foo_ui_columns configurations, Please do not post questions/comments in here.
picmixer
post Jan 27 2005, 23:30
Guidelines
Ok, it seems the old configurations thread got a bit messy over time and I thought it would be a nice idea to have something a bit more organized this time. Especially to make it easier for users that just want to browse for a nice config and apply it.
So the idea would be that you upload your configs in the following pattern here:
Make a small post about your config with a small screenshot and use a second post right underneath to upload your config.
Please don't upload any screenshots without configs here, but use the new foobar gallery thread instead.
Also please post your questions and comments about any formatting somewhere else, maybe with a link to the corresponding formatting in case there is one.
Irrelevant posts may be removed from this thread by moderation at any time.
I'll post two quick example posts underneath to show I would think this thread could look like in the future.
Thanks for taking all this into consideration and for everyones participation in the last thread.
Link to old columns UI formatting thread
This post has been edited by picmixer: Oct 14 2007, 18:34
/mnt
post Apr 2 2010, 20:45
foovert 2
Changes from 1.5:
- NEW themes: foovert Classic, foovert Classic+ and foovert Vista+. Which are designed for a specific version of Windows.
- NEW custom style scripts.
- NEW lower contrast colour scheme.
- NEW album list view, System.
- foovert.fcl now only contains color + fonts and playlist scripts. While "foovert mnt-*date.fcl" contains the whole config.
- Updated layout.
- Album header now displays bitrate from image files that have a cue sheet embedded.
- Album header now displays %system% or custom hardware id lable on video game files such as NSF.
- Album list views now list folders if %album% is not present.
- Album list views now remove " and ' charctors, for example "Weird Al" Yankovic will display as Weird Al Yankovic.
- Status now disables dynamic bitrate display when playing CBR encoded Mp3s.
- Main text now uses a lower contrast colour to avoid eye fatigue.
- All columns now have their own code (not stored on globals anymore).
- Title will display in red if it has been qeued.
- Added style scripts for album header and # columns.
- Added right frames for # columns.
- Added blending colour scripts.
- Added option to enable background strips for album view (off by default).
- Added colour config for now playing or paused.
- Added colour config for album header.
- Added colour config for # on album view.
- Added colour bleding scripts for playlist index, album header tech info, track artist, misc columns and open bracket text.
- Reduced global variables.
- Improved singles detection.
- Improved missing metadata support.
- Improved internet radio support.
- NG group now groups URL or folders if both %album% and %artist% tags are not present.
- Files that only use Trackgain will display in singles view.
- Album view will now display a dimmed playlist index number if %tracknumber% is not present.
- Moved all column display codes away from the global variables.
- Cleaned up almost all the formatting scripts.
- Cleaned up playlist filters.
- Renamed certain columns.
- Rewritten album list views.
- Rewritten album checker.
- Rewritten tracknumber display.
Install:
First open foobar2000 with the Columns UI interface. Make sure that you have your current setup with grouping and artwork enabled,
a quick and way to do this is to select "Groups (with artwork)" on the Quick setup window.
After the grouping with artwork is enabled, will need to go to File > Preferences > Columns UI > Main (Tab)
and then click on Import. Which will let you to browse for the foovert.fcl file.
After the fcl theme is loaded, you will need to add a NG Group. Which can be done by going to
File > Preferences > Display > Columns UI > Playlist View, then click on the Grouping and
replace the format with this:
// NG Group rgb
$puts(rgb_group,$rgb(42,85,170))
// NG Group format
$get(rgb_group)
$replace(
$if($or(%album%,%album artist%),
$if2(%album artist%,Unknown Artist)' - '['['%date%'] ']
$if2(%album%,Untitled Album),
$if2(%url%,$directory(%path%,1))),
' (',$blend($get(rgb_group),$rgb(255,255,255),1,3)' (',')',')'$get(rgb_group),' [',$blend($get(rgb_group),$rgb(255,255,255),1,3)' [',']',']'$get(rgb_group))
And also set the playlist filters to "Show only on playlists" and the fill the filter box with this:
*-s-*;*-abx-*;*--hidden--*;singles;shuffle
Feedback and bug reports can be posted here.
This post has been edited by /mnt: Apr 2 2010, 20:47
Attached File(s)
"I never thought I'd see this much candy in one mission!"
