Extract HDCD, How I Can extract HDCD by software?
SCIF
post Jan 27 2005, 08:34
How I Can extract HDCD by software(EAC, WMP9...)?
SebastianG
post Aug 27 2007, 08:21
QUOTE (Christopher Key @ Aug 24 2007, 12:03) *
I calculated all my constants and the compression curve by passing test cases through wmp. The interpolation between gain values is done by multiplying the current gain by a constant each sample until it exceeds the target gain.
Oh, right. Sorry, I forgot that you tested the 'black box' WMP.
QUOTE (Christopher Key @ Aug 25 2007, 17:42) *
The decoded files will be 50% larger when uncompressed, I'd be interested to know how their sizes differ when losslessly compressed with, e.g. FLAC.
Let me just share my opinion on that with you all. I think it's not a good idea to decode HDCD "just for lossless storage" for the same reason you wouldn't download MP3 files and store them decoded as WAVs or FLACs on your harddisk. This decoding should only be done as preprocessing (prior lossy encoding) or as "postprocessing" (within a player, like the player decodes MP3). Otherweise you'll be wasting a lot of harddisk space.
I'm sure FLAC will have trouble catching the gaps (sample values not in use). For example: If you convert 16 bit samples to 24 bit samples and adjust the gain by -9dB to undo the dynamics compression only one out of 91 possible 24bit samples values is used (assuming you don't dither). Since 91 is not a power of two the least significant bits of the samples will look like random bits so that FLAC can't exploit the fact that the signal has an effective resolution of only 17.5 bits (16+1.5 due to the gain of -9 dB). So, approximately 573 kilobits/s (2*(24-17.5)*44100) are wasted (!!!).
Cheers!
SG
This post has been edited by SebastianG: Aug 27 2007, 08:23
Christopher Key
post Aug 27 2007, 23:17
QUOTE (SebastianG @ Aug 27 2007, 08:21) *
The analogy to mp3 decoding is a good one. Conceptually, hdcd is really just a lossy way of encoding 20 bit audio with (by design) the very useful property that the compressed output is very similar to a 16 bit version of the original.
I'm inclined to agree with you in principal that the decoding process should be done during playback or transcoding. In practice however, one doesn't always have the means to do this, and converting before hand is a good alternative. I would *strongly* recommend never deleting the original rip however, as this is the master copy. Hopefully plugins will become available, removing the need to store a preconverted version though.
I've not looked closely at how FLAC operates, but this certainly sounds highly likely. Huffman coding would work relatively well for this sort of situation, but would be fairly pointless for most audio, so is likely not used.
One point to note however is that wmp does truncate the output to 20 bits; maybe FLAC would be able to take advantage of that.
Regards,
Chris
QUOTE (SebastianG @ Aug 27 2007, 18:10) *
Interesting result this, the 24bit HDCD decoded version compresses to a size even smaller than the original 16bit.
...which can only mean that your CD doesn't make use of all HDCD features (no "soft dynamics compression").
I'll have a go tomorrow at adding some more diagnostics, maybe a --verbose option, which will list which features get used after the track's been processed. I'd guess:
Peak extend enabled at some point during the audio
Peak extend disabled at some point during the audio
Peak extend used (|sample|>0x5980 while peak extend used)
Range of gain adjustment values used.
Christopher Key
post Aug 29 2007, 19:12
QUOTE (Christopher Key @ Aug 27 2007, 23:17) *
Well there's a new version available with a few more options and some more detailed information. For now it's available from,
http://www.srcf.ucam.org/~cjk32/hdcd/hdcd-new.zip
but it'll replace the existing version,
http://www.srcf.ucam.org/~cjk32/hdcd/hdcd.zip
fairly shortly.
To get usage information, run,
hdcd.exe -h
I won't explain here as I'd like the usage information to be self explanatory. If anything's unclear, let me know and I'll explain and update it.
Finally, if anyone gets a message, 'Unknown codes seen:...', could you please let me know the exact output, as well as which CD produced it.
