Toaster For Foobar2000, Based on Toaster for Winamp 0.7
shaneh
post Feb 20 2005, 06:23
Ive ported most of Toaster for Winamp across to Foobar2000. It was suprisingly easy, the modular design I used from the start paid off I guess.
A couple things might be a little sketchy. Remember you need id3lib.dll if you want id3v2 cover images to work.
Also remember you should remove foo_msn if you are using the msn title updates in this plugin, otherwise disable them in Toaster.
Please see http://www.myplugins.info for downloads and info.
Discussion here: http://www.hydrogenaudio.org/forums/index....showtopic=31695
This post has been edited by shaneh: Mar 1 2005, 13:36
[url=http://www.myplugins.info/]Music Plugins[/url]
shaneh
post Feb 20 2005, 07:37
hmm, not sure. I am simply using
metadb_handle *track = play_control::get()->get_now_playing();
to get the track for the title formatting and path retrieval etc. Or just using the handle passed in the play_callback on new track callback (as seen in the source to foo_msn). Does anyone know why this might not work for some people? I saw someone else had a similar problem with the foo_msn plugin.
If you delete Toaster.ini in the foobar directory (or profile directory) it should revert to some working defaults.
This post has been edited by shaneh: Feb 20 2005, 07:39
4nt1
post Feb 20 2005, 08:00
QUOTE (shaneh @ Feb 20 2005, 04:37 PM)
ok now narrowed it down to the naming of the files of album covers, i need to simply work out a better script to choose file names,i can grab one from coverart plugin.
i worked out the glitches i had..
problem is foreground and background dont make logical sense, i was setting bg as the bg, fg as another layer on top of the bg, then changing the shadow colour thinking it was font colour, so i was making the text invisible cause of colours choices, i now have it working the way i want... more or less...
any new options coming in new versions?
- shaneh   Toaster For Foobar2000   Feb 20 2005, 06:23
- - 4nt1   cant wait to try out... been looking forward to s...   Feb 20 2005, 06:42
|- - 4nt1   QUOTE (4nt1 @ Feb 20 2005, 03:42 PM)cant wait...   Feb 20 2005, 06:57
|- - 4nt1   QUOTE (4nt1 @ Feb 20 2005, 03:57 PM)QUOTE (4n...   Feb 20 2005, 07:32
- - shaneh   It uses folder.jpg or whatever other file you spec...   Feb 20 2005, 07:00
- - shaneh   hmm, not sure. I am simply using metadb_handle *t...   Feb 20 2005, 07:37
|- - 4nt1   QUOTE (shaneh @ Feb 20 2005, 04:37 PM)hmm, no...   Feb 20 2005, 08:00
- - shaneh   0.1 *is* the new version. It is based on the winam...   Feb 20 2005, 08:08
- - Hidea   will this have a support for MSGPlus! Plugins ...   Feb 20 2005, 08:58
- - JEN   this is cool where can we get skins for it? than...   Feb 20 2005, 09:41
- - outie   Hi, can you please add support for unicode charact...   Feb 20 2005, 10:05
- - JEN   I have ratings for my tracks. how do i display th...   Feb 20 2005, 10:19
- - shaneh   @JEN, outie: Do you have that support in the systr...   Feb 20 2005, 11:01
- - badrad   Nice to see you developing for foobar Shaneh! ...   Feb 20 2005, 12:27
- - JEN   I can get the rating to display using the %rating%...   Feb 20 2005, 12:48
- - shaneh   You won't be able to display those dynamic cir...   Feb 20 2005, 13:07
|- - foosion   QUOTE (shaneh @ Feb 20 2005, 01:07 PM)@outie:...   Feb 20 2005, 19:38
- - JEN   Yes I am after basic static circles or stars Than...   Feb 20 2005, 13:18
- - dano   JEN: you can enter some thing like $if(%ratin...   Feb 20 2005, 13:25
- - JEN   dano - thanks!   Feb 20 2005, 13:44
- - shaneh   I will hopefully update this plugin to be more in ...   Feb 20 2005, 14:29
- - MrEnergizer   Thanx Shaneh nice work Might be nice if you cou...   Feb 20 2005, 15:27
- - m-z   Wow, this thing is amazing. Thank you shaneh.   Feb 20 2005, 16:03
- - eliazu   hi! big problem with hebrew. its not possible ...   Feb 20 2005, 16:11
- - alphaex32   have any of you gotten id3 tag cover art to show u...   Feb 20 2005, 18:33
- - kl33per   I also have the same problem as badrad. I cannot ...   Feb 20 2005, 18:47
|- - synth7   QUOTE (kl33per @ Feb 20 2005, 12:47 PM)I also...   Feb 20 2005, 18:57
|- - alphaex32   QUOTE (kl33per @ Feb 20 2005, 12:47 PM)I also...   Feb 20 2005, 22:20
|- - aliumalik   Excellent working shaneh! this might be a sill...   Feb 20 2005, 22:37
|- - kpolice   QUOTE (aliumalik @ Feb 20 2005, 03:37 PM)Exce...   Feb 21 2005, 00:06
- - banjobacon   Nice plugin. However, I'm pretty sure it's...   Feb 20 2005, 19:51
|- - 4nt1   QUOTE (banjobacon @ Feb 21 2005, 04:51 AM)Nic...   Feb 20 2005, 21:49
- - Skates   Any chance of setting definable tag field name for...   Feb 21 2005, 00:24
- - badrad   QUOTE (alphaex32 @ Feb 20 2005, 01:20 PM)our ...   Feb 21 2005, 00:30
|- - synth7   QUOTE (badrad @ Feb 20 2005, 06:30 PM)QUOTE (...   Feb 21 2005, 01:29
- - Biscuits   I don't think there's an option already fo...   Feb 21 2005, 00:35
- - banjobacon   Edit: Post moved to new thread.   Feb 21 2005, 01:35
- - shaneh   Please use http://www.hydrogenaudio.org/forums/ind...   Feb 21 2005, 01:57
- - spase   i am having trouble with the downloads. what vers...   Feb 24 2005, 13:18
- - ChaosBladE   Same here, tried with latest 7zip and WinRAR, both...   Feb 28 2005, 16:23
|- - hunted   QUOTE (ChaosBladE @ Feb 28 2005, 07:23 AM)Sam...   Feb 28 2005, 19:51
- - ChaosBladE   Yup, that one worked. attaching it here aswell :   Feb 28 2005, 21:00
- - dimatrod   How can I make it appear when I press pause/play? ...   Oct 19 2005, 03:39
- - vendis   I have a problem with the plugin. I'm new here...   Jun 16 2006, 17:37
RSS Lo-Fi Version Time is now: 31st January 2015 - 05:32