- picmixer   foo_ui_columns configurations   Jan 27 2005, 23:30
- - picmixer   Insomnia Album formatting string supporting user ...   Jan 27 2005, 23:34
- - picmixer   Screenshot   Jan 27 2005, 23:35
- - Sandman2012   I had a request for this foobar config so here it ...   Jan 29 2005, 06:06
- - shasha   Well, I spent some time on this. I am not too dis...   Jan 30 2005, 13:14
- - Strictly4me   This config shows your missing tags for Titel - Al...   Feb 5 2005, 10:07
- - trance   Thanks for the code but I get all greyed circles n...   Feb 11 2005, 05:14
- - topdownjimmy   Hot Blue The primary purpose of this config is to...   Feb 20 2005, 16:21
- - Sandman2012   I had a request for this config.   Mar 4 2005, 02:31
- - Tri   I got a request for the fcs-file of my config (Pos...   Apr 17 2005, 22:42
- - Strictly4me   My new one! Same configuration like above (...   Apr 20 2005, 09:44
- - Strictly4me   One more. Download includes all colour-themes...   Apr 24 2005, 10:41
- - gob   heres one i just finished. it relies of properly t...   Jun 12 2005, 06:15
- - miscellanea   It shows as single if at least one of following is...   Jun 15 2005, 10:21
- - Strictly4me   For download 3 new styles, based by OLiGhT 2.02. ...   Jun 15 2005, 14:32
- - miscellanea   darkblue for 0.9 beta. (screenshots are the same a...   Jun 29 2005, 02:10
|- - Crissaegrim   Someone requested my iTunes style. Here it is.   Jul 17 2005, 02:28
|- - dannymichel   QUOTE (Crissaegrim @ Jul 16 2005, 21:28) ...   Mar 15 2009, 06:53
- - Acid8000   Someone requested my .fcs config so here it is. Un...   Jul 25 2005, 08:20
- - Sandman2012   Had a request for this one.   Oct 6 2005, 02:52
- - MenZa   screenshot Didn't do it myself. Get it here. ...   Oct 27 2005, 18:06
- - Sandman2012   Had a request for my latest config.   Nov 28 2005, 20:54
- - miscellanea   updated darkblue, fast rendering config. (this is ...   Nov 29 2005, 03:38
- - iStormy   [removed]   Dec 7 2005, 00:58
- - Sandman2012   Requested FCS.   Dec 17 2005, 04:36
- - brumal   Figured I would share my fcs for my latest fooby s...   Dec 17 2005, 07:22
- - miscellanea   darkblue. updated again for 0.9 beta 13 and 0.1.3 ...   Dec 19 2005, 12:50
|- - brumal   Update to my fooby config: - Added columns to show...   Dec 20 2005, 07:23
- - miscellanea   darkblue for 0.1.3 pre-alpha 16 v2. changed ...   Dec 21 2005, 14:07
- - brumal   Update to my config. CHANGES 2005-12-21 14:37 -...   Dec 22 2005, 07:47
- - miscellanea   darkblue, updated for 0.9 RC and 0.1.3 pre-alpha 1...   Feb 26 2006, 07:05
- - Strictly4me   Upps! Take it from here or here. If you hav...   Mar 22 2006, 10:50
- - mil3s   Here you go. Buttons here: http://www.famfamfam.c...   Mar 31 2006, 19:59
- - miscellanea   darkblue updated for 0.9 final and 0.1.3 pre-alpha...   Apr 3 2006, 00:41
- - skelly831   lextune requested this: here it is EDIT: remo...   Apr 6 2006, 04:12
- - picmixer   Hmh, didn't feel like updating my old config e...   Apr 17 2006, 23:18
- - picmixer   Alright, I finally cleaned up this thread a bit. P...   Apr 19 2006, 00:21
- - dBaines   dBaines ColumnsUI Config Heavily Modified Soap.fcs...   Apr 22 2006, 06:41
- - Dark-Demon   FCS my pack ~5.6M   Apr 24 2006, 15:24
- - Gord   frooptech Whipped this up after looking through B...   May 4 2006, 20:03
- - ChaosBladE   ChaosTECH I wanted to write a proper 0.9 style sc...   May 6 2006, 01:06
- - brumal   Here's my latest iteration: Foobar Milk. f...   May 22 2006, 07:53
- - gwiazdek   It's not mine foobar but i dont know how someo...   May 25 2006, 23:06
- - skelly831   My lates horizontal setup: Required tags: %albu...   May 27 2006, 02:06
- - dBaines   dBaines ColumnsUI Config Heavily Modified Soap.fcs...   May 30 2006, 06:56
- - Crissaegrim   My iTunes layout... Updated with lots of additions...   Jun 18 2006, 07:33
- - lextune   The fcs for this setup was requested: So here i...   Jun 19 2006, 23:51
- - lazy   This is my one-column hybrid mode config made with...   Jul 3 2006, 09:20
- - saivert   This is my columns ui playlist switcher titleforma...   Jul 31 2006, 23:29
- - brumal   Here's the config for this: Includes fcs, ...   Aug 19 2006, 00:22
|- - cartman(2vd)   QUOTE (brumal @ Aug 19 2006, 00:22) http:...   Aug 19 2006, 21:58
