foo_playlist_tree, still very experimental (beta stage)
cwbowron
post Nov 15 2004, 23:23
foo_playlist_tree is a very customizable media library, with support for hierarchical playlists as well as dynamic playlists. Dynamic playlists can be generated using the same syntax as foo_playlistgen_ex. It can operate in its own window or as a column_ui panel.
More information and downloads are available at:
http://www.bazquux.com/wiki/Foobar2000:Playlist_Tree
This post has been edited by cwbowron: Jan 4 2008, 01:47
There used to be a link to my website here.
Genesis
post Dec 2 2004, 01:30
execelent plugin this could be exactly what I've been looking for for several years wink.gif I have some reqs though.
in my folders there are a .m3u of all the files in that folder. This creates an unnessary subfolder in each folder. Could you include a possibility to ignore playlist files or at least not treat them as folders?
Option to select several folders at once and enque them.
Play musicfile or folder on doubleclick
Sorting possibilities
Faster enqueing to playlist. enqueing all files in my tree takes several hours
cwbowron
post Dec 2 2004, 18:22
QUOTE (Genesis @ Dec 1 2004, 07:30 PM)
Done.
Not Done. See Below.
Done.
Done.
The default treeview control in windows does not support multiple selections, and I am much too lazy to implement it myself. One possibilty would be to add check boxes next to every folder and add an option to enqueue all checked folders, but I don't know if that would look silly or not.
The faster enqueueing suggestion was a really good one... I had noticed that it took a while, but I might not have investigated it had you not brought it up... It should be *much* faster now...
Check out the new versions and look at the preferences... you can skip m3u files when dropping directories now with the checkbox... I also added an option for sending to playlist on doubleclick.
- cwbowron   foo_playlist_tree   Nov 15 2004, 23:23
- - foosion   QUOTE (cwbowron @ Nov 15 2004, 11:23 PM)If an...   Nov 16 2004, 01:30
- - cwbowron   I had not intended that the release I made be for ...   Nov 16 2004, 06:21
|- - NEMO7538   I would be very interested by such a plugin (once ...   Nov 16 2004, 07:00
|- - Sandman2012   QUOTE (NEMO7538 @ Nov 15 2004, 10:00 PM)Have ...   Nov 16 2004, 07:47
- - ssamadhi97   duplicate "http://" in the url. I just f...   Nov 16 2004, 07:54
|- - Sandman2012   QUOTE (ssamadhi97 @ Nov 15 2004, 10:54 PM)dup...   Nov 16 2004, 07:59
- - jkwarras   QUOTE (cwbowron @ Nov 15 2004, 02:23 PM)I...   Nov 16 2004, 12:00
- - upNorth   I think he actually wants to make a new playlist, ...   Nov 16 2004, 14:00
- - cwbowron   I've updated my program and made it availabe a...   Nov 17 2004, 20:13
|- - NEMO7538   QUOTE (cwbowron @ Nov 17 2004, 11:13 AM)... ...   Nov 17 2004, 20:38
|- - jkwarras   QUOTE (cwbowron @ Nov 17 2004, 11:13 AM)... I...   Nov 17 2004, 22:12
- - cwbowron   Ok, so i figured out today why no one could see di...   Nov 18 2004, 22:15
- - Killmaster   Looks like it needs a certain MSVCRTD.dll, is this...   Nov 18 2004, 23:34
- - cwbowron   I updated the zip file to include the missing dll.   Nov 19 2004, 01:54
