Navigator-Suite Feedback, questions, bug-reports or just chatting
Lyx
post Feb 14 2005, 01:28
Intro
This thread is for feedback, bug-reports or just chatting about "Navigator", a playlist design for Columns UI.
The layout is very modular and can easily be adapted to suit your needs - here is a screenshot which shows a few possibilities of what you can do with it:
Description
  • usually just works, no matter what you throw at it
  • (optional) advanced tag-guess-code
  • modular layout: you can enable/disable most columns without screwing up the design
  • Singlemode and Albummode (with configurable priority). No last-track tags necessary for albummode(with an obvious naming-scheme Albummode even works with no tags at all!).
  • supports the following non-id3v1-tags: discnumber, album artist, conductor, performer, publisher, style, play_counter, first_played, last_played, rating, album rating, encodedby
  • multiline display of comment-tags in albummode
  • efficient and flexible use of available space in albummode - no line gets wasted.
  • advanced playback-stats(requires a standards-compliant play_count-plugin (not the one available from the fb2k-site))
  • basic inline-metadata editing capabilities (edit your tags right in the playlist)
  • "Metadata-Matrix"-column for a better overview of which files in your collection have which tags
  • intelligent column-based sorting of files: sort by completeness of tags, sort by rating+genres, etc.
  • very easy to configure
  • comes with multiple premade color-schemes and the ability to easily create your own ones
  • includes an advanced copystring which makes use of the same tag-guess-code. Amount of copied data easily configurable.
  • can be made to occupy less than 25% screenspace on 1024x768
Download
Current version for foobar 0.9.x:
Old version for foobar 0.8.3:
Important!: You need columns_ui for this to work.
About feature-proposals
I currently have no interest in feature-proposals. This is because i consider the 1.x.x line of Navigator finished. Bug-reports however are welcome.
_______________________________________________________________
Changelog:
1.4.3 (foobar 0.9.x compatible)
- fixed display of singles in albummode for tracks with no ARTIST
- the "artist & album"-column now uses ARTIST instead of ALBUM for inline-metadata editing
- added new colorscheme by 4nt1
1.4.2
- moved albummode STYLE-display into a seperate line
- Tracks which have TOTALTRACKS=1 are now also considered singles
- fixed inverted colors in albummode when displaying: performer, conductor, publisher
1.4.1
- fixed wrong upload (STYLE didn't work)
1.4.0
- compatible with foobar 0.9 and the coresponding ui-columns (no need for legacy mode)
- improved performance by making use of new ui-columns style-features to reduce codesize
- sorting by all kinds of playback-stats works correct now
- added full support for the recently standardized STYLE-tag
- added basic support for inline-metadata editing
- redesigned hybrid-mode
- fixed statusbar display-errors when using RTL-languages
- when enqueueing audio-cds, albummode is now automatically activated
- properly honors the new field-remappings
- many bugfixes and code cleanup
- misc changes to the how-to docs
- probably some other stuff which i forgot
1.3.2 (foobar 0.8.3 compatible)
- bugfix: "daily plays"-column did show wrong values.
- last version for fb2k 0.8.3
1.3.1
- bugfix: in the "daily plays"-column, tracks which were played today the first time would show strange ratios
- finally replaced the ancient screenshot with an up-to-date one
1.3.0 - full support for the new playcount-plugin
- added "plays per day"-stats (new playcounter-plugin required for it to show up). You cannot sort by it yet.
- added first_played-column (new playcounter-plugin required for it to work).
- moved replaygain-indicators from the metadata-matrix into a seperate column
- dropped configurability of the seperator-char, since almost nobody used it anyways
- sorting-code polishing: you can now correctly sort by multiple columns (like for example first sorting by the album-column, and then sorting by rating)
This post has been edited by Lyx: May 21 2006, 15:19
musicmusic
post Feb 15 2005, 00:40
Columns UI developer
QUOTE (Lyx @ Feb 14 2005, 01:22 AM)
Hmm, someone else who did lots of test-runs of it for me has a 700mhz box, and he says it runs acceptable - but i guess your bars are higher because you're a coder :-)
Its probably my different habits - I like to use page up/down keys to navigate, with will load more tracks at once, and maybe my laptop's processor is melted also.
