Which is the best lossless codec?, Discussion thread
kotrtim
post Nov 26 2004, 05:40
1. LOWER COMPRESSION BUT HIGHER CPU USAGE
2. NO COMPRESSION MODE TO SELECT
EDIT : But compared with Monkey's Audio, WMA still use more power.
WMA = 34.0MB = ~13% CPU Usage
Monkey's Audio - High = 33.7MB = ~7% CPU Usage
This post has been edited by kotrtim: Nov 26 2004, 06:17
Skymmer
post Jan 22 2005, 04:36
Here is another suggestion and test... As you know WAV files can store not only audio data inside but also non-audio data like Standard RIFF text field names (Display Title, Original Artist, Name, Genre, Key Words, Digitization Source, Original Medium, Engineers, Digitizer, Source Supplier, Copyright, Software Package, Creation Date, Comments, Subject), Cue points and ranges, Loop infos, Sampler Infos, Bitmaps, EBU Extensions and some others.
Of course in most cases it's useless but in case of samples or some audio projects where you need to store for example CUE points or some notes it becomes usefull.
So lets see how compressors listed here friend with non-audio data. I just generated 10 seconds brown noise using Adobe Audition and puted cues, ranges, sampler info, bitmap and some text fields inside and resulting file is 1771654 bytes long. And now its time for the show...
ALAC
I have no software to test it.
FLAC
Surprise !
c:\Shifter\Software\MUSIC\Packers\Lossless\Flac v1.1.1>flac -8 Test.wav
flac 1.1.1, Copyright (C) 2000,2001,2002,2003,2004 Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
options: -P 4096 -b 4608 -m -l 12 -e -q 0 -r 0,6
Test.wav: 85% complete, ratio=0,617Test.wav: WARNING: skipping unknown sub-chunk 'LIST'
Test.wav: WARNING: skipping unknown sub-chunk 'cue '
Test.wav: WARNING: skipping unknown sub-chunk 'DISP'
Test.wav: WARNING: skipping unknown sub-chunk 'smpl'
Test.wav: wrote 1087112 bytes, ratio=0,616
FLAC doesn't support. Resulting decompressed files is 7610 bytes smaller !
Monkey
GUI supports and those files (decompressed with GUI or CLI are identical to original). Good boy !
CLI doesn't support.
OptimFROG
Well done !
Real Lossless
No software to test with.
Shorten
Yes !
Wavpack
Perfect !
WMA Lossless
No, no and no. 7610 bytes smaller.
LA
Without problems !
TTA
Same problem. 7610 bytes smaller.
LPAC
Yeeeh !
Well maybe for most people its not important but somehow my two cents rolleyes.gif
P.S. There are import/export filters for Adobe Audition for FLAC, Monkey and Wavpack but only wonderful Wavpack's filter supports non-audio data. Super !
Gabber, Jazz and IDM
rjamorim
post Jan 24 2005, 00:05
Rarewares admin
Thanks for that test you did. I am considering adding "RIFF data support" to the table and the summaries. It tends to be a sought-after feature among people dealing professionally with Audio.
QUOTE (Skymmer @ Jan 22 2005, 01:36 AM)
Indeed, David worked closely with some audio engineer that was after these features, so he managed to get it well supported inside WavPack.
http://www.rarewares.org
- kotrtim   Which is the best lossless codec?   Nov 26 2004, 05:40
- - rjamorim   Thanks. I added "unefficient" to WMA...   Nov 26 2004, 05:50
- - kotrtim   roberto , i'm so sorry wma compression is a bi...   Nov 26 2004, 06:04
- - sshd   1. inefficient not unefficient 2. Neither FLAC no...   Nov 26 2004, 06:09
|- - guruboolez   QUOTE (sshd @ Nov 26 2004, 06:09 AM)2. Neithe...   Nov 26 2004, 14:40
|- - jcoalson   this table is nice, good to finally have a sticky ...   Nov 28 2004, 11:51
|- - sshd   QUOTE (jcoalson @ Nov 28 2004, 11:51 AM)QUOTE...   Nov 28 2004, 16:16
|- - sehested   QUOTE (jcoalson @ Nov 28 2004, 02:51 AM)for t...   Nov 28 2004, 17:13
- - BoraBora   Another lossless comparison (in french, but the ta...   Nov 26 2004, 09:30