- - cwbowron   I've updated the file at http://www.bowron.us/...   Nov 19 2004, 23:00
- - jkwarras   Hi, I've finally understood what your plugin ...   Nov 20 2004, 00:35
- - Killmaster   This might be going past the focus of this plugin,...   Nov 20 2004, 08:31
- - spase   i VERY MUCH like this component idea, expecially b...   Nov 23 2004, 08:21
- - cwbowron   I'm glad some people are starting to understan...   Nov 23 2004, 20:46
- - spase   ok i opened playlist tree, right clicked on the ...   Nov 24 2004, 06:27
- - spase   also, i tried to add 333 tracks to the tree and it...   Nov 24 2004, 06:35
- - spase   i think this "freezing" was it just taki...   Nov 24 2004, 06:56
|- - cwbowron   QUOTE (spase @ Nov 24 2004, 12:56 AM)i think ...   Nov 24 2004, 18:58
|- - NEMO7538   Can you make it a panel?   Nov 24 2004, 21:30
- - cwbowron   I added a kludged version of scrolling... if you a...   Nov 24 2004, 23:59
- - anza   The zip file seems to be broken.   Nov 25 2004, 00:04
|- - cwbowron   QUOTE (anza @ Nov 24 2004, 06:04 PM)The zip f...   Nov 25 2004, 06:18
- - pIv   To cwbowron 1. When I try drag to playlist_tree_w...   Nov 25 2004, 13:23
- - cwbowron   playlist tree now works as a ui extension which me...   Nov 26 2004, 07:36
|- - Sperber   QUOTE (cwbowron @ Nov 26 2004, 08:36 AM)playl...   Nov 26 2004, 09:18
- - jkwarras   Ohoh! Thanks   Nov 26 2004, 09:20
- - stroke   the panel version of playlist tree is a great idea...   Nov 26 2004, 19:05
|- - jkwarras   QUOTE (stroke @ Nov 26 2004, 10:05 AM)what do...   Nov 27 2004, 11:39
|- - cwbowron   QUOTE (stroke @ Nov 26 2004, 01:05 PM)the pan...   Nov 28 2004, 22:59
|- - cwbowron   QUOTE (cwbowron @ Nov 28 2004, 04:59 PM)I hav...   Nov 29 2004, 01:18
- - spase   i like stroke's idea. also i have come across...   Nov 27 2004, 08:36
- - spase   also, in creating a new item or renaming an old on...   Nov 27 2004, 08:44
- - spase   looks good... i'm not sure if its possible, b...   Nov 29 2004, 23:18
- - spase   oh and also, do your ".col" files have t...   Nov 29 2004, 23:18
- - spase   hmm i got this crash one time when renaming an ite...   Nov 29 2004, 23:28
- - spase   hmm it also seems in this newest version that i ca...   Nov 29 2004, 23:33
|- - cwbowron   QUOTE (spase @ Nov 29 2004, 05:33 PM)hmm it a...   Nov 30 2004, 01:22
- - cwbowron   I've added folder and music file icons to the ...   Dec 1 2004, 20:05
- - cwbowron   I moved my files to http://foobar.bowron.us and I ...   Dec 1 2004, 22:51
- - Tomacco_Boy   Great work cwbowron, i have a question tho ? can y...   Dec 1 2004, 23:53
- - Genesis   execelent plugin this could be exactly what I...   Dec 2 2004, 01:30
|- - cwbowron   QUOTE (Genesis @ Dec 1 2004, 07:30 PM)in my f...   Dec 2 2004, 18:22
|- - cwbowron   QUOTE (cwbowron @ Dec 2 2004, 12:22 PM)Not Do...   Dec 2 2004, 19:49
|- - Genesis   QUOTE (cwbowron @ Dec 2 2004, 09:22 AM)QUOTE ...   Dec 2 2004, 19:51
- - jkwarras   Hey!, thanks a lot for this plugin and new bui...   Dec 2 2004, 20:10
|- - cwbowron   QUOTE (jkwarras @ Dec 2 2004, 02:10 PM)Hey...   Dec 2 2004, 20:30
||- - stroke   QUOTE (jkwarras @ Dec 2 2004, 02:10 PM)- I re...   Dec 2 2004, 21:38
