Navigator-Suite Feedback, questions, bug-reports or just chatting
Lyx
post Feb 14 2005, 01:28
Intro
This thread is for feedback, bug-reports or just chatting about "Navigator", a playlist design for Columns UI.
The layout is very modular and can easily be adapted to suit your needs - here is a screenshot which shows a few possibilities of what you can do with it:
Description
  • usually just works, no matter what you throw at it
  • (optional) advanced tag-guess-code
  • modular layout: you can enable/disable most columns without screwing up the design
  • Singlemode and Albummode (with configurable priority). No last-track tags necessary for albummode(with an obvious naming-scheme Albummode even works with no tags at all!).
  • supports the following non-id3v1-tags: discnumber, album artist, conductor, performer, publisher, style, play_counter, first_played, last_played, rating, album rating, encodedby
  • multiline display of comment-tags in albummode
  • efficient and flexible use of available space in albummode - no line gets wasted.
  • advanced playback-stats(requires a standards-compliant play_count-plugin (not the one available from the fb2k-site))
  • basic inline-metadata editing capabilities (edit your tags right in the playlist)
  • "Metadata-Matrix"-column for a better overview of which files in your collection have which tags
  • intelligent column-based sorting of files: sort by completeness of tags, sort by rating+genres, etc.
  • very easy to configure
  • comes with multiple premade color-schemes and the ability to easily create your own ones
  • includes an advanced copystring which makes use of the same tag-guess-code. Amount of copied data easily configurable.
  • can be made to occupy less than 25% screenspace on 1024x768
Download
Current version for foobar 0.9.x:
Old version for foobar 0.8.3:
Important!: You need columns_ui for this to work.
About feature-proposals
I currently have no interest in feature-proposals. This is because i consider the 1.x.x line of Navigator finished. Bug-reports however are welcome.
_______________________________________________________________
Changelog:
1.4.3 (foobar 0.9.x compatible)
- fixed display of singles in albummode for tracks with no ARTIST
- the "artist & album"-column now uses ARTIST instead of ALBUM for inline-metadata editing
- added new colorscheme by 4nt1
1.4.2
- moved albummode STYLE-display into a seperate line
- Tracks which have TOTALTRACKS=1 are now also considered singles
- fixed inverted colors in albummode when displaying: performer, conductor, publisher
1.4.1
- fixed wrong upload (STYLE didn't work)
1.4.0
- compatible with foobar 0.9 and the coresponding ui-columns (no need for legacy mode)
- improved performance by making use of new ui-columns style-features to reduce codesize
- sorting by all kinds of playback-stats works correct now
- added full support for the recently standardized STYLE-tag
- added basic support for inline-metadata editing
- redesigned hybrid-mode
- fixed statusbar display-errors when using RTL-languages
- when enqueueing audio-cds, albummode is now automatically activated
- properly honors the new field-remappings
- many bugfixes and code cleanup
- misc changes to the how-to docs
- probably some other stuff which i forgot
1.3.2 (foobar 0.8.3 compatible)
- bugfix: "daily plays"-column did show wrong values.
- last version for fb2k 0.8.3
1.3.1
- bugfix: in the "daily plays"-column, tracks which were played today the first time would show strange ratios
- finally replaced the ancient screenshot with an up-to-date one
1.3.0 - full support for the new playcount-plugin
- added "plays per day"-stats (new playcounter-plugin required for it to show up). You cannot sort by it yet.
- added first_played-column (new playcounter-plugin required for it to work).
- moved replaygain-indicators from the metadata-matrix into a seperate column
- dropped configurability of the seperator-char, since almost nobody used it anyways
- sorting-code polishing: you can now correctly sort by multiple columns (like for example first sorting by the album-column, and then sorting by rating)
This post has been edited by Lyx: May 21 2006, 15:19
addicted
post Feb 18 2005, 23:16
I'm not sure if this is possible with columns UI or not, but i'd like it of the album column and the title column resized together, kind of "maintaining aspect ratio" type thing. if i click the toggle area on the left of the side panel and the playlist expands, it would be cool if those two columns resized at the same rate. is this a possibility?
