3 Pages V  < 1 2 3 >
Analog VU Meters
onv
post May 17 2012, 16:24
Post #26
QUOTE (emte @ May 17 2012, 17:37) *
What's more, I made myself a skin that can't be set properly, because it has two channels at ones. If I mark Left+Right it doubles like that.
Also tried splitting this image in two and put two instances og VU Meter side by side showing different channels. One for Left and second for Right. Unfortunately, both of them displayed the same one. When I change the setting in one, second VU Meter albo changed. I wish they were independent.
Any chances to have a solution for any of these issues/offers?
Rename left bin to bla-bla1.bin and right to bla-bla2.bin and put your both *.bin with the file foo_vis_vumeter.dll
This post has been edited by onv: May 17 2012, 16:25
emte
post May 17 2012, 17:28
Post #27
What about replay gain? Is it possible to implement getting value for preamp from music files?
This post has been edited by db1989: May 17 2012, 20:06
Reason for edit: deleting pointless full quote of above post
onv
post May 17 2012, 17:37
Post #28
It's a question for the developer to plugin, I can't help
Reason for edit: as above
lvqcl
post May 17 2012, 17:45
Post #29
AFAIK foobar2000 sends audio data to vis plugins after RG correction and DSP plugins.
Mr.Duck
post May 22 2012, 18:29
Post #30
Mine quickly shoots up and just stays on +3 most the time.
I don't get clipping so shouldn't it peak at 0 ?
What settings to people use for preamp and the mouse wheel dB ?
Falstaff
post May 28 2012, 11:18
Post #31
WSH panel using Analog Vu Meter last version as an ActiveX object
work in progress, for now, VU meter for one or 2 channel works, i have to add peak meter and better design
preview:
http://youtu.be/W0oFhUHTbSg
http://br3tt.online.fr/
onv
post May 28 2012, 12:01
Post #32
QUOTE (Falstaff @ May 28 2012, 13:18) *
Remained an easy task - to teach WSH understand *.cdr files to scale without losing quality biggrin.gif
Falstaff
post May 28 2012, 12:34
Post #33
updated: http://youtu.be/dsZ1SrhQsp0
This post has been edited by Falstaff: May 28 2012, 12:38
onv
post May 28 2012, 13:04
Post #34
QUOTE (Falstaff @ May 28 2012, 14:34) *
updated:
Cool. Maybe full scale LED is excessive for the analog VU-meter, it is enough bandwidth (or single LED) for levels >=0dB in order not to disperse the attention between the arrow and LEDs
Falstaff
post May 28 2012, 14:01
Post #35
other peak style: http://youtu.be/25xWktITOWo
onv
post May 28 2012, 14:53
Post #36
QUOTE (Falstaff @ May 28 2012, 16:01) *
other peak style:
It's better in the sense that the eyes do not jump in different directions. Does it make sense to duplicate the angle of deflection with the color bar?
This post has been edited by onv: May 28 2012, 14:56
Falstaff
post May 28 2012, 15:09
Post #37
Falstaff
post May 28 2012, 19:25
Post #38
script + images available in WSH Panel Mod discussion thread : http://www.hydrogenaudio.org/forums/index....st&p=796858
San_dr
post Jun 9 2012, 11:12
Post #39
scripting, no images VU-meter and implements pikmetr rms VU meter in the same scale. Peak Meter on discrete LEDs of two colors, rms VU meter - a translucent solid fill, the color of which depends on the signal level
// @author "VU Meter component/object by DRON, jscript by Br3tt aka Falstaff >> http://br3tt.deviantart.com"
// @adapted - San_dr
ColorTypeDUI = {
background: 1,
textcolor: 0
function RGB(r, g, b) { return (0xff000000 | (r << 16) | (g << 8) | (b));
function RGBA(r, g, b, a) { return ((a << 24) | (r << 16) | (g << 8) | (b));
// VUMeter Object
VUMeter = new ActiveXObject("VUMeter");
VUMeter.RegisterWindow(window.ID);
// Globals
var ww = 0, wh = 0;
var g_backcolor = 0;
var g_textcolor = 0;
var g_syscolor = 0;
///var g_rightcolorL=0;
///var g_rightcolorR=0;
var COLOR_BTNFACE = 15;
var tooltip_timer = false;
function get_colors() {
g_backcolor = window.GetColorDUI(ColorTypeDUI.background);
g_syscolor = utils.GetSysColor(COLOR_BTNFACE);
g_textcolor = window.GetColorDUI(ColorTypeDUI.textcolor);
get_colors();
function on_size() {
ww = window.Width;
wh = window.Height;
// bg_img = bg.Resize(ww, wh);
function on_paint(gr) {
N=wh/12;
L=VUMeter.LeftLevel;
R=VUMeter.RightLevel;
LM = VUMeter.LeftPeak;
RM = VUMeter.RightPeak;
// create draw area
// fill bgcolor
gr.FillSolidRect(0, 0, ww, wh, g_syscolor);
gr.FillSolidRect(0, 2*N, ww, wh-4*N, g_backcolor);
// Draw Peak
// left peak
var i = 0;
while (i < ww*LM+1) {
var g_leftcolor = ( i>ww*5/7 ) ? RGB(255,140,0) : RGB(70,100,140);
gr.FillSolidRect(i-4, 2*N, 9, 3*N, g_leftcolor);
i = i +11;
// right peak
var k = 0;
while (k < ww*RM+1) {
var g_rightcolor = ( k>ww*5/7 ) ? RGB(255,140,0) : RGB(70,100,140);
gr.FillSolidRect(k-4, 7*N, 9, 3*N, g_rightcolor);
k = k +11;
// left level
var g_leftcolorL = ( ww*L>ww*5/7 ) ? RGBA(255,90,0,220) : RGBA(40,255,0,190);
gr.FillGradRect(0, N, ww*L, 4*N, 0, RGBA(150,155,0,200), g_leftcolorL, 1);
gr.FillSolidRect(ww*L-3, N, 4, 4*N, RGB(255,255,245));
// right level
var g_rightcolorR = ( ww*R>ww*5/7 ) ? RGBA(255,90,0,220) : RGBA(40,255,0,190);
gr.FillGradRect(0, 7*N, ww*R, 4*N, 0, RGBA(150,155,0,200),g_rightcolorR, 1);
gr.FillSolidRect(ww*R-3, 7*N, 4, 4*N, RGB(255,255,245));
// background
gr.DrawRect(2, N+3, ww-4, wh-2*N-6,6, g_backcolor);
function on_colors_changed() {
get_colors();
window.Repaint();
This post has been edited by db1989: Jun 9 2012, 19:40
Reason for edit: For large items, please use [codebox] rather than [code].
