SACD Ripping, ???????????
Donunus
post Oct 2 2005, 06:05
I have never used sacd but was wondering how big the uncompressed file out of an sacd is(Bitrate). Also, Is there a lossy encoder out there that can encode these files and actually do it justice?
Donunus
post Oct 3 2005, 12:50
What I mean by the word "analog" is that is sounds more like the original master or real life. More bits so that less quantization is needed. In theory, doesn't analog sort of mean unlimited bits and bandwidth since the sound of somebody speaking to you for example doesnt have x samples per second. It is unlimited. All thats done with digital audio is making enough samples per second to make the digital audio sound as if it is the "analog" or real sound that was originally recorded.
The argument is whether the difference of data between 2 channel 16 bit/44khz CD audio and 24/192 really have an audible difference
beto
post Oct 3 2005, 13:11
Group: Members (Donating)
QUOTE (Donunus @ Oct 3 2005, 08:50 AM)
Yes, analog may be thought as unlimited but your argument is a moot point because we can only hear frequencies up to 22khz (and sometimes even lower than that).
In the past Nyquist already proved that to fully represent the spectrum of a bandwidth limited signal you have to sample at a minimum of twice the highest frequency. Which is precisely the samplerate of a CD.
Going above that smells like snake oil, because for sure it has no scientific base...
This post has been edited by beto: Oct 3 2005, 13:11
http://volutabro.blogspot.com
Donunus
post Oct 3 2005, 13:19
QUOTE (beto @ Oct 3 2005, 08:11 PM)
Its not the frequency response I worry about, its the number of data bits making the sound "less jagged" like a higher polygon count 3D model for example that makes it smoother.
beto
post Oct 3 2005, 13:38
QUOTE (Donunus @ Oct 3 2005, 09:19 AM)
I don't understand you. huh.gif are you talking about the bit depth?
- Donunus   SACD Ripping   Oct 2 2005, 06:05
- - rjamorim   First, you (normally) can't read SACD data usi...   Oct 2 2005, 06:17
|- - WaveFiler   QUOTE (rjamorim @ Oct 2 2005, 12:17 AM)First,...   Oct 5 2005, 09:55
- - Defsac   SACD has copy protection on the physical level, si...   Oct 2 2005, 07:46
- - Donunus   OK, What about the DVD audio format? Is there anyt...   Oct 2 2005, 07:57
|- - user   DVD-Audio is the format one should prefer for high...   Oct 2 2005, 12:28
- - skamp   Yes, you can now rip DVD-Audio discs, although the...   Oct 2 2005, 13:53
- - SebastianG   QUOTE (Donunus @ Oct 2 2005, 06:05 AM)I have ...   Oct 2 2005, 14:35
|- - rjamorim   QUOTE (SebastianG @ Oct 2 2005, 10:35 AM)This...   Oct 2 2005, 16:04
|- - Garf   QUOTE (rjamorim @ Oct 2 2005, 05:04 PM)QUOTE ...   Oct 2 2005, 19:24
- - tgoose   Can DSD to PCM be done losslessly?   Oct 2 2005, 15:16
- - dekkersj   QUOTE (Garf @ Oct 2 2005, 07:24 PM)QUOTE (rja...   Oct 2 2005, 22:08
- - Donunus   So If you have to downsample when converting to pc...   Oct 3 2005, 03:28
