How To Use Mp3 Gain ?, 3 guides - normalization - maximizing
user
post Sep 1 2002, 20:56
Last update:
2004-08-16
Thanks to westgroveg, we have a brief summary of today's possibilities:
QUOTE (westgroveg @ Aug 16 2004, 12:28 AM)
This thread is always coming backup so here a few extra hints for users
  • Album analyses† calculates track/album values so performing an album analyses is all you need to do.
  • MP3Gain now supports writing changes to ID3 tag so it is 100% lossless, ie. completely reversible.
  • As of LAME 3.96 (track) replaygain values are automatically written to the lame tag,
  • Unlike MP3Gain, values stored in the lame tag need to be applied during playback which requires more CPU processing & the decoder to be aware.
  • Foobar can automatically scan & adjust replaygain values without any need for MP3Gain but of course some of us donít like this audio player.
  • One more thing, make sure, you tag before using replaygain or instead of your replaygain values being hidden they appear in the comment field for some reason which can be annoying.
This post has been edited by user: Aug 20 2004, 11:33
www.High-Quality.ch.vu -- High Quality Audio Archiving Tutorials
Joelman
post Aug 15 2004, 19:04
Ok, just to be sure ( I have lots of tunes and track info on my iPod and am nervous about wiping my iTunes library and reimporting):
Playcount, Ratings and Last Played Time will be lost, but restored by the script you showed me. How about stuff like EQ presets, Genre, and year? Will I lose those? Also, I use the "Grouping" field for key words and phrases that can be recognized for Smart Playlists, for example, "Cover Song" or "Single". Do they vanish as well when I clear and reimport my tunes after MP3gaining them?
On a side note, does ipod even use the EQ presets you specify in iTunes?
Thank you for your patience and expertise.
Otto42
post Aug 15 2004, 23:16
QUOTE (Joelman @ Aug 15 2004, 01:04 PM)
EQPresets would be lost. You could modify that script I wrote to save/restore the EQPresets as well though. I don't use them, so I didn't add them to the thing.
Genre and Year are in the file tags, so they would be pulled back in when you import the tunes.
Yep, grouping would be lost. Again, it's pretty easy to modify that script to save/restore that as well. And again, I don't use them, so they are not saved. And Grouping based smart playlist also don't work properly on the iPod, so I don't use them. They work fine if you have the latest iPod firmware, but the Live Updating feature fails on any Grouping-based SmartPlaylist, if you have a 3G or later iPod. Confused yet?
Simpler version: If you have a newer iPod (3rd Gen and above), then the smart playlists can work in real time on the iPod itself. Meaning that if I have a playlist defined as "Last Played is not in the last 2 weeks", and then I play a song from that playlist all the way through, and then go back to the playlist again, the song will no longer be in that playlist. All without syncing to a computer. The iPod is smart enough to remove the song from the playlist after it's played. This comes in very handy for me. However, any Smart Playlist that has a rule using either "Grouping" or "Playlist" breaks this functionality. The smart playlist will not change until it's synced to a computer again. Not critical for most people, but it annoys me so I avoid using those types of rules in smart playlists.
Also, use of the Grouping field is unsafe, as it's probably going to change in the future. Apple seems to have intended the grouping field to define groups of songs that should be played together. Think of Queen's "We Will Rock You" and "We are the Champions".. These songs are nearly always combined. The purpose of the grouping field seems to be to be able to define several songs as part of a single group and thus always play them together, even in randomized playlists and such. This is not yet fully implemented, it seems, but some songs being downloaded from the iTunes Music Store, notably classical works, have had the Grouping fields filled in this fashion. At some future point, they may get this working on the iPod and suddenly you'll find that the songs with the same grouping always play together.
My advice is to use the Comments field for this sort of thing instead, and leave Grouping blank or use it as it seems to be intended, to group songs together.
