> Upload forum rules
DSD-2-PCM -- proof of concept, test sample and source code here
SebastianG
post Oct 8 2005, 23:55
The ZIP contains 4 files:
- dsd2pcm.jar (the converter written in Java, outputs raw 24/88 PCM, intel byte order)
- info.txt (contains some infos)
- test2822k.dsd (14 seconds, mono DSD, 5 megs)
- test44k.mp3 (conversion result)
have fun,
Sebi
Edit-2011: For the latest C/C++ source code see https://code.google.com/p/dsd2pcm/ It is released under the new BSD license. The attatchment to this post is still the first Java release.
This post has been edited by SebastianG: Dec 4 2011, 17:45
Attached File(s)
spoon
post Dec 2 2009, 09:55
dBpowerAMP developer
Group: Developer (Donating)
I might be wrong, but I do not think there are any PC compatible drives which can read the SACD layer - I know Sony did a laptop once which could write them. Hence why people are resorting to tapping into the binary data stream inside a SACD player.
Spoon http://www.dbpoweramp.com
krabapple
post Dec 2 2009, 17:23
QUOTE (spoon @ Dec 2 2009, 03:55) *
Yeah, there is that. And the whole DRM thing. And the fact that SACD is basically moribund. But here's to hoping. wink.gif
- SebastianG   DSD-2-PCM -- proof of concept   Oct 8 2005, 23:55
- - skamp   Now you need to develop a DVD-ROM driver for readi...   Oct 9 2005, 01:27
|- - SebastianG   QUOTE (skamp @ Oct 9 2005, 01:27 AM)Now you n...   Oct 9 2005, 10:32
|- - SebastianG   Oh, I noticed a small bug: The dsd file size must ...   Oct 9 2005, 11:06
- - tarsier   So is it theoretically possible to convert the PCM...   Dec 24 2006, 20:33
|- - putanik   QUOTE (tarsier @ Dec 24 2006, 13:33) So i...   Dec 24 2006, 22:54
|- - tarsier   Thanks for the link. But right now, I'm only ...   Dec 26 2006, 16:28
|- - Kees de Visser   QUOTE (tarsier @ Dec 26 2006, 16:28) In d...   Dec 26 2006, 19:03
- - andyshedd   I'm mildly curious how this method compares an...   Jan 8 2007, 22:44
- - frenchglen   Is there any updated info about this program? I tr...   Jun 8 2009, 15:23
- - LukeS   I am bringing this back form years of being dead. ...   Nov 23 2009, 15:56
- - GeSomeone   I think it's in the first post. QUOTE (Sebasti...   Nov 23 2009, 19:12
|- - SebastianG   QUOTE (GeSomeone @ Nov 23 2009, 19:12) I ...   Nov 23 2009, 20:31
- - LukeS   SebastianG, Awesome job on the program, my proble...   Nov 23 2009, 22:32
|- - vincefalks   I am not an expert but it would be cool to compare...   Nov 24 2009, 00:17
|- - rpp3po   What would be a higher quality approach than 1. co...   Nov 24 2009, 02:48
- - SebastianG   QUOTE (LukeS @ Nov 23 2009, 22:32) The ou...   Nov 24 2009, 10:38
- - 2Bdecided   With the huge caveat that I made no attempt to do ...   Nov 24 2009, 12:40
- - vincefalks   The noise is indeed a problem with the DSD format ...   Nov 24 2009, 13:07
|- - rpp3po   The problem with the "most accurate capture...   Nov 24 2009, 14:01
|- - vincefalks   QUOTE (rpp3po @ Nov 24 2009, 15:01) The p...   Nov 24 2009, 14:25
||- - Canar   QUOTE (vincefalks @ Nov 24 2009, 08:25) I...   Nov 24 2009, 15:49
||- - rpp3po   Raw DSD means saving about 3 GB per 70 minute ster...   Nov 24 2009, 17:23
||- - BOBCHEWIE   QUOTE (rpp3po @ Nov 24 2009, 10:23) Raw D...   Jan 3 2010, 12:14
