List of DAE Drive Features, EAC & CD Paranoia
westgroveg
post Mar 7 2005, 06:21
This thread will be used to gather an accurate list of DAE drive features. Just post your drive(s) features in this thread & I will add them to my database.
The lists main purpose is to provide sample offsets for users who don't have one of EAC's key CD's & help people decide which is an optimal drive for use with EAC & which is a suitable drive for accurate results with CD Paranoia.
I will not add any incomplete records into the database so you must provide all the required fields.
Required Fields:
  • Manufacturer <-- First part of EAC's top-left list box
  • Type <-- Second part of EAC's top-left list box
  • Model <-- Third part of EAC's top-left list box
  • Accurate Stream <--Detect Drive Features....
  • Caching <--Detect Drive Features....
  • C2 Error Info <--Detect Drive Features....
  • Overread <--Detect read sample offset correction....
  • Sample Offset <--Detect read sample offset correction....
  • Firmware <--Drive tab of Nero InfoTool
Example:
Manufacturer - SAMSUNG
Type - CD-ROM
Model - SH-152A
Accurate Stream - YES
Caching - NO
C2 Error Info - YES
Overread - Lead Out
Sample Offset - +12
Firmware - C504
Results so far:
Database file (xls):
10-04-2005
This post has been edited by westgroveg: Apr 10 2005, 10:59
Moitah
post Oct 10 2008, 05:01
Samsung SH-S223Q
Firmware: SB01
Caching: No
Accurate Stream: Yes
C2 Error Info: Yes
Read Offset Correction: +6
Gap Detection Mode: A
Overread: Don't think so, only checked for the lead-out
HTOA: Yes -- HOWEVER, EAC reports a timing problem a few seconds before track 1 index 1, and when I compared the rip to the same one I'd done with my Pioneer DVR-111D (which unfortunately doesn't want to read CDs anymore sad.gif), there were 25 frames of digital silence at that area.
Other observations: Seems to read catalog numbers okay. ISRCs, on the other hand, are a bit messed up. For example, it reads "SC]QF0703807" when it should be "SEVGT0703807" -- the text part is wrong but the numbers are correct.
EDIT: I figured out how to get a perfect copy of the HTOA with CDex, see 6 posts down.
Also, I discovered that the ISRCs can be read properly with CDRDAO (which you probably already have in your EAC folder). Run "cdrdao scanbus" from the command prompt and copy your device number (e.g. "2,0,0"). Then run "cdrdao read-toc --device 2,0,0 mytoc.txt" (replace "2,0,0" with your device number) and it will scan the disc and write all TOC information including ISRCs to a text file. This also works on my Lite-On SHM-165P6S which doesn't normally read ISRC's properly either.
This post has been edited by Moitah: Oct 11 2008, 20:03
- westgroveg   List of DAE Drive Features   Mar 7 2005, 06:21
- - unfortunateson   CODEType - MICRO ADVANTAGE DVD-RW Model - IDE1008 ...   Mar 7 2005, 06:43
- - rutra80   Heh, not so long time ago AgentMil started the sam...   Mar 7 2005, 21:31
|- - westgroveg   QUOTE but lets make it the way it should be then -...   Mar 8 2005, 00:58
- - Eli   can you get a log output from Nero CD Speed? If s...   Mar 8 2005, 02:11
- - rutra80   QUOTE (westgroveg @ Mar 8 2005, 01:58 AM)Nega...   Mar 8 2005, 02:42
- - rutra80   Type: SONY DVD-ROM Model: DDU1621 Firmware: S2.9 A...   Mar 8 2005, 21:27