Yes and no. If you use the built in EQ Presets, like "Rock" and "Bass Booster" and so forth, then yes, they will transfer and be used on the iPod. For this to work, you need to have the iPod's EQ set to anything other than "Off". Setting it to "Flat" is the most common way to enable the EQ Presets to work.
If you have defined your own custom presets, then the data transfers, but the iPod does not currently use that data (I confirmed this myself through testing). So while it may work at some future point, it doesn't work currently. Everything the iPod needs to do it is there, it's just not doing it yet.
http://ottodestruct.com
- user   How To Use Mp3 Gain ?   Sep 1 2002, 20:56
- - user   Here is a very short and simple description How t...   Sep 1 2002, 21:31
- - user   MP3-CD album-based MP3Gain adjustment for newbies ...   Sep 1 2002, 21:38
- - Vincent Kargatis   Is there a way to have mp3gain automatically pick ...   Sep 17 2002, 17:39
- - Vincent Kargatis   Well, no answer, so I assume no. Anyway, here...   Sep 20 2002, 10:01
- - westgroveg   QUOTE (user @ Sep 2 2002 - 08:31 AM)Here is a...   Sep 29 2002, 07:16
- - High Speed Dubbing   Thanx for the tutorial, been looking for help for ...   Oct 10 2002, 23:27
- - holkie   QUOTE (7) Order files by Max Noclip Gain column (f...   Oct 23 2002, 12:19
- - user   I sort never manually songs. The first 2 posts sa...   Oct 26 2002, 09:59
- - floyd   ok.. what about the best settings for mp3 portabl...   Oct 28 2002, 07:53
- - user   mp3gain: Hardware support is NOT required... mp3g...   Oct 28 2002, 10:20
- - gfly3   i have searched for the answer for this but could ...   Oct 29 2002, 04:03
- - Snelg   QUOTE (gfly3 @ Oct 28 2002 - 09:03 PM)i have ...   Oct 29 2002, 14:59
- - gfly3   clear enough ! and a great app. thanks a mi...   Oct 29 2002, 21:53
- - AreteOne   This looks like just what I need for MP3 discs. M...   Nov 19 2002, 05:42
- - Jan S.   WAVgain: http://www.answermonkey.net/App_WAVGain.h...   Nov 19 2002, 08:03
- - illdie4u   Hello, how fast does mp3gain work? How long would...   Nov 19 2002, 09:03
- - Jan S.   It's the analyse that takes the time, not real...   Nov 19 2002, 14:48
- - CiTay   Time to apply AlbumGain on 12 MP3 files (PIII 1.13...   Nov 19 2002, 17:36
- - AreteOne   Now that I've played with MP3Gain, I've go...   Nov 20 2002, 13:06
- - AreteOne   Providing the thread with some more information af...   Nov 21 2002, 14:32
- - CiTay   I don't agree with 2), 3) and 5) (the latter p...   Nov 21 2002, 14:43
- - AreteOne   QUOTE (CiTay @ Nov 21 2002 - 05:43 AM)I don...   Nov 21 2002, 15:17
- - CiTay   Why i disagree... with 2): For the very reason yo...   Nov 21 2002, 16:42
- - user   Not the best way: Bottom line.... MP3 creation pr...   Nov 21 2002, 17:11
- - AreteOne   QUOTE with 2): For the very reason you mentioned: ...   Nov 21 2002, 18:01
- - CiTay   QUOTE As for the hiss, I should be clear that I...   Nov 21 2002, 18:27
- - AreteOne   QUOTE 3) no, no, no (this is my opinion, if mp3 is...   Nov 21 2002, 18:49
- - user   "If there hasn't been any testing, how do...   Nov 21 2002, 19:07
