Channel Mixer (foo_channel_mixer)
skipyrich
post Dec 11 2004, 22:58
Channel Mixer (foo_channel_mixer) for foobar2000 0.9
Latest version is: 0.9.6.3
Release date: 2007.11.21
Functionality:
* - (up|down)mix (to|from) 1-6 channels
* - redirect bass to subwoofer channel (6-channels output mode only)
* - delay rear channels by 1-40 ms (4 or 6-channels output mode only)
* - surround sound effect (2->4 or 2->6 mode only)
* - changing virtual width of a stereoimage
* - etc...
Plugin download:
http://www.skipyrich.com/store/foo_channel_mixer.7z
This post has been edited by skipyrich: Nov 21 2007, 19:07
My English is very good!
...in comparison with my Korean language...
19 Pages V   1 2 3 > »
Replies (1 - 24)
Duble0Syx
post Dec 12 2004, 03:29
QUOTE (skipyrich @ Dec 11 2004, 01:58 PM)
Channel Mixer (foo_channel_mixer) 0.2 alpha is out.
This plugin allows to (up|down)mix between 1-6 channels.
http://skipyrich.siteburg.com/store/foo_channel_mixer.zip
Post your suggestions and bugreports here.
The new subwoofer options are most useful. A good amount of 5.1 material doesn't not have a proper LFE track. The option to mix the bass from all the channels was something I was hoping to see for 5.1 sources. So far there doesn't appear to be anything malfunctioning.
skipyrich
post Dec 12 2004, 19:46
Version: 0.3 alpha
- changed: subwoofer volume and mode handling on 5.1 input
- added: delays
- changed: slightly changed filter constants
matrix
post Dec 12 2004, 22:48
crashes at end of song when used with "gap killer", although, skip silence dsp works with it
skipyrich
post Dec 12 2004, 23:09
QUOTE (matrix @ Dec 13 2004, 01:48 AM)
fast solution: move foo_dsp_nogaps on top of foo_channel_mixer.
I will try to locate and fix this problem...
AsILayDying
post Dec 13 2004, 03:15
this plugin is awesome, thank you very much........
matrix
post Dec 13 2004, 03:23
thx 4 the quickfix, forgot to thank you for this awesome plugin as well, great work, ive been searching for something like this ever since i started using foobar!
zetafunction
post Dec 13 2004, 03:57
Nice plugin. I've been playing around with it. It works well after tweaking the settings.
A few minor things:
There seems to be a minor bug when playing back silence (division by zeros or rounding errors somewhere, perhaps). This might be related to the gap killer problem. The track I noticed this problem with is The Atari's song, "Eight of Nine": there is a long period of silence at the end of the track. Playing that back with the channel mixer enabled results in 100% CPU usage when I reach the silent part (the channel mixer is the only DSP enabled at that point).
Edit: this seems to only appear with "use subwoofer" and "bass redirection" both enabled.
I use these two options, because without it, the low frequencies are too powerful--while I'm not familiar enough with this sort of thing to be able to know exactly why, I'm guessing it's because the audio is getting copied to 5 channel instead of just 2, and since each channel still contains a bass component, the speaker's crossover is taking bass from each of the 5 channels--making it louder than it should be. If anyone can shed more info on this, I'd appreciate it though.
Interestingly enough though, playing back silence://10 (for example) doesn't result in this CPU usage spike. I can post a FLAC of the ending of the song if it would help.
Using noise dithering seems to increase CPU usage by a lot--but this could be because foobar has to dither several channels at once though.
This post has been edited by zetafunction: Dec 13 2004, 04:19
skipyrich
post Dec 13 2004, 21:10
Use another plugin or write bugreport to its author...
skipyrich
post Dec 13 2004, 21:45
QUOTE (zetafunction @ Dec 13 2004, 06:57 AM)
This problem appears on any track in which there is a silence. It is a major bug, I shall try to correct it as soon as possible.
"2 to 6" mode without bass redirection:
sub = (left+right)/2 * sub_volume
"2 to 6" with bass redirection:
sub = lowpass( (left+right)/2 ) * sub_volume
left = highpass(left)
right = highpass(right)
skipyrich
post Dec 13 2004, 23:42
Version: 0.3.1 alpha
- quickfix: high CPU usage on silence with bass redirect enabled
GeSomeone
post Dec 14 2004, 23:13
skipyrich, this plugin is getting better and better.
I have just a remark about the handling of 5.1 sources.
Could you make it possible that 5.1 sources could pass unchanged (for instance when Downmix is off)?
I hope I'm not asking too much smile.gif The only way now is to switch to 6ch mode and switch on "Use subwoofer". But when I play a 2ch source with those settings I get the double amount of bass (like zetafunction).
skipyrich
post Dec 15 2004, 00:11
QUOTE (GeSomeone @ Dec 15 2004, 02:13 AM)
Version: 0.3.2 alpha
- added: volume control for upmixed subwoofer channel
The new control ("Upmixed volume") change volume of upmixed subwoofer channel only. Old ("Volume") control change volume of the subwoofer channel in all cases.
I hope, that it will allow to receive desirable results.
kRush-
post Dec 18 2004, 15:33
Finally my woofer is giving me nice kicks while listening to (stereo)music and the center is no more waste of space.
Good work!
