FLAC Stream Decoder Error, FLAC__STREAM_DECODER_ERROR_STATUS_LOST_S
Zennon
post Jan 16 2005, 03:01
I'm in the process of backing up 500 CD-DA discs in FLAC format (using EAC). I ran a shell script to test (flac.exe -t; flac version 1.1.1) the 4000 FLAC files on my hard drive so far and found that flac.exe reported errors for 36 files. All errors are the same:
<filename>: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
The files decompress fine, but now I'm not sure if I got the exact WAVs back. What does this error message mean, and how severe is the error? Moreover, is there a way to avoid it when compressing WAVs to FLAC in EAC?
This post has been edited by Zennon: Jan 17 2005, 00:10
viktor
post May 21 2007, 19:55
QUOTE (Roobar @ May 21 2007, 01:34) *
Hey viktor... I don't want to jump over your post, but I am having similar problems with my flacs. Not sure if this is hardware or software, but it sure seems like we need to regularly run tests on our flac library to check for errors.
yea i surely will, at least to recognize hdd failurs in time. this is the simplest way.
its more likely that you also have hw problems.
i cant be sure in my case, but now im waiting for any error to occur again. in theory my hw is fixed now, so it shouldnt.
well see.
anyway, havent you had any hw problems recently?
Roobar
post May 23 2007, 03:22
QUOTE (viktor @ May 22 2007, 04:55) *
It looks like it might be a problem with the firewire connection. I have moved the ext hdd to a USB2 port and will correct the corrupted files. There was also a problem with a previous release of Media Monkey that might have also corrupted some files. The problem with these types of things is that corrupt files are "hidden" until you try to use them again. In my case, I was playing around with Synthetic Soul's flac-verify.bat file and just happened to stumble on a corrupt flac file. Pure chance.
So now I have created a batch file that I can schedule overnight to check the entire flac library directory and flag any corrupted files into a log file. I have also created a batch file that can check an album directory, create a log file of the complete flac -t output for every track and store this in the album directory. It also creates a .swf file for the directory. Once this is done, I'll also include a check of the .swf file in the library check procedure to see if throws up any errors on all other files (jpg, etc) in my library.
The bottom line is that, if we're wanting to archive our CD collection with a lossless copy, we must have a system to regularly test the archive so that we can catch problems before they get out of control. If I had been able to see that I was getting corrupt flac files when I only had one or two, this would not have become such a big problem. I should also have checked my entire flac directory when I moved it from one external hdd to another before I formatted the source hdd.
This post has been edited by Roobar: May 23 2007, 03:24
- Zennon   FLAC Stream Decoder Error   Jan 16 2005, 03:01
- - jcoalson   if a file tests fine and the md5sum is non-zero (d...   Jan 16 2005, 05:56
|- - Zennon   Josh, thanks for your reply. It's always a del...   Jan 17 2005, 13:56
|- - jcoalson   QUOTE (Zennon @ Jan 17 2005, 07:56 AM)So the ...   Jan 17 2005, 23:14
|- - Zennon   QUOTE (jcoalson @ Jan 17 2005, 02:14 PM)QUOTE...   Jan 17 2005, 23:32
|- - Zennon   Yes, the error that I get is a decoder error. What...   Jan 17 2005, 23:37
- - jcoalson   the best way is if you can host it somewhere acces...   Jan 18 2005, 01:02
|- - Zennon   OK, I will upload a buggy FLAC tonight. Not sure ...   Jan 18 2005, 01:22
- - 80k   I had an interesting situation with the same error...   Jan 18 2005, 06:33
