List of DAE Drive Features, EAC & CD Paranoia
westgroveg
post Mar 7 2005, 06:21
This thread will be used to gather an accurate list of DAE drive features. Just post your drive(s) features in this thread & I will add them to my database.
The lists main purpose is to provide sample offsets for users who don't have one of EAC's key CD's & help people decide which is an optimal drive for use with EAC & which is a suitable drive for accurate results with CD Paranoia.
I will not add any incomplete records into the database so you must provide all the required fields.
Required Fields:
  • Manufacturer <-- First part of EAC's top-left list box
  • Type <-- Second part of EAC's top-left list box
  • Model <-- Third part of EAC's top-left list box
  • Accurate Stream <--Detect Drive Features....
  • Caching <--Detect Drive Features....
  • C2 Error Info <--Detect Drive Features....
  • Overread <--Detect read sample offset correction....
  • Sample Offset <--Detect read sample offset correction....
  • Firmware <--Drive tab of Nero InfoTool
Example:
Manufacturer - SAMSUNG
Type - CD-ROM
Model - SH-152A
Accurate Stream - YES
Caching - NO
C2 Error Info - YES
Overread - Lead Out
Sample Offset - +12
Firmware - C504
Results so far:
Database file (xls):
10-04-2005
This post has been edited by westgroveg: Apr 10 2005, 10:59
Eli
post Mar 21 2005, 00:46
I think it would be better is there was an app to detect and submitt these features. Maybe spoon would be willing to write one to go with AccurateRip?
http://forum.dbpoweramp.com/showthread.php?t=21072
spoon
post Mar 21 2005, 12:17
dBpowerAMP developer
Group: Developer (Donating)
QUOTE (Eli @ Mar 20 2005, 11:46 PM)
Many of the items would be difficult to automatically detect:
Manufacturer: No problem
Type: No problem
Model: No problem
Accurate Stream: No problem
Caching: This one is hit and miss to detect,
C2 Error Info: The firmware could lie about it's implementation / implementation could be poor you would need a cd with intentional errors
Overread: You would need a specific audio cd with sound data (values not 0) right upto the lead in / out, some drives when trying to overread just return 0's, you wouldn't spot this unless you had a cd as mentioned.
Sample Offset: No problem
Firmware: Is this drive specific?
AccurateRip contained pretty much all the items that could be autodetected with any audio cd, it has the Sample Offset and Accurate Stream.
Spoon http://www.dbpoweramp.com
TCM
post Jul 17 2005, 01:06
QUOTE (spoon @ Mar 21 2005, 06:17 AM)
i cannot comment on accurate stream, but "drive caches" can always be turned ON and "c2 error info" can always be turned OFF as a fail-safe fallback. all you get is a speed decrease with added safety.
especially c2 was unreliable with my liteon ltr-24103s. the drive reports c2 but repeatedly reripping a track would yield a different checksum each time. scary. so better be safe than sorry and keep those two options at their slow-but-reliable setting. my opinion.
edit: unless you mass-rip hundreds of cds where you need the speed. but i'd very carefully verify that the drive rips correctly. usually, the slightest sign of a checksum mismatch or similar makes me run screaming from ever using that option again. but that's just me :)
This post has been edited by TCM: Jul 17 2005, 01:09
- westgroveg   List of DAE Drive Features   Mar 7 2005, 06:21
- - unfortunateson   CODEType - MICRO ADVANTAGE DVD-RW Model - IDE1008 ...   Mar 7 2005, 06:43
- - rutra80   Heh, not so long time ago AgentMil started the sam...   Mar 7 2005, 21:31
