"ripping" LP's, how?
Woodinville
post Sep 15 2005, 20:35
( I think this is the right forum, I'm trying, at least, to get this right. )
Like some other old folks here, I have a lot of LP's that I would like to move over to my computer.
There are several issues.
First, it has to happen in real time, no faster. This is quite profoundly annoying.
Second, I'd like to be able to get things like album art, etc, by entering the catalog number or something like that, or searching CD databases, perhaps, for the info, although often tracks are different, moved, or present/missing.
Third, I'd like to process the stuff on the fly, using the sound card's analog level adjustment to keep me in a decent dynamic range, but providing some space for overloads.
Fourth, I'd like to be able to run things like de-clicking, de-noising, etc.
Fifth, I'd like to stuff that all into .wma Q90
Does anybody make anything like this?
You may assume I own:
A good turntable
A good record cleaner
A good cartridge and stylus
A good phono preamp/general preamp
So I can get line level signals that are properly equalized into my sound card, in fact using balanced lines so that I can even get some noise rejection.
J. D. (jj) Johnston
AndyH-ha
post Sep 16 2005, 00:35
It is true that a good 16 bit DAC will capture all that the LP can give you, but that isn't terribly relevant to using or not using a floating point file if you intend to do more than just record. Processing in integer produces rounding errors at every operation, every time the program makes calculations. Digital audio is all math. The errors are of course cumulative.
Also, assuming you have floating point at any particular time, converting to integer means either simple truncating or dithering. Neither is something you want to do multiple times; they are cumulative too. Therefore the reasonable thing is to capture in floating point (or integer, if you are so inclined, then do the extra step and convert to floating point). Maintain floating point until you have the final polish done and accepted, then convert to integer as your last step (or at least the last step as PCM). Of course no one forces this upon you, but you cannot beat the math with alternate choices.
- Woodinville   "ripping" LP's   Sep 15 2005, 20:35
- - skelly831   Audiograbber mentions Line-In recording as a featu...   Sep 15 2005, 21:52
- - Axon   It is very hard to run a rip faster than realtime....   Sep 15 2005, 22:02
- - AndyH-ha   There exist a number of sites with album art that ...   Sep 15 2005, 23:00
|- - Woodinville   QUOTE (AndyH-ha @ Sep 15 2005, 02:00 PM)...   Sep 15 2005, 23:41
- - AndyH-ha   It is true that a good 16 bit DAC will capture all...   Sep 16 2005, 00:35
|- - Woodinville   QUOTE (AndyH-ha @ Sep 15 2005, 03:35 PM)...   Sep 16 2005, 06:40
- - boojum   Stylus weights: usually magnetics tracked at 1 gr...   Sep 16 2005, 01:39
|- - Woodinville   QUOTE (boojum @ Sep 15 2005, 04:39 PM)Stylus ...   Sep 16 2005, 06:43
- - Axon   It's not the end of the world if all you can r...   Sep 16 2005, 02:27
- - boojum   QUOTE (Axon @ Sep 15 2005, 05:27 PM)as vinyl ...   Sep 16 2005, 05:27
|- - Woodinville   QUOTE (boojum @ Sep 15 2005, 08:27 PM)QUOTE (...   Sep 16 2005, 06:44
- - Axon   The Cardas Sweep Record has sweeps to 30Khz. Altho...   Sep 16 2005, 05:34
- - AndyH-ha   You want a recommendation for recording software? ...   Sep 16 2005, 08:51
|- - cliveb   Well, there have been lots of replies in this thre...   Sep 16 2005, 10:04
|- - Woodinville   QUOTE (cliveb @ Sep 16 2005, 01:04 AM)Well, t...   Sep 17 2005, 11:50
- - AndyH-ha   To keep thing truthful, I looked at my miscellaneo...   Sep 16 2005, 09:45
- - toot   Does it make sense to do a normalise on the record...   Sep 16 2005, 10:21
|- - Garf   QUOTE (toot @ Sep 16 2005, 11:21 AM)Does it m...   Sep 16 2005, 10:23
- - AndyH-ha   One general reason for normalizing is to make opti...   Sep 16 2005, 11:32
|- - cliveb   QUOTE (AndyH-ha @ Sep 16 2005, 11:32 AM)...   Sep 16 2005, 12:03
- - AndyH-ha   Of course the recording's noise is amplified b...   Sep 16 2005, 22:12