Regards,
Chris
- SCIF   Extract HDCD   Jan 27 2005, 08:34
- - Garf   HDCD just uses the standard 16 bit CD Audio encodi...   Jan 27 2005, 10:28
|- - PoisonDan   QUOTE (Garf @ Jan 27 2005, 11:28 AM)For playb...   Jan 27 2005, 10:50
|- - SCIF   QUOTE (PoisonDan @ Jan 27 2005, 07:50 PM)But ...   Jan 28 2005, 03:31
- - Garf   Perhaps it could work when you mount the ripped wa...   Jan 27 2005, 11:44
- - precisionist   QUOTE (SCIF @ Jan 28 2005, 03:31 AM)QUOTE (Po...   Jan 28 2005, 11:17
|- - SebastianG   QUOTE (precisionist @ Jan 28 2005, 02:17 AM)M...   Jan 28 2005, 17:02
- - adlai   I was always under the impression that HDCD was si...   Jan 28 2005, 18:00
|- - SebastianG   QUOTE (adlai @ Jan 28 2005, 09:00 AM)I was al...   Jan 28 2005, 18:59
|- - krabapple   QUOTE (SebastianG @ Jan 28 2005, 13:59) Q...   Jun 27 2007, 20:44
|- - ProtectYaNeck36   QUOTE (SebastianG @ Jan 28 2005, 11:59) Q...   Oct 20 2007, 17:41
- - user   QUOTE (SCIF @ Jan 27 2005, 08:34 AM)How I Can...   Feb 1 2005, 11:31
|- - Night Rain   QUOTE (user @ Feb 1 2005, 02:31) QUOTE (S...   Mar 21 2007, 12:38
- - ShowsOn   I just noticed this thread, and given that I fina...   Feb 1 2005, 13:10
|- - user   as written above, normally 24 bit playback of audi...   Feb 1 2005, 13:45
- - precisionist   QUOTE (ShowsOn @ Feb 1 2005, 01:10 PM)I resta...   Feb 2 2005, 13:26
|- - user   QUOTE (precisionist @ Feb 2 2005, 01:26 PM)My...   Feb 3 2005, 12:02
|- - Pio2001   QUOTE (user @ Feb 3 2005, 01:02 PM)QUOTE (pre...   Feb 3 2005, 21:25
- - precisionist   QUOTE (Pio2001 @ Feb 3 2005, 09:25 PM)QUOTE (...   Feb 4 2005, 14:23
|- - SebastianG   QUOTE (precisionist @ Feb 4 2005, 05:23 AM)Th...   Feb 4 2005, 16:34
- - Pio2001   No software, exept maybe the combination of Window...   Feb 4 2005, 23:29
|- - krabapple   QUOTE (Pio2001 @ Feb 4 2005, 17:29) No so...   Feb 8 2007, 19:15
- - precisionist   QUOTE (SebastianG @ Feb 4 2005, 04:34 PM)Does...   Feb 7 2005, 17:01
- - Eric Carroll   There has been a long running thread on the Slim D...   Feb 26 2007, 06:56
- - markanini   Wow, I wish I knew about this plugin before. Final...   Feb 27 2007, 01:40
|- - Eric Carroll   QUOTE (markanini @ Feb 26 2007, 19:40) Wo...   Feb 27 2007, 04:42
|- - markanini   QUOTE (Eric Carroll @ Feb 27 2007, 05:42)...   Feb 27 2007, 05:26
- - markanini   Since I got too excited about this, here are the w...   Feb 27 2007, 06:31
|- - Eric Carroll   Thanks for looking into this. QUOTE (markanini ...   Feb 27 2007, 06:57
- - markanini   For the sake of visual comparison I adjusted the w...   Feb 27 2007, 07:08
|- - Eric Carroll   Well your results sure look like what I expected t...   Feb 27 2007, 07:14
- - markanini   I used WMP 10.   Feb 27 2007, 07:17
- - SebastianG   I recall someone mentioning on the audioasylum for...   Feb 27 2007, 09:49
