> Upload forum rules
DSD-2-PCM -- proof of concept, test sample and source code here
SebastianG
post Oct 8 2005, 23:55
The ZIP contains 4 files:
- dsd2pcm.jar (the converter written in Java, outputs raw 24/88 PCM, intel byte order)
- info.txt (contains some infos)
- test2822k.dsd (14 seconds, mono DSD, 5 megs)
- test44k.mp3 (conversion result)
have fun,
Sebi
Edit-2011: For the latest C/C++ source code see https://code.google.com/p/dsd2pcm/ It is released under the new BSD license. The attatchment to this post is still the first Java release.
This post has been edited by SebastianG: Dec 4 2011, 17:45
Attached File(s)
SebastianG
post Nov 24 2009, 10:38
QUOTE (LukeS @ Nov 23 2009, 22:32) *
The output 88200Hz PCM has a hiss and static on it as you mentioned in your post. Is there a command line switch to output at the first stage 352kHz
No. That would not even help because the bit order affects the first stage. You could try to add a switch to enable/disable the "pre stage 1 bitreversal".
I will try an figure out how to extract the jar, look at the code, and see if I can tinker with it.
Just unzip it. .jar files are really .zip files with some added meta informations.
rpp3po is right. There's not a lot you can do differently in a mathematical sense than to pick other low pass filters. (Of course, the implementation might differ.) I even documented the properties of the two low pass filters. The paranoid user should be pleased with the 170 dB (IIRC) stopband rejection of the first stage. The lowpass filter's roll off starts at something around 25 kHz (IIRC). That's IMHO high enough because there's already an awful lot of noise just above it. (The DSD propaganda tells you that DSD has a "great dynamic range". That only applies to frequencies below 20kHz which is not surprizing).
SG
This post has been edited by SebastianG: Nov 24 2009, 10:41
- SebastianG   DSD-2-PCM -- proof of concept   Oct 8 2005, 23:55
- - skamp   Now you need to develop a DVD-ROM driver for readi...   Oct 9 2005, 01:27
|- - SebastianG   QUOTE (skamp @ Oct 9 2005, 01:27 AM)Now you n...   Oct 9 2005, 10:32
|- - SebastianG   Oh, I noticed a small bug: The dsd file size must ...   Oct 9 2005, 11:06
- - tarsier   So is it theoretically possible to convert the PCM...   Dec 24 2006, 20:33
|- - putanik   QUOTE (tarsier @ Dec 24 2006, 13:33) So i...   Dec 24 2006, 22:54
|- - tarsier   Thanks for the link. But right now, I'm only ...   Dec 26 2006, 16:28
|- - Kees de Visser   QUOTE (tarsier @ Dec 26 2006, 16:28) In d...   Dec 26 2006, 19:03
- - andyshedd   I'm mildly curious how this method compares an...   Jan 8 2007, 22:44
- - frenchglen   Is there any updated info about this program? I tr...   Jun 8 2009, 15:23
- - LukeS   I am bringing this back form years of being dead. ...   Nov 23 2009, 15:56
- - GeSomeone   I think it's in the first post. QUOTE (Sebasti...   Nov 23 2009, 19:12
|- - SebastianG   QUOTE (GeSomeone @ Nov 23 2009, 19:12) I ...   Nov 23 2009, 20:31
- - LukeS   SebastianG, Awesome job on the program, my proble...   Nov 23 2009, 22:32
|- - vincefalks   I am not an expert but it would be cool to compare...   Nov 24 2009, 00:17
|- - rpp3po   What would be a higher quality approach than 1. co...   Nov 24 2009, 02:48
- - SebastianG   QUOTE (LukeS @ Nov 23 2009, 22:32) The ou...   Nov 24 2009, 10:38
- - 2Bdecided   With the huge caveat that I made no attempt to do ...   Nov 24 2009, 12:40
- - vincefalks   The noise is indeed a problem with the DSD format ...   Nov 24 2009, 13:07