|- - westgroveg   QUOTE but lets make it the way it should be then -...   Mar 8 2005, 00:58
- - Eli   can you get a log output from Nero CD Speed? If s...   Mar 8 2005, 02:11
- - rutra80   QUOTE (westgroveg @ Mar 8 2005, 01:58 AM)Nega...   Mar 8 2005, 02:42
- - rutra80   Type: SONY DVD-ROM Model: DDU1621 Firmware: S2.9 A...   Mar 8 2005, 21:27
- - A_Man_Eating_Duck   CODEType: JLMS (Liteon) DVD-ROM Model...   Mar 8 2005, 23:35
- - Eli   Hmm, the SAMSUNG - SH-152A looks pretty good. ...   Mar 9 2005, 03:22
- - unfortunateson   QUOTE (unfortunateson @ Mar 6 2005, 09:43 PM)...   Mar 9 2005, 03:24
- - A_Man_Eating_Duck   I wonder if this thread could be stickied by a mod...   Mar 9 2005, 08:02
- - evereux   Would it be possible to split the manufacturer nam...   Mar 9 2005, 09:52
- - Martin H   Unfortunateson - It is because you are using a dif...   Mar 10 2005, 05:55
|- - westgroveg   QUOTE (Martin H @ Mar 10 2005, 04:55 PM)Unfor...   Mar 12 2005, 23:29
- - unfortunateson   sorry about the confusion... EAC reports neither t...   Mar 13 2005, 05:39
|- - westgroveg   QUOTE (unfortunateson @ Mar 13 2005, 04:39 PM...   Mar 13 2005, 07:47
- - Martin H   Unfortunateson - AccurateRip dosent check for over...   Mar 13 2005, 06:54
- - unfortunateson   ive checked, no overreading on neither   Mar 13 2005, 07:08
- - AndyMutz   Type: BenQ DVD-RW Model: DW1620 Pro Firmware: B7U9...   Mar 13 2005, 07:44
- - unfortunateson   looks good.   Mar 13 2005, 08:09
- - esa372   Manufacturer - Samsung Type - CD-RW/DVD Model - SM...   Mar 15 2005, 16:30
- - evereux   Just to keep people updated: I've now created...   Mar 17 2005, 13:14
- - Deep_Elem   Manufacturer: Samsung Type: CD-R/RW Model: SW-252B...   Mar 17 2005, 19:15
- - rutra80   I would remove the Matching column along with blue...   Mar 18 2005, 05:09
|- - evereux   QUOTE (rutra80 @ Mar 18 2005, 04:09 AM)I woul...   Mar 18 2005, 09:30
|- - westgroveg   QUOTE (rutra80 @ Mar 18 2005, 04:09 PM)I woul...   Mar 20 2005, 07:54
|- - rutra80   QUOTE (westgroveg @ Mar 20 2005, 08:54 AM)QUO...   Mar 20 2005, 08:47
|- - AndyMutz   rutra80, there is a slight misstake in your table:...   Mar 20 2005, 19:45
- - westgroveg   What I mean is that if we have a drive with an off...   Mar 20 2005, 12:59
|- - rutra80   QUOTE (westgroveg @ Mar 20 2005, 01:59 PM)Wha...   Mar 20 2005, 14:23
|- - Richard_Hsi   CODEType - SONY DVD-ROM Model - DDU1621( FIRMW...   Mar 20 2005, 17:54
|- - A_Man_Eating_Duck   QUOTE (Richard_Hsi @ Mar 20 2005, 04:54 PM)CO...   Mar 20 2005, 23:04
- - westgroveg   QUOTE (rutra80)The scoring could be like that: 1. ...   Mar 20 2005, 23:25
- - Eli   I think it would be better is there was an app to ...   Mar 21 2005, 00:46
|- - spoon   QUOTE (Eli @ Mar 20 2005, 11:46 PM)I think it...   Mar 21 2005, 12:17
|- - TCM   QUOTE (spoon @ Mar 21 2005, 06:17 AM)Accurate...   Jul 17 2005, 01:06
- - evereux   Why is the sample offset boundary of 1000 used to ...   Mar 21 2005, 10:47
- - rutra80   QUOTE (AndyMutz @ Mar 20 2005, 08:45 PM)rutra...   Mar 21 2005, 13:27
- - tas   QUOTE (westgroveg @ Mar 7 2005, 06:21 AM)This...   Mar 21 2005, 14:20
|- - westgroveg   QUOTE (tas @ Mar 22 2005, 01:20 AM)QUOTE (wes...   Mar 25 2005, 11:59
- - rutra80   Manufacturer: Philips Type: 36x (it's a CD-ROM...   Mar 27 2005, 00:15
- - DreamweaverN   CODEManufacturer - PIONEER Type - DVD-ROM Model - ...   Mar 28 2005, 05:01
- - R.A.F.   CODEManufacturer: BTC Type: DVD+-R/RW DL R...   Mar 28 2005, 05:23