- - ...Just Elliott   This is the fcs (rename it.) This is a screensho...   Aug 31 2006, 15:03
- - lazy   I still prefer old and good columnsUI (and even de...   Sep 4 2006, 09:38
- - lazy   new fcs with autocalculating colors and themes sup...   Sep 11 2006, 08:17
- - Gord   frooptech redux Got bored of my old config so I w...   Sep 12 2006, 10:23
- - lazy   CAUTION: Please do not post your comments/question...   Dec 11 2006, 08:26
- - lazy   updated fcs. Many bugfixes, light version of fcs.   Jan 23 2007, 01:25
- - lazy   Final version of fcs: - very simple code; - hybrid...   Feb 2 2007, 10:33
- - william7   simple and black background. It's my first fo...   Feb 16 2007, 17:04
- - miscellanea   this is a mod of "blued out" by picmixer...   Feb 25 2007, 14:55
- - lazy   version 1.1 of fcs: - added something; - removed s...   Mar 13 2007, 12:38
- - lazy   last update plus defaultUI config screenshots are ...   Mar 19 2007, 17:07
- - lazy   Version 1.4: - added possibility to change display...   Apr 3 2007, 16:12
- - veenone   Hi, This is mine. It's based on ShinyDotMatri...   Aug 22 2007, 16:30
- - lazy   fcs version 1.5 No special changes, just small fix...   Oct 11 2007, 12:24
- - cristox   This is not all my work. Thanks goes to miscell...   Oct 11 2007, 15:30
- - picmixer   Thread temporarily locked for cleanup reasons. Wil...   Oct 14 2007, 18:04
- - picmixer   Alright, reopened after another cleanup. Once an...   Oct 14 2007, 18:21
- - lazy   version 1.6, many changes. Try 'color.grouping...   Oct 20 2007, 08:15
- - lazy   Version 1.7, some minor changes. In next release i...   Oct 25 2007, 10:06
- - lazy   New config, called 'empty'.   Mar 19 2008, 11:19
- - Falstaff   i B i Z A ColumnsUI config for foobar2000 grab ...   Jun 17 2008, 15:41
- - zamiwas   Hi all, heres a nice simple one i love. For col...   Sep 3 2008, 01:06
- - Nevezen   myFoo. Really simple and uncluttered with a few ws...   Dec 5 2008, 11:07
- - /mnt   My Columns UI layout, foovert v 1.00. Album layou...   Mar 14 2009, 16:22
- - /mnt   I made some changes. foovert 1.1 - Album view ...   Mar 23 2009, 21:33
- - /mnt   A new update: foovert 1.2 - NEW Notification T...   May 2 2009, 00:03
- - pcstockton   REALLY nice config. I love it!!!...   Jun 6 2009, 20:07
|- - pcstockton   QUOTE (pcstockton @ Jun 6 2009, 11:07) Se...   Jun 8 2009, 17:30
|- - /mnt   QUOTE (pcstockton @ Jun 8 2009, 17:30) QU...   Jun 9 2009, 12:15
- - /mnt   Anyway i've decided to replace all the playlis...   Jun 9 2009, 13:56
- - radcki   I have never found a layout which suited my needs....   Jun 9 2009, 19:05
- - /mnt   A big update on my columns ui config. foovert 1...   Jun 18 2009, 13:52
- - qwertz   As requested my config: Notes: I cheated twice ...   Jun 22 2009, 08:48
- - aNTropocentrio   This is my config: It's a modification of a...   Jul 28 2009, 19:47
- - tjm16   Hey guys, My first post here on these forums, and...   Oct 13 2009, 19:57
- - tjm16   Just another one to demonstrate the colour changes...   Oct 13 2009, 20:01
- - /mnt   I've done alot of updates on my columns ui con...   Nov 26 2009, 13:04
- - /mnt   foovert 1.4 Beta 2 Changes from the first beta: ...   Dec 3 2009, 14:00
- - /mnt   foovert 1.4 Changelog - NEW foovert can now d...   Dec 19 2009, 13:54
- - /mnt   I have solved some issues for anyone that is havin...   Feb 8 2010, 00:53
- - 2E7AH   here is my fcl (it's safe config only with ti...   Feb 24 2010, 18:23
- - /mnt   foovert 2 Changes from 1.5: - NEW themes: foov...   Apr 2 2010, 20:45
- - /mnt   foovet 2.1 Now made of 40% potato: Improved Vi...   Dec 29 2010, 00:14
- - kvnfo   Preview: Installation files, and instructions...   Mar 19 2011, 06:35
- - /mnt   foovert 2.2 Default theme: Custom version with ...   Apr 29 2011, 19:29
|- - ryknow   QUOTE (/mnt @ Apr 29 2011, 18:29) foovert...   Oct 1 2012, 13:03
- - blackhorus   I just wanted a simple one... no fancy skin! S...   Nov 19 2011, 19:22
- - pmh   My current layout Its a slightly modified version...   Sep 17 2012, 19:22
- - pmh   Ok, a few changes made, here is my latest layout.....   Sep 25 2012, 23:55
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 18th April 2015 - 14:29