||- - rpp3po   QUOTE (BOBCHEWIE @ Jan 3 2010, 12:14) scr...   Jan 3 2010, 14:15
||- - Axon   QUOTE (BOBCHEWIE @ Jan 3 2010, 05:14) QUO...   Jan 3 2010, 14:22
||- - Martel   QUOTE (BOBCHEWIE @ Jan 3 2010, 12:14) ......   Jan 4 2010, 09:53
|- - Mike Giacomelli   QUOTE (rpp3po @ Nov 24 2009, 08:01) DSD h...   Nov 24 2009, 15:46
- - LukeS   QUOTE (rpp3po @ Nov 24 2009, 08:01) The p...   Nov 24 2009, 21:39
|- - rpp3po   QUOTE (LukeS @ Nov 24 2009, 21:39) 48kHz ...   Nov 25 2009, 03:00
||- - LukeS   QUOTE (rpp3po @ Nov 24 2009, 21:00) QUOTE...   Nov 25 2009, 04:20
||- - Mike Giacomelli   QUOTE (LukeS @ Nov 24 2009, 22:20) QUOTE ...   Nov 25 2009, 05:25
||- - LukeS   QUOTE (Mike Giacomelli @ Nov 24 2009, 23...   Nov 25 2009, 05:29
||- - Mike Giacomelli   QUOTE (LukeS @ Nov 24 2009, 23:29) Also I...   Nov 25 2009, 05:55
|- - vincefalks   QUOTE (LukeS @ Nov 24 2009, 22:39) I am v...   Nov 25 2009, 08:02
|- - knutinh   QUOTE (LukeS @ Nov 24 2009, 21:39) Also t...   Nov 25 2009, 08:36
- - Axon   Look into the dynamic range of SACD at 22khz somet...   Nov 24 2009, 21:56
- - Axon   Yes, let's all thank LukeS for being a boy sco...   Nov 25 2009, 04:59
|- - LukeS   QUOTE (Axon @ Nov 24 2009, 22:59) Yes, le...   Nov 25 2009, 05:21
||- - Martel   QUOTE (LukeS @ Nov 25 2009, 05:21) The bo...   Nov 25 2009, 10:24
|- - 2Bdecided   QUOTE (Axon @ Nov 25 2009, 03:59) Sorry f...   Nov 25 2009, 12:13
|- - udauda   QUOTE (Axon @ Nov 24 2009, 19:59) You...   Nov 26 2009, 02:31
|- - 2Bdecided   QUOTE (udauda @ Nov 26 2009, 01:31) Does ...   Nov 26 2009, 11:46
|- - vincefalks   QUOTE (2Bdecided @ Nov 26 2009, 12:46) Li...   Nov 26 2009, 12:02
|- - rpp3po   Yawn! Am I really the last one to get where t...   Nov 26 2009, 12:37
|- - vincefalks   QUOTE (rpp3po @ Nov 26 2009, 13:37) Yawn...   Nov 26 2009, 13:10
|- - rpp3po   At least you seem believe the life-like-analog-sou...   Nov 26 2009, 13:25
|- - vincefalks   QUOTE (rpp3po @ Nov 26 2009, 14:25) At le...   Nov 26 2009, 13:40
- - LukeS   QUOTE (vincefalks @ Nov 25 2009, 02:02) Q...   Nov 25 2009, 09:16
|- - SebastianG   QUOTE (LukeS @ Nov 25 2009, 09:16) See th...   Nov 25 2009, 10:32
|- - knutinh   QUOTE (LukeS @ Nov 25 2009, 09:16) DST wo...   Nov 25 2009, 18:02
|- - simmconn   QUOTE DST would work but I have not found a no low...   Nov 26 2009, 01:31
|- - vincefalks   QUOTE (simmconn @ Nov 26 2009, 02:31) QUO...   Nov 26 2009, 03:38
- - rpp3po   Sorry, if I didn't express myself clearly enou...   Nov 25 2009, 12:04
- - Axon   It's a surprisingly well known mod, actually. ...   Nov 25 2009, 19:38
|- - rpp3po   I find it interesting, nevertheless. What equipmen...   Nov 25 2009, 20:38
- - LukeS   Wow, I really am messing thing up lately ; I got ...   Nov 26 2009, 07:27
|- - simmconn   And I just spent one and a half hours to encode an...   Nov 26 2009, 08:16
- - 2Bdecided   Yes, the distortions of SACD are inaudible. Especi...   Nov 26 2009, 15:57
- - Canar   So that's what they mean by "warm" s...   Nov 26 2009, 16:22
- - Axon   If SACD really did have a similar distortion profi...   Nov 26 2009, 21:14
- - SebastianG   Just for kicks and giggles I rewrote most of ...   Nov 27 2009, 03:26
|- - vincefalks   QUOTE (SebastianG @ Nov 27 2009, 03:26) J...   Nov 27 2009, 03:44