- - A_Man_Eating_Duck   CODEType: JLMS (Liteon) DVD-ROM Model...   Mar 8 2005, 23:35
- - Eli   Hmm, the SAMSUNG - SH-152A looks pretty good. ...   Mar 9 2005, 03:22
- - unfortunateson   QUOTE (unfortunateson @ Mar 6 2005, 09:43 PM)...   Mar 9 2005, 03:24
- - A_Man_Eating_Duck   I wonder if this thread could be stickied by a mod...   Mar 9 2005, 08:02
- - evereux   Would it be possible to split the manufacturer nam...   Mar 9 2005, 09:52
- - Martin H   Unfortunateson - It is because you are using a dif...   Mar 10 2005, 05:55
|- - westgroveg   QUOTE (Martin H @ Mar 10 2005, 04:55 PM)Unfor...   Mar 12 2005, 23:29
- - unfortunateson   sorry about the confusion... EAC reports neither t...   Mar 13 2005, 05:39
|- - westgroveg   QUOTE (unfortunateson @ Mar 13 2005, 04:39 PM...   Mar 13 2005, 07:47
- - Martin H   Unfortunateson - AccurateRip dosent check for over...   Mar 13 2005, 06:54
- - unfortunateson   ive checked, no overreading on neither   Mar 13 2005, 07:08
- - AndyMutz   Type: BenQ DVD-RW Model: DW1620 Pro Firmware: B7U9...   Mar 13 2005, 07:44
- - unfortunateson   looks good.   Mar 13 2005, 08:09
- - esa372   Manufacturer - Samsung Type - CD-RW/DVD Model - SM...   Mar 15 2005, 16:30
- - evereux   Just to keep people updated: I've now created...   Mar 17 2005, 13:14
- - Deep_Elem   Manufacturer: Samsung Type: CD-R/RW Model: SW-252B...   Mar 17 2005, 19:15
- - rutra80   I would remove the Matching column along with blue...   Mar 18 2005, 05:09
|- - evereux   QUOTE (rutra80 @ Mar 18 2005, 04:09 AM)I woul...   Mar 18 2005, 09:30
|- - westgroveg   QUOTE (rutra80 @ Mar 18 2005, 04:09 PM)I woul...   Mar 20 2005, 07:54
|- - rutra80   QUOTE (westgroveg @ Mar 20 2005, 08:54 AM)QUO...   Mar 20 2005, 08:47
|- - AndyMutz   rutra80, there is a slight misstake in your table:...   Mar 20 2005, 19:45
- - westgroveg   What I mean is that if we have a drive with an off...   Mar 20 2005, 12:59
|- - rutra80   QUOTE (westgroveg @ Mar 20 2005, 01:59 PM)Wha...   Mar 20 2005, 14:23
|- - Richard_Hsi   CODEType - SONY DVD-ROM Model - DDU1621( FIRMW...   Mar 20 2005, 17:54
|- - A_Man_Eating_Duck   QUOTE (Richard_Hsi @ Mar 20 2005, 04:54 PM)CO...   Mar 20 2005, 23:04
- - westgroveg   QUOTE (rutra80)The scoring could be like that: 1. ...   Mar 20 2005, 23:25
- - Eli   I think it would be better is there was an app to ...   Mar 21 2005, 00:46
|- - spoon   QUOTE (Eli @ Mar 20 2005, 11:46 PM)I think it...   Mar 21 2005, 12:17
|- - TCM   QUOTE (spoon @ Mar 21 2005, 06:17 AM)Accurate...   Jul 17 2005, 01:06
- - evereux   Why is the sample offset boundary of 1000 used to ...   Mar 21 2005, 10:47
- - rutra80   QUOTE (AndyMutz @ Mar 20 2005, 08:45 PM)rutra...   Mar 21 2005, 13:27
- - tas   QUOTE (westgroveg @ Mar 7 2005, 06:21 AM)This...   Mar 21 2005, 14:20
|- - westgroveg   QUOTE (tas @ Mar 22 2005, 01:20 AM)QUOTE (wes...   Mar 25 2005, 11:59
- - rutra80   Manufacturer: Philips Type: 36x (it's a CD-ROM...   Mar 27 2005, 00:15
- - DreamweaverN   CODEManufacturer - PIONEER Type - DVD-ROM Model - ...   Mar 28 2005, 05:01
- - R.A.F.   CODEManufacturer: BTC Type: DVD+-R/RW DL R...   Mar 28 2005, 05:23
- - westgroveg   Updates: -Switched to Interlaced GIF -Added positi...   Mar 31 2005, 04:03
|- - Duble0Syx   CODEManufacturer - PLEXTOR Type - CD-RW Model - PX...   Mar 31 2005, 05:58
