17 Pages V  « < 4 5 6 7 8 > »
foo_skip: skip tracks that match a specified search query, Was: [Request] Inactive Tracks
burn416
post May 4 2009, 22:27
Post #126
Hi, I just downloaded foobar, and was hoping to install this add on. The only thing is I dont know how to use it. So far I have downloaded foo_skip and placed it in my components folder. Under playback, I can see that it is installed correctly because an option says skip tracks. from here I dont know what to do. I was wondering if someone could give my step by step instructions on how to use this. Thanks.
2E7AH
post May 4 2009, 22:44
Post #127
Group: Validating
In "Preferences > Advanced > Playback > Skip Track" you have to enter title formatting script that will be used for skip action, f.e.:
$if(%rating%,$ifgreater(3,%rating%,skip,)) will skip any track with rating less than 3
$ifequal(%skip%,1,skip,) will skip if you have added skip tag in your file, and set it to 1
vogliadicane
post May 17 2009, 21:11
Post #128
is this component still in development?
I like and use it a lot. What I would like to see, is the ability to set some tag, which skips tracks only when shuffle(tracks) is set.
Why? Cause there are many albums I would like to listen to but donīt want them to be part of some mix play. If I set all ratings to 1 (my condition to skip a track), I can only hear this particular track by double-clicking, whereas all others are skipped...
edit: or something like %playback_order% to make $ifequal(%playback_order%,"Shuffle (tracks)",$ifequal(%rating%,1,skip,),)
This post has been edited by vogliadicane: May 17 2009, 21:17
v.43
post Jun 3 2009, 01:13
Post #129
EDIT:
sorry, i was unaware of the updated version.
maybe that link should be put in the first post of the thread and on the wiki page smile.gif
EDIT2:
i've some problems finding the settings for the component O_o
i only got that command: playback/skip tracks
This post has been edited by v.43: Jun 3 2009, 01:47
Dirhael
post Jun 3 2009, 01:55
Post #130
Look under Advanced -> Playback.
v.43
post Jun 3 2009, 02:18
Post #131
QUOTE (Dirhael @ Jun 3 2009, 01:55) *
thanks!
pstrg
post Jun 13 2009, 23:00
Post #132
QUOTE (Dirhael @ Jun 2 2009, 21:55) *
Downloaded and copied up261.dll to the \Components folder.
Tried to see a new entry under Advanced -> Playback, there was none.
Looked for the component under Components, it was not loaded.
Is foo_skip incompatible with fb2k 0.9.6.8 and thus not loadable?
fbuser
post Jun 13 2009, 23:16
Post #133
You have to rename it to foo_skip.dll. up261.dll is not a valid name for a foobar plugin.
Sam Stoat
post Aug 10 2009, 09:35
Post #134
Foobar says foo_skip is incompatible with Windows 7 RC. Any chance of re-compiling?
odyssey
post Aug 10 2009, 10:24
Post #135
Why not use autoplaylists?
smkk
post Aug 10 2009, 10:28
Post #136
Autoplaylists don't even come close to the functionality prvided by foo_skip.
Yirkha
post Aug 10 2009, 10:59
Post #137
Group: FB2K Moderator
Case kindly provides an up-to-date version.
http://www.saunalahti.fi/cse/foobar2000/?changes=foo_skip
odyssey
post Aug 10 2009, 11:41
Post #138
Personally I like the idea of using foo_skip, but most of the functionality did I just put in my autoplaylists.
A thing I don't like with the current foo_skip is the way it's implemented. I think it should have been a DSP instead, since a DSP can control exactly what to be played and thus prevent the possibility of playing small part of a skipped track that are currently a problem with foo_skip.
Another thing that could be implemented if it was a DSP, is partial skipping in songs. Many album-tracks have interludes appended on tracks instead of separated, which would be nice to circumvent in a shuffle-play.
