FLAC Stream Decoder Error, FLAC__STREAM_DECODER_ERROR_STATUS_LOST_S
Zennon
post Jan 16 2005, 03:01
I'm in the process of backing up 500 CD-DA discs in FLAC format (using EAC). I ran a shell script to test (flac.exe -t; flac version 1.1.1) the 4000 FLAC files on my hard drive so far and found that flac.exe reported errors for 36 files. All errors are the same:
<filename>: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
The files decompress fine, but now I'm not sure if I got the exact WAVs back. What does this error message mean, and how severe is the error? Moreover, is there a way to avoid it when compressing WAVs to FLAC in EAC?
This post has been edited by Zennon: Jan 17 2005, 00:10
jcoalson
post Jan 24 2005, 01:22
FLAC Developer
OK, found the problem. it is a decoder bug that is exposed when there is an id3 tag at the end of the file AND the last frame of the audio stream has a certain blocksize. integrity of the audio is not affected but the sync error is annoying. no need to re-encode either.
it's fixed in CVS and will be in the next release.
Josh
80k
post Jan 24 2005, 07:33
QUOTE (jcoalson @ Jan 23 2005, 04:22 PM)
Josh
interesting. yea it has happened to me a bunch, and i just decoded and reencoded (which stripped the id3 tag, i guess). i did it because foobar always pops up a message and i wanted it to go away smile.gif
so a fix would be to set EAC to not "add ID3 tag", huh? in fact, the ID3 tag really does nothing and has no place/purpose in a flac file, cuz it uses a different tagging system?
Zennon
post Jan 26 2005, 01:33
Josh, many thanks for sorting this out. Glad to hear I don't have to re-rip/re-encode.
Zennon
KingTubba
post Apr 20 2005, 16:18
I was wondering if you could help me out. I have a bunch of flacs (with no access to the original sources) that I encoded but give the LOST_SYNC error when verified. The strange thing is they will play fine in Media Monkey if a non LOST_SYNC file is played first (?). Anyway, is there anyway to fix the files? flac -d doesn't work. It gives the same error, and if you tell decode through errors is says something about the source file being to big for a single wav chunk. Note: Yes, these were originally encoded with an id3 tag, silly of me...
Any ideas on how to fix the files? I do have a 4MB sample (its an intro to a "song") that I could email over if anyone needs to see it. Feel free to reply here or email me at maps1@nesurf.com.
jcoalson
post Apr 21 2005, 01:45
FLAC Developer
QUOTE (KingTubba @ Apr 20 2005, 10:18 AM)
got the file. it's corrupted. I can see in a hex editor that there are big blocks of zeroes where the middle of the id3v2 tag and beginning of the FLAC stream should be.
flac -dF is currently not able to decode through errors like this.
Josh
KingTubba
post Apr 21 2005, 15:13
QUOTE (jcoalson @ Apr 20 2005, 08:45 PM)
Josh
So no way to fix it yet? No flac repair tools out there yet huh? Will using Case's Tag as stated above have any effect?
By the way, I repeat, the files play and sound great in Media Monkey (if I play a song that does not have this problem first), so I'm a little confused by your statement that the begining of the FLAC stream has a bunch of zeros in it...
P.S. I forgot to mention, that if there is a way to repari the file I do not mind loosing any of the tags as there are a plenty of programs that will be able to retag them from their filename/directory struction.
This post has been edited by KingTubba: Apr 21 2005, 17:55
jcoalson
post Apr 21 2005, 18:03
FLAC Developer
QUOTE (KingTubba @ Apr 21 2005, 09:13 AM)
no, the damage is too severe. it is possible to recover frames on a frame-by-frame basis totally ignoring the metadata but I still have to add that functionality to -F.
another FLAC developer has written a frame decoder that includes recovery but I haven't tried it. it may work for your files:
http://phoenix.inf.upol.cz/~lichvarm/affd/affd-0.1.0.tar.gz
not on this file I don't think. even the id3v2 tag is corrupted.
can't explain that.