|- - user   I have an alternative idea to capture the 2 stream...   Mar 21 2007, 11:41
- - SebastianG   I reviewed the papers about HDCD you can find on t...   Jun 28 2007, 11:21
|- - Christopher Key   I've had a go at understanding hdcd; see, htt...   Aug 22 2007, 10:57
|- - M   QUOTE (Christopher Key @ Aug 22 2007, 04...   Aug 22 2007, 15:33
||- - Christopher Key   QUOTE (M @ Aug 22 2007, 15:33) QUOTE (Chr...   Aug 22 2007, 17:54
|- - gabeg   QUOTE (Christopher Key @ Aug 22 2007, 03...   Aug 24 2007, 01:15
||- - Christopher Key   QUOTE (gabeg @ Aug 24 2007, 01:15) QUOTE ...   Aug 24 2007, 11:03
|- - MRC01   QUOTE (Christopher Key @ Aug 22 2007, 01...   Oct 18 2007, 06:14
- - SebastianG   Nice work! ... The infos about the LFSR are av...   Aug 22 2007, 13:50
|- - Christopher Key   QUOTE (SebastianG @ Aug 22 2007, 13:50) N...   Aug 22 2007, 14:04
- - eevan   You can find this link at Wikipedia. Take a look...   Aug 22 2007, 15:29
|- - Christopher Key   QUOTE (eevan @ Aug 22 2007, 15:29) You ca...   Aug 22 2007, 16:28
- - eevan   I've just tried your command-line decoder on o...   Aug 22 2007, 17:12
- - eevan   Thanks! Cheers   Aug 22 2007, 17:58
- - SebastianG   I didn't try but I'd guess the answer is: ...   Aug 24 2007, 09:15
- - dmckean   It works for me. I think the real solution needs t...   Aug 25 2007, 01:24
|- - Christopher Key   QUOTE (dmckean @ Aug 25 2007, 01:24) It w...   Aug 25 2007, 16:42
- - SebastianG   QUOTE (Christopher Key @ Aug 24 2007, 12...   Aug 27 2007, 08:21
|- - Christopher Key   QUOTE (SebastianG @ Aug 27 2007, 08:21) Q...   Aug 27 2007, 23:17
|- - Christopher Key   QUOTE (Christopher Key @ Aug 27 2007, 23...   Aug 29 2007, 19:12
|- - krabapple   QUOTE (Christopher Key @ Aug 29 2007, 14...   Aug 30 2007, 20:20
- - Walrusbonzo   Interesting stuff, I have 20~ HDCDs around here. ...   Aug 27 2007, 09:45
|- - adamjk   QUOTE (Walrusbonzo @ Aug 27 2007, 10:45) ...   Aug 27 2007, 11:36
- - Raiden   hdcd.exe < 16bit.wav > 24bit.wav   Aug 27 2007, 12:02
- - Walrusbonzo   Thanks guys.... Got it working.   Aug 27 2007, 13:44
- - Walrusbonzo   I've started to run all my known HDCD encoded ...   Aug 27 2007, 15:20
|- - bryant   QUOTE (Walrusbonzo @ Aug 27 2007, 07:20) ...   Aug 31 2007, 05:36
|- - SebastianG   QUOTE (bryant @ Aug 31 2007, 06:36) I als...   Aug 31 2007, 08:27
||- - bryant   QUOTE (SebastianG @ Aug 31 2007, 00:27) Q...   Sep 1 2007, 05:49
|- - Christopher Key   QUOTE (bryant @ Aug 31 2007, 05:36) Chris...   Aug 31 2007, 11:55
|- - bryant   QUOTE (Christopher Key @ Aug 31 2007, 03...   Sep 1 2007, 06:14
|- - Christopher Key   QUOTE (bryant @ Sep 1 2007, 06:14) I had ...   Sep 13 2007, 13:19
- - skamp   FLAC seems to support 20 bit audio. I don't su...   Aug 27 2007, 16:38
|- - Walrusbonzo   QUOTE (skamp @ Aug 27 2007, 16:38) FLAC s...   Aug 27 2007, 17:43
- - SebastianG   One could modify the decoder to output 24 bit samp...   Aug 27 2007, 18:10