- - Donunus   What I was getting at when posting this thread was...   Oct 3 2005, 03:34
|- - Defsac   QUOTE (Donunus @ Oct 3 2005, 12:34 PM)What I ...   Oct 3 2005, 03:48
- - dekkersj   QUOTE (Defsac @ Oct 3 2005, 03:48 AM)QUOTE (D...   Oct 3 2005, 09:58
|- - Donunus   QUOTE (dekkersj @ Oct 3 2005, 04:58 PM)QUOTE ...   Oct 3 2005, 10:40
- - dekkersj   QUOTE (Donunus @ Oct 3 2005, 10:40 AM)QUOTE (...   Oct 3 2005, 11:10
|- - guruboolez   QUOTE (dekkersj @ Oct 3 2005, 11:10 AM)Since ...   Oct 8 2005, 15:34
|- - krabapple   QUOTE (guruboolez @ Oct 8 2005, 06:34 AM)QUOT...   Oct 10 2005, 08:31
- - Donunus   What is DVD audio by the way 24 bit 96khz? that in...   Oct 3 2005, 11:27
- - dekkersj   DVD-A is at best 192 kHz 24 bits and in multichann...   Oct 3 2005, 11:50
- - Donunus   What I mean by the word "analog" is that...   Oct 3 2005, 12:50
|- - beto   QUOTE (Donunus @ Oct 3 2005, 08:50 AM)What I ...   Oct 3 2005, 13:11
|- - Donunus   QUOTE (beto @ Oct 3 2005, 08:11 PM)QUOTE (Don...   Oct 3 2005, 13:19
||- - beto   QUOTE (Donunus @ Oct 3 2005, 09:19 AM)Its not...   Oct 3 2005, 13:38
|- - krabapple   QUOTE (beto @ Oct 3 2005, 04:11 AM)QUOTE (Don...   Oct 10 2005, 07:48
- - dekkersj   QUOTE (Donunus @ Oct 3 2005, 12:50 PM)More bi...   Oct 3 2005, 13:05
|- - Donunus   QUOTE (dekkersj @ Oct 3 2005, 08:05 PM)QUOTE ...   Oct 3 2005, 13:25
|- - krabapple   QUOTE (Donunus @ Oct 3 2005, 04:25 AM)QUOTE (...   Oct 10 2005, 08:02
- - dekkersj   Interpolation is something that simply belongs to ...   Oct 3 2005, 13:36
- - Donunus   no one seems to be joining us in this conversation...   Oct 3 2005, 13:41
- - KikeG   Interpolation, also called reconstruction, of the ...   Oct 3 2005, 13:54
- - beto   You may also want to read the FAQ. This has been ...   Oct 3 2005, 14:04
- - SebastianG   QUOTE (tgoose @ Oct 2 2005, 03:16 PM)Can DSD ...   Oct 3 2005, 14:17
|- - Donunus   QUOTE (SebastianG @ Oct 3 2005, 09:17 PM)QUOT...   Oct 3 2005, 14:32
- - daybreaker   "The Type R is Sony's ultimate video and ...   Oct 4 2005, 23:10
|- - skamp   QUOTE (daybreaker @ Oct 4 2005, 11:10 PM)...   Oct 5 2005, 08:22
- - dreamliner77   The only way that DVD-A or SACD (2 channel) can so...   Oct 5 2005, 04:52
|- - legg   QUOTE (dreamliner77 @ Oct 4 2005, 10:52 PM)Th...   Oct 8 2005, 19:28
- - karlie   well probably the advantage of having more dynamic...   Oct 5 2005, 09:42
|- - KikeG   QUOTE (karlie @ Oct 5 2005, 09:42 AM)well pro...   Oct 5 2005, 11:10
|- - spoon   QUOTE it is quite debatable whether the filters re...   Oct 5 2005, 14:10
- - daybreaker   QUOTE (skamp @ Oct 4 2005, 11:22 PM)I read th...   Oct 5 2005, 09:51
- - KikeG   Well, DSD is a lousy format for mastering, process...   Oct 5 2005, 10:57
|- - krabapple   QUOTE (KikeG @ Oct 5 2005, 01:57 AM)Well, DSD...   Oct 10 2005, 08:12
- - Clemech   http://www.homecinemachoice.com/cgi-bin/ou...033_E...   Oct 8 2005, 14:27
|- - krabapple   QUOTE (Clemech @ Oct 8 2005, 05:27 AM)The fig...   Oct 10 2005, 08:22