- - AreteOne   QUOTE hmm, probably your misconception of mp3 Wel...   Nov 21 2002, 21:05
- - user   you know my opinion. to do it with the least time...   Nov 21 2002, 22:06
- - CiTay   Here's the file i mentioned before: overloadte...   Nov 21 2002, 22:37
- - tangent   QUOTE (AreteOne @ Nov 22 2002 - 04:05 AM)So, ...   Nov 22 2002, 05:29
- - AreteOne   QUOTE Here's the file i mentioned before: over...   Nov 22 2002, 10:45
- - AreteOne   QUOTE If you have been around for a while, the for...   Nov 22 2002, 10:55
- - tangent   QUOTE (AreteOne @ Nov 22 2002 - 05:55 PM)Yes,...   Nov 22 2002, 11:39
- - floyd   I got quite a bit of clipping in some Iron Maiden ...   Nov 22 2002, 11:49
- - CiTay   QUOTE (AreteOne @ Nov 22 2002 - 10:45 AM)Woul...   Nov 22 2002, 13:26
- - AreteOne   QUOTE This depends on settings used. -aps should c...   Nov 22 2002, 13:51
- - AreteOne   QUOTE Just listen to it. You shouldn't hear th...   Nov 22 2002, 13:57
- - CiTay   QUOTE (AreteOne @ Nov 22 2002 - 01:57 PM)Afte...   Nov 22 2002, 14:01
- - tangent   QUOTE (AreteOne @ Nov 22 2002 - 08:51 PM)Look...   Nov 22 2002, 16:56
- - illdie4u   Is there any problem if I set the output level in ...   Nov 28 2002, 08:51
- - user   if there is no clipping, all is fine. For those r...   Nov 28 2002, 08:57
- - illdie4u   But for portable reasons I want my whole collectio...   Nov 28 2002, 09:04
- - ronnie_t   what mp3-gain program should i use, and where can ...   Jan 5 2003, 12:53
- - Volcano   http://www.geocities.com/mp3gain/ If you wait a f...   Jan 5 2003, 14:48
- - ronnie_t   i use that version, but again, I can't follow ...   Jan 5 2003, 16:41
- - Bones   I just checked out that overload sample. I used a...   Jan 5 2003, 17:46
- - Volcano   ronnie_t: QUOTE Can I use an older version or doe...   Jan 6 2003, 15:42
- - Moguta   mp3gain claims to be a lossless change to mp3 file...   Apr 26 2003, 02:47
- - Volcano   The current (non-public) beta version of MP3Gain d...   Apr 26 2003, 11:58
- - Moguta   Sweet! Actually, a question occured to me... ...   Apr 26 2003, 19:02
- - Volcano   QUOTE Actually, a question occured to me... *CAN* ...   Apr 27 2003, 16:48
- - Moguta   QUOTE (Volcano @ Apr 26 2003 - 10:58 AM)I sup...   May 9 2003, 01:32
- - MadBison   I have an Archos Jukebox Multimedia 020. This is a...   Jun 6 2003, 00:16
- - Jebus   QUOTE (MadBison @ Jun 5 2003 - 03:16 PM)I hav...   Jun 6 2003, 03:38
- - AlfredSka   QUOTE (user @ Sep 1 2002 - 12:56 PM)- Outdate...   Jun 6 2003, 09:01
- - pepe,pepe!   I totally agree with Jebus the best way to use mp3...   Jun 7 2003, 01:46
- - RaWShadow   I have never used this mp3gain before and was wond...   Jun 26 2003, 22:42
- - CiTay   QUOTE (RaWShadow @ Jun 26 2003 - 11:42 PM)I h...   Jun 26 2003, 23:21
- - RaWShadow   Okay i think i understand now. I read the windows ...   Jun 27 2003, 00:25
- - Jebus   QUOTE (RaWShadow @ Jun 26 2003 - 03:25 PM)Oka...   Jun 27 2003, 00:48
- - AstralStorm   Auto Gain Control reduces/increases gain to match ...   Jun 27 2003, 00:55
- - Raffles   Am I right in assuming mp3gain is the same thing a...   Jul 26 2003, 01:33
