Which is the best lossless codec?, Discussion thread
kotrtim
post Nov 26 2004, 05:40
1. LOWER COMPRESSION BUT HIGHER CPU USAGE
2. NO COMPRESSION MODE TO SELECT
EDIT : But compared with Monkey's Audio, WMA still use more power.
WMA = 34.0MB = ~13% CPU Usage
Monkey's Audio - High = 33.7MB = ~7% CPU Usage
This post has been edited by kotrtim: Nov 26 2004, 06:17
rjamorim
post Dec 10 2004, 16:32
Rarewares admin
I just edited the main post. Here are some comments:
QUOTE (guruboolez @ Dec 9 2004, 05:08 PM)
LA has both seeking and tagging functionality. I can't answer for multichannel/high resolution.
Thanks for the info. I just added it to the table.
Edit: I tried LA on my multichannel test stream, and it choked ("Warning: wav file contains more than 2 channels - only mono or stereo currently supported!"). So, no multichannel support for it...
Edit2: Tried LA on my 24bit test stream. "Error - La currently only supports 16-bit files!". Meh...
QUOTE (witt @ Dec 9 2004, 08:33 PM)
Monkey's Audio supoports 24bit/192KHz. No multichannel support.
What app can it mux?
mkvtoolnix (still) doesn't support WavPack.
Fixed both, thanks.
QUOTE (kurtnoise @ Dec 9 2004, 11:07 PM)
I noticed also a mistake for TTA (in the PROS & CONS part) :no streaming support. wink.gif And TTA supports ID3v2 tags system.
Fixed, merci.
- 6 different modes for the compression : fastest to most compressible.
- Flexibility : bad
Indeed, it's funny. It features several compression modes, but all of them have nearly the same speed and output a similar compression ratio.
This post has been edited by rjamorim: Dec 10 2004, 16:45
http://www.rarewares.org
- kotrtim   Which is the best lossless codec?   Nov 26 2004, 05:40
- - rjamorim   Thanks. I added "unefficient" to WMA...   Nov 26 2004, 05:50
- - kotrtim   roberto , i'm so sorry wma compression is a bi...   Nov 26 2004, 06:04
- - sshd   1. inefficient not unefficient 2. Neither FLAC no...   Nov 26 2004, 06:09
|- - guruboolez   QUOTE (sshd @ Nov 26 2004, 06:09 AM)2. Neithe...   Nov 26 2004, 14:40
|- - jcoalson   this table is nice, good to finally have a sticky ...   Nov 28 2004, 11:51
|- - sshd   QUOTE (jcoalson @ Nov 28 2004, 11:51 AM)QUOTE...   Nov 28 2004, 16:16
|- - sehested   QUOTE (jcoalson @ Nov 28 2004, 02:51 AM)for t...   Nov 28 2004, 17:13
- - BoraBora   Another lossless comparison (in french, but the ta...   Nov 26 2004, 09:30
- - rjamorim   QUOTE (kotrtim @ Nov 26 2004, 02:04 AM)I...   Nov 26 2004, 13:12
- - Garf   <zealot> I see no reason to put very fast d...   Nov 26 2004, 13:39
|- - rjamorim   QUOTE (Garf @ Nov 26 2004, 09:39 AM)<zealo...   Nov 26 2004, 13:53
- - kurtnoise   Some notes about RALF : I made some quick tests w...   Nov 26 2004, 14:44
- - guruboolez   I forgot: nice initiative Roberto. Two comments: ...   Nov 26 2004, 14:44
- - kotrtim   according to the player itself (Itunes n Real) App...   Nov 26 2004, 15:28
- - rjamorim   QUOTE (guruboolez @ Nov 26 2004, 10:40 AM)I...   Nov 26 2004, 18:36
|- - HansHeijden   QUOTE (rjamorim @ Nov 26 2004, 06:36 PM)Since...   Nov 26 2004, 20:17
- - guruboolez   Another suggestion: what about "adaptability...   Nov 26 2004, 18:52
|- - rjamorim   QUOTE (guruboolez @ Nov 26 2004, 02:52 PM)Som...   Nov 26 2004, 19:13
