Some EAC + LAME quests
Antec
post Jun 29 2005, 14:41
Hi.
I'm quite new to mp3 ripping and getting started with this. I'm using LAME 3.90.3 and EAC. First, I want to know what is --alt-present standard in "code".
I have thought if it's "-b 192 -m j -h -V 2 -B 192" but you wiser say that cool.gif
Next ones depends on ID3v2 tags. Now when I use EAC, it adds v1 tags perfectly, but v2 is a bit different. In "Track" there reads 04/18 but just want it to 4.
And what about "Encoded by" text? There is: Exact Audio Copy (Secure mode)
No way, I want that away tongue.gif (And even add some my own text there, such as LAME 3.90.3 or so, cause that is the encoder)
And still. I have managed to EAC name the files like this:
04 - French Affair - My heart goes boom (la di da).mp3
How can I get some of those letters to lowercase?
That is all because:
a) I don't want to use some ID3 tag editor. Takes too much time. And also I want files to be exactly as they are encoded.
b) I have quite large collection to move on mp3.
Synthetic Soul
post Jun 29 2005, 15:13
QUOTE (Antec @ Jun 29 2005, 02:41 PM)
I couldn't give a fetid dingo's kidney. I suggest you just use the presets and don't worry about it. You aren't going to improve them by deconstructing them and tweaking. Give it up.
Go to Compression Options > ID3 Tag > Use track format xx/xx in ID3V2 tags
I don't think you can stop EAC writing this.
If you want to resolve this issue, and have more control over the encoding/tagging, I would suggest using LAME.EXE as an external compressor, and letting LAME tag the files. This would resolve the xx/xx issue also.
I don't think you can - unless you lowercase all your tag info (Database > Transform Actual CD Information > Lower All Characters). Not advisable though.
I'm on a horse.
Antec
post Jun 29 2005, 20:47
Cannot find. Maybe this version 0.95 prebeta 5 have not it? I remember seen it in earlier versions. Thanks.
I don't think you can stop  EAC writing this.    If you want to resolve this issue, and have more control over the encoding/tagging, I would suggest using LAME.EXE as an external compressor, and letting LAME tag the files.  This would resolve the xx/xx issue also.
Or what program to use? (LAMEs command line?? That is a bit slow and doesn't have freedb support smile.gif
Well, then also ID3 tags are in lowercase (?) which I don't want. I think it is better to have another program just for making filenames in lowercase. Know any?
This post has been edited by Antec: Jun 29 2005, 20:56
Synthetic Soul
post Jun 29 2005, 22:31
QUOTE (Antec @ Jun 29 2005, 08:47 PM)
Do you have any objections to upgrading to 0.95b2? NB: if you choose to use LAME.EXE as an external compressor (see below) you can ignore this anyway.
Check the wiki.
NB: the recommended command line does not pass genre information - as LAME has a limited list of genres it understands and by default will not run if an unrecognised genre is passed. As you ask about freedb I assume genre info is a requirement for you.
With this in mind I would suggest that you use LAME 3.96.1, and add --ignore-tag-errors in the command line to stop LAME falling over with an unknown genre, i.e.:
-alt-preset standard --add-id3v2 --pad-id3v2 --ignore-tag-errors --ta "%a" --tt "%t" --tl "%g" --ty "%y" --tn "%n" --tg "%m" %s %d
Also, obviously, be careful that the genre info in EAC has been populated and is a recognised/legal genre.
If you want to stay with 3.90.3 then you will just need to be extra careful with the genre you use in EAC (run LAME --genre-list to see all the genres LAME will accept). You will also need to remove --ignore-tag-errors from the command line above.
No. Not as part of the EAC process. As a stand alone app I would use THE Rename (which is just a generally useful tool for renaming files, etc.)...
Edit: more info on commandline and linked links rinky dink.
This post has been edited by Synthetic Soul: Jun 30 2005, 08:50
I'm on a horse.
Kenno
post Jun 29 2005, 22:35
QUOTE (Antec @ Jun 29 2005, 03:41 PM)
I don't know where you got that one, but it doesn't even come close. And by the way, setting the lower bitrate limit equal to the higher bitrate limit completely defeats the purpose of VBR. rolleyes.gif
As a matter of fact, there is no command-line equivalent to --alt-present standard in lame 3.90.3. --alt-present standard uses some code-level tweaks that just aren't accessible through the command line.
Besides, I fully agree with Synthetic Soul that you can't improve it; it's already tweaked to death. Messing with the lame command-line is a commonly made newbie mistake, and you'd only make yourself look like a fool by trying to do so. wink.gif
This post has been edited by Kenno: Jun 29 2005, 22:39
mathematician
post Jun 30 2005, 20:09
I don't know why every one wants to know command-line equivalent for APS? May be that's popularity of APS. wink.gif I think there should be a pinned thread in CAPITAL letters saying
1. APS in LAME 3.90.3 CAN"T BE ACTIVATED BY ANY OTHER SWITCH COMBOs EXCEPT APS ITSELF ONLY
2. ADDING FURTHER SWITCHES WITH APS IS NOT ADVISABLE BECAUSE IT MAY CONFLICT WITH THE CODE LEVEL CHANGES MADE IN APS TO MAKE IT SOUND EXCELLENT.
