Toaster For Foobar2000, Based on Toaster for Winamp 0.7
shaneh
post Feb 20 2005, 06:23
Ive ported most of Toaster for Winamp across to Foobar2000. It was suprisingly easy, the modular design I used from the start paid off I guess.
A couple things might be a little sketchy. Remember you need id3lib.dll if you want id3v2 cover images to work.
Also remember you should remove foo_msn if you are using the msn title updates in this plugin, otherwise disable them in Toaster.
Please see http://www.myplugins.info for downloads and info.
Discussion here: http://www.hydrogenaudio.org/forums/index....showtopic=31695
This post has been edited by shaneh: Mar 1 2005, 13:36
[url=http://www.myplugins.info/]Music Plugins[/url]
shaneh
post Feb 20 2005, 11:01
@JEN, outie: Do you have that support in the systray balloon tip? If not, then Toaster will also not have the support. It uses the same method for obtaining meta data.
EDIT: I have slightly fixed the way meta data retrieval works so you can use things like time elapsed etc. But it doesnt fix the unicode support.
@Hidea: This is a plugin for foobar2000 and winamp, not msgplus.
@JEN: skins are nothing more than images in toaster, unless you want to use winamp style skins. Grab any gen.bmp from a classic skin and name it "toast.bmp" and put it in your foobar directory. Turn on "winamp skin" and "borders".
Download Toaster 0.6 for winamp to see more info on the plugin
This post has been edited by shaneh: Feb 20 2005, 11:25
- shaneh   Toaster For Foobar2000   Feb 20 2005, 06:23
- - 4nt1   cant wait to try out... been looking forward to s...   Feb 20 2005, 06:42
|- - 4nt1   QUOTE (4nt1 @ Feb 20 2005, 03:42 PM)cant wait...   Feb 20 2005, 06:57
|- - 4nt1   QUOTE (4nt1 @ Feb 20 2005, 03:57 PM)QUOTE (4n...   Feb 20 2005, 07:32
- - shaneh   It uses folder.jpg or whatever other file you spec...   Feb 20 2005, 07:00
- - shaneh   hmm, not sure. I am simply using metadb_handle *t...   Feb 20 2005, 07:37
|- - 4nt1   QUOTE (shaneh @ Feb 20 2005, 04:37 PM)hmm, no...   Feb 20 2005, 08:00
- - shaneh   0.1 *is* the new version. It is based on the winam...   Feb 20 2005, 08:08
- - Hidea   will this have a support for MSGPlus! Plugins ...   Feb 20 2005, 08:58
- - JEN   this is cool where can we get skins for it? than...   Feb 20 2005, 09:41
- - outie   Hi, can you please add support for unicode charact...   Feb 20 2005, 10:05
- - JEN   I have ratings for my tracks. how do i display th...   Feb 20 2005, 10:19
- - shaneh   @JEN, outie: Do you have that support in the systr...   Feb 20 2005, 11:01
- - badrad   Nice to see you developing for foobar Shaneh! ...   Feb 20 2005, 12:27
- - JEN   I can get the rating to display using the %rating%...   Feb 20 2005, 12:48
- - shaneh   You won't be able to display those dynamic cir...   Feb 20 2005, 13:07
|- - foosion   QUOTE (shaneh @ Feb 20 2005, 01:07 PM)@outie:...   Feb 20 2005, 19:38
- - JEN   Yes I am after basic static circles or stars Than...   Feb 20 2005, 13:18
- - dano   JEN: you can enter some thing like $if(%ratin...   Feb 20 2005, 13:25
- - JEN   dano - thanks!   Feb 20 2005, 13:44
- - shaneh   I will hopefully update this plugin to be more in ...   Feb 20 2005, 14:29
- - MrEnergizer   Thanx Shaneh nice work Might be nice if you cou...   Feb 20 2005, 15:27
- - m-z   Wow, this thing is amazing. Thank you shaneh.   Feb 20 2005, 16:03
- - eliazu   hi! big problem with hebrew. its not possible ...   Feb 20 2005, 16:11
- - alphaex32   have any of you gotten id3 tag cover art to show u...   Feb 20 2005, 18:33
- - kl33per   I also have the same problem as badrad. I cannot ...   Feb 20 2005, 18:47
|- - synth7   QUOTE (kl33per @ Feb 20 2005, 12:47 PM)I also...   Feb 20 2005, 18:57
|- - alphaex32   QUOTE (kl33per @ Feb 20 2005, 12:47 PM)I also...   Feb 20 2005, 22:20
|- - aliumalik   Excellent working shaneh! this might be a sill...   Feb 20 2005, 22:37
|- - kpolice   QUOTE (aliumalik @ Feb 20 2005, 03:37 PM)Exce...   Feb 21 2005, 00:06
- - banjobacon   Nice plugin. However, I'm pretty sure it's...   Feb 20 2005, 19:51
|- - 4nt1   QUOTE (banjobacon @ Feb 21 2005, 04:51 AM)Nic...   Feb 20 2005, 21:49
- - Skates   Any chance of setting definable tag field name for...   Feb 21 2005, 00:24
- - badrad   QUOTE (alphaex32 @ Feb 20 2005, 01:20 PM)our ...   Feb 21 2005, 00:30
|- - synth7   QUOTE (badrad @ Feb 20 2005, 06:30 PM)QUOTE (...   Feb 21 2005, 01:29
- - Biscuits   I don't think there's an option already fo...   Feb 21 2005, 00:35
- - banjobacon   Edit: Post moved to new thread.   Feb 21 2005, 01:35
- - shaneh   Please use http://www.hydrogenaudio.org/forums/ind...   Feb 21 2005, 01:57
- - spase   i am having trouble with the downloads. what vers...   Feb 24 2005, 13:18
- - ChaosBladE   Same here, tried with latest 7zip and WinRAR, both...   Feb 28 2005, 16:23
|- - hunted   QUOTE (ChaosBladE @ Feb 28 2005, 07:23 AM)Sam...   Feb 28 2005, 19:51
- - ChaosBladE   Yup, that one worked. attaching it here aswell :   Feb 28 2005, 21:00
- - dimatrod   How can I make it appear when I press pause/play? ...   Oct 19 2005, 03:39
- - vendis   I have a problem with the plugin. I'm new here...   Jun 16 2006, 17:37
RSS Lo-Fi Version Time is now: 3rd September 2015 - 15:10
