Any listening test Stereo vs Joint stereo in mp3?
crazyman
post Jan 14 2005, 14:46
Hi all,
in many discussions I read about mp3 via Lame encoder the result is that the best solution is joint stereo. I believe in that as the developers who I highly esteem say so. But is this statement supported also by more independent listening tests? Especially I would be interested in comparison between --preset standard (joint stereo) and dtto with stereo mode.
Can the result in general depend also on the Lame version? From the tests I could read usually still the old good Lame 3.90.3 comes out as the winner.
Crazyman
beto
post Jan 14 2005, 14:51
Group: Members (Donating)
This makes no sense, since joint stereo is just a way to encode stereo losslessly.
There should be no audible difference between them AFAIK....
http://volutabro.blogspot.com
mithrandir
post Jan 14 2005, 16:38
QUOTE (beto @ Jan 14 2005, 08:51 AM)
No, joint stereo is lossy. That's what directed the Scene to use full stereo mode (not that they really know what they are doing). But joint stereo can be objectively transparent if implemented properly...and it can save you a lot of bits. There is generally no need to use full stereo in LAME.
Otto42
post Jan 14 2005, 16:50
QUOTE (mithrandir @ Jan 14 2005, 09:38 AM)
Depends on what you're talking about. As I understood it, there's two ways to do Joint Stereo. Mid/Side Stereo is lossless. Intensity Stereo is lossy. But intensity stereo is only used at low bitrates (96k and less) and so Joint Stereo is lossless at normal bitrates used for audio anyway.
So in other words, Joint Stereo can only improve quality by offering another possible data set to compress and giving a possible higher quality. Using Stereo Only makes no sense because that's just eliminating the possibility of using M/S encoding.
This post has been edited by Otto42: Jan 14 2005, 16:53
http://ottodestruct.com
- crazyman   Any listening test Stereo vs Joint stereo in mp3?   Jan 14 2005, 14:46
- - beto   This makes no sense, since joint stereo is just a ...   Jan 14 2005, 14:51
|- - mithrandir   QUOTE (beto @ Jan 14 2005, 08:51 AM)This make...   Jan 14 2005, 16:38
|- - Otto42   QUOTE (mithrandir @ Jan 14 2005, 09:38 AM)No,...   Jan 14 2005, 16:50
|- - dev0   QUOTE (mithrandir @ Jan 14 2005, 04:38 PM)No,...   Jan 14 2005, 18:42
|- - Mark7   QUOTE (dev0 @ Jan 14 2005, 09:42 AM)QUOTE (mi...   Jan 14 2005, 19:04
|- - mithrandir   QUOTE (dev0 @ Jan 14 2005, 12:42 PM)QUOTE (mi...   Jan 14 2005, 22:44
|- - Jojo   QUOTE (mithrandir @ Jan 14 2005, 01:44 PM)If ...   Jan 15 2005, 01:49
|- - Busemann   QUOTE (Jojo @ Jan 14 2005, 04:49 PM)QUOTE (mi...   Jan 15 2005, 01:55
|- - Jojo   QUOTE (Busemann @ Jan 14 2005, 04:55 PM)QUOTE...   Jan 15 2005, 02:03
- - SirGrey   >>No, joint stereo is lossy. Wrong. joint-st...   Jan 14 2005, 16:48
- - SirGrey   Addenium: Lots of the confusion goes from Fhg. The...   Jan 14 2005, 16:53
- - Gray_Wolf   This is incredible Many people in present mome...   Jan 14 2005, 17:10
|- - crazyman   QUOTE (Gray_Wolf @ Jan 14 2005, 08:10 AM)This...   Jan 19 2005, 09:30
|- - Busemann   QUOTE (crazyman @ Jan 19 2005, 12:30 AM)Quite...   Jan 19 2005, 11:44
|- - crazyman   QUOTE (Busemann @ Jan 19 2005, 02:44 AM)QUOTE...   Jan 20 2005, 11:29
- - Jojo   The bottom line is that Joint-Stereo used in LAME ...   Jan 14 2005, 17:53
- - 2Bdecided   The stereo to joint stereo (i.e. L+R>M+S) trans...   Jan 17 2005, 16:34
|- - crazyman   QUOTE (2Bdecided @ Jan 17 2005, 07:34 AM)The ...   Jan 19 2005, 09:25
|- - mithrandir   QUOTE (2Bdecided @ Jan 17 2005, 10:34 AM)The ...   Jan 20 2005, 05:52
- - MugFunky   guh, why has this myth never been dispelled? it s...   Jan 20 2005, 06:29
|- - DreamTactix291   QUOTE (MugFunky @ Jan 19 2005, 11:29 PM)guh, ...   Jan 20 2005, 06:56
- - Gabriel   The M/S stereo transform itself is lossless. Howev...   Jan 20 2005, 09:13
- - 2Bdecided   Talk about things coming back to bite you... I...   Jan 21 2005, 12:10
- - Gabriel   Well, in your case intensity stereo is a good thin...   Jan 21 2005, 13:55
|- - Bogalvator   QUOTE (Gabriel @ Jan 21 2005, 04:55 AM)Well, ...   Jan 22 2005, 04:49
|- - 2Bdecided   QUOTE (Gabriel @ Jan 21 2005, 12:55 PM)Well, ...   Jan 24 2005, 17:00
- - Gabriel   QUOTE but the broadcasters have reportedly asked f...   Jan 24 2005, 20:41
- - Ossie   Hi, I just want to check if the following staement...   May 21 2005, 10:57
- - Pio2001   It all depends if the psychoacoustic model can han...   May 21 2005, 13:01
- - Pio2001   Oh, that's not all, you'll have to force m...   May 21 2005, 13:07
- - mjkng2   hey this is an old article against Joint Stereo: ...   Aug 4 2006, 19:20
|- - Garf   QUOTE (mjkng2 @ Aug 4 2006, 20:20) hey t...   Aug 5 2006, 09:44
- - stephanV   It's not against JS... it just says that an al...   Aug 4 2006, 20:16
- - Pio2001   I've performed two joint stereo listening test...   Aug 4 2006, 22:52
- - haregoo   This sample is ABXable(16/16) even with -V 0 becau...   Aug 5 2006, 03:57
- - Gabriel   QUOTE (haregoo @ Aug 5 2006, 04:57) This ...   Aug 5 2006, 08:48
- - haregoo   QUOTE (Gabriel @ Aug 5 2006, 16:48) Regar...   Aug 5 2006, 14:14
RSS Lo-Fi Version Time is now: 26th January 2015 - 10:22