Large parts of the code is non-trackspecific stuff *hinthint*
Lets not turn this into a columns ui thread wink.gif Developments in that area will come in due time (yes i know its been long enough as it is)
To be more specific....... the "culprits" for the resource-hog are two:
1. non-trackspecific code - like calculation of secondary colors
2. the tag-guess code eats resources even though its inside a large if-loop which only gets executed when not all standard tags are there - but the parsing alone seems to be heavy already.
Well probably the general overhead of parsing the script, or something, I dont know. But you're not going to make a "do-everything" script that is fast without rewriting the tagz engine or something. Of course a non-track specific string will help significantly, though.
- Lyx   Navigator-Suite Feedback   Feb 14 2005, 01:28
- - Tomacco_Boy   That looks awesome Lyx, will definetly give this a...   Feb 14 2005, 01:37
- - musicmusic   Looks pretty (very) nice, probably first time ive ...   Feb 14 2005, 01:58
|- - Lyx   QUOTE (musicmusic @ Feb 14 2005, 02:58 AM)Loo...   Feb 14 2005, 02:22
- - Lyx   Updated final 1.00 version. The only change is tha...   Feb 14 2005, 12:19
- - dano   Lyx you can also ask Neksus for an account or use ...   Feb 14 2005, 12:32
- - mazy   thumbs up! great work lyx, i like how easy i...   Feb 14 2005, 15:27
|- - upNorth   QUOTE (mazy @ Feb 14 2005, 03:27 PM)lyx - i...   Feb 14 2005, 20:00
- - .zolder   congrats on the release may it bring enlightenme...   Feb 14 2005, 15:34
- - mazy   lyx: it seems the string doesn't recognize my ...   Feb 14 2005, 16:09
|- - Lyx   mazy, i will look into the va-issue later today to...   Feb 14 2005, 16:46
- - mazy   great, thanks ...   Feb 14 2005, 16:48
- - Lyx   Hmm, i just had an idea how to speedup the code a ...   Feb 14 2005, 17:24
- - dano   Does the OST thing stay optional? Not all my OST...   Feb 14 2005, 17:34
- - Lyx   Yes, i'll make an option in the config "T...   Feb 14 2005, 17:38
- - Lyx   1.01 uploaded - changelog is in the first post of ...   Feb 14 2005, 20:22
|- - upNorth   QUOTE (Lyx @ Feb 14 2005, 08:22 PM)@upnorth: ...   Feb 14 2005, 20:47
|- - topdownjimmy   QUOTE (upNorth @ Feb 14 2005, 02:47 PM)QUOTE ...   Feb 14 2005, 20:58
|- - Lyx   QUOTE (topdownjimmy @ Feb 14 2005, 09:58 PM)o...   Feb 14 2005, 21:09
|- - topdownjimmy   QUOTE (Lyx @ Feb 14 2005, 03:09 PM)QUOTE (top...   Feb 14 2005, 21:51
- - upNorth   I don't remember the contents of the default P...   Feb 14 2005, 21:19
- - Lyx   the default content is DDMMYY if i remember right....   Feb 14 2005, 21:26
- - Lyx   Sidenote: When deciding about a standard, it shoul...   Feb 14 2005, 21:58
- - mazy   i'm too for YYYY-MM-DD, it's better to hav...   Feb 14 2005, 22:11
- - Lyx   Thats not a typo, thats intentional. :-) Otherwis...   Feb 14 2005, 23:05
|- - fakeplastictrees   Awesome config, i will try it!   Feb 15 2005, 17:24
- - mazy   ah, i see ... but you do $lower on it, so it ...   Feb 14 2005, 23:17
- - Lyx   good call - that was quite stupid of me - i just c...   Feb 14 2005, 23:25