- - guruboolez   I would say "none" rather than "bad...   Nov 26 2004, 19:17
- - kotrtim   QUOTE Haha, dude, you said yourself Real is very f...   Nov 27 2004, 04:48
- - rjamorim   QUOTE (HansHeijden @ Nov 26 2004, 04:17 PM)Ed...   Nov 27 2004, 21:33
- - Zurman   How about an overall notation system? 3 points for...   Nov 28 2004, 20:56
|- - guruboolez   QUOTE (Zurman @ Nov 28 2004, 08:56 PM)How abo...   Nov 29 2004, 10:18
- - BoraBora   About OS support: I understand what it means, but ...   Nov 28 2004, 23:50
- - WaldoMonster   Nice work. I'm missing native ReplayGain in t...   Nov 28 2004, 23:52
|- - rjamorim   QUOTE (WaldoMonster @ Nov 28 2004, 07:52 PM)I...   Nov 29 2004, 00:34
- - rjamorim   QUOTE (jcoalson @ Nov 28 2004, 07:51 AM)for t...   Nov 29 2004, 00:26
|- - Zurman   QUOTE (rjamorim @ Nov 28 2004, 03:26 PM)QUOTE...   Nov 29 2004, 01:53
||- - dev0   QUOTE (Zurman @ Nov 29 2004, 01:53 AM)Just to...   Nov 29 2004, 06:33
|- - BoraBora   QUOTE (rjamorim @ Nov 29 2004, 01:26 AM)For l...   Nov 29 2004, 09:20
|- - jcoalson   QUOTE (rjamorim @ Nov 28 2004, 06:26 PM)QUOTE...   Nov 30 2004, 06:20
- - Tang   Hi, Very nice THREAD thanks to Amorim and every co...   Nov 29 2004, 07:20
|- - music_man_mpc   QUOTE (Tang @ Nov 28 2004, 10:20 PM)Recently ...   Nov 29 2004, 08:57
|- - guruboolez   QUOTE (music_man_mpc @ Nov 29 2004, 08:57 AM)...   Nov 29 2004, 10:40
|- - Tang   QUOTE (guruboolez @ Nov 29 2004, 01:40 AM)QUO...   Nov 30 2004, 04:35
- - rjamorim   QUOTE (dev0 @ Nov 29 2004, 02:33 AM)I don...   Nov 29 2004, 13:23
|- - guruboolez   QUOTE (rjamorim @ Nov 29 2004, 01:23 PM)Indee...   Nov 29 2004, 14:22
|- - rjamorim   QUOTE (guruboolez @ Nov 29 2004, 10:22 AM)Is ...   Nov 29 2004, 14:29
- - guruboolez   You're right. I had in might asymetrical with ...   Nov 29 2004, 14:34
- - GeSomeone   RJAmorim, I think it would be a good idea to add v...   Dec 2 2004, 13:42
|- - Faelix   QUOTE (GeSomeone @ Dec 2 2004, 09:42 AM)Anoth...   Dec 2 2004, 14:12
- - rjamorim   QUOTE (GeSomeone @ Dec 2 2004, 09:42 AM)I thi...   Dec 9 2004, 18:43
- - kurtnoise   For TTA : Encoding Speed : fast Decoding Speed : ...   Dec 9 2004, 19:21
|- - rjamorim   Excellent. Thank-you for the info. I just updates ...   Dec 9 2004, 19:45
|- - buzzy   Nice work. As some of the comments here suggest, ...   Dec 9 2004, 20:56
|- - rjamorim   QUOTE (buzzy @ Dec 9 2004, 04:56 PM)As some o...   Dec 10 2004, 21:13
|- - buzzy   Sorry, the comment about hardware support was a re...   Dec 13 2004, 20:33
- - guruboolez   LA has both seeking and tagging functionality. I c...   Dec 9 2004, 21:08
- - Mindaxiz   EDIT: --post deleted-- Looks like TTA has been ...   Dec 9 2004, 22:44
- - Mindaxiz   Rjamorim, you either edited the table super fast o...   Dec 9 2004, 23:52
- - evereux   This spreadsheet is an excellent reference, thanks...   Dec 10 2004, 15:36
- - guruboolez   very slow seeking could be highly irritating. I ne...   Dec 10 2004, 15:48
- - rjamorim   Hello. I just added a new table design, and would ...   Dec 10 2004, 16:14
- - rjamorim   I just edited the main post. Here are some comment...   Dec 10 2004, 16:32
- - rjamorim   Since I was already playing with my test streams, ...   Dec 10 2004, 17:06
- - roweezy   WMAL / WMA Lossless 9.1 DOES support 24bit / 24-b...   Jan 1 2005, 04:23
