Open Source ALAC Decoder
Bonzi
post Mar 5 2005, 20:28
A/V Moderator
Hi, David Hammerton from the ffmpeg mailing list wrote a reverse engineered ALAC decoder.
Located here is a basic decoder for Apple Lossless Audio Codec files (ALAC). ALAC is a proprietary lossless audio compression scheme. Apple never released any documents on the format.
What I provide here is a C implementation of a decoder, written from reverse engineering the file format. It turns out that most of the algorithms in the codec are fairly well known. ALAC uses an adaptive FIR prediction algorithm and stores the error values using a modified rice or golumb algorithm. Further details are in alac.c.
Although an encoder is not provided, by using the decoder as a sort of specification it should be fairly trivial to write an encoder. By exploiting other lossless audio encoders, such as FLAC, the task will be much easier. Although one wouldn't be able to copy the compression algorithms verbatim, as adaptive compression is used in ALAC and not in FLAC. There are, however, a bunch of academic papers on the issue.
The program located here will not be able to handle all ALAC files, it can only handle mono or stereo files. ALAC allows up to 8 channels. It should be trivial to finish the implementation once I find files that I can test it with. Likewise the decoder only supports 16bit sample sizes. Again, it should be trivial to fix.
The decoder is fairly self explanatory, it can read an ALAC stream from either a file or from stdin, and write it as raw PCM data or as a WAV file to either stdout or a file. In theory one should be able to stream data to the decoder.
I uploaded a binary here. Not sure about the legality of this, I will remove if necessary.
jcoalson
post Mar 5 2005, 21:26
FLAC Developer
very cool. I was about half-way done reverse engineering it last year, but I stopped when it seemed unlikely that ALAC could be converted to FLAC without reencoding. but they are very close.
apple would be crazy to go after this though, as this will help adoption of the format.
Josh
- Bonzi   Open Source ALAC Decoder   Mar 5 2005, 20:28
- - jcoalson   very cool. I was about half-way done reverse engi...   Mar 5 2005, 21:26
- - guruboolez   Very nice new I suppose that foobar2000, winamp o...   Mar 5 2005, 22:34
|- - Tec9SD   QUOTE (guruboolez @ Mar 5 2005, 04:34 PM)Very...   Mar 7 2005, 02:34
|- - yong   QUOTE (Tec9SD @ Mar 7 2005, 09:34 AM)QUOTE (g...   Mar 7 2005, 11:42
- - Bonzi   I should say that the binary that I uploaded is ju...   Mar 5 2005, 22:50
|- - guruboolez   QUOTE (Bonzi @ Mar 5 2005, 10:50 PM)I should ...   Mar 6 2005, 00:09
- - rjamorim   Amazing shit. /me goes to change the lossless com...   Mar 6 2005, 00:27
|- - guest0101   QUOTE (rjamorim @ Mar 5 2005, 04:27 PM)...   Mar 6 2005, 00:35
|- - krmathis   QUOTE (guest0101 @ Mar 6 2005, 12:35 AM)Anybo...   Mar 6 2005, 17:28
|- - rjamorim   QUOTE (solaris @ Mar 6 2005, 01:28 PM)I'v...   Mar 6 2005, 17:34
|- - krmathis   QUOTE (rjamorim @ Mar 6 2005, 05:34 PM)Sweet....   Mar 6 2005, 18:08
- - Mike Giacomelli   I think under MacOS you could just unzip it, brows...   Mar 6 2005, 02:37
|- - guest0101   QUOTE (Mike Giacomelli @ Mar 5 2005, 06:37 PM...   Mar 6 2005, 03:42
|- - Dibrom   QUOTE (guest0101 @ Mar 5 2005, 06:42 PM)QUOTE...   Mar 6 2005, 04:00
|- - guest0101   QUOTE (Dibrom @ Mar 5 2005, 08:00 PM)You need...   Mar 6 2005, 05:28
- - svkelley   It would be great to also extract the tags and the...   Mar 6 2005, 03:26
- - JEN   QUOTE (rjamorim @ Mar 6 2005, 12:27 AM)...   Mar 6 2005, 09:55
|- - rjamorim   QUOTE (JEN @ Mar 6 2005, 05:55 AM)When will t...   Mar 6 2005, 16:09
- - ffooky   On my 1.25 gHz/ 768MB eMac it seems significantly...   Mar 6 2005, 12:56
- - Latexxx   This hasn't been optimised in any way. So it i...   Mar 6 2005, 13:01
- - JEN   QUOTE (rjamorim @ Mar 6 2005, 04:09 PM)QUOTE ...   Mar 6 2005, 16:35
- - jcoalson   just got finished looking over the decoder source....   Mar 6 2005, 21:24
|- - Tang   QUOTE (jcoalson @ Mar 6 2005, 12:24 PM)just g...   Mar 7 2005, 11:50
|- - Busemann   QUOTE (jcoalson @ Mar 6 2005, 12:24 PM)what...   Mar 7 2005, 12:43
|- - jcoalson   QUOTE (Busemann @ Mar 7 2005, 06:43 AM)Well, ...   Mar 7 2005, 16:45
|- - guest0101   Uh, oh, now the news outlets just released a story...   Mar 7 2005, 18:09
- - AtaqueEG   Do you think we will see software implementation (...   Mar 6 2005, 21:53
- - guest0101   Well it appears that news sources are quoting/meti...   Mar 7 2005, 15:39
- - xmixahlx   this wasn't not mentioned here, and i thought ...   Mar 7 2005, 21:17
- - yong   Did someone know? Mplayer(Daily CVS version) now i...   Apr 2 2005, 10:38
- - keytotime   Could somebody please compile the latest version f...   Oct 26 2006, 01:13
- - kurtnoise   For windows I guess ? http://kurtnoise.free.fr/in...   Oct 26 2006, 09:19
- - john33   Updated Win32 compiles at Rarewares Lossless page ...   Oct 26 2006, 09:48
- - keytotime   Wow That was Fast. Thank You.   Oct 26 2006, 12:19
RSS Lo-Fi Version Time is now: 6th March 2015 - 10:05