One thing that would be cool though: if one could reset settings to default (after messing around with a settings and not remembering what the default was. laugh.gif )
This post has been edited by kRush-: Dec 18 2004, 16:14
*sigh*
skipyrich
post Dec 19 2004, 21:40
Post #15
Version: 0.3.3 alpha
- added: Reset button on each configuration tab
skipyrich
post Dec 23 2004, 03:36
Post #16
Version: 0.3.4 alpha
- added: option to invert rear channels
waileongyeo
post Dec 23 2004, 13:13
Post #17
Thanks for your great work!
I'm going to try it out tonite with my Abit NF7-S v2.0 motherboard. cool.gif
Chastity
post Dec 27 2004, 02:47
Post #18
People who use Audigys to AV receivers will really appreciate this, since you create a true 6 channel output, you don't suffer the normal LFE attenuation loss.
In Case Of Bose, Break Glass
Flac yuo in teh ASIO!
skipyrich
post Dec 30 2004, 05:01
Post #19
Version: 0.4 alpha
- added: changing virtual width of a stereoimage
- changed: moved some controls
WiLLiE
post Dec 30 2004, 19:40
Post #20
QUOTE (waileongyeo @ Dec 23 2004, 04:13 AM)
Why do you wanna do that? Soundstorm converts all sound sources to AC3 in realtime.
I'ts just a matter of pluging in the cable and you'll have sound in all 6 speakers.
GeSomeone
post Dec 30 2004, 20:27
Post #21
QUOTE (skipyrich @ Dec 30 2004, 06:01 AM)
Version: 0.4 alpha
Thanks again,
I just want to make a note that there is a relation between
- upmix->subwoofer (volume of content send to subwoofer) and
- subwoofer-> Bass redirection
As an example: In my case upmix->subwoofer is 0, because my speakerset handles the crossover between satelites and (sub)woofer itself. When I now try Bass redirection, which is on another tab, I lose the bass (which is OK!). So maybe these settings should be kept on the same tab.
or just forget about upmix->subwoofer (level) and only have a "bass redirection level" grouped with the other Bass redirection settings, which I think makes more sense?
Happy 2005.
AsILayDying
post Dec 31 2004, 02:39
Post #22
QUOTE (WiLLiE @ Dec 30 2004, 02:40 PM)
negative, I am using the newest drivers, with z-680's with the soundstorm, (Abit-NF7-s V2.0) with the optical cable and with DD live setting you only hear sound on the channels foobar is using, so with channel mixer you can play with 2 to 5.1 sound, without it and with no hardware acceleration its 2 channels, with hardware its 4.
The plugin lets me (turning hardware acceleration off) up mix to 5.1, turn set the center channel to 0, play with the front and reat channels settings, and play with the bass, my music has never sounded better.
And the only difference between the 5.1 setting snd 5.1 DD live setting is that 5.1 all the channel mixing is done by my 680's and with 5.1 DD live its foobar doing the channel mixing since hardware acceleration is off.
This post has been edited by AsILayDying: Dec 31 2004, 02:51
WiLLiE
post Jan 1 2005, 07:14
Post #23
QUOTE (AsILayDying @ Dec 30 2004, 05:39 PM)
Hmm.. Soundstorm does AC3 encoding realtime. (No other soundcard does that.)
I'm not sure thats what you're doing.
Well, I also have an optical cable between my computer and my Home Cinema Receiver (Yamaha RX-V596RDS).
Works like a charm.
My brother have the same setup, he recently bought a Yamaha RX-V650 Reciever (and some new speakers), and voilá..
No matter what sound is playing, windows, Winamp, Foobar, MPC, WMP, PVR-250 (TV-Card) whatever.. Sound in all 5.1 (7.1+2 in his case) speakers.
All sound is digital in AC3.
Edit: I have the exact same mobo as you aswell.
This post has been edited by WiLLiE: Jan 1 2005, 07:25
AsILayDying
post Jan 1 2005, 23:33
Post #24
QUOTE (WiLLiE @ Jan 1 2005, 02:14 AM)
Works like a charm.
I only get full 5.1 with everything on when I have my output set to 5.1 in NV Mixer and have my z-680's set to PL Movie or PL Music.
If you look at the NV mixer you'll see what channels are being output by Soundstorm, you and your brothers recievers are mixing and decoding, because, with creative desktop 5.1 with digital coax out and with Logitech Z680's optical I have gotten the same results.......sound storm will not up mix stereo sound to 5.1 unless you tell it to with hardware acceleration, and if you reghack NV mixer to all add a center channel (if none exists in the source)
Yes it may do AC3 encoding in realtime however that doesnt mean that the out put is in 5.1 sound. Secondly SS only does 5.1 sound so the fact that your brothers get 7.1 +2 sound means that his reciever is take the source audio and upmixing.......
This post has been edited by AsILayDying: Jan 1 2005, 23:54
WiLLiE
post Jan 2 2005, 01:29
Post #25
Well, if I set nvmixer to "5.1 Speakers (Dolby Digital)" my reciever reacts and shows "Dolby Digital".. If I set it to anything else my reciever displays "Pro Logic".
(The reciever is set to "Auto" so it detects what comes in.)
So the reciever detects AC3.
Same with DVD's (from my standalone player).
In the movies menu's the reciever shows "Pro Logic".
When the movie starts it either shows "Dolby Digital" or "DTS".
So there is no upmixing going on. (In my case)
Oh, and I have sound in my center.
RSS Lo-Fi Version Time is now: 26th April 2015 - 04:14