|- - SebastianG   QUOTE (vincefalks @ Nov 27 2009, 03:44) T...   Nov 27 2009, 04:14
||- - vincefalks   QUOTE (SebastianG @ Nov 27 2009, 04:14) S...   Nov 27 2009, 05:11
||- - Kees de Visser   There seems to be a growing (niche) market for onl...   Nov 27 2009, 09:02
||- - 2Bdecided   QUOTE (vincefalks @ Nov 27 2009, 04:11) N...   Nov 27 2009, 10:59
||- - rpp3po   QUOTE (vincefalks @ Nov 27 2009, 05:11) N...   Nov 27 2009, 12:55
|||- - 2Bdecided   QUOTE (rpp3po @ Nov 27 2009, 11:55) An an...   Nov 27 2009, 13:00
||- - krabapple   QUOTE (vincefalks @ Nov 26 2009, 23:11) T...   Nov 29 2009, 03:56
|- - rpp3po   QUOTE (vincefalks @ Nov 27 2009, 03:44) H...   Nov 27 2009, 04:16
- - LukeS   QUOTE (SebastianG @ Nov 26 2009, 21:26) J...   Nov 27 2009, 07:33
|- - smack   QUOTE (LukeS @ Nov 27 2009, 07:33) Window...   Nov 27 2009, 11:00
- - .halverhahn   DXD is PCM - just with a bunch of noise above 48kH...   Nov 27 2009, 15:34
|- - rpp3po   Wow! The DXD track is certainly nothing Bruce ...   Nov 27 2009, 17:47
- - spoon   As the noise is constant this shows the levels qui...   Nov 29 2009, 20:54
- - spoon   QUOTE The final amusing aspect to all this is that...   Nov 29 2009, 22:51
|- - krabapple   QUOTE (spoon @ Nov 29 2009, 16:51) QUOTE ...   Nov 30 2009, 06:33
- - spoon   Based on Sebastians good work I have wrapped the d...   Dec 1 2009, 17:49
- - kode54   @spoon: I presume you modified the stage 1 filter ...   Dec 1 2009, 19:55
- - spoon   I thought it was a command line option on dsd2pcm?   Dec 1 2009, 20:15
|- - kode54   QUOTE (spoon @ Dec 1 2009, 11:15) I thoug...   Dec 7 2009, 15:32
- - krabapple   This is all peachy for those recording DSD files o...   Dec 2 2009, 06:56
|- - BOBCHEWIE   QUOTE (krabapple @ Dec 1 2009, 23:56) Thi...   Jan 3 2010, 13:33
- - spoon   I might be wrong, but I do not think there are any...   Dec 2 2009, 09:55
|- - krabapple   QUOTE (spoon @ Dec 2 2009, 03:55) I might...   Dec 2 2009, 17:23
- - Martel   QUOTE There are three types of SACDs[9]: * Hy...   Dec 2 2009, 10:35
- - .halverhahn   Just for your information: Wheatus is offering The...   Dec 2 2009, 11:38
|- - 2Bdecided   QUOTE (.halverhahn @ Dec 2 2009, 10:38) J...   Dec 2 2009, 15:11
- - vincefalks   Ok finally my warning was lifted after a little si...   Dec 7 2009, 17:55
|- - krabapple   QUOTE (vincefalks @ Dec 7 2009, 11:55) QU...   Dec 7 2009, 18:26
|- - 2Bdecided   QUOTE (vincefalks @ Dec 7 2009, 16:55) I...   Dec 7 2009, 18:33
|- - spoon   Did anyone manage to decode a .dsf file? (such as ...   Dec 8 2009, 10:21
- - Martel   A (square analog) pulse has an infinitely wide spe...   Dec 7 2009, 18:26
- - udauda   I wonder, how come Pro-DSD never comes up with a s...   Jan 4 2010, 13:39
- - rpp3po   Excellent paper, thanks!   Jan 4 2010, 14:31
- - krabapple   I remember this one from a few years back....I for...   Jan 8 2010, 22:05
- - ElfeJoyeux   Hello, I just discovered this awesome topic durin...   Mar 11 2010, 22:34
|- - Hobbit13   QUOTE (ElfeJoyeux @ Mar 11 2010, 22:34) T...   Jul 19 2010, 10:48
- - Sik_Lescinovid   Has anyone so far noticed that when creating a 24 ...   Nov 27 2011, 18:28
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 6th May 2015 - 15:05