- Lyx   Navigator-Suite Feedback   Feb 14 2005, 01:28
- - Tomacco_Boy   That looks awesome Lyx, will definetly give this a...   Feb 14 2005, 01:37
- - musicmusic   Looks pretty (very) nice, probably first time ive ...   Feb 14 2005, 01:58
|- - Lyx   QUOTE (musicmusic @ Feb 14 2005, 02:58 AM)Loo...   Feb 14 2005, 02:22
- - Lyx   Updated final 1.00 version. The only change is tha...   Feb 14 2005, 12:19
- - dano   Lyx you can also ask Neksus for an account or use ...   Feb 14 2005, 12:32
- - mazy   thumbs up! great work lyx, i like how easy i...   Feb 14 2005, 15:27
|- - upNorth   QUOTE (mazy @ Feb 14 2005, 03:27 PM)lyx - i...   Feb 14 2005, 20:00
- - .zolder   congrats on the release may it bring enlightenme...   Feb 14 2005, 15:34
- - mazy   lyx: it seems the string doesn't recognize my ...   Feb 14 2005, 16:09
|- - Lyx   mazy, i will look into the va-issue later today to...   Feb 14 2005, 16:46
- - mazy   great, thanks ...   Feb 14 2005, 16:48
- - Lyx   Hmm, i just had an idea how to speedup the code a ...   Feb 14 2005, 17:24
- - dano   Does the OST thing stay optional? Not all my OST...   Feb 14 2005, 17:34
- - Lyx   Yes, i'll make an option in the config "T...   Feb 14 2005, 17:38
- - Lyx   1.01 uploaded - changelog is in the first post of ...   Feb 14 2005, 20:22
|- - upNorth   QUOTE (Lyx @ Feb 14 2005, 08:22 PM)@upnorth: ...   Feb 14 2005, 20:47
|- - topdownjimmy   QUOTE (upNorth @ Feb 14 2005, 02:47 PM)QUOTE ...   Feb 14 2005, 20:58
|- - Lyx   QUOTE (topdownjimmy @ Feb 14 2005, 09:58 PM)o...   Feb 14 2005, 21:09
|- - topdownjimmy   QUOTE (Lyx @ Feb 14 2005, 03:09 PM)QUOTE (top...   Feb 14 2005, 21:51
- - upNorth   I don't remember the contents of the default P...   Feb 14 2005, 21:19
- - Lyx   the default content is DDMMYY if i remember right....   Feb 14 2005, 21:26
- - Lyx   Sidenote: When deciding about a standard, it shoul...   Feb 14 2005, 21:58
- - mazy   i'm too for YYYY-MM-DD, it's better to hav...   Feb 14 2005, 22:11
- - Lyx   Thats not a typo, thats intentional. :-) Otherwis...   Feb 14 2005, 23:05
|- - fakeplastictrees   Awesome config, i will try it!   Feb 15 2005, 17:24
- - mazy   ah, i see ... but you do $lower on it, so it ...   Feb 14 2005, 23:17
- - Lyx   good call - that was quite stupid of me - i just c...   Feb 14 2005, 23:25
- - mazy   Lyx, as for speed-ups, i think we should bug music...   Feb 15 2005, 00:26
- - musicmusic   QUOTE (Lyx @ Feb 14 2005, 01:22 AM)Hmm, someo...   Feb 15 2005, 00:40
- - Lyx   @mazy Mmh, i'll try to make the situation and ...   Feb 15 2005, 00:57
- - mazy   yep Lyx, that makes sense ... and that's one w...   Feb 15 2005, 01:06
- - landy   how about an option to display just the artist and...   Feb 15 2005, 01:17
|- - Lyx   QUOTE (landy @ Feb 15 2005, 02:17 AM)how abou...   Feb 15 2005, 01:25
- - landy   thanks, i really like this fcs.   Feb 15 2005, 01:42
- - MrEnergizer   Thanx Lyx, just when I thought I had Foobar how I ...   Feb 15 2005, 02:01
- - DustMagnet   Sweet fcs, Lyx! Much classier than my own. ...   Feb 15 2005, 02:38
- - Lyx   I should have been really worried if any kind of l...   Feb 15 2005, 03:00
- - mazy   thinking about tagz, it would be great to have som...   Feb 15 2005, 13:30
- - Lyx   Umm, i'm sorry i can't follow your idea? T...   Feb 15 2005, 13:43
- - mazy   sorry Lyx, i know i go way to far sometimes . you...   Feb 15 2005, 14:44
- - Lyx   Okay, now i understood what it does, but not ...   Feb 15 2005, 14:51
- - Lyx   hmm, can i have IFs inside of a $strstr and ...   Feb 15 2005, 15:36
- - mobyduck   Hi Lyx. Just downloaded Navigator 1.01 and I real...   Feb 15 2005, 16:18
- - Lyx   Just rightclick the column-headers - there you can...   Feb 15 2005, 16:23
- - mobyduck   Soo easy! Thank you! Alessandro   Feb 15 2005, 17:25
- - Lyx   updated to v1.02 - changelog is in the first post ...   Feb 15 2005, 22:27
- - Languid   I had been using eriks3 format string for quite so...   Feb 16 2005, 00:56
- - Lyx   cool, thanks for sharing this one. Now, if i woul...   Feb 16 2005, 01:10
|- - Languid   As far as I'm concerned, you can just give the...   Feb 16 2005, 01:18
- - Lyx   Okay. One problem: while declaring it as a dark-sc...   Feb 16 2005, 01:22
