linux encoder
rudefyet
post Feb 8 2005, 18:48
I downloaded the source code from muspeack.net and compiled mppenc myself...
I've noticed that my compile encodes around 17x, whereas the precompiled versions on musepack.net only run about 15.5x
I was wondering what was different here, I didn't change anything in the Makefile, so why would they be different?
Is there any certain reason i should use the precompiled binary?
and also, I can't get mppdec to compile from source, it fails on wave_out.c every time
Replies (1 - 7)
NumLOCK
post Feb 8 2005, 20:06
Neutrino G-RSA developer
QUOTE (rudefyet @ Feb 8 2005, 06:48 PM)
You probably have a different gcc version...
Probably not.. since gcc is a quite reliable tool, so your mppenc should encode safely smile.gif
Try Leeloo Chat at http://leeloo.webhop.net
rudefyet
post Feb 8 2005, 20:18
thanks...i figured i was just being too paranoid
Seed
post Feb 8 2005, 20:35
Musepack Project Coordinator
We kept the -ffast-math flag in the makefile and this is the reason your compile is faster. It is very likely to fail on teh_sample, though, and will cause other problems with other samples. Disable it. It will be removed from the makefile too.
And if Warhol's a genius, what am I? A speck of lint on the ***** of an alien
rjamorim
post Feb 8 2005, 20:42
Rarewares admin
QUOTE (NumLOCK @ Feb 8 2005, 05:06 PM)
GCC is reliable indeed, but the MPPenc code doesn't seem to be.
http://www.hydrogenaudio.org/forums/index....howtopic=30758&
http://www.rarewares.org
ak
post Feb 8 2005, 22:14
Musepack Developer
-ffast-math is there, as it makes things run faster.
But parts of it, that appear to cause teh_sample artifacts, explicitely disabled in Makefile.
Besides musepack.net mppenc was built with -O1, as -O2 and up caused another problems.
But parts of -O2, that seem to be responsible, are also disabled in Makefile.
So in sum if you build it yourself, it's (hopefully) still safe enough.
Anyways you can always check by doing some encodes with musepack.net build and your compile and comparing the results.
rudefyet
post Feb 9 2005, 00:01
I see...i will admit, i've heard a few artifacts in the songs i've encoded using --fast-math (although it could just be the fact i upgraded my audio hardware, it's much easier to abx between different bitrates now)
that was the exact flag that worried me in the Makefile
I think i'll stick with the official builds
I'll have to figure out the difference between the dynamicly and staticlly linked builds (i know its common *nix knowledge, but i've forgotten over the years)
This post has been edited by rudefyet: Feb 9 2005, 00:03
xmixahlx
post Feb 14 2005, 21:11
a "static" compile includes - within the executable - the linked libraries that a "dynamic" compile depends on.
later
RareWares/Debian :: http://www.rarewares.org/debian.html
RSS Lo-Fi Version Time is now: 2nd June 2015 - 03:32
