foo_skip: skip tracks that match a specified search query, Was: [Request] Inactive Tracks
TheDom
post Jan 3 2005, 12:23
Hi!
I would like to see a plugin that skips tracks that are marked via a tag as inactive. I don't like some tracks on albums and so I don't want to hear them (except if I click on them) but I want to keep them on my playlist because of the completeness.
Would be great if anybody could code something like this!
andreas
post Jan 15 2005, 11:13
I'm not quite sure, if I absolutely understood the function of the menu entries.
If I manually add a SKIP tag to my files everything works perfectly. And 'Activate' and 'Deactivate' also seem to work as i expect, but I would have loved some sort of signal, if skip-mode is activated (perhaps a checkmark in front of 'Activate' or 'Deactivate'). At the moment I seem to have to remember or try.
Then I thought, 'toggle' would toggle the SKIP tag in files, but it also seems to activate or deactivate the skip mode. I'm missing a way to add the skip tags. Currently im using the Quick-Tag plugin for this, but I would have liked this feature in the Skip submenu and I can't get the Quick-Tag functions in the main menu.
Also I can't realize a "Toggle" function with quicktag.
Another thing: I've changed my playlist (based on plisk's column_ui playlist) to sort of grey out the entries, which will be skipped. I could try to post my changes, if somebody is interested in this.
In foo_trackinfo I use the following to show the skipped info:
$if($strcmp(%skip%,1),,0080ff)$caps2(%artist%)$if($strcmp(%skip%,1), '['skipped']',)
Many thanks for this plugin,
Andreas
Strictly4me
post Jan 15 2005, 12:37
QUOTE (andreas @ Jan 15 2005, 11:13 AM)
Nice, i have interest for it! - THX
@kdx
Realy good work and THX for that!
One question:
If i mark a song for "skipped", all other songs behind are not playing too, without SKIP-TAG.
Whats wrong?
((((( Strictly4me )))))
This post has been edited by Strictly4me: Jan 15 2005, 12:38
andreas
post Jan 15 2005, 16:36
Well, here we go.
Only files which have their skip tag set to "1" will be greyed out.
Please, don't mind that I do not post my entire skripts, because I changed some stuff in plisks-config, which don't seem usefull for everybody (e.g.: I removed the colour theme switching for a bit more performance) and the scripts look a bit messy.
It basically comes down to add this to your "Globals":
$if($strcmp(%skip%,1),is_skipped=1,)
Now, you can use %_is_skipped% in your columns.
In plisks configuration this basically involves two flavours of insertions:
First flavour for columns, where there's already something configured in the "Colour"-Tab.
E.g. the Title column: Go to the "Colour"-Tab:
Change this:
$if(%_isplaying%,%_ptext%,
$if($and(%_is_first%,$not(%_is_single%)),%_altext%,
%_ntext%))|
into this:
$if(%_is_skipped%,%_brtext%,$if($and(%_is_first%,$not(%_is_single%)),%_altext%,
%_ntext%)))|
Pay attention to the third closing braket at the end! This way, the song title colour is changed only, when the song is NOT playing (remember: you can play songs marked as skipped with a double-click). Actually the colour is changed to the colour normally used for less important text %_brtext% (e.g. text in brakets).
The other sort of change is bit more concise, for columns which don't have anything in their "Colour"-tab:
E.g.: Bitrate-column: Go to the "Display"-Tab:
Change this:
$if(%_isplaying%,%__bitrate_dynamic%,%__bitrate%)
into this:
$if(%_isplaying%,%__bitrate_dynamic%,$if(%_is_skipped%,%_brtext%,)%__bitrate%)
Since there's no colour, we only need to set the new one for skipped files, so the second change boils down to the insertion of the following in such columns:
I hope, this sounds somewhat sensible to you.
One question:
Whats wrong?
For me everything works as it ought to. So I guess, I can't be of any help here.