Josh
- Zennon   FLAC Stream Decoder Error   Jan 16 2005, 03:01
- - jcoalson   if a file tests fine and the md5sum is non-zero (d...   Jan 16 2005, 05:56
|- - Zennon   Josh, thanks for your reply. It's always a del...   Jan 17 2005, 13:56
|- - jcoalson   QUOTE (Zennon @ Jan 17 2005, 07:56 AM)So the ...   Jan 17 2005, 23:14
|- - Zennon   QUOTE (jcoalson @ Jan 17 2005, 02:14 PM)QUOTE...   Jan 17 2005, 23:32
|- - Zennon   Yes, the error that I get is a decoder error. What...   Jan 17 2005, 23:37
- - jcoalson   the best way is if you can host it somewhere acces...   Jan 18 2005, 01:02
|- - Zennon   OK, I will upload a buggy FLAC tonight. Not sure ...   Jan 18 2005, 01:22
- - 80k   I had an interesting situation with the same error...   Jan 18 2005, 06:33
|- - jcoalson   QUOTE (80k @ Jan 18 2005, 12:33 AM)... any id...   Jan 18 2005, 06:39
- - jcoalson   I looked at your files quickly... the sync error s...   Jan 20 2005, 01:35
|- - Zennon   Thanks Josh, that's good news. I guess now I d...   Jan 20 2005, 03:48
- - jcoalson   OK, found the problem. it is a decoder bug that i...   Jan 24 2005, 01:22
|- - 80k   QUOTE (jcoalson @ Jan 23 2005, 04:22 PM)OK, f...   Jan 24 2005, 07:33
|- - jcoalson   QUOTE (80k @ Jan 24 2005, 01:33 AM)so a fix w...   Jan 24 2005, 09:01
|- - Zennon   Josh, many thanks for sorting this out. Glad to he...   Jan 26 2005, 01:33
|- - KingTubba   I was wondering if you could help me out. I have a...   Apr 20 2005, 16:18
|- - jcoalson   QUOTE (KingTubba @ Apr 20 2005, 10:18 AM)I wa...   Apr 20 2005, 17:49
|- - jcoalson   QUOTE (KingTubba @ Apr 20 2005, 10:18 AM)I wa...   Apr 21 2005, 01:45
|- - KingTubba   QUOTE (jcoalson @ Apr 20 2005, 08:45 PM)got t...   Apr 21 2005, 15:13
|- - jcoalson   QUOTE (KingTubba @ Apr 21 2005, 09:13 AM)So n...   Apr 21 2005, 18:03
|- - guygee   QUOTE (jcoalson @ Apr 21 2005, 12:03 PM)no, t...   Apr 1 2006, 16:16
|- - guygee   QUOTE (guygee @ Apr 1 2006, 10:16 AM)--------...   Apr 1 2006, 17:00
- - kjoonlee   How about using an ID3 editor to just chop the ID3...   Apr 20 2005, 16:46
|- - guest0101   QUOTE (kjoonlee @ Apr 20 2005, 08:46 AM)How a...   Apr 20 2005, 16:57
- - kjoonlee   Well, have you tried Case's Tag?   Apr 20 2005, 17:26
- - Synthetic Soul   QUOTE (kjoonlee @ Apr 20 2005, 05:26 PM)Well,...   Apr 20 2005, 22:07
|- - kjoonlee   QUOTE (Synthetic Soul @ Apr 21 2005, 06:07 AM...   Apr 21 2005, 03:33
|- - Deep_Elem   QUOTE (Synthetic Soul @ Apr 20 2005)I believe...   Apr 21 2005, 05:46
- - KingTubba   Thanks for the help. I'll check out affd. Keep...   Apr 21 2005, 18:09
- - mad_arab   I have the same problem. 3 songs out of 7 albums g...   May 2 2005, 11:11
- - KingTubba   Still have those files... ...still haven't fou...   Feb 17 2006, 22:35
- - KingTubba   CORRECTION: flacdec was able to recover each one o...   Feb 24 2006, 14:37
- - jcoalson   ok, I just checked in a fix for -F that will allow...   Jun 14 2006, 02:46
|- - axisjack   [quote name='jcoalson' date='Jun 13 20...   Sep 2 2006, 10:54
- - jcoalson   hopefully some time this month. most of the new m...   Sep 5 2006, 20:50
|- - towolf   QUOTE (jcoalson @ Sep 5 2006, 21:50) hope...   Oct 1 2006, 16:08
- - jcoalson   sorry, code is too different. there will be a bet...   Oct 2 2006, 05:23
- - xmixahlx   affd was updated to 0.1.1 (last year, actually) ht...   Oct 5 2006, 09:08
- - viktor   hi, i have several flac files on my laptop hdd. s...   May 19 2007, 02:56
- - viktor   i think ive realised the source of the problem. on...   May 20 2007, 08:53
|- - jcoalson   QUOTE (viktor @ May 20 2007, 02:53) offto...   May 20 2007, 16:56
- - viktor   QUOTE (jcoalson @ May 20 2007, 16:56) QUO...   May 20 2007, 21:15
- - Roobar   Hey viktor... I don't want to jump over your p...   May 21 2007, 01:34
- - viktor   QUOTE (Roobar @ May 21 2007, 01:34) Hey v...   May 21 2007, 19:55
|- - Roobar   QUOTE (viktor @ May 22 2007, 04:55) anywa...   May 23 2007, 03:22
- - viktor   hmm i think its not that serious.. once you locate...   May 23 2007, 08:45
- - tenfoot   Hello: I've got a similar problem to that des...   Jan 6 2012, 04:38
- - tenfoot   I've uploaded the flac in question to hotfile:...   Jan 6 2012, 04:51
- - Porcus   Destroyed beyond repair. Try to .zip it, and you w...   Jan 6 2012, 12:35
- - tenfoot   QUOTE (Porcus @ Jan 6 2012, 03:35) Destro...   Jan 6 2012, 20:25
- - Porcus   QUOTE (tenfoot @ Jan 6 2012, 20:25) Still...   Jan 7 2012, 01:55
RSS Lo-Fi Version Time is now: 27th May 2015 - 19:47
