Adding ReplayGain tags kills/moves original tags!
Rowan
post Aug 17 2005, 23:04
I can't seem to add ReplayGain tags to my mp3s without foobar mutilating my other tags. For example, depending on the options I've chosen (tag to write: ID3v1 only, ID3v1 & V2, etc), instead of simply adding replaygain tags (ID3v2), foobar decides to either:
(a) copy my ID3v2 tags over to my ID3v1 tags (artist, title, etc)
(b) delete my ID3v1 tags (artist, title, etc)
These are things I don't want it to do. All I'm trying to do is ADD ReplayGain tags, and I dont want any of my other tags touched, copied, or moved. Is it possible somehow?
I'm not the only one getting frustrated by this it seems... http://www.misticriver.net/boards/showthre...ed=1#post294203
[ 1st post - sorry if its in the wrong place. ]
[ I'm a lover of foobar, keep up the good work - I love the ORDER BY ARTIST feature in the playlist, which winamp doesnt have]
This post has been edited by Rowan: Aug 17 2005, 23:07
sithia
post Aug 18 2005, 18:50
I just found foobar2000 and it actually does the one function I want it to do: write replaygain ID3v2 tags. I run linux and was able to load up 0.8.3 under Wine (the 0.9 beta painfully refuses to install because "win2k is required") and while fb2k does in fact run none of my ID3v2 tags (very standard tags, no custom ones) are recognized and in fact when I process a list of files fb2k successfully removes all my standard ID2v3 tags and leaves my files with *only* the four replaygain tags. And since I don't use APE or ID3v1 tags I couldn't care less if it mutilates them. By all means, remove them. But is it normal for fb2k to remove the standard ID3v2 tags?
Thankfully I am and always will be wary of tagging apps so I run a great many tests on a select handful of files to make sure my many, many, many hours of efforts getting my audio files setup just right are not lost to apps that seemingly do things of their own accord.
Failing a way to make fb2k write the four replaygain tags (and remove NOTHING) I will have to download the mp3gain source and figure out how it's written and add support for applying ID3v2 tags (it only write APE tags) unless someone knows another app that will write ID3v2 replaygain tags.
saratoga
post Aug 19 2005, 01:23
QUOTE (sithia @ Aug 18 2005, 10:50 AM)
If you're run mp3gain on your files, you have APEv2 tags. Foobar ignored your ID3v2 tags since it found the APEv2 tags first (in .8 APE > ID3v2 > ID3v1, use .9 if this bothers you).
- Rowan   Adding ReplayGain tags kills/moves original tags!   Aug 17 2005, 23:04
- - foosion   QUOTE (Rowan @ Aug 18 2005, 12:04 AM)(a) copy...   Aug 18 2005, 02:15
- - Lyx   Reason why it is handled this way is because fb2k ...   Aug 18 2005, 10:17
- - Rowan   Rather than have foobar helpfully asume it knows w...   Aug 18 2005, 11:34
|- - anza   QUOTE (Rowan @ Aug 18 2005, 12:34 PM)What oth...   Aug 18 2005, 12:17
||- - Rowan   You right click, you choose Replaygain scan - ther...   Aug 18 2005, 12:56
|- - Lyx   QUOTE (Rowan @ Aug 18 2005, 12:34 PM)Rather t...   Aug 18 2005, 21:59
- - sithia   I just found foobar2000 and it actually does the o...   Aug 18 2005, 18:50
|- - Lyx   QUOTE (sithia @ Aug 18 2005, 07:50 PM)I run l...   Aug 18 2005, 22:07
||- - sithia   QUOTE (Lyx @ Aug 18 2005, 02:07 PM)I am not s...   Aug 18 2005, 23:14
|- - Mike Giacomelli   QUOTE (sithia @ Aug 18 2005, 10:50 AM)I just ...   Aug 19 2005, 01:23
- - Lyx   Hmm, wait a min - i think i may know where the pro...   Aug 19 2005, 00:10
|- - sithia   QUOTE (Lyx @ Aug 18 2005, 04:10 PM)It will st...   Aug 19 2005, 04:24
- - sithia   Seems Lyx hit it right. I was able to remove APE t...   Aug 19 2005, 16:04
- - rasher   QUOTE (foosion @ Aug 18 2005, 03:15 AM)Neithe...   Aug 30 2005, 16:54
- - Mike Giacomelli   QUOTE Well, that screenshots say that "Other ...   Aug 30 2005, 19:25
|- - rasher   QUOTE (Mike Giacomelli @ Aug 30 2005, 08:25 P...   Aug 30 2005, 21:27
- - picmixer   @rasher: Your tagging needs do not cohere with th...   Aug 30 2005, 21:42
|- - rasher   QUOTE (picmixer @ Aug 30 2005, 10:42 PM)@rash...   Aug 30 2005, 21:56
- - picmixer   You current posting style is not compatible with t...   Aug 30 2005, 22:00
- - foosion   foobar2000 is a general audio player with metadata...   Aug 30 2005, 22:54
|- - rasher   QUOTE (foosion @ Aug 30 2005, 11:54 PM)foobar...   Aug 30 2005, 23:14
|- - GHammer   Why not just re-run mp3gain and remove the tags? I...   Sep 3 2005, 05:31
- - R2D2   Why would you wan't apev2 tags anyway? Just do...   Sep 7 2005, 07:05
- - skywalka   I was thinnking of trying foobar. The Replay Gain...   Dec 22 2007, 13:00
- - shoe   I used foobar2000 9.5.1 to write replaygain info t...   Apr 8 2008, 20:16
RSS Lo-Fi Version Time is now: 29th July 2015 - 05:53
