SACD Ripping, ???????????
Donunus
post Oct 2 2005, 06:05
I have never used sacd but was wondering how big the uncompressed file out of an sacd is(Bitrate). Also, Is there a lossy encoder out there that can encode these files and actually do it justice?
spoon
post Oct 8 2005, 23:36
dBpowerAMP developer
Group: Developer (Donating)
>The point is the cd standard encompasses the range of human hearing already.
It is what is playing the audio - the cheapest portable CD player is going to have a 16 bit DAC inside - noise will be present from the cheapy DAC component on the LSB bits of DAC. You would hope that a cheapest portable DVD-A (ok fast forward 5 years) would have a 24 bit DAC, the noise on the same LSB bits on a 24 bit chip might give 22 good bits, 8 more than the cheapest 16 bit DAC.
Top end stuff, I doubt you could blind test 16 bit or 24 bit, so it only improves bottom end stuff. Now if only they could improve those 45 cents headpones... smile.gif
<edit: just realized in 5 years time portable digital players might have taken over, the same applies - 24 bit components in an iPod, all the better>
This post has been edited by spoon: Oct 8 2005, 23:37
Spoon http://www.dbpoweramp.com
- Donunus   SACD Ripping   Oct 2 2005, 06:05
- - rjamorim   First, you (normally) can't read SACD data usi...   Oct 2 2005, 06:17
|- - WaveFiler   QUOTE (rjamorim @ Oct 2 2005, 12:17 AM)First,...   Oct 5 2005, 09:55
- - Defsac   SACD has copy protection on the physical level, si...   Oct 2 2005, 07:46
- - Donunus   OK, What about the DVD audio format? Is there anyt...   Oct 2 2005, 07:57
|- - user   DVD-Audio is the format one should prefer for high...   Oct 2 2005, 12:28
- - skamp   Yes, you can now rip DVD-Audio discs, although the...   Oct 2 2005, 13:53
- - SebastianG   QUOTE (Donunus @ Oct 2 2005, 06:05 AM)I have ...   Oct 2 2005, 14:35
|- - rjamorim   QUOTE (SebastianG @ Oct 2 2005, 10:35 AM)This...   Oct 2 2005, 16:04
|- - Garf   QUOTE (rjamorim @ Oct 2 2005, 05:04 PM)QUOTE ...   Oct 2 2005, 19:24
- - tgoose   Can DSD to PCM be done losslessly?   Oct 2 2005, 15:16
- - dekkersj   QUOTE (Garf @ Oct 2 2005, 07:24 PM)QUOTE (rja...   Oct 2 2005, 22:08
- - Donunus   So If you have to downsample when converting to pc...   Oct 3 2005, 03:28
- - Donunus   What I was getting at when posting this thread was...   Oct 3 2005, 03:34
|- - Defsac   QUOTE (Donunus @ Oct 3 2005, 12:34 PM)What I ...   Oct 3 2005, 03:48
- - dekkersj   QUOTE (Defsac @ Oct 3 2005, 03:48 AM)QUOTE (D...   Oct 3 2005, 09:58
|- - Donunus   QUOTE (dekkersj @ Oct 3 2005, 04:58 PM)QUOTE ...   Oct 3 2005, 10:40
- - dekkersj   QUOTE (Donunus @ Oct 3 2005, 10:40 AM)QUOTE (...   Oct 3 2005, 11:10
|- - guruboolez   QUOTE (dekkersj @ Oct 3 2005, 11:10 AM)Since ...   Oct 8 2005, 15:34
|- - krabapple   QUOTE (guruboolez @ Oct 8 2005, 06:34 AM)QUOT...   Oct 10 2005, 08:31
- - Donunus   What is DVD audio by the way 24 bit 96khz? that in...   Oct 3 2005, 11:27
- - dekkersj   DVD-A is at best 192 kHz 24 bits and in multichann...   Oct 3 2005, 11:50
- - Donunus   What I mean by the word "analog" is that...   Oct 3 2005, 12:50
|- - beto   QUOTE (Donunus @ Oct 3 2005, 08:50 AM)What I ...   Oct 3 2005, 13:11
|- - Donunus   QUOTE (beto @ Oct 3 2005, 08:11 PM)QUOTE (Don...   Oct 3 2005, 13:19
||- - beto   QUOTE (Donunus @ Oct 3 2005, 09:19 AM)Its not...   Oct 3 2005, 13:38
|- - krabapple   QUOTE (beto @ Oct 3 2005, 04:11 AM)QUOTE (Don...   Oct 10 2005, 07:48
- - dekkersj   QUOTE (Donunus @ Oct 3 2005, 12:50 PM)More bi...   Oct 3 2005, 13:05
|- - Donunus   QUOTE (dekkersj @ Oct 3 2005, 08:05 PM)QUOTE ...   Oct 3 2005, 13:25
|- - krabapple   QUOTE (Donunus @ Oct 3 2005, 04:25 AM)QUOTE (...   Oct 10 2005, 08:02
- - dekkersj   Interpolation is something that simply belongs to ...   Oct 3 2005, 13:36
- - Donunus   no one seems to be joining us in this conversation...   Oct 3 2005, 13:41
- - KikeG   Interpolation, also called reconstruction, of the ...   Oct 3 2005, 13:54
- - beto   You may also want to read the FAQ. This has been ...   Oct 3 2005, 14:04
- - SebastianG   QUOTE (tgoose @ Oct 2 2005, 03:16 PM)Can DSD ...   Oct 3 2005, 14:17