|- - Languid   QUOTE (Lyx @ Feb 15 2005, 04:22 PM)Okay. One ...   Feb 16 2005, 02:17
- - Lyx   Nope, i made the special-color cyan with medium-sa...   Feb 16 2005, 02:26
- - Comanche -hM   I really liked this Fcs, i did some color changes ...   Feb 16 2005, 02:27
- - MrEnergizer   Comanche Your link isnt working for me   Feb 16 2005, 02:39
- - Comanche -hM   retry using the alternative link please, i sended ...   Feb 16 2005, 02:43
- - Languid   Just a thought, and I don't know if it's f...   Feb 16 2005, 03:27
|- - fakeplastictrees   Can't seem to get the ext and quality tab to d...   Feb 16 2005, 09:17
||- - Lyx   QUOTE (fakeplastictrees @ Feb 16 2005, 10:17 ...   Feb 16 2005, 14:13
||- - fakeplastictrees   QUOTE (Lyx @ Feb 16 2005, 10:13 PM)QUOTE (fak...   Feb 16 2005, 19:38
|- - Lyx   QUOTE (Languid @ Feb 16 2005, 04:27 AM)Just a...   Feb 16 2005, 14:02
- - Tomacco_Boy   Is there a chance of adding in the trackrating col...   Feb 16 2005, 13:06
|- - Lyx   QUOTE (Tomacco_Boy @ Feb 16 2005, 02:06 PM)Is...   Feb 16 2005, 14:20
- - Lyx   updated to 1.03 - changelong as usual in the first...   Feb 17 2005, 00:27
- - addicted   When sorting by play counter, as the single digits...   Feb 17 2005, 04:03
- - Lyx   Sure, i didn't think of that - will be fixed i...   Feb 17 2005, 04:07
- - mazy   Lyx, i have feature request regarding tag guessing...   Feb 17 2005, 13:38
|- - Lyx   QUOTE (mazy @ Feb 17 2005, 02:38 PM)Lyx, i ha...   Feb 17 2005, 14:29
|- - mazy   yeah, i know ... but i did that even in my old for...   Feb 17 2005, 14:37
- - Lyx   How much faster is tag-guessing in LUA?   Feb 17 2005, 14:42
- - mazy   it is faster, but i do way to much in it and on pe...   Feb 17 2005, 15:03
- - Lyx   So, if one would use it only for those tasks which...   Feb 17 2005, 15:07
- - mazy   well with current sdk, all you can do is to tell t...   Feb 17 2005, 15:19
- - Lyx   QUOTE well with current sdk, all you can do is to ...   Feb 17 2005, 15:22
- - mazy   yep, of course ... we've been talking about th...   Feb 17 2005, 15:28
- - Lyx   Bummer. So the situation is still the same - i...   Feb 17 2005, 15:31
- - addicted   QUOTE (Lyx @ Feb 16 2005, 10:07 PM)Sure, i di...   Feb 17 2005, 15:53
- - Lyx   Weird *checks again, because that should usually f...   Feb 17 2005, 15:56
- - addicted   sorry, my bad. I was sorting by the toolbar sort o...   Feb 17 2005, 16:05
- - Lyx   np :)   Feb 17 2005, 16:06
- - parallax   Great fcs! This is probably dumb but... The ...   Feb 18 2005, 01:01
|- - Languid   QUOTE (parallax @ Feb 17 2005, 04:01 PM)I hav...   Feb 18 2005, 02:44
- - Lyx   You probably have fb2k set to automatically add ...   Feb 18 2005, 01:13
|- - parallax   QUOTE edit: forget what i said about the playlist ...   Feb 18 2005, 01:34
- - Prodoc   Just to comment on the date/time format stuff ment...   Feb 18 2005, 01:49
|- - foosion   QUOTE (Prodoc @ Feb 18 2005, 01:49 AM)Just to...   Feb 19 2005, 00:58
|- - Lyx   QUOTE (foosion @ Feb 19 2005, 01:58 AM)QUOTE ...   Feb 19 2005, 01:29
- - Lyx   Something very similiar to that has already been a...   Feb 18 2005, 01:56
- - Lyx   well, i could change the default to dark-grey. Mak...   Feb 18 2005, 03:01
|- - parallax   QUOTE (Lyx @ Feb 17 2005, 06:01 PM)well, i co...   Feb 19 2005, 03:32
- - Languid   Perhaps you could give instructions on how to chan...   Feb 18 2005, 03:08
- - pIv   Lyx May you change sort of Pos. column to [%_pat...   Feb 18 2005, 05:54
|- - Lyx   QUOTE (pIv @ Feb 18 2005, 06:54 AM)Lyx May ...   Feb 18 2005, 06:32
- - pIv   To Lyx When I add all files from any directory ...   Feb 18 2005, 07:21
- - Lyx   Yes, but the problem is that not everyone is using...   Feb 18 2005, 07:59
- - addicted   I'm not sure if this is possible with columns ...   Feb 18 2005, 23:16
|- - Lyx   QUOTE (addicted @ Feb 19 2005, 12:16 AM)I...   Feb 18 2005, 23:52
- - Lyx   major update - changelog as usual in the first-pos...   Feb 21 2005, 11:55
- - Comanche -hM   Lyx, i don't know exactly what i did, but when...   Feb 21 2005, 22:44
- - Comanche -hM   an small change in the color, i made it dark: Da...   Feb 21 2005, 23:09
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd April 2015 - 06:26
