Eli's Suggested EAC settings for FLAC, See wiki for official EAC guides
Eli
post Jan 26 2005, 07:19
This guide is now becoming out of date, but should still give a very good start. I have not personally used EAC since some time mid-07. I now strongly suggest using dBpoweramp Reference. Note, EAC is free, dBpoweramp is not, plus to get the real benefits you need the better (ie more expensive package - Reference, not powerpack). However, dBpoweramp outperforms EAC in secure ripping on drives with C2 handling (basically most modern drives), being both faster and more reliable. In my experience dBpoweramp is also more stable than EAC. dBpoweramp is also being actively developed and updated. Spoon, its developer, is an active member here at HA. dBpoweramp is much easier to set up and configure, and features the best meta-data system available - PerfectMeta! A guide is available dBpoweramp FLAC guide
First, install EAC V0.95, Accurate Rip and configure with a key disk, and FLAC
EAC Options:
Extraction Tab
[X] Fill up missing offset samples with silence *Optional. For drives that overread lead in/out this is not needed.*
[ ] No use of null samples for CRC calculations *Doesnt change audio*
[X] Synchronize between tracks
[ ] Delete leading and trailing silent blocks
[X] Skip track extraction on read or sync errors (wont affect rip, but I check yes for next 3)
[X] Skip track extraction after duration longer than X times realtime
[X] After each 30 minutes of extraction, cool down the drive for 5 mins
[X] Lock drive tray during extraction
Extraction and compression priority: Normal
Error recovery quality: Medium **this is a change from my previous recommendation. This will decrease the number of error bars from 5 to 3. I have never had a rip go past 3 bars (really usually only 2 at most) and have an error free rip. Save the time. Plus its easier on your drive.
General Tab
doesnt matter for ripping.
Tools Tab
[X] Retrieve UPC/ISRC codes in CUE sheet generation
[X] Use CD-Text information in CUE sheet generation
[ ] Create '.m3u' playlist on extraction - **user option
[X] Automatically write status report on extraction
[X] On extraction, start external compressors queued in the background [1] - **user option.
[X] Do not open external compressor window - **user option
[X] Submit drive features after detection
[ ] Activate beginner mode, disable all advanced features
Normalization Tab
NOT CHECKED!!!
Filename Tab
Naming Scheme: %A - %C - %N - %T (or as you prefer, check EAC's FAQ.txt)
Various Artists: %C - %N - %A - %T (see above)
Catalog Tab
Not important
Directories Tab
**user option.
Write Tab
Nothing to do with extraction here
Interface Tab
Not so important, you can use the Native one
Drive Options
Extraction Method Tab
Secure Mode (after "detect read features" option is used, with appropriate settings)
**It is also reasonable to use Burst Mode if you always use Shift-F6 (Test & Copy). It has been argued that this is more secure then secure mode and its tends to be faster. Burst mode alone (without Test & Copy) is not secure!
[X] Drive caches audio data (clears the drive cache)
[ ] Drive is capable of C2
Drive Tab
Autodetect for drive read command
[ ] Big endian
[ ] Swap channels
[X] Spin up before extraction
Offset / Speed Tab
Offset locked by AccurateRip
Overread into lead-in and lead-out data (You will need to test this one on a disc, if you get a read sync error on the first or last track of a new CD your drive cant overread and the option should be unchecked - this will mean that you loose the number of samples equal to your drive offeset on either the first or last song, the only solution is a different drive)
[X] Allow speed reduction during extraction
[X] CD-Text Read capable drive
Gap Detection Tab
Gap/Index retreval method: per drive setting (start with method A or B)
Detection Accuracy: Secure (some prefer to use accurate)
Compression Options
External Compression Tab
[X] Use external compression
User defined encoder
Use file extension: .flac
Program including path: -browse and select flac.exe-
Additional Command Line Options:
-6 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T comment="%e" -T "comment=EAC (Secure Mode)" %s
Bitrate: Doesn't matter
[X] Delete WAV after compression
[ ] Use CRC check
[ ] Add ID3 tag
[X] Check for external compression return code
Offset Tab
[ ] Use offset detection for encoding and decoding Do NOT check this as it will add gaps to gapless music
When ripping the tracks, I suggest using Shift-F6 (test & copy) to decrease the chance of having a bad rip go undetected. The CRCs should match for the T&C, if they don't there is a problem.
You may want to look for a drive that can overread into the lead in and lead out. You will need to get this feature to get 100% perfect copies of CDs, though you probably wont notice if you dont have it. A list of drive features can be found here:
DAE Drive Feature Database - look for green in the overread column. The smaller the read offset the better too.
