10 Pages V  « < 4 5 6 7 8 > »
NoCover-Image, Show your image if no cover exist
Yotsuya
post Jul 10 2006, 14:55
Post #126
prettypop auto-adds the file extension so given your example you should be able to use:
|components\nocover\NoCover$rand(10)
Lycox
post Jul 10 2006, 15:47
Post #127
QUOTE (Yotsuya @ Jul 10 2006, 14:55) *
Thanks. Works great.
HYDE
post Jul 10 2006, 16:21
Post #128
QUOTE (Yotsuya @ Jul 10 2006, 07:55) *
thanks \o/ laugh.gif
_gue_
post Aug 16 2006, 12:52
Post #129
Two more.
aeroman
post Aug 19 2006, 19:16
Post #130
Ten noCovers for those who love turntables... Enjoy
and
Download
callisto
post Sep 7 2006, 17:18
Post #131
There are mine:
no-cover:........................radiostream:...................cd-playback:...................
greetz,
callisto
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Jubei
post Sep 8 2006, 06:25
Post #132
I have downloaded some of the artwork but can't get foobar to display it. I'm using foobar v0.9.4. beta 1 and the source code is as follows
$replace(%path%,%filename_ext%,)*
-$replace(%path%,%filename_ext%,)..\*
I have 2 png files in the components folder named default0.png and default1.png.
What am i missing?
Yotsuya
post Sep 8 2006, 06:37
Post #133
what if $rand(10) picks a number bigger than 1? if the first two sources are not satisfied then you get no image. Either make more default images or change 10 to a lower number.
http://www.ubuntu.com
Jubei
post Sep 8 2006, 06:59
Post #134
thanks. worked after you advice.
Jubei
post Sep 11 2006, 04:20
Post #135
Strangely, after 3 days of working, foobar has suddenly stopped displaying no cover art pngs again!! Code has not changed - I have not tweaked anything apart from DSP settings which shouldn't affect it. Normal album art is still working though, which is a relief.
Very baffled.
This post has been edited by Jubei: Sep 11 2006, 04:20
Jubei
post Sep 12 2006, 20:53
Post #136
QUOTE (Jubei @ Sep 11 2006, 11:20) *
Very baffled.
Well, just downloaded the latest version of album art panel and now no cover works. Still baffled at why it didn't work before since the source code is the same.
Jubei
post Sep 13 2006, 05:20
Post #137
What the hell?? Turned off PC last night, restarted today and it is not working again!!!!!!!! I haven't changed anything.
walla
post Sep 25 2006, 15:08
Post #138
schmakk
post Oct 3 2006, 15:23
Post #139
Heavily inspired by some of the previous posts, i made 10 images for "no cover"
and 10 for "stream"
(The forum allows 10 pictures per post, cant link them all)
Take those you like or get them all here: albumart.zip
All 20 images are in that one, around 2.5 megs.
If you want to randomly select one of them, and have streams display one of the "stream" images, place all the files in a subfolder of "components" called "albumart", then put this in a .txt file:
[foo_uie_albumart]
$if($stricmp($left(%path%,7),'http://'),'components\albumart\radio*.png',)
$replace(%path%,%filename_ext%,)*front*
-$replace(%path%,%filename_ext%,)*cover*
$replace(%path%,$directory(%path%,1)\%filename_ext%,)*front*
-$replace(%path%,$directory(%path%,1)\%filename_ext%,)*cover*
[End]
then import that file into foo_uie_albumart. You have to select "Cycle all wildcard matches" and "Random" in the Behaviour settings, or manualle use $rand(10) in the sources to have random selection.
These sources will look for covers for your ordinary music in the same directory as the playing file is, or one directory up.
This post has been edited by schmakk: Oct 3 2006, 17:02
golphcart
post Oct 9 2006, 08:49
Post #140
Jubei: You did change the $rand(10) to $rand(2) didn't you? The random function [ $rand(x) ] picks a number from 0 to x-1, so if you make x any number that doesn't exist in your no cover image filename, then nothing will be displayed. For example, if you changed your source to:
then the random number could be 0,1,2,3,4, or 5, so that 2/3 of the time a picture will not show. got it?
This post has been edited by golphcart: Oct 10 2006, 02:26
kieran
post Nov 29 2006, 21:27
Post #141
just used the default icon set
kyller
post Dec 31 2006, 20:44
Post #142
107x107 px
gnostic19
post Jan 1 2007, 21:15
Post #143
New to Foobar intricacies...how do i set a default "no cover" pic? Where in the code/preferences is this set and how is it doen? Thanks for help.
NEVER MIND......i followed some advice printed earlier in thread (what a concept, right?) and got it working.
This post has been edited by gnostic19: Jan 1 2007, 23:39
nebula
post Jan 5 2007, 10:50
Post #144
QUOTE (PiezoTransducer @ Apr 30 2006, 22:19) *
anymore like these? >.>
DarkSol
post Jan 14 2007, 18:46
Post #145
I have a question about prettypop up and having it display certain images.
album_art;folder;cover;coverart;front;%ALBUM%;|C:\albumart\%ALBUM%;|components\albumart\default$rand(10);*
That's what I have now, but is there any way for it to display a random stream image if I'm listening to an online radio station?
Yotsuya
post Jan 14 2007, 21:32
Post #146
// For Online Radio
$if($strcmp($left(%path%,7),http$char(58)$char(47)$char(47)),
|components\albumart\online-radio$rand(10)
// And while we're at it, for audio cd's
$if($strcmp($left(%path%,7),cdda$char(58)$char(47)$char(47)),
|components\albumart\audiocd$rand(10)
// NOTE: For Prettypop you do not need to specify a file extension for your image sources, it automatically performs wildcard matching for all supported image types.
This post has been edited by Yotsuya: Jan 16 2007, 02:27
leokennis
post Jan 19 2007, 00:33
Post #147
I've got a pretty basic one smile.gif :
Les mots d'amour...
Bodhi
post Jan 21 2007, 22:46
Post #148
Do you know what is the maximum size that can be supported by an mp3 file?
Bodhi
post Jan 22 2007, 21:43
Post #149
UP Please
legallyillegal
post Jan 29 2007, 18:48
Post #150
nothing too advanced, just a simple feathering of XP's music logo
RSS Lo-Fi Version Time is now: 29th March 2015 - 23:24
