Flac Doesn't Let Me Embed This Cuesheet, What's wrong with it?
smz
post Feb 6 2005, 13:43
Flac (1.1.2) doesn't let me embed the follwing cuesheet
PERFORMER "Performer Name"
TITLE "Album Title"
FILE "mytestfile.wav" WAVE
 TRACK 01 AUDIO
   TITLE "Track01 Title"
   INDEX 01 00:00:00
with this error:
ERROR initializing encoder
state= FLAC_STREAM_ENCODER_INVALID_METADATA
Is this a bug or there is something wrong with my cuesheet that I can't spot?
Cheers
Sergio
Edit: spelling. If also a mod could fix the topic title... thanks! (Done, thanks to the mod!)
Edit2: removed great part of the cuesheet as the problem was not with it (see subsequent posts), to make the thread more readable.
Edit3: Modified cuesheet example so that RIAA doesn't sue me, in case I die...
This post has been edited by smz: Feb 9 2005, 02:34
Sergio
Revox B150 + (JBL 4301B | Sennheiser HD430)
Synthetic Soul
post Feb 8 2005, 13:21
I just tested your WAVE and CUE and got the same result.
However, I then tried the CUE with a WAVE I have kicking about, and still got the same result/error.
I tried it with another WAVE with another CUE and it worked fine. I tried the new CUE with my "bad" WAVE and it didn't work. I have therefore concluded that it is the WAVE files (as I think we knew).
I have just converted a small MP3 I had kicking about to WAV using foobar, and got the same error. If I convert the file to FLAC and then back again to WAVE I still get the error, so I have uploaded it to my webspace (I can't upload to HA as it is a Zuton's track at 37 seconds). Please feel free to download, convert to WAVE and try adding a cuesheet using FLAC --cuesheet=<x> untitled.wav. Please delete after testing though.
I used METAFLAC to add the cuesheet using --import-cuesheet-from and it seems to have worked (I'm not familiar with METAFLAC or FLAC). If I do METAFLAC --list I get:
METADATA block #0
type: 0 (STREAMINFO)
is last: false
length: 34
minumum blocksize: 4608 samples
maximum blocksize: 4608 samples
minimum framesize: 3261 bytes
maximum framesize: 11467 bytes
sample_rate: 44100 Hz
channels: 2
bits-per-sample: 16
total samples: 1668096
MD5 signature: 875b837e0fcf8df4f5a8f97292d97d6a
METADATA block #1
type: 3 (SEEKTABLE)
is last: false
length: 90
seek points: 5
point 0: sample_number=0, stream_offset=0, frame_samples=4608
point 1: sample_number=552960, stream_offset=892787, frame_samples=4608
point 2: sample_number=880128, stream_offset=1585974, frame_samples=4608
point 3: sample_number=1110528, stream_offset=2085320, frame_samples=4608
point 4: sample_number=1764000, stream_offset=0, frame_samples=0
METADATA block #2
type: 4 (VORBIS_COMMENT)
is last: false
length: 40
vendor string: reference libFLAC 1.1.2 20050205
comments: 0
METADATA block #3
type: 5 (CUESHEET)
is last: false
length: 576
media catalog number:
lead-in: 88200
is CD: true
number of tracks: 4
track[0]
offset: 0
number: 1
ISRC:
type: AUDIO
pre-emphasis: false
number of index points: 1
index[0]
offset: 0
number: 1
track[1]
offset: 882000
number: 2
ISRC:
type: AUDIO
pre-emphasis: false
index[0]
offset: 0
number: 1
track[2]
offset: 1764000
number: 3
ISRC:
type: AUDIO
pre-emphasis: false
index[0]
offset: 0
number: 1
track[3]
offset: 1668096
number: 170 (LEAD-OUT)
METADATA block #4
type: 1 (PADDING)
is last: true
length: 3480
Edit: link to FLAC file removed
This post has been edited by Synthetic Soul: Feb 10 2005, 15:51
I'm on a horse.