Regards,
Andreas
- TheDom   foo_skip: skip tracks that match a specified search query   Jan 3 2005, 12:23
- - Silverbolt   Sounds like a cool idea.   Jan 3 2005, 12:33
- - Strictly4me   Very impressive and cool! I like this idea. (...   Jan 3 2005, 13:20
- - Strictly4me   Another way: Maybe there is a way only to play tra...   Jan 3 2005, 18:47
- - TheDom   I don't have and don't like ratings...   Jan 3 2005, 19:33
|- - lightbulb   EDIT - never mind.   Jan 10 2005, 21:06
- - Lyx   Great idea! It would be especially cool, if o...   Jan 3 2005, 22:41
- - mazy   well i'm all for configurable plugin, that wou...   Jan 3 2005, 23:06
- - TheDom   *bump* Anyone?   Jan 6 2005, 13:01
|- - Der_Iltis   Isn't it possible with playlist_gen or Playlis...   Jan 6 2005, 16:19
- - TheDom   QUOTE (Der_Iltis @ Jan 6 2005, 04:19 PM)Isn...   Jan 6 2005, 17:47
- - kdx   Well, I quickly put something together which might...   Jan 9 2005, 22:27
- - mazy   nice! but could you please add adjustable for...   Jan 10 2005, 01:46
- - kdx   okay, done The formatting string now must evalua...   Jan 10 2005, 16:02
- - anza   Cool, now we'll only have to wait for Peter to...   Jan 10 2005, 17:11
|- - Fishy Joe   QUOTE (anza @ Jan 11 2005, 03:11 AM)Cool, now...   Jan 11 2005, 03:17
- - TheDom   Works great. Thank you!!!   Jan 10 2005, 17:16
- - mazy   thanks a lot!   Jan 10 2005, 19:10
- - Zurman   Amazing plugin. I would just suggest a few things ...   Jan 11 2005, 19:22
- - Zurman   Just another thing : make the plugin always play t...   Jan 11 2005, 19:34
- - Lyx   Cool, thanks :) - Lyx edit: eek, go away smiley...   Jan 11 2005, 20:19
- - Zurman   Sorry to have another request When the plugin s...   Jan 11 2005, 20:22
- - kdx   QUOTE Amazing plugin. I would just suggest a few t...   Jan 13 2005, 02:30
|- - Zurman   Thanks for updating   Jan 13 2005, 12:47
- - andreas   Hi, I'm not quite sure, if I absolutely under...   Jan 15 2005, 11:13
|- - Strictly4me   QUOTE (andreas @ Jan 15 2005, 11:13 AM)Anothe...   Jan 15 2005, 12:37
|- - andreas   QUOTE Nice, i have interest for it! - THX Well...   Jan 15 2005, 16:36
- - Strictly4me   @andreas Nice explanation ..... THX! But i...   Jan 15 2005, 22:10
- - kdx   QUOTE I'm not quite sure, if I absolutely unde...   Jan 17 2005, 02:23
|- - Strictly4me   QUOTE (kdx @ Jan 17 2005, 02:23 AM)Are you us...   Jan 17 2005, 02:33
|- - andreas   QUOTE (kdx @ Jan 16 2005, 05:23 PM)QUOTE I...   Jan 17 2005, 08:14
- - kdx   QUOTE Well, in case I want to skip the files tempo...   Jan 17 2005, 12:13
|- - andreas   QUOTE (kdx @ Jan 17 2005, 03:13 AM)QUOTE Well...   Jan 17 2005, 19:00
- - Strictly4me   QUOTE 'true' or '1' .. which one d...   Jan 17 2005, 12:23
- - kdx   QUOTE I use "true"now , but i also tried...   Jan 17 2005, 12:40
|- - xliu5   How does it work on multiple evaluations? I see th...   Mar 27 2005, 20:30
- - Strictly4me   QUOTE try the default '$if2(%skip%,0)...   Jan 17 2005, 13:06
- - Olive   Nice plugin! Could you make it so that when yo...   Jan 18 2005, 23:58
|- - kdx   QUOTE (Olive @ Jan 18 2005, 02:58 PM)Nice plu...   Jan 19 2005, 03:09
- - Olive   I was assuming that Previous & Next were more ...   Jan 19 2005, 05:02
- - anza   Thanks for teh plugin! It works well enough fo...   Mar 26 2005, 22:50
- - matth6546   great plug-in, but i have a suggestion: it'd ...   Apr 24 2005, 05:57
|- - Lance Uppercut   QUOTE (matth6546 @ Apr 23 2005, 11:57 PM)grea...   Apr 24 2005, 13:31
|- - Strictly4me   QUOTE (Lance Uppercut @ Apr 24 2005, 01:31 PM...   Jun 16 2005, 22:00
- - Squeller   I found a problem. I use foo_dsp_continuator. At ...   Apr 27 2005, 08:06
- - Anas   Thanks a lot for this great plugin! It's r...   Jun 17 2005, 07:12
- - fabiospark   Just installed foo_skip 0.1. Found a bug: Playba...   Oct 4 2005, 22:06
- - SoulMan   Good little plugin, thank you.   Oct 5 2005, 11:07
- - iOsiris   Due to the fact that my ratings use bars instead o...   Dec 12 2005, 19:33
|- - iStormy   [removed]   Dec 14 2005, 05:44
- - digidistortions   $ifgreater($len(%rating%),3,0,1) I didn...   Dec 12 2005, 19:53
- - iOsiris   Well Lance Uppercut uses "$ifgreater(%ra...   Dec 13 2005, 00:37