onv
post Jun 9 2012, 11:52
Post #40
QUOTE (San_dr @ Jun 9 2012, 13:12) *
ColorTypeDUI = {
background: 1,
textcolor: 0
Why DUI only ?
Think, perhaps, there is a sense in the mid-hight between the channels to draw a text scale (-20 -15 ....) ?
San_dr
post Jun 9 2012, 14:59
Post #41
QUOTE (onv @ Jun 9 2012, 11:52) *
Why DUI only ?
information about the excess of 0 dB LED provides color and changing the dynamics of the mean color of the solid line. Sam engine plugin provides optimal curve luminous scales. I think the numbering of the scale away from 0 dB is unnecessary... decor
Bob Brines
post Jun 10 2012, 17:27
Post #42
The VU meters have stopped working. They display fine, but no needle movement. The meters were working, now they don't. the only change I made was upgrading to FB1.1.13, but have the same results with 1.1.10. Same result in DUI and CUI. I uninstalled the component andTreinstalled it with a fresh download. No help. The only DSP I am running is the SoX resampler set to 96K, but removing this made no difference.
Any hints?
Bob
onv
post Jun 10 2012, 17:40
Post #43
QUOTE (Bob Brines @ Jun 10 2012, 19:27) *
Any hints?
https://sites.google.com/site/foobar2000com...eter/2012-06-07
jonpb
post Jul 12 2012, 03:56
Post #44
QUOTE (Bob Brines @ Jun 10 2012, 09:27) *
I had the same problem. It appeared to happen after the computer went to sleep while fb2k was still open, although I'm not sure. In any case, I went to the <foobar2000>\Configuration folder and deleted the foo_vis_vumeter.dll.cfg file. Voila, the file was rebuilt when I started fb2k back up and the meters were working again.
carpman
post Jan 17 2013, 17:59
Post #45
Hi all,
I'm trying to get hold of these 2 VU Meter skins from here:
The download site that hosts them has been down for quite a while.
Anyone happen to have them?
Would be nice to get hold of them.
C.
TAK -p4m :: LossyWAV -q 6 | TAK :: Lame 3.98 -V 2
onv
post Jan 17 2013, 19:35
Post #46
QUOTE (carpman @ Jan 17 2013, 19:59) *
this is mine. New links :
https://www.dropbox.com/s/9isr3e0qs5jkeq4/06_onv.bin
https://www.dropbox.com/s/vcpn8usgvs592nx/07_onv.bin
something else:
https://www.dropbox.com/s/j9hh7fpyjiwyhkj/01_onv.bin
https://www.dropbox.com/s/xejwkzupmw529u2/03_onv.bin
https://www.dropbox.com/s/qbxnyxpsfp2i07x/05_onv.bin
https://www.dropbox.com/s/17u6dpqyj02ggb5/08-5_onv.bin
carpman
post Jan 17 2013, 20:08
Post #47
C.
Bob Brines
post Jan 18 2013, 14:22
Post #48
QUOTE (onv @ Jan 17 2013, 13:35) *
I downloaded your .bin files into the foo_vis_vumeter folder, but only Model 702 (2).bin is displayed. I scrolled back through this thread to find some instructions as to how to change the skin, but those instructions don't work for me. I tried any number of click and key combinations, but no joy. Note that I am using a laptop with a touch pad.
Also, Foobar displays the version number as 2012-05-12. Is this the current version?
Thanks,
Bob
onv
post Jan 18 2013, 15:34
Post #49
QUOTE (Bob Brines @ Jan 18 2013, 16:22) *
Thanks,
Bob
right/left flips with mouse, with touchscreen so:
with touchscreen
Bob Brines
post Jan 18 2013, 17:03
Post #50
QUOTE (onv @ Jan 18 2013, 09:34) *
with touchscreen
Sorry, that's touch PAD, not touch SCREEN. When I right click on the meters, I get the "Layout"pull-down menu. When I right click on any of the options, nothing happens. When I left click, the menu goes away. This could be a problem with my computer. I will have to load up and try it on a desktop.
Bob
3 Pages V  < 1 2 3 >
RSS Lo-Fi Version Time is now: 5th September 2015 - 10:04