|- - jcoalson   QUOTE (80k @ Jan 18 2005, 12:33 AM)... any id...   Jan 18 2005, 06:39
- - jcoalson   I looked at your files quickly... the sync error s...   Jan 20 2005, 01:35
|- - Zennon   Thanks Josh, that's good news. I guess now I d...   Jan 20 2005, 03:48
- - jcoalson   OK, found the problem. it is a decoder bug that i...   Jan 24 2005, 01:22
|- - 80k   QUOTE (jcoalson @ Jan 23 2005, 04:22 PM)OK, f...   Jan 24 2005, 07:33
|- - jcoalson   QUOTE (80k @ Jan 24 2005, 01:33 AM)so a fix w...   Jan 24 2005, 09:01
|- - Zennon   Josh, many thanks for sorting this out. Glad to he...   Jan 26 2005, 01:33
|- - KingTubba   I was wondering if you could help me out. I have a...   Apr 20 2005, 16:18
|- - jcoalson   QUOTE (KingTubba @ Apr 20 2005, 10:18 AM)I wa...   Apr 20 2005, 17:49
|- - jcoalson   QUOTE (KingTubba @ Apr 20 2005, 10:18 AM)I wa...   Apr 21 2005, 01:45
|- - KingTubba   QUOTE (jcoalson @ Apr 20 2005, 08:45 PM)got t...   Apr 21 2005, 15:13
|- - jcoalson   QUOTE (KingTubba @ Apr 21 2005, 09:13 AM)So n...   Apr 21 2005, 18:03
|- - guygee   QUOTE (jcoalson @ Apr 21 2005, 12:03 PM)no, t...   Apr 1 2006, 16:16
|- - guygee   QUOTE (guygee @ Apr 1 2006, 10:16 AM)--------...   Apr 1 2006, 17:00
- - kjoonlee   How about using an ID3 editor to just chop the ID3...   Apr 20 2005, 16:46
|- - guest0101   QUOTE (kjoonlee @ Apr 20 2005, 08:46 AM)How a...   Apr 20 2005, 16:57
- - kjoonlee   Well, have you tried Case's Tag?   Apr 20 2005, 17:26
- - Synthetic Soul   QUOTE (kjoonlee @ Apr 20 2005, 05:26 PM)Well,...   Apr 20 2005, 22:07
|- - kjoonlee   QUOTE (Synthetic Soul @ Apr 21 2005, 06:07 AM...   Apr 21 2005, 03:33
|- - Deep_Elem   QUOTE (Synthetic Soul @ Apr 20 2005)I believe...   Apr 21 2005, 05:46
- - KingTubba   Thanks for the help. I'll check out affd. Keep...   Apr 21 2005, 18:09
- - mad_arab   I have the same problem. 3 songs out of 7 albums g...   May 2 2005, 11:11
- - KingTubba   Still have those files... ...still haven't fou...   Feb 17 2006, 22:35
- - KingTubba   CORRECTION: flacdec was able to recover each one o...   Feb 24 2006, 14:37
- - jcoalson   ok, I just checked in a fix for -F that will allow...   Jun 14 2006, 02:46
|- - axisjack   [quote name='jcoalson' date='Jun 13 20...   Sep 2 2006, 10:54
- - jcoalson   hopefully some time this month. most of the new m...   Sep 5 2006, 20:50
|- - towolf   QUOTE (jcoalson @ Sep 5 2006, 21:50) hope...   Oct 1 2006, 16:08
- - jcoalson   sorry, code is too different. there will be a bet...   Oct 2 2006, 05:23
- - xmixahlx   affd was updated to 0.1.1 (last year, actually) ht...   Oct 5 2006, 09:08
- - viktor   hi, i have several flac files on my laptop hdd. s...   May 19 2007, 02:56
- - viktor   i think ive realised the source of the problem. on...   May 20 2007, 08:53
|- - jcoalson   QUOTE (viktor @ May 20 2007, 02:53) offto...   May 20 2007, 16:56
- - viktor   QUOTE (jcoalson @ May 20 2007, 16:56) QUO...   May 20 2007, 21:15
- - Roobar   Hey viktor... I don't want to jump over your p...   May 21 2007, 01:34
- - viktor   QUOTE (Roobar @ May 21 2007, 01:34) Hey v...   May 21 2007, 19:55
|- - Roobar   QUOTE (viktor @ May 22 2007, 04:55) anywa...   May 23 2007, 03:22
- - viktor   hmm i think its not that serious.. once you locate...   May 23 2007, 08:45
- - tenfoot   Hello: I've got a similar problem to that des...   Jan 6 2012, 04:38
- - tenfoot   I've uploaded the flac in question to hotfile:...   Jan 6 2012, 04:51
- - Porcus   Destroyed beyond repair. Try to .zip it, and you w...   Jan 6 2012, 12:35
- - tenfoot   QUOTE (Porcus @ Jan 6 2012, 03:35) Destro...   Jan 6 2012, 20:25
- - Porcus   QUOTE (tenfoot @ Jan 6 2012, 20:25) Still...   Jan 7 2012, 01:55
RSS Lo-Fi Version Time is now: 2nd June 2015 - 10:37