|- - legg   QUOTE (AndyH-ha @ Sep 16 2005, 04:12 PM)...   Sep 18 2005, 22:54
|- - krabapple   QUOTE (AndyH-ha @ Sep 16 2005, 01:12 PM)...   Sep 20 2005, 17:57
- - slangtruth   And while cliveb rightly won't mention it. as ...   Sep 16 2005, 22:20
- - Axon   One criticism of the "LPs only have 70db of d...   Sep 16 2005, 22:31
|- - Woodinville   QUOTE (Axon @ Sep 16 2005, 01:31 PM)One criti...   Sep 17 2005, 11:59
|- - Axon   QUOTE (Woodinville @ Sep 17 2005, 05:59 AM)We...   Sep 17 2005, 19:53
|- - cliveb   QUOTE (Axon @ Sep 17 2005, 07:53 PM)I just ge...   Sep 18 2005, 13:48
|- - Woodinville   QUOTE (Axon @ Sep 17 2005, 10:53 AM)QUOTE Now...   Sep 19 2005, 05:15
- - AndyH-ha   QUOTE would be to try recording the end of Neptune...   Sep 18 2005, 22:01
|- - cliveb   QUOTE (AndyH-ha @ Sep 18 2005, 10:01 PM)...   Sep 19 2005, 09:21
- - Axon   I'd like to interject here to say that so far,...   Sep 18 2005, 22:14
- - AndyH-ha   Unless I missed it, there has not been any discuss...   Sep 19 2005, 02:28
|- - Woodinville   QUOTE (AndyH-ha @ Sep 18 2005, 05:28 PM)...   Sep 19 2005, 05:17
- - AndyH-ha   Since I don't do anything in fixed point, none...   Sep 19 2005, 07:53
- - AndyH-ha   I think yes, if there is some difference to be hea...   Sep 19 2005, 11:25
- - DonP   One thing I didn't see mentioned about normali...   Sep 19 2005, 12:08
|- - Woodinville   QUOTE (DonP @ Sep 19 2005, 03:08 AM)One thing...   Sep 19 2005, 17:55
- - Axon   What filter settings are recommended for a rumble ...   Sep 19 2005, 19:55
|- - Woodinville   QUOTE (Axon @ Sep 19 2005, 10:55 AM)What filt...   Sep 20 2005, 21:22
- - Axon   EDIT: Got confused by my waveform plots. There is ...   Sep 19 2005, 23:14
|- - Woodinville   QUOTE (Axon @ Sep 19 2005, 02:14 PM)EDIT: Got...   Sep 20 2005, 21:24
|- - Axon   QUOTE (Woodinville @ Sep 20 2005, 03:24 PM)QU...   Sep 20 2005, 22:30
|- - Woodinville   QUOTE (Axon @ Sep 20 2005, 01:30 PM)An honest...   Sep 21 2005, 04:20
- - AndyH-ha   There are a number of filters in CoolEdit that can...   Sep 20 2005, 04:56
|- - Woodinville   QUOTE (AndyH-ha @ Sep 19 2005, 07:56 PM)...   Sep 20 2005, 21:25
- - AndyH-ha   Just curious. Ripping is a term often applied to d...   Sep 21 2005, 02:12
- - NogginJ   something tells me autechre werent using mics and/...   Sep 22 2005, 15:28
|- - cliveb   QUOTE (NogginJ @ Sep 22 2005, 03:28 PM)im usi...   Sep 23 2005, 11:20
- - AndyH-ha   Writing your recordings to CD-R does not involve a...   Sep 22 2005, 19:31
- - NogginJ   amen to all that. but any insight onto this ...   Sep 22 2005, 22:32
- - AndyH-ha   cda is simply the extension Windows puts on the fi...   Sep 22 2005, 23:31
- - Axon   About the only thing that I would find unnatural t...   Sep 23 2005, 11:44
- - hujay   Ripping seems to have changed it's meaning sli...   Sep 23 2005, 13:08
- - landy   i have tried to get feedback on my vinyl rips befo...   Sep 23 2005, 14:21
|- - Pio2001   QUOTE (landy @ Sep 23 2005, 03:21 PM)A1 - DJ ...   Sep 25 2005, 14:39
- - Axon   I do hear some clicking in that but it only seems ...   Sep 23 2005, 19:29
- - AndyH-ha   specific words for specific things makes for less ...   Sep 23 2005, 20:15
- - AndyH-ha   Unless Iím missing something, these recording samp...   Sep 23 2005, 21:06
- - Axon   Uh.... 7-zip? RAR support is generally available f...   Sep 23 2005, 22:17
- - landy   i used store mode so no extra compression was done...   Sep 24 2005, 01:13
- - AndyH-ha   It isn't clear to me what kind of feedback you...   Sep 24 2005, 01:53
- - landy   thanks for the reply andy and axon, i did mean to ...   Sep 24 2005, 05:01
- - AndyH-ha   Cartridges do differ but whether or not a more exp...   Sep 24 2005, 23:36
- - Axon   FWIW, apparantly the common term in some circles f...   Sep 30 2005, 17:53
- - landy   pio2001 thanks for the feedback, i have a cd versi...   Sep 30 2005, 20:07
- - mixminus1   QUOTE (landy @ Sep 30 2005, 12:07 PM)if anyon...   Sep 30 2005, 20:14
RSS Lo-Fi Version Time is now: 29th July 2015 - 18:37