Plextors are almost a universally good choice. I strongly suggest investing in a Plextor since you will be archiving your CD collection. Do it once and do it right. In addition, there is a switch available that works for most Plextor drives that disables the drives cache. This gives burst mode speeds (often >30x) in secure mode. Search the forum for the -USEFUA switch if you have a plextor drive.
Edit: Removed broken links.
This post has been edited by Eli: May 5 2009, 22:24
http://forum.dbpoweramp.com/showthread.php?t=21072
westgroveg
post Jan 28 2005, 11:52
Filename Tab
Naming Scheme: %N - %T
Why do you suggest to include the CD title with various artists albums & not with single artist albums?
Eli
post Jan 28 2005, 20:23
encoding to -5 vs -8, on most modern computers will see little difference in encoding time. Plus encoding is a 1 time thing, so its my opinion that a little space savings is worth it. That being said, -5 is perfectly acceptable
This post has been edited by Eli: Jan 31 2005, 07:18
westgroveg
post Jan 31 2005, 06:23
QUOTE (Eli @ Jan 29 2005, 07:23 AM)
QUOTE (westgroveg @ Jan 28 2005, 05:52 AM)
Filename Tab
Since I also suggested Artist/Album file directories, which dont apply with various artist disks
This would result in files named
TrackNumber-Title (for same artist albums)
CDTitle-TrackNumber-TrackTitle (for various artists)
& are you suggesting various artist albums not have folders at all?
Still doesn’t make sense to me
Directories Tab
%A/%C  - **user option. This will give you Aritist/Album file directories
The directories tab is obviously not meant for this, it’s meant for creating a standard extraction directory such as “EAC Rips”. Folder & file name constructions should be defined in the Filename tab.
[X] Drive has ''Accurate Stream' feature
[_] Drive is capable of retrieving C2 error infomation
If unsure, these are the drive features I would suggest, they are the most generic & safest.
This post has been edited by westgroveg: Jan 31 2005, 07:47
- Eli   Eli's Suggested EAC settings for FLAC   Jan 26 2005, 07:19
- - Tomcat   About used commandline options: Why -8? If we...   Jan 28 2005, 11:24
|- - R.A.F.   QUOTE (Tomcat @ Jan 28 2005, 12:24) About...   Aug 20 2006, 05:21
- - westgroveg   QUOTE Filename Tab Naming Scheme: %N - %T Various ...   Jan 28 2005, 11:52
|- - Eli   encoding to -5 vs -8, on most modern computers wil...   Jan 28 2005, 20:23
|- - westgroveg   QUOTE (Eli @ Jan 29 2005, 07:23 AM)QUOTE (wes...   Jan 31 2005, 06:23
||- - Eli   oops, your right. Fixed   Jan 31 2005, 07:18
|- - JWolf   QUOTE (Eli @ Jan 28 2005, 15:23) encoding...   Aug 10 2006, 14:43
|- - wylistener   QUOTE (JWolf @ Aug 10 2006, 08:43) QUOTE ...   Aug 10 2006, 16:39
|- - Eli   My experience is not based on such large scale enc...   Aug 10 2006, 17:25
|- - wylistener   QUOTE (Eli @ Aug 10 2006, 11:25) My exper...   Aug 10 2006, 17:37
- - PachmanP   QUOTE (Tomcat @ Jan 28 2005, 06:24 AM)About u...   Jan 28 2005, 19:32
- - darky   QUOTE (Eli @ Jan 26 2005, 08:19 AM)First, ins...   Jan 28 2005, 21:13
- - Tomcat   Because I'm working at time the flac is compre...   Jan 31 2005, 05:51
- - user   and drives, which don't have accurate stream ?...   Jan 31 2005, 13:25
- - westgroveg   (user) QUOTE and drives, which don't have accu...   Jan 31 2005, 13:36
|- - Eli   QUOTE (westgroveg @ Jan 31 2005, 07:36 AM)Fol...   Jul 31 2005, 14:49
|- - Calufraxis   QUOTE I personally am divided between: Artist/Alb...   Jul 31 2005, 18:03