- - mazy   Lyx, as for speed-ups, i think we should bug music...   Feb 15 2005, 00:26
- - musicmusic   QUOTE (Lyx @ Feb 14 2005, 01:22 AM)Hmm, someo...   Feb 15 2005, 00:40
- - Lyx   @mazy Mmh, i'll try to make the situation and ...   Feb 15 2005, 00:57
- - mazy   yep Lyx, that makes sense ... and that's one w...   Feb 15 2005, 01:06
- - landy   how about an option to display just the artist and...   Feb 15 2005, 01:17
|- - Lyx   QUOTE (landy @ Feb 15 2005, 02:17 AM)how abou...   Feb 15 2005, 01:25
- - landy   thanks, i really like this fcs.   Feb 15 2005, 01:42
- - MrEnergizer   Thanx Lyx, just when I thought I had Foobar how I ...   Feb 15 2005, 02:01
- - DustMagnet   Sweet fcs, Lyx! Much classier than my own. ...   Feb 15 2005, 02:38
- - Lyx   I should have been really worried if any kind of l...   Feb 15 2005, 03:00
- - mazy   thinking about tagz, it would be great to have som...   Feb 15 2005, 13:30
- - Lyx   Umm, i'm sorry i can't follow your idea? T...   Feb 15 2005, 13:43
- - mazy   sorry Lyx, i know i go way to far sometimes . you...   Feb 15 2005, 14:44
- - Lyx   Okay, now i understood what it does, but not ...   Feb 15 2005, 14:51
- - Lyx   hmm, can i have IFs inside of a $strstr and ...   Feb 15 2005, 15:36
- - mobyduck   Hi Lyx. Just downloaded Navigator 1.01 and I real...   Feb 15 2005, 16:18
- - Lyx   Just rightclick the column-headers - there you can...   Feb 15 2005, 16:23
- - mobyduck   Soo easy! Thank you! Alessandro   Feb 15 2005, 17:25
- - Lyx   updated to v1.02 - changelog is in the first post ...   Feb 15 2005, 22:27
- - Languid   I had been using eriks3 format string for quite so...   Feb 16 2005, 00:56
- - Lyx   cool, thanks for sharing this one. Now, if i woul...   Feb 16 2005, 01:10
|- - Languid   As far as I'm concerned, you can just give the...   Feb 16 2005, 01:18
- - Lyx   Okay. One problem: while declaring it as a dark-sc...   Feb 16 2005, 01:22
|- - Languid   QUOTE (Lyx @ Feb 15 2005, 04:22 PM)Okay. One ...   Feb 16 2005, 02:17
- - Lyx   Nope, i made the special-color cyan with medium-sa...   Feb 16 2005, 02:26
- - Comanche -hM   I really liked this Fcs, i did some color changes ...   Feb 16 2005, 02:27
- - MrEnergizer   Comanche Your link isnt working for me   Feb 16 2005, 02:39
- - Comanche -hM   retry using the alternative link please, i sended ...   Feb 16 2005, 02:43
- - Languid   Just a thought, and I don't know if it's f...   Feb 16 2005, 03:27
|- - fakeplastictrees   Can't seem to get the ext and quality tab to d...   Feb 16 2005, 09:17
||- - Lyx   QUOTE (fakeplastictrees @ Feb 16 2005, 10:17 ...   Feb 16 2005, 14:13
||- - fakeplastictrees   QUOTE (Lyx @ Feb 16 2005, 10:13 PM)QUOTE (fak...   Feb 16 2005, 19:38
|- - Lyx   QUOTE (Languid @ Feb 16 2005, 04:27 AM)Just a...   Feb 16 2005, 14:02
- - Tomacco_Boy   Is there a chance of adding in the trackrating col...   Feb 16 2005, 13:06
|- - Lyx   QUOTE (Tomacco_Boy @ Feb 16 2005, 02:06 PM)Is...   Feb 16 2005, 14:20
- - Lyx   updated to 1.03 - changelong as usual in the first...   Feb 17 2005, 00:27