- - 12345   QUOTE (Raffles @ Jul 26 2003, 01:33 AM)Am I r...   Jul 27 2003, 19:09
- - Pio2001   89 db reference question splitted here : http://w...   Aug 16 2003, 09:49
- - Agitator   Hi, I have some questions regarding MP3Gain. Let...   Dec 11 2003, 13:55
- - Hanky   @Agitator, This has been discussed many times befo...   Dec 11 2003, 14:14
- - Agitator   Thanks, I looked for something like that, but didn...   Dec 11 2003, 14:20
- - PeterGV   I've used MP3GAIN for quite a while, and I...   Dec 24 2003, 01:25
- - Squibbles1092   I just started MP3Gaining my files, but I couldn...   Dec 24 2003, 03:43
- - AtaqueEG   QUOTE (Squibbles1092 @ Dec 23 2003, 08:43 PM)...   Dec 24 2003, 05:34
- - TwoJ   Actually, not so If you load up a folder, each sub...   Dec 24 2003, 07:58
- - Squibbles1092   Ahh. Thanks. I queued up my entire folder with sub...   Dec 24 2003, 08:14
- - Jack Comics   QUOTE (user @ Sep 1 2002, 02:56 PM)- Outdated...   Jan 12 2004, 01:30
- - mj-barton   Once my semester finals are out of the way. I...   Jan 12 2004, 08:20
- - user   for mp3, you need EAC, Lame.exe, mp3gain, nothing ...   Jan 12 2004, 09:40
- - Moguta   I'm getting an error whenever I use MP3gain......   Jan 24 2004, 23:11
- - user   somebody requested in PM to me a rewrite of the mp...   Mar 17 2004, 21:18
- - Dr.Karnage   Maybe this has already been answered, but should I...   Mar 17 2004, 22:22
- - AstralStorm   MP3Gain is applied to the file - any player (inclu...   Mar 17 2004, 22:33
- - HiFiRE   Couple questions... I'm running MP3Gain 1.2.3...   Jul 4 2004, 02:02
- - Joelman   I'm brand new to this forum, and I hope I...   Aug 11 2004, 14:45
|- - Otto42   QUOTE (Joelman @ Aug 11 2004, 08:45 AM)Now, I...   Aug 11 2004, 15:36
- - Joelman   Thanks Otto-- Soundcheck has been problematic for...   Aug 11 2004, 15:54
|- - odious malefactor   QUOTE (Joelman @ Aug 11 2004, 06:54 AM)As for...   Aug 11 2004, 16:23
- - Joelman   QUOTE Of course, clearing the iTunes library and r...   Aug 11 2004, 18:35
|- - Otto42   QUOTE (Joelman @ Aug 11 2004, 12:35 PM)Can I ...   Aug 11 2004, 21:00
- - Joelman   Ok, just to be sure ( I have lots of tunes and tra...   Aug 15 2004, 19:04
|- - Otto42   QUOTE (Joelman @ Aug 15 2004, 01:04 PM)How ab...   Aug 15 2004, 23:16
- - westgroveg   This thread is always coming backup so here a few ...   Aug 16 2004, 00:28
|- - user   QUOTE (westgroveg @ Aug 16 2004, 12:28 AM)Thi...   Aug 16 2004, 09:32
||- - westgroveg   QUOTE (user @ Aug 16 2004, 08:32 PM)QUOTE (we...   Aug 16 2004, 11:15
|- - jth   QUOTE (westgroveg @ Aug 15 2004, 04:28 PM)[*]...   Aug 17 2004, 23:58
- - Joelman   QUOTE Of course, clearing the iTunes library and r...   Aug 17 2004, 14:15
|- - Otto42   QUOTE (Joelman @ Aug 17 2004, 08:15 AM)I...   Aug 17 2004, 15:32
- - Joelman   Thanks Otto42. Unfortunately it turns out a large ...   Aug 17 2004, 23:42
- - Joelman   Does anyone have a solution on how to fix the fluc...   Sep 23 2004, 13:52
- - Otto42   Joelman: The only suggestion I have left for you i...   Sep 23 2004, 15:38
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th August 2015 - 20:35