|- - Walrusbonzo   QUOTE (SebastianG @ Aug 27 2007, 18:10) S...   Aug 27 2007, 18:30
|- - skamp   QUOTE (SebastianG @ Aug 27 2007, 19:10) S...   Aug 27 2007, 18:42
||- - lucas1985   I'm with SebastianG. This decoder should be re...   Aug 27 2007, 20:09
|- - SiriusB   QUOTE (SebastianG @ Aug 27 2007, 11:10) O...   Aug 30 2007, 03:38
|- - eevan   QUOTE (SiriusB @ Aug 30 2007, 04:38) Rega...   Aug 30 2007, 11:39
||- - skelly831   QUOTE (eevan @ Aug 30 2007, 03:39) When I...   Aug 30 2007, 15:33
|- - Christopher Key   QUOTE (SiriusB @ Aug 30 2007, 03:38) Hi g...   Aug 30 2007, 16:33
|- - krabapple   QUOTE (Christopher Key @ Aug 30 2007, 11...   Aug 30 2007, 19:56
|- - Christopher Key   [quote name='krabapple' date='Aug 30 2...   Aug 31 2007, 11:37
|- - SiriusB   QUOTE (Christopher Key @ Aug 31 2007, 04...   Aug 31 2007, 12:14
||- - Christopher Key   QUOTE (SiriusB @ Aug 31 2007, 12:14) Rega...   Aug 31 2007, 12:50
|- - Christopher Key   QUOTE (Christopher Key @ Aug 31 2007, 11...   Aug 31 2007, 17:35
|- - Christopher Key   QUOTE (Christopher Key @ Aug 31 2007, 17...   Aug 31 2007, 21:52
||- - SebastianG   QUOTE (Christopher Key @ Aug 31 2007, 22...   Sep 3 2007, 12:27
||- - gabeg   QUOTE (SebastianG @ Sep 3 2007, 05:27) Pe...   Sep 4 2007, 17:31
||- - SebastianG   QUOTE (gabeg @ Sep 4 2007, 18:31) So does...   Sep 5 2007, 08:29
||- - Christopher Key   QUOTE (SebastianG @ Sep 5 2007, 08:29) QU...   Sep 13 2007, 14:13
|- - SiriusB   QUOTE If anyone has access to a hardware decoder w...   Sep 1 2007, 00:36
|- - Christopher Key   QUOTE (SiriusB @ Sep 1 2007, 00:36) QUOTE...   Sep 1 2007, 16:09
|- - skamp   QUOTE (Christopher Key @ Sep 1 2007, 17:0...   Sep 1 2007, 18:50
|- - Christopher Key   QUOTE (skamp @ Sep 1 2007, 18:50) QUOTE (...   Sep 13 2007, 14:02
- - edwardar   Can I just say I'm very excited about this too...   Aug 27 2007, 23:05
- - Dynamic   The older foobar v0.8 series do allow Playback/Bit...   Aug 28 2007, 10:06
- - SiriusB   Yes, piping makes more sense than the way I did it...   Aug 31 2007, 13:20
- - Egor   FLAC --best compression results, 1.2.0 ICL compile...   Aug 31 2007, 14:38
|- - Christopher Key   QUOTE (Egor @ Aug 31 2007, 14:38) FLAC --...   Aug 31 2007, 22:40
- - Fool_on_the_hill   I did ABX on track Wag The Dog from Mark Knopfler...   Aug 31 2007, 21:19
|- - Dynamic   QUOTE (Fool_on_the_hill @ Aug 31 2007, 21...   Sep 1 2007, 01:13
- - Triza   Excellent work. Christopher. Well done. Any chan...   Sep 1 2007, 00:34
- - Fool_on_the_hill   QUOTE Dynamic Posted Yesterday, 18:13 QUOTE(...   Sep 1 2007, 20:32
- - Dynamic   Thanks for the info, FotH. I hadn't noticed th...   Sep 2 2007, 18:37
- - Cavaille   for heavens sake!!! it´s finally happe...   Sep 6 2007, 18:55
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th May 2015 - 21:26
