Toaster for Fb2k, The port of the Winamp Toaster plugin
shaneh
post Feb 21 2005, 01:53
Discussion about the Toaster plugin, continued from:
http://www.hydrogenaudio.org/forums/index....ndpost&p=275216
Current version is 0.1.6 (http://www.myplugins.info), updated 5/03/2005
The Toaster plugin is a port from the Toaster for Winamp plugin:
http://www.winamp.com/plugins/details.php?id=138586
and http://forums.winamp.com/showthread.php?s=&threadid=207630
As the port was done in about 20 minutes, there is still quite a bit of development to be done to get it working smoothly under fb2k.
FAQ
Where is the Foobar 2000 0.9 port?
Porting to fb2k 0.9 would require a fair amount of work, due to the fact Toaster is not native unicode. I am planning a complete rewrite of Toaster, which should be a lot nicer. It should allow tiling custom skins, progress bars, buttons etc, and proper skin packaging support. So I wont bother porting this version of Toaster across, as it needs to be re-written anyway.
This post has been edited by shaneh: May 12 2006, 00:31
[url=http://www.myplugins.info/]Music Plugins[/url]
war59312
post Mar 11 2005, 05:19
I am trying to get this to work with shoutcast as well.
Ok I am getting the pop up with correct info but still in msn it just shows the name of the shoutcast server. Its not chaning dynamicly?
How can I get it to work correctly?
See what I mean:
Thanks,
Will
This post has been edited by war59312: Mar 11 2005, 05:25
God Bless U.S.A
- shaneh   Toaster for Fb2k   Feb 21 2005, 01:53
- - banjobacon   I'll just paste what I wrote in the other thre...   Feb 21 2005, 01:58
- - MrEnergizer   Yeah I got the same errors. Removed Toaster and th...   Feb 21 2005, 02:01
- - shaneh   @badrad, kl33per, synth7: The configuration should...   Feb 21 2005, 02:30
- - shaneh   @alphaex32: I havent fully tested the id3v2 image ...   Feb 21 2005, 02:34
|- - alphaex32   QUOTE (shaneh @ Feb 20 2005, 08:34 PM)@alphae...   Feb 21 2005, 16:02
- - shaneh   @eliazu: I will fix up the utf8 etc stuff in a fut...   Feb 21 2005, 02:51
|- - eliazu   QUOTE (shaneh @ Feb 21 2005, 03:51 AM)@eliazu...   Feb 21 2005, 17:49
- - shaneh   @Skates: It currently just uses the first ID3FID_...   Feb 21 2005, 03:09
|- - Skates   QUOTE (shaneh @ Feb 20 2005, 08:09 PM)@Skates...   Feb 21 2005, 03:55
- - shaneh   Could you try using the winamp Toaster plugin and ...   Feb 21 2005, 05:30
|- - Skates   QUOTE (shaneh @ Feb 20 2005, 10:30 PM)Could y...   Feb 21 2005, 06:09
- - spaceships   what xp theme are you using?   Feb 21 2005, 05:57
- - aliumalik   Excellent working shaneh! this might be a sill...   Feb 21 2005, 06:10
- - shaneh   @Skates: I'll take a look when it comes throug...   Feb 21 2005, 06:22
- - aliumalik   shaneh from toaster's settings I figured you k...   Feb 21 2005, 07:50
|- - Mike Giacomelli   QUOTE (aliumalik @ Feb 20 2005, 10:50 PM)shan...   Feb 21 2005, 19:46
|- - Skates   QUOTE (Mike Giacomelli @ Feb 21 2005, 12:46 P...   Feb 21 2005, 20:03
|- - anza   QUOTE (Skates @ Feb 21 2005, 09:03 PM)QUOTE (...   Feb 21 2005, 20:42
- - shaneh   @skates: That file you sent me showed the cover im...   Feb 21 2005, 08:44
|- - Skates   QUOTE (shaneh @ Feb 21 2005, 01:44 AM)@skates...   Feb 21 2005, 15:13
- - shaneh   Ive fixed up the support for ID3v2 cover images an...   Feb 21 2005, 12:59
- - shaneh   alphaex32: Have you tried the new version I posted...   Feb 21 2005, 16:16