- - addicted   When sorting by play counter, as the single digits...   Feb 17 2005, 04:03
- - Lyx   Sure, i didn't think of that - will be fixed i...   Feb 17 2005, 04:07
- - mazy   Lyx, i have feature request regarding tag guessing...   Feb 17 2005, 13:38
|- - Lyx   QUOTE (mazy @ Feb 17 2005, 02:38 PM)Lyx, i ha...   Feb 17 2005, 14:29
|- - mazy   yeah, i know ... but i did that even in my old for...   Feb 17 2005, 14:37
- - Lyx   How much faster is tag-guessing in LUA?   Feb 17 2005, 14:42
- - mazy   it is faster, but i do way to much in it and on pe...   Feb 17 2005, 15:03
- - Lyx   So, if one would use it only for those tasks which...   Feb 17 2005, 15:07
- - mazy   well with current sdk, all you can do is to tell t...   Feb 17 2005, 15:19
- - Lyx   QUOTE well with current sdk, all you can do is to ...   Feb 17 2005, 15:22
- - mazy   yep, of course ... we've been talking about th...   Feb 17 2005, 15:28
- - Lyx   Bummer. So the situation is still the same - i...   Feb 17 2005, 15:31
- - addicted   QUOTE (Lyx @ Feb 16 2005, 10:07 PM)Sure, i di...   Feb 17 2005, 15:53
- - Lyx   Weird *checks again, because that should usually f...   Feb 17 2005, 15:56
- - addicted   sorry, my bad. I was sorting by the toolbar sort o...   Feb 17 2005, 16:05
- - Lyx   np :)   Feb 17 2005, 16:06
- - parallax   Great fcs! This is probably dumb but... The ...   Feb 18 2005, 01:01
|- - Languid   QUOTE (parallax @ Feb 17 2005, 04:01 PM)I hav...   Feb 18 2005, 02:44
- - Lyx   You probably have fb2k set to automatically add ...   Feb 18 2005, 01:13
|- - parallax   QUOTE edit: forget what i said about the playlist ...   Feb 18 2005, 01:34
- - Prodoc   Just to comment on the date/time format stuff ment...   Feb 18 2005, 01:49
|- - foosion   QUOTE (Prodoc @ Feb 18 2005, 01:49 AM)Just to...   Feb 19 2005, 00:58
|- - Lyx   QUOTE (foosion @ Feb 19 2005, 01:58 AM)QUOTE ...   Feb 19 2005, 01:29
- - Lyx   Something very similiar to that has already been a...   Feb 18 2005, 01:56
- - Lyx   well, i could change the default to dark-grey. Mak...   Feb 18 2005, 03:01
|- - parallax   QUOTE (Lyx @ Feb 17 2005, 06:01 PM)well, i co...   Feb 19 2005, 03:32
- - Languid   Perhaps you could give instructions on how to chan...   Feb 18 2005, 03:08
- - pIv   Lyx May you change sort of Pos. column to [%_pat...   Feb 18 2005, 05:54
|- - Lyx   QUOTE (pIv @ Feb 18 2005, 06:54 AM)Lyx May ...   Feb 18 2005, 06:32
- - pIv   To Lyx When I add all files from any directory ...   Feb 18 2005, 07:21
- - Lyx   Yes, but the problem is that not everyone is using...   Feb 18 2005, 07:59
- - addicted   I'm not sure if this is possible with columns ...   Feb 18 2005, 23:16
|- - Lyx   QUOTE (addicted @ Feb 19 2005, 12:16 AM)I...   Feb 18 2005, 23:52
- - Lyx   major update - changelog as usual in the first-pos...   Feb 21 2005, 11:55
- - Comanche -hM   Lyx, i don't know exactly what i did, but when...   Feb 21 2005, 22:44
- - Comanche -hM   an small change in the color, i made it dark: Da...   Feb 21 2005, 23:09
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd April 2015 - 04:22