- - Martin H   My ideal naming scheme : Artist/(Year) Album/nn. ...   Aug 1 2005, 03:32
- - clintb   QUOTE (Calufraxis @ Jul 31 2005, 11:03 AM)QUO...   Aug 1 2005, 15:25
|- - Martin H   QUOTE (clintb @ Aug 1 2005, 04:25 PM)Easily s...   Aug 2 2005, 02:07
- - user   Hi Martin, very good summary, why I prefer rippin...   Aug 4 2005, 13:26
|- - TCM   QUOTE [ ]Fill up missing offset samples with silen...   Aug 4 2005, 17:37
|- - Mechannibal   QUOTE [ ]Fill up missing offset samples with silen...   Aug 4 2005, 18:43
||- - TCM   QUOTE (Mechannibal @ Aug 4 2005, 07:43 PM)In ...   Aug 4 2005, 19:13
|- - lmpine   QUOTE (TCM @ Aug 4 2005, 12:37 PM)QUOTE [ ]Fi...   Aug 4 2005, 21:03
|- - MarkK   QUOTE (lmpine @ Aug 4 2005, 03:03 PM)QUOTE (T...   Aug 4 2005, 21:12
|- - lmpine   QUOTE (MarkK @ Aug 4 2005, 04:12 PM)QUOTE (lm...   Aug 4 2005, 21:21
|- - MarkK   Thanks for the response. Should I be doing somet...   Aug 4 2005, 21:37
|- - Mechannibal   QUOTE (lmpine @ Aug 4 2005, 08:21 PM)Should I...   Aug 4 2005, 21:55
|- - TCM   from what i understand, the "more sophisticat...   Aug 4 2005, 22:04
|- - Mechannibal   QUOTE (TCM @ Aug 4 2005, 09:04 PM)from what i...   Aug 4 2005, 22:47
- - Martin H   QUOTE (user @ Aug 4 2005, 02:26 PM)Hi Martin,...   Aug 4 2005, 23:54
|- - lmpine   QUOTE (Martin H @ Aug 4 2005, 06:54 PM)QUOTE ...   Sep 23 2005, 03:29
|- - Martin H   QUOTE (lmpine @ Sep 23 2005, 04:29 AM)I assum...   Sep 23 2005, 03:48
|- - lmpine   QUOTE (Martin H @ Sep 22 2005, 10:48 PM)QUOTE...   Sep 23 2005, 04:00
|- - user   Thanks for the reply. Sorry for being dense, but ...   Sep 23 2005, 09:07
- - Eli   Only a matching CRC in EAC or a match in AccurateR...   Sep 24 2005, 13:14
- - Bourne   Let me see if I understood this thread: To get a ...   Aug 19 2006, 03:39
|- - greynol   QUOTE (Bourne @ Aug 18 2006, 19:39) #1 - ...   Aug 19 2006, 18:04
- - Eli   There is a difference between getting a perfect ri...   Aug 19 2006, 19:51
- - Bourne   let me see if I understood this... Not even Secur...   Aug 19 2006, 22:05
|- - greynol   I use Test & Copy in burst mode or in secure m...   Aug 19 2006, 23:20
|- - Eli   QUOTE (greynol @ Aug 19 2006, 18:20) What...   Aug 20 2006, 00:09
|- - greynol   QUOTE (Eli @ Aug 19 2006, 16:09) This is ...   Aug 20 2006, 00:57
|- - Eli   greynol, I think we are saying the same thing. I b...   Aug 20 2006, 03:00
- - Bourne   well, I read your explanations.... but the funny t...   Aug 20 2006, 05:44
- - unmake   Quick question: does the "Spin Up Drive Befor...   Aug 20 2006, 06:45
|- - Eli   QUOTE (unmake @ Aug 20 2006, 01:45) Quick...   Aug 20 2006, 14:28
- - greynol   @Eli, yes we agree. I am more confident with mat...   Aug 20 2006, 19:00
- - Bourne   -   Aug 20 2006, 20:30
- - hellokeith   Two questions: 1. Only half of my tracks are rep...   Aug 24 2006, 03:38
- - Bourne   I am seriously MISSING the LP and Cassette days......   Aug 26 2006, 23:36
- - hellokeith   Well I've immensely improved AccurateRip resul...   Aug 29 2006, 05:31
|- - heavyblow   I have a problem... The result of my ripping is t...   Sep 6 2006, 17:09
|- - dewey1973   QUOTE (heavyblow @ Sep 6 2006, 08:09) I h...   Dec 13 2006, 23:20
- - MusX   QUOTE Drive Options... Offset / Speed Tab... Offse...   Sep 7 2006, 09:37
|- - Eli   QUOTE (MusX @ Sep 7 2006, 04:37) QUOTE Dr...   Sep 11 2006, 23:08
- - Jipcy   What's the best method for appending gaps? Ap...   Sep 20 2006, 06:25