|- - Skates   QUOTE (shaneh @ Feb 21 2005, 09:16 AM)@Skates...   Feb 21 2005, 16:31
|- - alphaex32   QUOTE (shaneh @ Feb 21 2005, 10:16 AM)alphaex...   Feb 21 2005, 16:47
- - shaneh   Why am I having that problem so much? Ive havent e...   Feb 21 2005, 17:02
|- - Skates   QUOTE (shaneh @ Feb 21 2005, 10:02 AM)@Skates...   Feb 21 2005, 17:42
- - Canar   foobar2000 will remove cover art when the tag is a...   Feb 21 2005, 18:10
- - banjobacon   Well, my latest crash came when I double clicked m...   Feb 21 2005, 18:54
- - aliumalik   shaneh your plugin is open source right? Why not h...   Feb 21 2005, 19:19
- - banjobacon   You could also upload your plugin to the 3rd party...   Feb 21 2005, 19:28
- - Biscuits   Hey, I got the latest version (.zip file worked...   Feb 21 2005, 19:30
- - rossthiof   Seems there is a problem with displaying album cov...   Feb 21 2005, 21:36
- - shaneh   I think I may have found the cause of at least one...   Feb 22 2005, 01:13
|- - ssamadhi97   QUOTE (shaneh @ Feb 22 2005, 01:13 AM)Id be m...   Feb 22 2005, 02:06
- - shaneh   Maybe so, but if you want to keep statistics in th...   Feb 22 2005, 02:18
|- - aliumalik   QUOTE (shaneh @ Feb 22 2005, 06:18 AM)Maybe s...   Feb 22 2005, 12:30
|- - Mike Giacomelli   QUOTE (shaneh @ Feb 21 2005, 05:18 PM)Regardl...   Feb 22 2005, 21:20
|- - Skates   QUOTE (Mike Giacomelli @ Feb 22 2005, 02:20 P...   Feb 22 2005, 22:23
- - amppa   QUOTE (shaneh @ Feb 20 2005, 08:23 AM)All dow...   Feb 22 2005, 11:16
- - A_Man_Eating_Duck   is there any chance of getting support for multipl...   Feb 22 2005, 11:50
- - shaneh   A_Man_Eating_Duck: You can separate strings by ; a...   Feb 22 2005, 12:23
|- - A_Man_Eating_Duck   QUOTE (shaneh @ Feb 22 2005, 11:23 AM)A_Man_E...   Feb 22 2005, 12:31
- - shaneh   @rossthiof+eliazu: try the new 0.1.3 version and s...   Feb 22 2005, 17:06
- - rossthiof   I'm on the way to test it, but there is one pr...   Feb 22 2005, 17:35
- - banjobacon   I downloaded a file with Toaster skins from the Wi...   Feb 22 2005, 18:01
- - eliazu   hebrew covers and fonts are displayed great now on...   Feb 22 2005, 18:41
- - Duble0Syx   I've just dl v 0.1.3 and now I get the "c...   Feb 22 2005, 18:41
- - dano   you can get the 2 dll's needed for debug versi...   Feb 22 2005, 19:35
- - Duble0Syx   Could someone maybe mirror the files? The 7zip fi...   Feb 22 2005, 23:52
- - sPeziFisH   uuh, always the same - those pissy installers some...   Feb 24 2005, 12:22
- - shaneh   @sPeziFish: What? Is that a reply to a post that ...   Feb 24 2005, 13:15
- - sPeziFisH   no shaneh, my brain misled me (once again, damn ch...   Feb 24 2005, 13:32
- - eliazu   how do i move the cover a little left so it wont b...   Feb 26 2005, 22:58
- - shaneh   Use the right border padding ®.   Feb 27 2005, 03:14
- - kpolice   I keep getting ERROR (CORE) : Failed to load DLL: ...   Feb 27 2005, 03:46
- - shaneh   Try the release version instead, it doesnt use the...   Feb 27 2005, 04:47
- - kpolice   I cant open the 7z file, tried with WinRAR and 7zi...   Feb 27 2005, 05:52
|- - 4nt1   QUOTE (kpolice @ Feb 27 2005, 02:52 PM)I cant...   Feb 27 2005, 06:33
- - shaneh   The hydrogen forums cant handle attachments for wh...   Feb 27 2005, 06:42
- - spase   @shaneh: i would be happy to mirror the plugin on ...   Feb 27 2005, 17:19
