:56
- - kode54   I'll add checking so that if you set the song ...   Jan 31 2011, 01:30
- - gorkha   foo_sid seems to disregard all settings in portabl...   Jan 31 2011, 06:56
|- - fuffi   QUOTE (gorkha @ Jan 31 2011, 05:56) songl...   Jan 31 2011, 12:08
- - kode54   I've implemented relative path support, curren...   Feb 2 2011, 07:53
|- - fuffi   wow, that was fast :-) i put STIL.txt and Songlen...   Feb 2 2011, 18:32
- - kode54   Are you sure both installations are using the same...   Feb 2 2011, 23:36
|- - fuffi   QUOTE (kode54 @ Feb 2 2011, 22:36) Are yo...   Feb 3 2011, 00:13
- - kode54   I updated it to fix the relative path support for ...   Feb 3 2011, 08:56
- - fuffi   great, thanks. i downloaded and installed the vers...   Feb 3 2011, 12:29
- - kode54   Fixed and uploaded in the usual place. Debug versi...   Feb 3 2011, 15:55
|- - fuffi   QUOTE (kode54 @ Feb 3 2011, 15:55) Fixed ...   Feb 3 2011, 16:20
|- - fuffi   QUOTE (kode54 @ Feb 3 2011, 15:55) Fixed ...   Feb 4 2011, 12:10
- - kode54   This is from foobar2000 itself. If you want to kee...   Feb 3 2011, 16:27
- - kode54   The debugging information is only there to help yo...   Feb 4 2011, 14:55
|- - fuffi   QUOTE (kode54 @ Feb 4 2011, 14:55) The de...   Feb 4 2011, 15:01
- - gorkha   foo_sid version 1.22 It does go on to the next si...   Feb 18 2011, 04:48
- - kode54   If you added the files to your playlist after sett...   Feb 18 2011, 06:00
- - gorkha   Ahh, I see Removed them from library and added th...   Feb 18 2011, 08:29
- - kode54   Simply right clicking on the files and either open...   Feb 18 2011, 09:01
- - Videogamer555   I don't know where you live but I live in the ...   Aug 21 2011, 13:05
|- - db1989   QUOTE (Videogamer555 @ Aug 21 2011, 13:05...   Aug 21 2011, 13:17
- - kode54   SID files may specify whether they want NTSC or PA...   Aug 21 2011, 23:07
|- - deus-ex   The new release of Foo_SID v1.24 has "slightl...   Dec 23 2011, 15:48
- - kode54   Nope, that's not clipping, that's a slow s...   Dec 23 2011, 19:08
|- - deus-ex   QUOTE (kode54 @ Dec 23 2011, 20:08) I don...   Dec 23 2011, 21:52
|- - deus-ex   QUOTE (kode54 @ Dec 23 2011, 20:08) Feel ...   Jan 9 2012, 16:44
- - Videogamer555   SID plugin needs oscillator frequency switch The ...   Jan 26 2012, 07:53
- - kode54   No, I am not living anywhere in Europe, I just nev...   Jan 26 2012, 23:15
- - hdnine   I have a request that you hopefully can implement ...   Mar 20 2012, 09:13
- - Dhry   Hi kode54. Another vote here for stereo output fro...   Feb 1 2013, 22:45
- - kode54   I could look into how to play a fake stereo mode, ...   Feb 2 2013, 09:21
|- - Dhry   QUOTE (kode54 @ Feb 2 2013, 01:21) I coul...   Feb 4 2013, 02:35
- - GreenLantern   Nice plugin! I'm having trouble playing a...   Mar 26 2013, 00:07
- - trumad   Hey You've got a lot of people asking for thi...   Jul 31 2013, 20:17
- - gorkha   I am using foobar 1.2.9 with foo_sid 1.31 in porta...   Aug 2 2013, 05:53
- - kode54   Songs will end if the original song ends inside th...   Aug 2 2013, 19:01
- - gorkha   QUOTE Songs will end if the original song ends ins...   Aug 5 2013, 20:50
- - deus-ex   Hi kode54, one for reed.rsid can't be played ...   Apr 1 2014, 21:57
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 5th August 2015 - 09:31