|- - Donunus   QUOTE (SebastianG @ Oct 3 2005, 09:17 PM)QUOT...   Oct 3 2005, 14:32
- - daybreaker   "The Type R is Sony's ultimate video and ...   Oct 4 2005, 23:10
|- - skamp   QUOTE (daybreaker @ Oct 4 2005, 11:10 PM)...   Oct 5 2005, 08:22
- - dreamliner77   The only way that DVD-A or SACD (2 channel) can so...   Oct 5 2005, 04:52
|- - legg   QUOTE (dreamliner77 @ Oct 4 2005, 10:52 PM)Th...   Oct 8 2005, 19:28
- - karlie   well probably the advantage of having more dynamic...   Oct 5 2005, 09:42
|- - KikeG   QUOTE (karlie @ Oct 5 2005, 09:42 AM)well pro...   Oct 5 2005, 11:10
|- - spoon   QUOTE it is quite debatable whether the filters re...   Oct 5 2005, 14:10
- - daybreaker   QUOTE (skamp @ Oct 4 2005, 11:22 PM)I read th...   Oct 5 2005, 09:51
- - KikeG   Well, DSD is a lousy format for mastering, process...   Oct 5 2005, 10:57
|- - krabapple   QUOTE (KikeG @ Oct 5 2005, 01:57 AM)Well, DSD...   Oct 10 2005, 08:12
- - Clemech   http://www.homecinemachoice.com/cgi-bin/ou...033_E...   Oct 8 2005, 14:27
|- - krabapple   QUOTE (Clemech @ Oct 8 2005, 05:27 AM)The fig...   Oct 10 2005, 08:22
- - SebastianG   There are only two technical terms we need to use ...   Oct 8 2005, 15:56
|- - Mo0zOoH   QUOTE (SebastianG @ Oct 8 2005, 05:56 PM)Ther...   Oct 9 2005, 01:08
|- - SebastianG   QUOTE (Mo0zOoH @ Oct 9 2005, 01:08 AM)Uh, and...   Oct 9 2005, 10:29
- - KikeG   Clemech: nobody can assure that the CD layer and S...   Oct 8 2005, 16:02
- - dreamliner77   The point is the cd standard encompasses the range...   Oct 8 2005, 21:57
- - spoon   >The point is the cd standard encompasses the r...   Oct 8 2005, 23:36
- - spoon   When used in the real world increased sample rate ...   Oct 9 2005, 12:57
|- - SebastianG   QUOTE (spoon @ Oct 9 2005, 12:57 PM)When used...   Oct 9 2005, 14:45
- - dekkersj   QUOTE (guruboolez @ Oct 8 2005, 03:34 PM)QUOT...   Oct 9 2005, 22:28
- - dekkersj   QUOTE (krabapple @ Oct 10 2005, 08:31 AM)QUOT...   Oct 10 2005, 15:13
- - Clemech   I accept the criticism of my comparison of SACD an...   Oct 10 2005, 16:21
|- - krabapple   QUOTE (Clemech @ Oct 10 2005, 07:21 AM)I acce...   Oct 10 2005, 17:06
|- - Clemech   QUOTE It's possible to comment on what you hea...   Oct 10 2005, 17:18
|- - krabapple   QUOTE (Clemech @ Oct 10 2005, 08:18 AM)QUOTE ...   Oct 10 2005, 21:46
- - Axon   Nitpick: Orange Book or Scarlet Book?   Oct 10 2005, 22:01
|- - rjamorim   QUOTE (Axon @ Oct 10 2005, 06:01 PM)Nitpick: ...   Oct 10 2005, 22:44
|- - krabapple   QUOTE (Axon @ Oct 10 2005, 01:01 PM)Nitpick: ...   Oct 11 2005, 01:28
- - ToS_Maverick   hm, what about bringing the discussion about dvd-a...   Oct 10 2005, 23:40
- - dekkersj   QUOTE (ToS_Maverick @ Oct 10 2005, 11:40 PM)h...   Oct 10 2005, 23:59
|- - krabapple   QUOTE (dekkersj @ Oct 10 2005, 02:59 PM)QUOTE...   Oct 11 2005, 01:39
|- - user   Hi krabapple, as you have similar equipment like ...   Oct 11 2005, 09:07
- - Axon   I agree that a 96->44 conversion necessarily en...   Oct 11 2005, 00:09
- - ToS_Maverick   where is the difference if we convert this file to...   Oct 11 2005, 00:21
- - kode54   The only appropriate way to listen to the 24/96 fi...   Oct 11 2005, 00:29
|- - krabapple   QUOTE (kode54 @ Oct 10 2005, 03:29 PM)The onl...   Oct 11 2005, 01:34
- - dekkersj   QUOTE (ToS_Maverick @ Oct 11 2005, 12:21 AM)w...   Oct 11 2005, 12:49
- - ToS_Maverick   my webspace-provider is currently doing a server-m...   Oct 11 2005, 13:01
- - ToS_Maverick   my webspace is up again! you can download the...   Oct 11 2005, 19:25
- - KikeG   In order to avoid any possible differences caused ...   Oct 11 2005, 22:23
- - dekkersj   QUOTE (ToS_Maverick @ Oct 11 2005, 07:25 PM)m...   Oct 11 2005, 23:15
- - ToS_Maverick   QUOTE (dekkersj @ Oct 12 2005, 12:15 AM)Nice ...   Oct 11 2005, 23:25
- - dekkersj   QUOTE (ToS_Maverick @ Oct 11 2005, 11:25 PM)Q...   Oct 11 2005, 23:34
- - bugsy_pal   I think that SACD definitely sounds better than CD...   Oct 15 2005, 03:31
- - user   well, your preference of sacd vs. cd will be only ...   Oct 15 2005, 09:46
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 30th January 2015 - 08:13