- - rjamorim   QUOTE (kotrtim @ Nov 26 2004, 02:04 AM)I...   Nov 26 2004, 13:12
- - Garf   <zealot> I see no reason to put very fast d...   Nov 26 2004, 13:39
|- - rjamorim   QUOTE (Garf @ Nov 26 2004, 09:39 AM)<zealo...   Nov 26 2004, 13:53
- - kurtnoise   Some notes about RALF : I made some quick tests w...   Nov 26 2004, 14:44
- - guruboolez   I forgot: nice initiative Roberto. Two comments: ...   Nov 26 2004, 14:44
- - kotrtim   according to the player itself (Itunes n Real) App...   Nov 26 2004, 15:28
- - rjamorim   QUOTE (guruboolez @ Nov 26 2004, 10:40 AM)I...   Nov 26 2004, 18:36
|- - HansHeijden   QUOTE (rjamorim @ Nov 26 2004, 06:36 PM)Since...   Nov 26 2004, 20:17
- - guruboolez   Another suggestion: what about "adaptability...   Nov 26 2004, 18:52
|- - rjamorim   QUOTE (guruboolez @ Nov 26 2004, 02:52 PM)Som...   Nov 26 2004, 19:13
- - guruboolez   I would say "none" rather than "bad...   Nov 26 2004, 19:17
- - kotrtim   QUOTE Haha, dude, you said yourself Real is very f...   Nov 27 2004, 04:48
- - rjamorim   QUOTE (HansHeijden @ Nov 26 2004, 04:17 PM)Ed...   Nov 27 2004, 21:33
- - Zurman   How about an overall notation system? 3 points for...   Nov 28 2004, 20:56
|- - guruboolez   QUOTE (Zurman @ Nov 28 2004, 08:56 PM)How abo...   Nov 29 2004, 10:18
- - BoraBora   About OS support: I understand what it means, but ...   Nov 28 2004, 23:50
- - WaldoMonster   Nice work. I'm missing native ReplayGain in t...   Nov 28 2004, 23:52
|- - rjamorim   QUOTE (WaldoMonster @ Nov 28 2004, 07:52 PM)I...   Nov 29 2004, 00:34
- - rjamorim   QUOTE (jcoalson @ Nov 28 2004, 07:51 AM)for t...   Nov 29 2004, 00:26
|- - Zurman   QUOTE (rjamorim @ Nov 28 2004, 03:26 PM)QUOTE...   Nov 29 2004, 01:53
||- - dev0   QUOTE (Zurman @ Nov 29 2004, 01:53 AM)Just to...   Nov 29 2004, 06:33
|- - BoraBora   QUOTE (rjamorim @ Nov 29 2004, 01:26 AM)For l...   Nov 29 2004, 09:20
|- - jcoalson   QUOTE (rjamorim @ Nov 28 2004, 06:26 PM)QUOTE...   Nov 30 2004, 06:20
- - Tang   Hi, Very nice THREAD thanks to Amorim and every co...   Nov 29 2004, 07:20
|- - music_man_mpc   QUOTE (Tang @ Nov 28 2004, 10:20 PM)Recently ...   Nov 29 2004, 08:57
|- - guruboolez   QUOTE (music_man_mpc @ Nov 29 2004, 08:57 AM)...   Nov 29 2004, 10:40
|- - Tang   QUOTE (guruboolez @ Nov 29 2004, 01:40 AM)QUO...   Nov 30 2004, 04:35
- - rjamorim   QUOTE (dev0 @ Nov 29 2004, 02:33 AM)I don...   Nov 29 2004, 13:23
|- - guruboolez   QUOTE (rjamorim @ Nov 29 2004, 01:23 PM)Indee...   Nov 29 2004, 14:22
|- - rjamorim   QUOTE (guruboolez @ Nov 29 2004, 10:22 AM)Is ...   Nov 29 2004, 14:29
- - guruboolez   You're right. I had in might asymetrical with ...   Nov 29 2004, 14:34
- - GeSomeone   RJAmorim, I think it would be a good idea to add v...   Dec 2 2004, 13:42
|- - Faelix   QUOTE (GeSomeone @ Dec 2 2004, 09:42 AM)Anoth...   Dec 2 2004, 14:12
- - rjamorim   QUOTE (GeSomeone @ Dec 2 2004, 09:42 AM)I thi...   Dec 9 2004, 18:43
- - kurtnoise   For TTA : Encoding Speed : fast Decoding Speed : ...   Dec 9 2004, 19:21
|- - rjamorim   Excellent. Thank-you for the info. I just updates ...   Dec 9 2004, 19:45
|- - buzzy   Nice work. As some of the comments here suggest, ...   Dec 9 2004, 20:56
|- - rjamorim   QUOTE (buzzy @ Dec 9 2004, 04:56 PM)As some o...   Dec 10 2004, 21:13
|- - buzzy   Sorry, the comment about hardware support was a re...   Dec 13 2004, 20:33
- - guruboolez   LA has both seeking and tagging functionality. I c...   Dec 9 2004, 21:08
- - Mindaxiz   EDIT: --post deleted-- Looks like TTA has been ...   Dec 9 2004, 22:44
- - Mindaxiz   Rjamorim, you either edited the table super fast o...   Dec 9 2004, 23:52
- - evereux   This spreadsheet is an excellent reference, thanks...   Dec 10 2004, 15:36
