Topic: AAC file header (Read 13539 times) previous topic - next topic
AAC file header
I saw a description for the AAC file header here:
http://www.audiocoding.com/wiki/index.php?page=AAC , but I could not find how can I get the bitrate/duration from the ADTS header? Does anybody know a better description?
And another question: what encoder uses the ADIF header?
Please help...
AAC file header
Count the number of frames, then you'll know the filesize, samplerate and number of frames, with that you can calculate the bitrate.
There's no easier way I believe, unless someone here has a good suggestion?
Menno
AAC file header
BTW: ADTS is the same as the headers in MP3, so you should be able to use about the same code (mind the emphasis bits for MPEG-2).
ADIF is supported by PsyTEL and very old versions of FAAC too (before it had ADTS support). Also, the FhG command line encoders use it by default and all the ISO reference AAC files have an ADIF header.
Menno
AAC file header
> menno: Count the number of frames
Should I read the whole file trough? There must be a better solution, I think...
AAC file header
How much samples does an AAC frame contain?
AAC file header
AAC files always have 1024 samples per frame.
In MP4 files it can be 960 too, but I guess you're not working on that yet?
Menno
AAC file header
What solution are you thinking of? There is no way of telling the number of frames in a VBR file without going through the whole file. There's also no extra header available for that.
Menno
AAC file header
How the ACC-Plugin for Winamp get the duration? It doesn't scan the whole file for calculating the number of frames.
AAC file header
Yes it does, check aacinfo.c.
It can also be set to check 30 seconds for example and take the average bitrate of that.
Menno
AAC file header
Where can I find the source of the AAC-Plugin for Winamp?
AAC file header
1024 samples per frame, per channel
AAC file header
Right! :-)
AAC file header
BTW: Upto channel_configuration == 6 the number of channels is the same as the channel_configuration.
I'll try to add some more info about the headers on the wiki soon.
Menno
AAC file header
Where can I download AAC examples with ADIF header?
AAC file header
I would like to implement support for AAC files in my project MPEG Audio Collection , therefore I asked for the info.
1) What kind of AAC files are there?
2) Where can I find other ACC encoders (like FhG etc.)?
3) I need ACC examples (various encoders, modes etc.) - for in-depth tests.
AAC file header
The ISO reference files found at that at&t website should cover everything. You will not find the FhG encoder that creates AAC files.
There are three different AAC formats possible (4 actually but let's not get into that):
RAW
ADIF
ADTS
You will not be able to extract any info from RAW files unless you decode them (which would make binary distribution of your program illegal). ADIF and ADTS I told about, you can find more info on http://www.audiocoding.com/wiki.
Menno
AAC file header
How can I get the sampling rate from the ADIF header?
AAC file header
Sampling rate is taken from the sampling_frequency_index in the program_config_element.
I updated the ADIF page to describe this program_config_element:
http://www.audiocoding.com/wiki/index.php?page=ADIF
Menno
AAC file header
Thank you!
AAC file header
Aah its cool to see you're adding AAC support to your MAC program  Thanks JF!
< w o g o n e . c o m / l o l >
AAC file header
I would like to get a sample encoded with the FhG ACC coder. Where can I download one?
AAC file header
If you send me an email, I can send you some.
Menno
AAC file header
> menno: If you send me an email, I can send you some.
jfaul at gmx dot de
