Displaying M4A/MP4-Tags in Windows Explorer?, Like it does with MP3/WMA-Tags by defaul
tedgo
post Mar 18 2005, 11:27
I want to know if its possible to display m4a/mp4- or APEv2-tags in windows explorer like it does with the id3v2-tags in mp3/wma by default.
I tried a program called "AudioShell 1.0" that did a good job, but it only adds new column headers to windows explorer and i have to set these column headers in every folder by hand (its not a good idea for more than 500 album folders...)
So is there any shell extension for the windows explorer that uses the default audio column headers and displays file information like for mp3's/wma's?
Or is there any possibility to "persuade" windows explorer to recognise m4a/mp4 (and perhaps some other formats) as audio files and displaying their informations without a program?
EDIT: orthography
This post has been edited by tedgo: Mar 18 2005, 12:57
andrewfg
post May 12 2008, 18:45
QUOTE (tedgo @ Mar 18 2005, 11:27) *
I have written such a shell extension.
See http://www.whitebear.ch/music for information and download
AndrewFG
AndrewFG (Whitebear -- http://www.whitebear.ch/mediaserver )
M
post May 13 2008, 19:58
QUOTE (andrewfg @ May 12 2008, 12:45) *
AndrewFG
Haven't had a chance to install or test this yet, but I am curious as to whether your shell extension will also display the appropriate properties for *.m4v (movie) and *.m4b (audiobook) files. Is this already included, and if not, would it be fairly simple to add?
- M.
andrewfg
post May 17 2008, 13:37
QUOTE (M @ May 13 2008, 19:58) *
I does not (yet) support the properties of .m4v / .m4b or .m4r files.
However, insofar as these file types are (I think) also based on (Apple's extensions of) the ISO 14496 (MPEG4) file format, I suppose that it could easily support these file types too. Indeed it would probably just be a question of adding some file association entries in the Windows Registry.
I don't have any such files on my PC, but if you want to make a quick test, you could make a copy of one of your .m4v files (say) and rename it as .m4a and then see if Windows Explorer displays the properties.
AndrewFG
Thug Esquire
post May 28 2008, 09:04
QUOTE (andrewfg @ May 17 2008, 07:37) *
I installed your extension (thanks for making it!) but it doesn't make the tag information show up in explorer. Here's an example of what I do see:
Running Vista Ultimate 64-bit SP1. What might be the problem?
andrewfg
post May 29 2008, 16:47
QUOTE (Thug Esquire @ May 28 2008, 09:04) *
Very interesting screen shot!!
My shell extension is 32 bit code, and so to be on the safe side my setup program will not install the extension on a 64 bit machine (yet). Indeed when you run the setup, you should have got an error message to this effect. => Can you please confirm?
On the other hand, your screen shot shows a hint box that does display tags from the .m4a file. (In fact it shows more tags than the ones supported by my shell extension). So I am guessing that you have another shell extension installed which is (also) handling .m4a files. => Is this the case? => So far as I know, Windows only allows one shell extension for any particular file type. (Probably the last one installed wins.)
So in short it looks like you already have another extension installed, and because of the 32/64 bit safety my extension is not being installed, so the other shell extension is winning. => Does this hypothesis match your symptoms?
AndrewFG
Thug Esquire
post May 31 2008, 23:04
QUOTE (andrewfg @ May 29 2008, 10:47) *
Yes, I have dBpoweramp installed, and it would make sense if that's what's allowing the tooltip to show the tag information. However, I do not receive any error during installation on my 64-bit Vista box. In fact, installation and uninstallation complete successfully. I've tested several times. Would it be difficult to create a 64-bit version of this extension?
- tedgo   Displaying M4A/MP4-Tags in Windows Explorer?   Mar 18 2005, 11:27
- - Klyith   If you are comfortable with regedit, you may be ab...   Mar 18 2005, 19:58
- - tedgo   Thanks for your reply. But audioshell hasn't a...   Mar 18 2005, 21:55
- - spoon   >default audio column headers and displays file...   Mar 19 2005, 11:59
- - tedgo   It's too bad... But what do you mean with ...   Mar 19 2005, 20:27
- - spoon   I found it got the bitrates wrong (when XP was rel...   Mar 19 2005, 23:19
|- - LANjackal   QUOTE (spoon @ Mar 19 2005, 17:19) I foun...   May 13 2008, 01:32
- - andrewfg   QUOTE (tedgo @ Mar 18 2005, 11:27) I want...   May 12 2008, 18:45
|- - M   QUOTE (andrewfg @ May 12 2008, 12:45) I h...   May 13 2008, 19:58
||- - andrewfg   QUOTE (M @ May 13 2008, 19:58) Haven...   May 17 2008, 13:37
||- - Thug Esquire   QUOTE (andrewfg @ May 17 2008, 07:37) I d...   May 28 2008, 09:04
||- - andrewfg   QUOTE (Thug Esquire @ May 28 2008, 09:04)...   May 29 2008, 16:47
||- - Thug Esquire   QUOTE (andrewfg @ May 29 2008, 10:47) Ver...   May 31 2008, 23:04
||- - andrewfg   QUOTE (Thug Esquire @ May 31 2008, 23:04)...   Jun 1 2008, 15:19
||- - Thug Esquire   QUOTE (andrewfg @ Jun 1 2008, 09:19) Most...   Jun 1 2008, 19:58
||- - andrewfg   QUOTE (Thug Esquire @ Jun 1 2008, 19:58) ...   Jun 3 2008, 21:25
||- - Thug Esquire   QUOTE (andrewfg @ Jun 3 2008, 15:25) I bu...   Jun 4 2008, 07:07
||- - andrewfg   QUOTE (Thug Esquire @ Jun 4 2008, 07:07) ...   Jun 5 2008, 21:58
|- - theboyjenkins   QUOTE (andrewfg @ May 12 2008, 17:45) QUO...   May 29 2008, 17:23
- - retro83   QUOTE (andrewfg @ May 12 2008, 18:45) QUO...   May 13 2008, 07:51
|- - andrewfg   QUOTE (retro83 @ May 13 2008, 07:51) Look...   May 13 2008, 11:46
|- - andrewfg   QUOTE (retro83 @ May 13 2008, 07:51) Look...   Oct 6 2008, 14:43
|- - lame 321   [/quote] I have recently added support for Windows...   Oct 8 2008, 22:13
|- - MrSinatra   QUOTE (andrewfg @ Oct 6 2008, 09:43) QUOT...   Aug 7 2010, 23:57
- - ~*McoreD*~   andrewfg, What he has installed is dbPowerAMP. I...   May 29 2008, 16:58
|- - andrewfg   QUOTE (~*McoreD*~ @ May 29 2008, 16:58) W...   May 30 2008, 19:27
|- - grommet   QUOTE (andrewfg @ May 30 2008, 11:27) I n...   May 30 2008, 20:51
- - spoon   That popup info box is from dBpoweramp.   May 29 2008, 17:16
- - spoon   >I believe that it is also allowed to embed ID3...   May 30 2008, 21:37
- - andrewfg   QUOTE (spoon @ May 30 2008, 21:37) QUOTE ...   May 30 2008, 22:31
RSS Lo-Fi Version Time is now: 29th May 2015 - 03:35