- - bukem   is there any way to display dynamic data on toast ...   Feb 27 2005, 20:00
|- - Duble0Syx   I think it would be useful to allow for wildcards ...   Feb 27 2005, 21:11
- - shaneh   @spase: I have site space and domain etc, just hav...   Feb 28 2005, 14:18
- - eliazu   where can i get skins for the toaster?   Feb 28 2005, 17:06
- - BlueDev   First off, amazingly cool plugin. I love this. B...   Mar 1 2005, 03:36
- - shaneh   See reply to @bukem. The only way Ive seen plugi...   Mar 1 2005, 03:59
|- - foosion   QUOTE (shaneh @ Mar 1 2005, 03:59 AM)There sh...   Mar 1 2005, 10:40
|- - eliazu   QUOTE (shaneh @ Mar 1 2005, 04:59 AM)@eliazu:...   Mar 1 2005, 11:33
- - bukem   QUOTE play_callback::on_playback_time() is called ...   Mar 1 2005, 11:55
- - shaneh   yeah, that works ok. I noticed it when I bothered ...   Mar 1 2005, 13:04
- - shaneh   Please see: http://www.myplugins.info for download...   Mar 1 2005, 13:38
|- - Skates   QUOTE (shaneh @ Mar 1 2005, 06:38 AM)Please s...   Mar 1 2005, 22:41
- - bukem   thank you shaneh - this's what i was waiting f...   Mar 1 2005, 19:02
- - kalmark   Use %_time_elapsed% instead.   Mar 1 2005, 23:41
|- - BlueDev   QUOTE (kalmark @ Mar 1 2005, 06:41 PM)Use %_t...   Mar 5 2005, 19:07
- - SNAG   Sorry for being a real n00b, but how do I change t...   Mar 2 2005, 16:37
- - shaneh   Now updated for MSN Messenger 7.0.0632 support. No...   Mar 4 2005, 06:46
- - Superunknown   no more transparency on the new version ? before ...   Mar 4 2005, 13:56
- - shaneh   Ive resolved the aa text problem, but am not sure ...   Mar 4 2005, 15:05
- - Superunknown   thank you very much ! tell me when the correct...   Mar 4 2005, 15:19
- - shaneh   The problem should hopefully be fixed in 0.1.6 up ...   Mar 4 2005, 15:41
- - Superunknown   it works very well now ! thanks and congrats f...   Mar 4 2005, 16:46
- - kalmark   I use %_time_elapsed%/%_length% and it works as in...   Mar 5 2005, 19:12
- - BlueDev   That was the trick kalmark. Thanks so much for th...   Mar 5 2005, 20:06
- - Superunknown   what about a functionnality that automatically dis...   Mar 7 2005, 15:51
- - Hawk   I can't seem to find the configuration. I thin...   Mar 8 2005, 00:22
|- - synth7   QUOTE (Hawk @ Mar 7 2005, 06:22 PM)I can...   Mar 8 2005, 02:29
|- - Hawk   QUOTE (synth7 @ Mar 8 2005, 03:29 AM)QUOTE (H...   Mar 8 2005, 09:30
|- - mixcherry   You can add it by yourself: Preferences -> Core...   Mar 8 2005, 12:14
|- - Hawk   QUOTE (mixcherry @ Mar 8 2005, 01:14 PM)You c...   Mar 8 2005, 12:56
- - waileongyeo   This is really a great plugin for foobar2000. Than...   Mar 10 2005, 10:31
- - war59312   I am trying to get this to work with shoutcast as ...   Mar 11 2005, 05:19
- - shaneh   @waileongyeo: I have this already coded for the wi...   Mar 11 2005, 06:26
|- - XQC   I don't know if this was suggested before but ...   Mar 13 2005, 01:00
- - war59312   Dang. Dont know, but foo_osd.dll does it some how...   Mar 13 2005, 02:44
- - war59312   Well, I have also notice if you launch MSN Messeng...   Mar 13 2005, 21:52
- - waileongyeo   Dear friends, I found this free program is qu...   Mar 14 2005, 06:50
- - shaneh   @war59312: Thats expected behaviour and won't ...   Mar 14 2005, 09:59
- - Lyx   Hmm, would it involve much effort to make this wor...   Mar 15 2005, 00:30
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 6th May 2015 - 00:00