- - guruboolez   very slow seeking could be highly irritating. I ne...   Dec 10 2004, 15:48
- - rjamorim   Hello. I just added a new table design, and would ...   Dec 10 2004, 16:14
- - rjamorim   I just edited the main post. Here are some comment...   Dec 10 2004, 16:32
- - rjamorim   Since I was already playing with my test streams, ...   Dec 10 2004, 17:06
- - roweezy   WMAL / WMA Lossless 9.1 DOES support 24bit / 24-b...   Jan 1 2005, 04:23
- - Zurman   I think there's a mistak in the table : Monkey...   Jan 3 2005, 19:37
|- - rjamorim   QUOTE (Zurman @ Jan 3 2005, 03:37 PM)I think ...   Jan 3 2005, 19:48
|- - Zurman   QUOTE (rjamorim @ Jan 3 2005, 10:48 AM)QUOTE ...   Jan 3 2005, 20:08
- - Erich w/ an h   are the percentages in the original post based on ...   Jan 10 2005, 10:22
- - Skymmer   Here is another suggestion and test... As you know...   Jan 22 2005, 04:36
|- - rjamorim   Thanks for that test you did. I am considering add...   Jan 24 2005, 00:05
- - jcoalson   even better would be if a codec could store all AI...   Jan 22 2005, 06:04
- - Skymmer   Quite agree but I'm pretty sure that formats w...   Jan 22 2005, 06:34
|- - jcoalson   QUOTE (Skymmer @ Jan 22 2005, 12:34 AM)Quite ...   Jan 23 2005, 18:56
- - Skymmer   OK. Again 10 seconds brown noise but without any m...   Jan 22 2005, 07:22
- - Skymmer   QUOTE (jcoalson @ Jan 23 2005, 08:56 PM)anywa...   Jan 23 2005, 19:53
|- - jcoalson   QUOTE (Skymmer @ Jan 23 2005, 01:53 PM)QUOTE ...   Jan 24 2005, 01:13
|- - rjamorim   QUOTE (jcoalson @ Jan 23 2005, 10:13 PM)my co...   Jan 24 2005, 01:28
|- - kjoonlee   QUOTE (jcoalson @ Jan 24 2005, 09:13 AM)2. wh...   Jan 24 2005, 03:01
- - Skymmer   QUOTE (rjamorim @ Jan 24 2005, 02:05 AM)Thank...   Jan 24 2005, 02:11
|- - jcoalson   QUOTE (Skymmer @ Jan 23 2005, 08:11 PM)QUOTE ...   Jan 24 2005, 08:57
- - adlai   my take as a dumb end-user. MAC is the best. Best...   Jan 24 2005, 02:35
|- - Skymmer   QUOTE (adlai @ Jan 24 2005, 04:35 AM)MAC is t...   Jan 24 2005, 02:57
|- - buzzy   QUOTE (adlai @ Jan 23 2005, 08:35 PM)MAC is t...   Feb 12 2005, 18:27
|- - johnsonlam   To be short: Everyone who create a free loseless c...   Feb 12 2005, 18:48
- - Synthetic Soul   QUOTE (jcoalson @ Jan 24 2005, 07:57 AM)QUOTE...   Jan 24 2005, 09:38
|- - rjamorim   QUOTE (Synthetic Soul @ Jan 24 2005, 06:38 AM...   Jan 24 2005, 14:52
- - m0rbidini   Is it difficult to guarantee full reconstruction o...   Jan 24 2005, 10:23
- - Synthetic Soul   QUOTE (rjamorim @ Jan 24 2005, 01:52 PM)No fl...   Jan 24 2005, 20:43
- - Mindaxiz   QUOTE (Synthetic Soul @ Jan 24 2005, 02:43 PM...   Jan 24 2005, 21:11
|- - rjamorim   QUOTE (Mindaxiz @ Jan 24 2005, 06:11 PM)I am ...   Jan 24 2005, 23:33
- - rjamorim   QUOTE (Erich w/ an h @ Jan 10 2005, 07:22 AM)...   Feb 2 2005, 04:54
- - guruboolez   I've selected one mono album for my classical ...   Feb 3 2005, 08:19
- - p0wder   I recently converted from FLAC to Wavpack in order...   Feb 3 2005, 10:10
|- - Polar   QUOTE (p0wder @ Feb 3 2005, 09:10 UTC)I'm...   Feb 3 2005, 12:39
- - rjamorim   QUOTE (guruboolez @ Feb 3 2005, 05:19 AM)I...   Feb 3 2005, 15:30
- - rutra80   How about adding to the "Tagging" row th...   Feb 8 2005, 20:35
- - WaldoMonster   Adding "PIPE support" to the table would...   Feb 11 2005, 15:46
- - rjamorim   QUOTE (rutra80 @ Feb 8 2005, 05:35 PM)How abo...   Feb 11 2005, 19:31
|- - WaldoMonster   QUOTE (rjamorim @ Feb 11 2005, 10:31 PM)Well,...   Feb 11 2005, 22:43
- - rjamorim   QUOTE (buzzy @ Feb 12 2005, 03:27 PM)An examp...   Feb 12 2005, 23:17
- - johnsonlam   QUOTE One sentence: competition is good. I agree....   Feb 13 2005, 17:32
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st April 2015 - 07:32