|- - rpp3po   The problem with the "most accurate capture...   Nov 24 2009, 14:01
|- - vincefalks   QUOTE (rpp3po @ Nov 24 2009, 15:01) The p...   Nov 24 2009, 14:25
||- - Canar   QUOTE (vincefalks @ Nov 24 2009, 08:25) I...   Nov 24 2009, 15:49
||- - rpp3po   Raw DSD means saving about 3 GB per 70 minute ster...   Nov 24 2009, 17:23
||- - BOBCHEWIE   QUOTE (rpp3po @ Nov 24 2009, 10:23) Raw D...   Jan 3 2010, 12:14
||- - rpp3po   QUOTE (BOBCHEWIE @ Jan 3 2010, 12:14) scr...   Jan 3 2010, 14:15
||- - Axon   QUOTE (BOBCHEWIE @ Jan 3 2010, 05:14) QUO...   Jan 3 2010, 14:22
||- - Martel   QUOTE (BOBCHEWIE @ Jan 3 2010, 12:14) ......   Jan 4 2010, 09:53
|- - Mike Giacomelli   QUOTE (rpp3po @ Nov 24 2009, 08:01) DSD h...   Nov 24 2009, 15:46
- - LukeS   QUOTE (rpp3po @ Nov 24 2009, 08:01) The p...   Nov 24 2009, 21:39
|- - rpp3po   QUOTE (LukeS @ Nov 24 2009, 21:39) 48kHz ...   Nov 25 2009, 03:00
||- - LukeS   QUOTE (rpp3po @ Nov 24 2009, 21:00) QUOTE...   Nov 25 2009, 04:20
||- - Mike Giacomelli   QUOTE (LukeS @ Nov 24 2009, 22:20) QUOTE ...   Nov 25 2009, 05:25
||- - LukeS   QUOTE (Mike Giacomelli @ Nov 24 2009, 23...   Nov 25 2009, 05:29
||- - Mike Giacomelli   QUOTE (LukeS @ Nov 24 2009, 23:29) Also I...   Nov 25 2009, 05:55
|- - vincefalks   QUOTE (LukeS @ Nov 24 2009, 22:39) I am v...   Nov 25 2009, 08:02
|- - knutinh   QUOTE (LukeS @ Nov 24 2009, 21:39) Also t...   Nov 25 2009, 08:36
- - Axon   Look into the dynamic range of SACD at 22khz somet...   Nov 24 2009, 21:56
- - Axon   Yes, let's all thank LukeS for being a boy sco...   Nov 25 2009, 04:59
|- - LukeS   QUOTE (Axon @ Nov 24 2009, 22:59) Yes, le...   Nov 25 2009, 05:21
||- - Martel   QUOTE (LukeS @ Nov 25 2009, 05:21) The bo...   Nov 25 2009, 10:24
|- - 2Bdecided   QUOTE (Axon @ Nov 25 2009, 03:59) Sorry f...   Nov 25 2009, 12:13
|- - udauda   QUOTE (Axon @ Nov 24 2009, 19:59) You...   Nov 26 2009, 02:31
|- - 2Bdecided   QUOTE (udauda @ Nov 26 2009, 01:31) Does ...   Nov 26 2009, 11:46
|- - vincefalks   QUOTE (2Bdecided @ Nov 26 2009, 12:46) Li...   Nov 26 2009, 12:02
|- - rpp3po   Yawn! Am I really the last one to get where t...   Nov 26 2009, 12:37
|- - vincefalks   QUOTE (rpp3po @ Nov 26 2009, 13:37) Yawn...   Nov 26 2009, 13:10
|- - rpp3po   At least you seem believe the life-like-analog-sou...   Nov 26 2009, 13:25
|- - vincefalks   QUOTE (rpp3po @ Nov 26 2009, 14:25) At le...   Nov 26 2009, 13:40
- - LukeS   QUOTE (vincefalks @ Nov 25 2009, 02:02) Q...   Nov 25 2009, 09:16
|- - SebastianG   QUOTE (LukeS @ Nov 25 2009, 09:16) See th...   Nov 25 2009, 10:32
|- - knutinh   QUOTE (LukeS @ Nov 25 2009, 09:16) DST wo...   Nov 25 2009, 18:02
|- - simmconn   QUOTE DST would work but I have not found a no low...   Nov 26 2009, 01:31
|- - vincefalks   QUOTE (simmconn @ Nov 26 2009, 02:31) QUO...   Nov 26 2009, 03:38
- - rpp3po   Sorry, if I didn't express myself clearly enou...   Nov 25 2009, 12:04
- - Axon   It's a surprisingly well known mod, actually. ...   Nov 25 2009, 19:38
|- - rpp3po   I find it interesting, nevertheless. What equipmen...   Nov 25 2009, 20:38
- - LukeS   Wow, I really am messing thing up lately ; I got ...   Nov 26 2009, 07:27
|- - simmconn   And I just spent one and a half hours to encode an...   Nov 26 2009, 08:16
- - 2Bdecided   Yes, the distortions of SACD are inaudible. Especi...   Nov 26 2009, 15:57
- - Canar   So that's what they mean by "warm" s...   Nov 26 2009, 16:22