- smz   Flac Doesn't Let Me Embed This Cuesheet   Feb 6 2005, 13:43
- - BruRob   Your third line reads: FILE "Nearness of You-...   Feb 6 2005, 14:56
|- - smz   QUOTE (BruRob @ Feb 6 2005, 03:56 PM)Your thi...   Feb 6 2005, 15:23
|- - smz   Sorry to bump this post, but I think I have some (...   Feb 6 2005, 20:11
|- - jcoalson   I probably cannot tell anything without having the...   Feb 7 2005, 05:28
|- - smz   QUOTE (jcoalson @ Feb 7 2005, 06:28 AM)I prob...   Feb 7 2005, 12:32
|- - lexor   QUOTE (smz @ Feb 7 2005, 03:32 AM)QUOTE (jcoa...   Feb 7 2005, 13:44
|- - smz   QUOTE (lexor @ Feb 7 2005, 02:44 PM)try and s...   Feb 7 2005, 14:16
|- - smz   Does anybody knows a tool to validate the structur...   Feb 8 2005, 12:04
|- - rjamorim   QUOTE (smz @ Feb 8 2005, 09:04 AM)Does anybod...   Feb 8 2005, 13:21
- - Synthetic Soul   I just tested your WAVE and CUE and got the same r...   Feb 8 2005, 13:21
- - Synthetic Soul   QUOTE (rjamorim @ Feb 8 2005, 12:21 PM)QUOTE ...   Feb 8 2005, 13:33
- - jcoalson   I see the problem, but I'm not sure what to do...   Feb 8 2005, 19:04
|- - smz   Josh, thank-you for analyzing the problem. Here a...   Feb 9 2005, 02:26
- - Synthetic Soul   QUOTE (smz @ Feb 9 2005, 01:26 AM)QUOTE (jcoa...   Feb 9 2005, 11:23
- - kjoonlee   IMHO the assumption(s) that flac and metaflac make...   Feb 9 2005, 15:22
|- - smz   QUOTE (kjoonlee @ Feb 9 2005, 03:22 PM)... Th...   Feb 9 2005, 15:41
|- - rjamorim   QUOTE (kjoonlee @ Feb 9 2005, 12:22 PM)One vo...   Feb 9 2005, 18:04
- - jcoalson   the majority of cuesheet use is via cuesheets ripp...   Feb 9 2005, 18:56
|- - rjamorim   QUOTE (jcoalson @ Feb 9 2005, 03:56 PM)the ma...   Feb 9 2005, 19:01
- - kjoonlee   The cuesheet format screams out "CD-DA"....   Feb 10 2005, 12:51
|- - smz   QUOTE (kjoonlee @ Feb 10 2005, 12:51 PM)The c...   Feb 10 2005, 13:17
|- - rjamorim   QUOTE (smz @ Feb 10 2005, 10:17 AM)Correct. W...   Feb 12 2005, 03:24
|- - smz   QUOTE (rjamorim @ Feb 12 2005, 03:24 AM)QUOTE...   Feb 12 2005, 03:38
|- - rjamorim   QUOTE (smz @ Feb 12 2005, 12:38 AM)I didn...   Feb 12 2005, 17:11
- - m0rbidini   I agree with rjamorim and smz. FLAC is making assu...   Feb 10 2005, 13:18
- - m0rbidini   Er, correction. I wrote: QUOTE Cue sheets don...   Feb 10 2005, 13:25
- - Synthetic Soul   QUOTE (m0rbidini @ Feb 10 2005, 12:25 PM)...   Feb 10 2005, 13:46
- - jcoalson   how is the cuesheet duration specified if there is...   Feb 10 2005, 16:24
- - Synthetic Soul   Point taken. You could ascertain whether the last...   Feb 10 2005, 16:30
- - m0rbidini   Meh, I had it "more or less right" the f...   Feb 11 2005, 15:09
- - Synthetic Soul   Actually, on re-reading, I think you said it just ...   Feb 11 2005, 15:23
|- - smz   I would like to make with you all a sanity check o...   Feb 12 2005, 01:23
|- - smz   One more consideration: If foobar2000 easly accep...   Feb 12 2005, 02:16
|- - rjamorim   ...   Feb 12 2005, 03:28
- - jcoalson   following up, this is changed in CVS, output now l...   Aug 24 2005, 01:27
- - Synthetic Soul   Thanks Josh. As you say, it's up to the user ...   Aug 24 2005, 09:40
RSS Lo-Fi Version Time is now: 30th July 2015 - 06:08