- - westgroveg   Updates: -Switched to Interlaced GIF -Added positi...   Mar 31 2005, 04:03
|- - Duble0Syx   CODEManufacturer - PLEXTOR Type - CD-RW Model - PX...   Mar 31 2005, 05:58
|- - Duble0Syx   CODEManufacturer - ASUS Type - CD-RW Model - CRW-4...   Mar 31 2005, 06:09
- - VCSkier   what happened to the chart? i could see it last t...   Apr 4 2005, 06:24
|- - westgroveg   QUOTE (VCSkier @ Apr 4 2005, 05:24 PM)what ha...   Apr 4 2005, 13:35
- - VCSkier   yeah, its working fine now. thanks   Apr 5 2005, 03:23
- - JuanK   Some days ago, I submitted a new entry but i made ...   Apr 29 2005, 16:50
|- - westgroveg   QUOTE (JuanK @ Apr 30 2005, 03:50 AM)Some day...   Apr 30 2005, 08:42
|- - evereux   QUOTE (JuanK @ Apr 29 2005, 03:50 PM)Some day...   Apr 30 2005, 12:42
- - Synthetic Soul   QUOTE (rutra80 @ Mar 20 2005, 02:23 PM)QUOTE ...   Apr 30 2005, 14:56
- - HbG   Here's my contribution: CODE    Manu...   May 14 2005, 14:54
- - baldrick   Manufacturer - PIONEER Type - DVD±R/RW Recorder Mo...   May 30 2005, 15:17
- - evereux   http://www.daefeatures.co.uk has now been updated ...   Jun 12 2005, 08:57
- - Pop   Manufacturer - PIONEER Type - DVD±R/RW Recorder Mo...   Jun 12 2005, 10:08
- - WaldoMonster   Here are my two drives: Manufacturer: Asus Type: ...   Jul 17 2005, 01:31
- - micmac   Hi all, I bought a new drive 2 weeks ago and I...   Oct 30 2005, 12:22
- - landy   Type: HL-DT-STDVDRAM (it's LG) Model: GSA-4120...   Oct 30 2005, 14:04
- - evereux   I don't think it's worth posting your resu...   Oct 30 2005, 14:40
- - landy   that was supposed to be a quote of the first perso...   Oct 30 2005, 16:58
- - jhartmann   The LG/HL-DT-ST GSA-4120B as well as its relatives...   Dec 22 2005, 11:55
- - incognitu   What about the GSA-4082N? It's a slim drive (...   Jan 17 2006, 23:26
- - rutra80   AFAIK Feurio! has some more advanced caching-d...   Jan 18 2006, 09:52
|- - Mefodiy   QUOTE (rutra80 @ Jan 18 2006, 03:52 AM)AFAIK ...   Feb 19 2006, 03:59
|- - rutra80   QUOTE (Mefodiy @ Feb 19 2006, 04:59 AM)1. The...   Feb 22 2006, 22:31
|- - Mefodiy   QUOTE (rutra80 @ Feb 22 2006, 04:31 PM)... Th...   Mar 3 2006, 04:54
|- - rutra80   QUOTE (Mefodiy @ Mar 3 2006, 05:54 AM)Where i...   Mar 6 2006, 09:15
- - Mefodiy   I'd still appreciate 1,2,&3 being addresse...   Feb 22 2006, 05:38
- - DreamweaverN   QUOTE (DreamweaverN @ Mar 28 2005, 01:31 PM)C...   Mar 6 2006, 03:09
- - pike   download link is broken   Jun 24 2006, 05:33
- - Be Positive   Manufacturer: Plextor Type: DVD-ROM ...   Oct 14 2006, 19:25
- - Joshatdot   CODEManufacturer - OPTORITE Type - DVD-RW Model - ...   Dec 11 2007, 06:42
- - JoeGons   Acer Laptop.2480-2943 TSST Corp. CDW/DVD TS-L462D...   Jan 23 2008, 19:15
- - RamonSalazar   Manufacturer - PIONEER Type - DVD-RW Model - DVR-2...   May 1 2008, 20:23
- - Moitah   Samsung SH-S223Q Firmware: SB01 Caching: No Accura...   Oct 10 2008, 05:01
|- - greynol   QUOTE (Moitah @ Oct 9 2008, 21:01) HTOA: ...   Oct 10 2008, 05:11
|- - Moitah   QUOTE (greynol @ Oct 10 2008, 00:11) Soun...   Oct 10 2008, 05:17
- - greynol   Well maybe it is a yes. What happens when you try...   Oct 10 2008, 05:23
- - Moitah   I still get that bit of silence in secure mode, EA...   Oct 10 2008, 05:38
- - greynol   Any old disc should do for that test. EDIT: or new...   Oct 10 2008, 05:41
- - Moitah   EAC's offset test says "None" for ov...   Oct 11 2008, 02:32
- - ssjkakaroto   Hi guys, do you know if any new drive can overread...   Oct 23 2008, 12:04
RSS Lo-Fi Version Time is now: 25th January 2015 - 14:04
