Toaster For Foobar2000, Based on Toaster for Winamp 0.7
shaneh
post Feb 20 2005, 06:23
Ive ported most of Toaster for Winamp across to Foobar2000. It was suprisingly easy, the modular design I used from the start paid off I guess.
A couple things might be a little sketchy. Remember you need id3lib.dll if you want id3v2 cover images to work.
Also remember you should remove foo_msn if you are using the msn title updates in this plugin, otherwise disable them in Toaster.
Please see http://www.myplugins.info for downloads and info.
Discussion here: http://www.hydrogenaudio.org/forums/index....showtopic=31695
This post has been edited by shaneh: Mar 1 2005, 13:36
[url=http://www.myplugins.info/]Music Plugins[/url]
kl33per
post Feb 20 2005, 18:47
A/V Moderator
I also have the same problem as badrad. I cannot see the Toaster config under the components menu. The only thing I can think of is some kind of conflict with another plugin. Like badrad, it loads fine and displays on track change. I don't have the extra dll installed as I don't need id3v2 support.
www.sessions.com.au - Sessions Entertainment
alphaex32
post Feb 20 2005, 22:20
QUOTE (kl33per @ Feb 20 2005, 12:47 PM)
Check your components menu. I got confused at first also.
This post has been edited by alphaex32: Feb 20 2005, 22:20
wortels
post Feb 20 2005, 22:37
Group: Banned
Excellent working shaneh!
this might be a silly request (memory freak sad.gif) but is it possible that after the toast fades out the ram usage can be returned to normal?
Thanks for an excellent plugin
kpolice
post Feb 21 2005, 00:06
QUOTE (aliumalik @ Feb 20 2005, 03:37 PM)
Mine is using 3Mb minimized and 6MB maximized with the plugin.
Great plugin THX.
- shaneh   Toaster For Foobar2000   Feb 20 2005, 06:23
- - 4nt1   cant wait to try out... been looking forward to s...   Feb 20 2005, 06:42
|- - 4nt1   QUOTE (4nt1 @ Feb 20 2005, 03:42 PM)cant wait...   Feb 20 2005, 06:57
|- - 4nt1   QUOTE (4nt1 @ Feb 20 2005, 03:57 PM)QUOTE (4n...   Feb 20 2005, 07:32
- - shaneh   It uses folder.jpg or whatever other file you spec...   Feb 20 2005, 07:00
- - shaneh   hmm, not sure. I am simply using metadb_handle *t...   Feb 20 2005, 07:37
|- - 4nt1   QUOTE (shaneh @ Feb 20 2005, 04:37 PM)hmm, no...   Feb 20 2005, 08:00
- - shaneh   0.1 *is* the new version. It is based on the winam...   Feb 20 2005, 08:08
- - Hidea   will this have a support for MSGPlus! Plugins ...   Feb 20 2005, 08:58
- - JEN   this is cool where can we get skins for it? than...   Feb 20 2005, 09:41
- - outie   Hi, can you please add support for unicode charact...   Feb 20 2005, 10:05
- - JEN   I have ratings for my tracks. how do i display th...   Feb 20 2005, 10:19
- - shaneh   @JEN, outie: Do you have that support in the systr...   Feb 20 2005, 11:01
- - badrad   Nice to see you developing for foobar Shaneh! ...   Feb 20 2005, 12:27
- - JEN   I can get the rating to display using the %rating%...   Feb 20 2005, 12:48
- - shaneh   You won't be able to display those dynamic cir...   Feb 20 2005, 13:07
|- - foosion   QUOTE (shaneh @ Feb 20 2005, 01:07 PM)@outie:...   Feb 20 2005, 19:38
- - JEN   Yes I am after basic static circles or stars Than...   Feb 20 2005, 13:18
- - dano   JEN: you can enter some thing like $if(%ratin...   Feb 20 2005, 13:25
- - JEN   dano - thanks!   Feb 20 2005, 13:44
- - shaneh   I will hopefully update this plugin to be more in ...   Feb 20 2005, 14:29
- - MrEnergizer   Thanx Shaneh nice work Might be nice if you cou...   Feb 20 2005, 15:27
- - m-z   Wow, this thing is amazing. Thank you shaneh.   Feb 20 2005, 16:03
- - eliazu   hi! big problem with hebrew. its not possible ...   Feb 20 2005, 16:11
- - alphaex32   have any of you gotten id3 tag cover art to show u...   Feb 20 2005, 18:33
- - kl33per   I also have the same problem as badrad. I cannot ...   Feb 20 2005, 18:47
|- - synth7   QUOTE (kl33per @ Feb 20 2005, 12:47 PM)I also...   Feb 20 2005, 18:57
|- - alphaex32   QUOTE (kl33per @ Feb 20 2005, 12:47 PM)I also...   Feb 20 2005, 22:20
|- - aliumalik   Excellent working shaneh! this might be a sill...   Feb 20 2005, 22:37
|- - kpolice   QUOTE (aliumalik @ Feb 20 2005, 03:37 PM)Exce...   Feb 21 2005, 00:06
- - banjobacon   Nice plugin. However, I'm pretty sure it's...   Feb 20 2005, 19:51
|- - 4nt1   QUOTE (banjobacon @ Feb 21 2005, 04:51 AM)Nic...   Feb 20 2005, 21:49
- - Skates   Any chance of setting definable tag field name for...   Feb 21 2005, 00:24
- - badrad   QUOTE (alphaex32 @ Feb 20 2005, 01:20 PM)our ...   Feb 21 2005, 00:30
|- - synth7   QUOTE (badrad @ Feb 20 2005, 06:30 PM)QUOTE (...   Feb 21 2005, 01:29
- - Biscuits   I don't think there's an option already fo...   Feb 21 2005, 00:35
- - banjobacon   Edit: Post moved to new thread.   Feb 21 2005, 01:35
- - shaneh   Please use http://www.hydrogenaudio.org/forums/ind...   Feb 21 2005, 01:57
- - spase   i am having trouble with the downloads. what vers...   Feb 24 2005, 13:18
- - ChaosBladE   Same here, tried with latest 7zip and WinRAR, both...   Feb 28 2005, 16:23
|- - hunted   QUOTE (ChaosBladE @ Feb 28 2005, 07:23 AM)Sam...   Feb 28 2005, 19:51
- - ChaosBladE   Yup, that one worked. attaching it here aswell :   Feb 28 2005, 21:00
- - dimatrod   How can I make it appear when I press pause/play? ...   Oct 19 2005, 03:39
- - vendis   I have a problem with the plugin. I'm new here...   Jun 16 2006, 17:37
RSS Lo-Fi Version Time is now: 3rd May 2015 - 20:13