- - digidistortions   QUOTE (iOsiris @ Dec 12 2005, 03:37 PM)Well L...   Dec 13 2005, 01:54
- - iOsiris   Ah I see, your code does work $ifgreater(...   Dec 13 2005, 02:50
- - SoulMan   A great way to have a random that play mors most r...   Dec 14 2005, 10:58
- - randal1013   is there any plan to update this for .9?   Apr 9 2006, 20:27
|- - Bacchus95   QUOTE (randal1013 @ Apr 9 2006, 08:27 PM)...   Apr 23 2006, 11:58
- - randal1013   anyone feel like porting this?   May 25 2006, 09:04
|- - iOsiris   QUOTE (randal1013 @ May 25 2006, 02:04) a...   Jun 13 2006, 17:50
- - DanDanRevolution   (*bump*) some kind coder, please port? i think i...   Jun 25 2006, 04:26
|- - DanDanRevolution   QUOTE (DanDanRevolution @ Jun 24 2006, 21...   Jul 2 2006, 21:10
|- - bytemastr   Unless I'm missing something (and I've tri...   Jul 5 2006, 04:02
|- - kdx   QUOTE (bytemastr @ Jul 4 2006, 19:02) Unl...   Jul 6 2006, 00:50
|- - randal1013   QUOTE (kdx @ Jul 5 2006, 19:50) QUOTE (by...   Jul 6 2006, 05:39
||- - bytemastr   I went back and used this original link in the for...   Jul 6 2006, 06:09
||- - kdx   QUOTE (randal1013 @ Jul 5 2006, 20:39) th...   Jul 6 2006, 10:44
||- - randal1013   QUOTE (kdx @ Jul 6 2006, 05:44) QUOTE (ra...   Jul 6 2006, 18:58
|- - DanDanRevolution   QUOTE (kdx @ Jul 5 2006, 17:50) QUOTE (by...   Jul 7 2006, 02:13
- - Brainbug   cool thing! big big thanx   Jul 6 2006, 20:04
- - randal1013   would it be possible for foo_skip to recognize %_s...   Jul 22 2006, 16:50
|- - Sam Stoat   QUOTE (randal1013 @ Jul 22 2006, 16:50) w...   Aug 14 2006, 19:57
- - TheTravis   Is there some way to change font on the playlist f...   Jul 24 2006, 13:41
- - Brother John   Thanks for the port, kdx. This was the last plugin...   Jul 25 2006, 15:35
- - randal1013   it would be of great help if this plug-in could re...   Aug 1 2006, 18:56
- - rouge   This is sort-of related, but I thought a plug-in t...   Aug 8 2006, 19:33
- - q-stankovic   Thanks for porting! I would like to make a...   Aug 13 2006, 20:39
- - q-stankovic   @sam stoat This plugin will make %systemdate% and%...   Aug 15 2006, 12:39
- - ojdo   In this post I'm requesting a new feature: Wei...   Sep 1 2006, 14:41
|- - Bacchus95   QUOTE (ojdo @ Sep 1 2006, 14:41) In this ...   Sep 1 2006, 15:24
|- - TheTravis   QUOTE (Bacchus95 @ Sep 1 2006, 17:24) You...   Sep 1 2006, 16:45
|- - ojdo   QUOTE (Bacchus95 @ Sep 1 2006, 16:24) QUO...   Sep 3 2006, 21:50
- - lakser   download link is dead anyone can help?   Nov 1 2006, 19:36
- - Strictly4me   foo_skip Download ((((( Strictly4me )))))   Nov 1 2006, 19:39
|- - lakser   thanks Kdx also sent link for old version, Much...   Nov 1 2006, 20:49
|- - chair   QUOTE (Strictly4me @ Nov 1 2006, 13:39) f...   Mar 14 2007, 02:08
- - worldestroyer   How would one go about adapting the "$if...   Dec 31 2006, 12:00
|- - Zoominee   QUOTE (worldestroyer @ Dec 31 2006, 12:00...   Jan 31 2007, 13:07
- - Jugdish   If playback mode is set to repeat the playlist and...   Mar 27 2007, 01:38
- - x10   just discoverd this so when i make it $ifgrea...   Apr 3 2007, 19:51
|- - funkfuzz   QUOTE (x10 @ Apr 3 2007, 13:51) just disc...   Apr 27 2007, 20:00
- - BenAddiction   @funkfuzz $if(%rating%,$ifgreater(3,%ra...   Apr 27 2007, 22:29
|- - funkfuzz   QUOTE (BenAddiction @ Apr 27 2007, 16:29)...   Apr 30 2007, 18:31
|- - ppnilpa   Script CODE$if($or(%talking%,...   Feb 4 2008, 19:35
|- - Zoominee   QUOTE (ppnilpa @ Feb 4 2008, 19:35) Maybe...   Feb 4 2008, 20:23
|- - ppnilpa   QUOTE (Zoominee @ Feb 4 2008, 22:23) QUOT...   Feb 4 2008, 20:37
- - eradumvelhinho   Let's see if someone can help me. Problem: wh...   May 3 2007, 13:09
|- - locutus   Any working link for this plugin for foobar 0.9 av...   Aug 13 2007, 14:02
|- - locutus   QUOTE (locutus @ Aug 13 2007, 07:02) Any ...   Aug 13 2007, 15:58
- - buktore   QUOTE I've mentioned single line hotness scrip...   Feb 4 2008, 22:38
- - jacobbrett   A database method implementation would convince me...   Mar 19 2008, 11:39
5 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th January 2015 - 14:03