Sam Stoat
post Aug 11 2009, 10:03
Post #139
QUOTE (Yirkha @ Aug 10 2009, 10:59) *
Working. Thank you.
crusher
post Aug 19 2009, 05:57
Post #140
hi,
I'm trying to use this plugin to skip songs that I don't wanna hear when I listen to the last.fm radio using foobar.
after studying the foobar helpfile I've got this one working:
$if($stricmp(%title%,A Random Songtitle),skip,)
Unfortunatly it seems not to support wildcards and I didn't find a better function for this case.
Oh and of course I'd like to add several songs, artists and albums that I want to skip.
do you have any suggestion?
Nixdagibts
post Oct 11 2009, 16:44
Post #141
What is the correct syntax to exclude a specific playlist for this plugin?
Example with 3 Playlists:
1 Autoplaylist with Monitoring all Musicfolders - skipping should be allowed
1 Custom Playlists - skipping should be allowed
1 Empty Playlist - a doubleclick on a mp3 in my windows explorer add this file to this empty playlist and plays it.
- this works for all non-tagged (rating!=1) music files
- but rated files are of course skipped
In this specific case, I want to play this file even though it is marked for skipping (rating=1)
This is my skip command: $if(%rating%,$ifgreater(2,%rating%,skip,))
IF rating IS 1 AND activeplaylist IS NOT "mywindowsplaylist"
Can somebody transform this to the correct syntax?
crimson
post Oct 28 2009, 02:34
Post #142
Just wanted to share....I've implemented foo_skip with foo_custominfo in .9.5.1 and now in .9.6.9 with foo_customdb
I use a toggle mechanism with boxes which I don't think you can create with playlist statistics. For toggle using the same keyboard shortcut or context menu item you need the db.
If you like this implementation you can read about it in this thread:
http://www.hydrogenaudio.org/forums/index....mp;#entry664533
I'm very grateful to the updaters of foo_skip and foo_customdb for the excellent work, thanks!
Nixdagibts
post Dec 14 2009, 09:48
Post #143
How do I get the name of an active playlist?
The Titleformat_Reference didn't helped me enough.
My problem is (in some rare cases) I have a playlist only with skipped tracks. This causes a never ending loop.
So I tried to exclude this problematic playlist. But no luck.
$if(%LIST_NAME%,"Windows Explorer",,$ifequal(%rating%,1,skip))
MusX
post Jan 19 2010, 19:07
Post #144
does it still work for you guys on 1.0?
my last.fm profile:
http://www.last.fm/user/MusX
Nixdagibts
post Jan 19 2010, 20:14
Post #145
Yes, it does
MusX
post Jan 19 2010, 20:51
Post #146
ok, thanks. don't know why, after installing 1.0 my %skip% has changed to %rating% I think. now it's ok smile.gif
my last.fm profile:
v.43
post Apr 12 2010, 16:39
Post #147
is it possible to convert this script to the new query sintax?
$ifgreater(
$right($crc32(%title%),2),  --almost random number 0 to 99
$if(%RATING%,
  $ifequal(%RATING%,0,101,   --tracks rated 0
   $ifequal(%RATING%,-1,-1,  --tracks rated -1, ie: to be skipped
    $mul(%RATING%,35)        --for other ratings. the lower this parameter, the most likely the track will be skipped
101),   --unrated tracks
1,      --skip
0       --play
$ifgreater($right($crc32(%title%),2),$if(%RATING%,$ifequal(%RATING%,0,101,$ifequal(%RATING%,-1,-1,$mul(%RATING%,35))),101),1,0)
if not, i'll stick with the old version..
This post has been edited by v.43: Apr 12 2010, 16:40
Case
post Apr 12 2010, 17:17
Post #148
Group: Developer (Donating)
Without trying to analyze your string further you can just use syntax: "$ifgreater($right($crc32(%title%),2),$if(%RATING%,$ifequal(%RATING%,0,101,$ifequal(%RATING%,-1,-1,$mul(%RATING%,35))),101),1,0)" IS 1.
v.43
post Apr 12 2010, 21:01
Post #149
thank you! that worked great
Nixdagibts
post Apr 24 2010, 22:27
Post #150
Thanks for the update (foo_skip 0.8)
Hope you will add querying the active playlist. =)
RSS Lo-Fi Version Time is now: 2nd June 2015 - 07:03