|- - Duble0Syx   CODEManufacturer - ASUS Type - CD-RW Model - CRW-4...   Mar 31 2005, 06:09
- - VCSkier   what happened to the chart? i could see it last t...   Apr 4 2005, 06:24
|- - westgroveg   QUOTE (VCSkier @ Apr 4 2005, 05:24 PM)what ha...   Apr 4 2005, 13:35
- - VCSkier   yeah, its working fine now. thanks   Apr 5 2005, 03:23
- - JuanK   Some days ago, I submitted a new entry but i made ...   Apr 29 2005, 16:50
|- - westgroveg   QUOTE (JuanK @ Apr 30 2005, 03:50 AM)Some day...   Apr 30 2005, 08:42
|- - evereux   QUOTE (JuanK @ Apr 29 2005, 03:50 PM)Some day...   Apr 30 2005, 12:42
- - Synthetic Soul   QUOTE (rutra80 @ Mar 20 2005, 02:23 PM)QUOTE ...   Apr 30 2005, 14:56
- - HbG   Here's my contribution: CODE    Manu...   May 14 2005, 14:54
- - baldrick   Manufacturer - PIONEER Type - DVD±R/RW Recorder Mo...   May 30 2005, 15:17
- - evereux   http://www.daefeatures.co.uk has now been updated ...   Jun 12 2005, 08:57
- - Pop   Manufacturer - PIONEER Type - DVD±R/RW Recorder Mo...   Jun 12 2005, 10:08
- - WaldoMonster   Here are my two drives: Manufacturer: Asus Type: ...   Jul 17 2005, 01:31
- - micmac   Hi all, I bought a new drive 2 weeks ago and I...   Oct 30 2005, 12:22
- - landy   Type: HL-DT-STDVDRAM (it's LG) Model: GSA-4120...   Oct 30 2005, 14:04
- - evereux   I don't think it's worth posting your resu...   Oct 30 2005, 14:40
- - landy   that was supposed to be a quote of the first perso...   Oct 30 2005, 16:58
- - jhartmann   The LG/HL-DT-ST GSA-4120B as well as its relatives...   Dec 22 2005, 11:55
- - incognitu   What about the GSA-4082N? It's a slim drive (...   Jan 17 2006, 23:26
- - rutra80   AFAIK Feurio! has some more advanced caching-d...   Jan 18 2006, 09:52
|- - Mefodiy   QUOTE (rutra80 @ Jan 18 2006, 03:52 AM)AFAIK ...   Feb 19 2006, 03:59
|- - rutra80   QUOTE (Mefodiy @ Feb 19 2006, 04:59 AM)1. The...   Feb 22 2006, 22:31
|- - Mefodiy   QUOTE (rutra80 @ Feb 22 2006, 04:31 PM)... Th...   Mar 3 2006, 04:54
|- - rutra80   QUOTE (Mefodiy @ Mar 3 2006, 05:54 AM)Where i...   Mar 6 2006, 09:15
- - Mefodiy   I'd still appreciate 1,2,&3 being addresse...   Feb 22 2006, 05:38
- - DreamweaverN   QUOTE (DreamweaverN @ Mar 28 2005, 01:31 PM)C...   Mar 6 2006, 03:09
- - pike   download link is broken   Jun 24 2006, 05:33
- - Be Positive   Manufacturer: Plextor Type: DVD-ROM ...   Oct 14 2006, 19:25
- - Joshatdot   CODEManufacturer - OPTORITE Type - DVD-RW Model - ...   Dec 11 2007, 06:42
- - JoeGons   Acer Laptop.2480-2943 TSST Corp. CDW/DVD TS-L462D...   Jan 23 2008, 19:15
- - RamonSalazar   Manufacturer - PIONEER Type - DVD-RW Model - DVR-2...   May 1 2008, 20:23
- - Moitah   Samsung SH-S223Q Firmware: SB01 Caching: No Accura...   Oct 10 2008, 05:01
|- - greynol   QUOTE (Moitah @ Oct 9 2008, 21:01) HTOA: ...   Oct 10 2008, 05:11
|- - Moitah   QUOTE (greynol @ Oct 10 2008, 00:11) Soun...   Oct 10 2008, 05:17
- - greynol   Well maybe it is a yes. What happens when you try...   Oct 10 2008, 05:23
- - Moitah   I still get that bit of silence in secure mode, EA...   Oct 10 2008, 05:38
- - greynol   Any old disc should do for that test. EDIT: or new...   Oct 10 2008, 05:41
- - Moitah   EAC's offset test says "None" for ov...   Oct 11 2008, 02:32
- - ssjkakaroto   Hi guys, do you know if any new drive can overread...   Oct 23 2008, 12:04
RSS Lo-Fi Version Time is now: 30th March 2015 - 02:32