3. ANYBODY HAVING DOUBT ABOUT TRANSPARENCY OF APS SHOULD RECONSIDER AND DO SOME ABX.
(It doesn't mean that other settings are not transparent. And, however transparency is relative term which depends upon person's ability to hear. But again for that ABX is necessary. And after ABX people would definitely switch over to APS (w/o any extra switch, just APS). Many people have done this in past. exhaustive listening tests. That's the reason why it is still recommended. It is trusted. However, let me state again. APS is transp. to most doesnt mean that other settings and other versions are not, but APS is most of the time winner of all as far as 3.90.3 is concerned.)
This post has been edited by mathematician: Jun 30 2005, 20:13
"M"
Mathematician
Email: admin@mathematician.cjb.net
Website: mathematician.cjb.net
Never_Again
Group: Members (Donating)
QUOTE (Kenno @ Jun 29 2005, 05:35 PM)
That is no longer true. --preset tweaks have been incorporated into LAME's core, and --preset standard now corresponds to -V2.
mathematician
post Jun 30 2005, 20:15
QUOTE (Never_Again @ Jul 1 2005, 12:39 AM)
I think he was talking about 3.90.3! Of-course for new versions it's not true! smile.gif
"M"
Mathematician
sTisTi
post Jun 30 2005, 20:17
QUOTE (Never_Again @ Jun 30 2005, 11:09 AM)
You could also say that before it was not possible to enable the presets via command line switches, while now it is not possible to disable them, as they are used by default in all modes.
Proverb for Paranoids: "If they can get you asking the wrong questions, they don't have to worry about answers."
-T. Pynchon (Gravity's Rainbow)
Spam Fodder
post Jun 30 2005, 23:26
Besides, I fully agree with Synthetic Soul that you can't improve it; it's already tweaked to death. Messing with the lame command-line is a commonly made newbie mistake, and you'd only make yourself look like a fool by trying to do so. ;)
so how does the bitrate and the 'High/Low Quaility' settings fit in with the command line settings?
LAME 3.96.1: %l--alt-preset 128%l%h--alt-preset standard%h %s %d
Acid8000
post Jul 1 2005, 00:22
QUOTE (Spam Fodder @ Jul 1 2005, 08:26 AM)
If you use LAME as an external compressor, it doesn't make any difference.
This post has been edited by Acid8000: Jul 1 2005, 00:23
Acid8000 aka. PhilDEE
mathematician
post Jul 1 2005, 07:01
QUOTE (Spam Fodder @ Jul 1 2005, 03:56 AM)
If you're using "User Defined Encoder", changing these bitrates tab along with presets in commandline won't affect at all as long as you don't use %r.
Setting High Quality - (Alternate) Preset Standard (V2 Quality)
Low Quality - 128kbps Average Bitrate (Which will be quite high q then 128kbps cbr)
If you're using "Lame Encoder", changing these bitrates tab along with presets in commandline will affect! It will set the lower bitrate baseline for the range of VBR (i.e. if set to 192, the minimum bitrate VBR will use is 192) generally not recommended (read some previous threads)
So User defined encoder is what you should be using, otherwise w/o your knowledge this bitrate tab will affect your preset setting. (atleast if you're using VBR). and of course for other settings such as abr/cbr %r could be added to make it more flexible.
This post has been edited by mathematician: Jul 1 2005, 09:12
"M"
Mathematician
Synthetic Soul
post Jul 1 2005, 08:39
The %l...%l and %h...%h placeholders are used to add text according to whether the High quality or Low quality radio button is selected.
LAME.EXE %l--alt-preset 128%l%h--alt-preset standard%h %s %d
Therefore, if you select Low quality the command will be:
LAME.EXE --alt-preset 128 %s %d
..and if you select High quality it will be:
LAME.EXE --alt-preset standard %s %d
You can access the bitrate value in the dropdown using the %r placeholder, e.g.:
LAME.EXE --alt-preset %r %s %d
So, if you had the dropdown selected at 192 kBit/s the command line would be:
LAME.EXE --alt-preset 192 %s %d
Most people will say "the bitrate dropdown doesn't affect the command line". In essence this is correct, as it will not affect the command line unless you use the %r placeholder. Using ABR or CBR generally isn't as preferred as VBR anyway, so the bitrate dropdown isn't ever going to be that useful. That said, I use the %l and %h palceholders in my batch files. I could possibly change this so that the value of %r is queried and an appropriate setting used based on that value (e.g..: you could map LAME's -V values to each of the dropdown items (e.g.: 128kBit/s -> -V5)). But I digress...
I'm on a horse.
Kenno
post Jul 5 2005, 23:42
QUOTE (Spam Fodder @ Jul 1 2005, 12:26 AM)
I'm aware of the improved VBR control in lame 3.96.1. I'm currently using it in combination with
%l-V 4%l %h-V 2%h %s %d
in EAC. See synthetic soul's post for an explanation about the %l and %h placeholders. Btw, %s and %d are also placeholders, for the source and destination file. But these are not optional; EAC probably won't work with lame if you omit them.
JunkieXL
post Aug 7 2005, 23:17
Post #15
EAC will work without %s and %d perfectly. It is just recommended that you use them.
J
Frank Bicking
post Aug 7 2005, 23:31
Post #16
QUOTE (JunkieXL @ Aug 8 2005, 12:17 AM)
J
It depends on the parameter passing scheme you are using. %s %d is required for "user defined encoder" and not required for "LAME MP3 Encoder", since EAC then knows which additional parameters have to be passed to the encoder.
JunkieXL
post Aug 8 2005, 00:05
Post #17
Ya, I forgot to mention that part...thanks for the correction.
J
RSS Lo-Fi Version Time is now: 31st January 2015 - 10:48