- - Zurman   I think there's a mistak in the table : Monkey...   Jan 3 2005, 19:37
|- - rjamorim   QUOTE (Zurman @ Jan 3 2005, 03:37 PM)I think ...   Jan 3 2005, 19:48
|- - Zurman   QUOTE (rjamorim @ Jan 3 2005, 10:48 AM)QUOTE ...   Jan 3 2005, 20:08
- - Erich w/ an h   are the percentages in the original post based on ...   Jan 10 2005, 10:22
- - Skymmer   Here is another suggestion and test... As you know...   Jan 22 2005, 04:36
|- - rjamorim   Thanks for that test you did. I am considering add...   Jan 24 2005, 00:05
- - jcoalson   even better would be if a codec could store all AI...   Jan 22 2005, 06:04
- - Skymmer   Quite agree but I'm pretty sure that formats w...   Jan 22 2005, 06:34
|- - jcoalson   QUOTE (Skymmer @ Jan 22 2005, 12:34 AM)Quite ...   Jan 23 2005, 18:56
- - Skymmer   OK. Again 10 seconds brown noise but without any m...   Jan 22 2005, 07:22
- - Skymmer   QUOTE (jcoalson @ Jan 23 2005, 08:56 PM)anywa...   Jan 23 2005, 19:53
|- - jcoalson   QUOTE (Skymmer @ Jan 23 2005, 01:53 PM)QUOTE ...   Jan 24 2005, 01:13
|- - rjamorim   QUOTE (jcoalson @ Jan 23 2005, 10:13 PM)my co...   Jan 24 2005, 01:28
|- - kjoonlee   QUOTE (jcoalson @ Jan 24 2005, 09:13 AM)2. wh...   Jan 24 2005, 03:01
- - Skymmer   QUOTE (rjamorim @ Jan 24 2005, 02:05 AM)Thank...   Jan 24 2005, 02:11
|- - jcoalson   QUOTE (Skymmer @ Jan 23 2005, 08:11 PM)QUOTE ...   Jan 24 2005, 08:57
- - adlai   my take as a dumb end-user. MAC is the best. Best...   Jan 24 2005, 02:35
|- - Skymmer   QUOTE (adlai @ Jan 24 2005, 04:35 AM)MAC is t...   Jan 24 2005, 02:57
|- - buzzy   QUOTE (adlai @ Jan 23 2005, 08:35 PM)MAC is t...   Feb 12 2005, 18:27
|- - johnsonlam   To be short: Everyone who create a free loseless c...   Feb 12 2005, 18:48
- - Synthetic Soul   QUOTE (jcoalson @ Jan 24 2005, 07:57 AM)QUOTE...   Jan 24 2005, 09:38
|- - rjamorim   QUOTE (Synthetic Soul @ Jan 24 2005, 06:38 AM...   Jan 24 2005, 14:52
- - m0rbidini   Is it difficult to guarantee full reconstruction o...   Jan 24 2005, 10:23
- - Synthetic Soul   QUOTE (rjamorim @ Jan 24 2005, 01:52 PM)No fl...   Jan 24 2005, 20:43
- - Mindaxiz   QUOTE (Synthetic Soul @ Jan 24 2005, 02:43 PM...   Jan 24 2005, 21:11
|- - rjamorim   QUOTE (Mindaxiz @ Jan 24 2005, 06:11 PM)I am ...   Jan 24 2005, 23:33
- - rjamorim   QUOTE (Erich w/ an h @ Jan 10 2005, 07:22 AM)...   Feb 2 2005, 04:54
- - guruboolez   I've selected one mono album for my classical ...   Feb 3 2005, 08:19
- - p0wder   I recently converted from FLAC to Wavpack in order...   Feb 3 2005, 10:10
|- - Polar   QUOTE (p0wder @ Feb 3 2005, 09:10 UTC)I'm...   Feb 3 2005, 12:39
- - rjamorim   QUOTE (guruboolez @ Feb 3 2005, 05:19 AM)I...   Feb 3 2005, 15:30
- - rutra80   How about adding to the "Tagging" row th...   Feb 8 2005, 20:35
- - WaldoMonster   Adding "PIPE support" to the table would...   Feb 11 2005, 15:46
- - rjamorim   QUOTE (rutra80 @ Feb 8 2005, 05:35 PM)How abo...   Feb 11 2005, 19:31
|- - WaldoMonster   QUOTE (rjamorim @ Feb 11 2005, 10:31 PM)Well,...   Feb 11 2005, 22:43
- - rjamorim   QUOTE (buzzy @ Feb 12 2005, 03:27 PM)An examp...   Feb 12 2005, 23:17
- - johnsonlam   QUOTE One sentence: competition is good. I agree....   Feb 13 2005, 17:32
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 31st March 2015 - 12:37