- - Axon   If SACD really did have a similar distortion profi...   Nov 26 2009, 21:14
- - SebastianG   Just for kicks and giggles I rewrote most of ...   Nov 27 2009, 03:26
|- - vincefalks   QUOTE (SebastianG @ Nov 27 2009, 03:26) J...   Nov 27 2009, 03:44
|- - SebastianG   QUOTE (vincefalks @ Nov 27 2009, 03:44) T...   Nov 27 2009, 04:14
||- - vincefalks   QUOTE (SebastianG @ Nov 27 2009, 04:14) S...   Nov 27 2009, 05:11
||- - Kees de Visser   There seems to be a growing (niche) market for onl...   Nov 27 2009, 09:02
||- - 2Bdecided   QUOTE (vincefalks @ Nov 27 2009, 04:11) N...   Nov 27 2009, 10:59
||- - rpp3po   QUOTE (vincefalks @ Nov 27 2009, 05:11) N...   Nov 27 2009, 12:55
|||- - 2Bdecided   QUOTE (rpp3po @ Nov 27 2009, 11:55) An an...   Nov 27 2009, 13:00
||- - krabapple   QUOTE (vincefalks @ Nov 26 2009, 23:11) T...   Nov 29 2009, 03:56
|- - rpp3po   QUOTE (vincefalks @ Nov 27 2009, 03:44) H...   Nov 27 2009, 04:16
- - LukeS   QUOTE (SebastianG @ Nov 26 2009, 21:26) J...   Nov 27 2009, 07:33
|- - smack   QUOTE (LukeS @ Nov 27 2009, 07:33) Window...   Nov 27 2009, 11:00
- - .halverhahn   DXD is PCM - just with a bunch of noise above 48kH...   Nov 27 2009, 15:34
|- - rpp3po   Wow! The DXD track is certainly nothing Bruce ...   Nov 27 2009, 17:47
- - spoon   As the noise is constant this shows the levels qui...   Nov 29 2009, 20:54
- - spoon   QUOTE The final amusing aspect to all this is that...   Nov 29 2009, 22:51
|- - krabapple   QUOTE (spoon @ Nov 29 2009, 16:51) QUOTE ...   Nov 30 2009, 06:33
- - spoon   Based on Sebastians good work I have wrapped the d...   Dec 1 2009, 17:49
- - kode54   @spoon: I presume you modified the stage 1 filter ...   Dec 1 2009, 19:55
- - spoon   I thought it was a command line option on dsd2pcm?   Dec 1 2009, 20:15
|- - kode54   QUOTE (spoon @ Dec 1 2009, 11:15) I thoug...   Dec 7 2009, 15:32
- - krabapple   This is all peachy for those recording DSD files o...   Dec 2 2009, 06:56
|- - BOBCHEWIE   QUOTE (krabapple @ Dec 1 2009, 23:56) Thi...   Jan 3 2010, 13:33
- - spoon   I might be wrong, but I do not think there are any...   Dec 2 2009, 09:55
|- - krabapple   QUOTE (spoon @ Dec 2 2009, 03:55) I might...   Dec 2 2009, 17:23
- - Martel   QUOTE There are three types of SACDs[9]: * Hy...   Dec 2 2009, 10:35
- - .halverhahn   Just for your information: Wheatus is offering The...   Dec 2 2009, 11:38
|- - 2Bdecided   QUOTE (.halverhahn @ Dec 2 2009, 10:38) J...   Dec 2 2009, 15:11
- - vincefalks   Ok finally my warning was lifted after a little si...   Dec 7 2009, 17:55
|- - krabapple   QUOTE (vincefalks @ Dec 7 2009, 11:55) QU...   Dec 7 2009, 18:26
|- - 2Bdecided   QUOTE (vincefalks @ Dec 7 2009, 16:55) I...   Dec 7 2009, 18:33
|- - spoon   Did anyone manage to decode a .dsf file? (such as ...   Dec 8 2009, 10:21
- - Martel   A (square analog) pulse has an infinitely wide spe...   Dec 7 2009, 18:26
- - udauda   I wonder, how come Pro-DSD never comes up with a s...   Jan 4 2010, 13:39
- - rpp3po   Excellent paper, thanks!   Jan 4 2010, 14:31
- - krabapple   I remember this one from a few years back....I for...   Jan 8 2010, 22:05
- - ElfeJoyeux   Hello, I just discovered this awesome topic durin...   Mar 11 2010, 22:34
|- - Hobbit13   QUOTE (ElfeJoyeux @ Mar 11 2010, 22:34) T...   Jul 19 2010, 10:48
- - Sik_Lescinovid   Has anyone so far noticed that when creating a 24 ...   Nov 27 2011, 18:28
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 22nd May 2015 - 17:36