|- - user   QUOTE (Jipcy @ Sep 20 2006, 07:25) [b]Wha...   Sep 27 2006, 14:42
- - Bobjua   what about under the waveform tab in compression o...   Oct 27 2006, 01:26
- - greynol   You'll notice that everthing in the Waveform t...   Oct 27 2006, 01:39
- - Bobjua   damn. i just ripped 2 cds, but for some reason the...   Oct 27 2006, 02:57
- - nilsHaus   This is a pretty long thread, so can anyone tell m...   Oct 28 2006, 01:16
|- - JWolf   QUOTE (nilsHaus @ Oct 27 2006, 19:16) Thi...   Dec 1 2006, 01:44
- - Mekatype   I plan to create backups of all my rother's co...   Jan 3 2007, 14:07
- - hellokeith   As I understand it, in all likelihood the missing ...   Jan 5 2007, 03:01
|- - greynol   QUOTE (hellokeith @ Jan 4 2007, 18:01) As...   Jan 5 2007, 03:56
- - hellokeith   No. The Read-Offset only affects the reading of t...   Jan 5 2007, 04:13
|- - greynol   QUOTE (hellokeith @ Jan 4 2007, 19:13) No...   Jan 5 2007, 07:52
- - Mekatype   So I shouldn't worry too much then. Thanks for...   Jan 8 2007, 05:19
- - ricecake   QUOTE (Eli @ Jan 26 2005, 02:19) Addition...   Feb 18 2007, 09:14
|- - Eli   QUOTE (ricecake @ Feb 18 2007, 03:14) QUO...   Mar 4 2007, 17:23
- - Desides   Excellent guide. Thank you, Eli, for writing it...   Mar 22 2007, 23:07
|- - Eli   QUOTE (Desides @ Mar 22 2007, 18:07) Exce...   Mar 25 2007, 16:21
- - JJZolx   QUOTE (Eli @ Jan 26 2005, 00:19) Addition...   Mar 26 2007, 03:58
- - isamu   Guys, I'm currently ripping my CDs to flac via...   Apr 21 2007, 07:52
|- - user   timing problems ? sounds, you rip in EACs burst mo...   Apr 21 2007, 19:47
- - greynol   QUOTE (user @ Apr 21 2007, 11:47) [...] i...   Apr 21 2007, 21:14
- - Petlydecker   Hello, I am using Exact Audio Copy 0.99 Bet...   Jul 24 2007, 17:39
|- - Eli   QUOTE (Petlydecker @ Jul 24 2007, 12:39) ...   Jul 24 2007, 18:48
- - verbajim   QUOTE (Petlydecker @ Jul 24 2007, 18:39) ...   Jul 25 2007, 00:13
- - countryman   QUOTE (Eli @ Jan 26 2005, 06:19) However,...   Aug 17 2007, 03:32
- - Empgamer   Must admit I'd be interested to hear to. If d...   Aug 26 2007, 13:29
- - Sgt_Strider   Hey guys, I'm just wondering if it's still...   Sep 11 2007, 04:59
- - greynol   I personally think a guide designed to help people...   Sep 11 2007, 06:40
|- - Sgt_Strider   QUOTE (greynol @ Sep 10 2007, 22:40) I pe...   Sep 12 2007, 08:44
- - greynol   C2 pointers with T&C in EAC is perfectly fine....   Sep 12 2007, 09:01
|- - Sgt_Strider   QUOTE (greynol @ Sep 12 2007, 01:01) C2 p...   Sep 14 2007, 05:18
|- - greynol   QUOTE (Sgt_Strider @ Sep 13 2007, 21:18) ...   Sep 14 2007, 06:37
|- - Sgt_Strider   QUOTE (greynol @ Sep 13 2007, 22:37) QUOT...   Sep 14 2007, 09:30
|- - greynol   QUOTE (Sgt_Strider @ Sep 14 2007, 01:30) ...   Sep 14 2007, 18:38
|- - Sgt_Strider   QUOTE (greynol @ Sep 14 2007, 10:38) QUOT...   Sep 14 2007, 22:21
|- - greynol   QUOTE (Sgt_Strider @ Sep 14 2007, 14:21) ...   Sep 14 2007, 22:28
- - rickd   Do I need to have a cuesheet with my flac rips to ...   Dec 8 2007, 03:08
|- - Synthetic Soul   QUOTE (rickd @ Dec 8 2007, 02:08) Do I ne...   Dec 8 2007, 12:01
- - eevan   He said that he's ripping to single files So...   Dec 8 2007, 12:12
|- - Synthetic Soul   QUOTE (eevan @ Dec 8 2007, 11:12) He said...   Dec 8 2007, 12:14
|- - greynol   QUOTE (eevan @ Dec 8 2007, 03:12) So, the...   Dec 8 2007, 20:18
- - lipidicman   A question for Greynol I guess. I've had some ...   Jan 11 2008, 11:49
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th March 2015 - 07:44