- - SebastianG   There are only two technical terms we need to use ...   Oct 8 2005, 15:56
|- - Mo0zOoH   QUOTE (SebastianG @ Oct 8 2005, 05:56 PM)Ther...   Oct 9 2005, 01:08
|- - SebastianG   QUOTE (Mo0zOoH @ Oct 9 2005, 01:08 AM)Uh, and...   Oct 9 2005, 10:29
- - KikeG   Clemech: nobody can assure that the CD layer and S...   Oct 8 2005, 16:02
- - dreamliner77   The point is the cd standard encompasses the range...   Oct 8 2005, 21:57
- - spoon   >The point is the cd standard encompasses the r...   Oct 8 2005, 23:36
- - spoon   When used in the real world increased sample rate ...   Oct 9 2005, 12:57
|- - SebastianG   QUOTE (spoon @ Oct 9 2005, 12:57 PM)When used...   Oct 9 2005, 14:45
- - dekkersj   QUOTE (guruboolez @ Oct 8 2005, 03:34 PM)QUOT...   Oct 9 2005, 22:28
- - dekkersj   QUOTE (krabapple @ Oct 10 2005, 08:31 AM)QUOT...   Oct 10 2005, 15:13
- - Clemech   I accept the criticism of my comparison of SACD an...   Oct 10 2005, 16:21
|- - krabapple   QUOTE (Clemech @ Oct 10 2005, 07:21 AM)I acce...   Oct 10 2005, 17:06
|- - Clemech   QUOTE It's possible to comment on what you hea...   Oct 10 2005, 17:18
|- - krabapple   QUOTE (Clemech @ Oct 10 2005, 08:18 AM)QUOTE ...   Oct 10 2005, 21:46
- - Axon   Nitpick: Orange Book or Scarlet Book?   Oct 10 2005, 22:01
|- - rjamorim   QUOTE (Axon @ Oct 10 2005, 06:01 PM)Nitpick: ...   Oct 10 2005, 22:44
|- - krabapple   QUOTE (Axon @ Oct 10 2005, 01:01 PM)Nitpick: ...   Oct 11 2005, 01:28
- - ToS_Maverick   hm, what about bringing the discussion about dvd-a...   Oct 10 2005, 23:40
- - dekkersj   QUOTE (ToS_Maverick @ Oct 10 2005, 11:40 PM)h...   Oct 10 2005, 23:59
|- - krabapple   QUOTE (dekkersj @ Oct 10 2005, 02:59 PM)QUOTE...   Oct 11 2005, 01:39
|- - user   Hi krabapple, as you have similar equipment like ...   Oct 11 2005, 09:07
- - Axon   I agree that a 96->44 conversion necessarily en...   Oct 11 2005, 00:09
- - ToS_Maverick   where is the difference if we convert this file to...   Oct 11 2005, 00:21
- - kode54   The only appropriate way to listen to the 24/96 fi...   Oct 11 2005, 00:29
|- - krabapple   QUOTE (kode54 @ Oct 10 2005, 03:29 PM)The onl...   Oct 11 2005, 01:34
- - dekkersj   QUOTE (ToS_Maverick @ Oct 11 2005, 12:21 AM)w...   Oct 11 2005, 12:49
- - ToS_Maverick   my webspace-provider is currently doing a server-m...   Oct 11 2005, 13:01
- - ToS_Maverick   my webspace is up again! you can download the...   Oct 11 2005, 19:25
- - KikeG   In order to avoid any possible differences caused ...   Oct 11 2005, 22:23
- - dekkersj   QUOTE (ToS_Maverick @ Oct 11 2005, 07:25 PM)m...   Oct 11 2005, 23:15
- - ToS_Maverick   QUOTE (dekkersj @ Oct 12 2005, 12:15 AM)Nice ...   Oct 11 2005, 23:25
- - dekkersj   QUOTE (ToS_Maverick @ Oct 11 2005, 11:25 PM)Q...   Oct 11 2005, 23:34
- - bugsy_pal   I think that SACD definitely sounds better than CD...   Oct 15 2005, 03:31
- - user   well, your preference of sacd vs. cd will be only ...   Oct 15 2005, 09:46
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 30th May 2015 - 04:10