||- - jkwarras   QUOTE (stroke @ Dec 2 2004, 12:38 PM)not exac...   Dec 2 2004, 21:53
|||- - cwbowron   QUOTE (jkwarras @ Dec 2 2004, 03:53 PM)BTW, o...   Dec 2 2004, 23:06
|||- - jkwarras   QUOTE (cwbowron @ Dec 2 2004, 02:06 PM)QUOTE ...   Dec 2 2004, 23:26
|||- - Genesis   Do you have any idea why foobar justs exits when l...   Dec 3 2004, 10:34
||- - jkwarras   QUOTE (stroke @ Dec 2 2004, 12:38 PM)not exac...   Dec 3 2004, 12:35
||- - phwip   Thanks for a very useful component. QUOTE (jkwarr...   Dec 3 2004, 13:36
||- - jkwarras   QUOTE (phwip @ Dec 3 2004, 04:36 AM)And I am ...   Dec 3 2004, 13:54
||- - phwip   QUOTE (jkwarras @ Dec 3 2004, 12:54 PM)I thin...   Dec 3 2004, 14:07
|- - jkwarras   QUOTE (jkwarras @ Dec 2 2004, 11:10 AM)Just s...   Dec 5 2004, 19:39
- - jkwarras   @cwbowron: Maybe you can add the component in the ...   Dec 3 2004, 14:44
- - witt   foo_playlist_tree still lacks Unicode support...   Dec 3 2004, 15:14
- - cwbowron   Latest version uploaded this morning supports cust...   Dec 3 2004, 16:47
|- - jkwarras   QUOTE (cwbowron @ Dec 3 2004, 07:47 AM)Latest...   Dec 3 2004, 17:05
||- - cwbowron   QUOTE (jkwarras @ Dec 3 2004, 11:05 AM)hmmm.....   Dec 3 2004, 18:49
||- - jkwarras   QUOTE (cwbowron @ Dec 3 2004, 09:49 AM)Yes, y...   Dec 3 2004, 19:23
|- - Genesis   QUOTE (cwbowron @ Dec 3 2004, 07:47 AM)To Gen...   Dec 3 2004, 20:50
|- - cwbowron   QUOTE (Genesis @ Dec 3 2004, 02:50 PM)QUOTE (...   Dec 3 2004, 23:59
- - jkwarras   ops! Last version of your plugin: I'm gett...   Dec 3 2004, 17:11
- - spase   afaik it already has a "link to the database,...   Dec 3 2004, 17:35
- - cwbowron   Dynamic Playlists are in. The way I have implem...   Dec 4 2004, 00:04
|- - jkwarras   QUOTE (cwbowron @ Dec 3 2004, 03:04 PM)Dynami...   Dec 4 2004, 00:33
|- - stroke   QUOTE (cwbowron @ Dec 4 2004, 01:04 AM)Dynami...   Dec 4 2004, 00:59
- - spase   afaik it used to be a panel. maybe he hasn't ...   Dec 4 2004, 01:19
|- - NEMO7538   I support the idea of making it a panel. In aditi...   Dec 4 2004, 03:24
- - stroke   i've just recollected that some time ago i wro...   Dec 4 2004, 15:28
|- - cwbowron   QUOTE (stroke @ Dec 4 2004, 09:28 AM)i've...   Dec 4 2004, 17:06
|- - stroke   QUOTE (cwbowron @ Dec 4 2004, 06:06 PM)QUOTE ...   Dec 4 2004, 17:31
- - cwbowron   Updated current version to support the latest ui_c...   Dec 4 2004, 18:53
- - The Link   Since you updated to the latest ui_columns api I t...   Dec 4 2004, 19:47
- - spase   shouldnt i be able to just copy and paste any view...   Dec 5 2004, 01:05
- - spase   also how do i get it to sort the dynamic folders p...   Dec 5 2004, 01:18
- - spase   another thing i found, if you hide the window, the...   Dec 5 2004, 01:54
- - spase   found a reproducible crash: occurs when trying to...   Dec 5 2004, 02:11
- - cwbowron   I've updated the dynamic playlists to increase...   Dec 5 2004, 05:56
|- - spase   QUOTE (cwbowron @ Dec 4 2004, 11:56 PM)I...   Dec 5 2004, 17:52
- - The Link   The recursive sorting works great but it would be ...   Dec 5 2004, 12:47
|- - Genesis   Now it finally works to add my albums I have som...   Dec 5 2004, 14:54
|- - The Link   QUOTE (Genesis @ Dec 5 2004, 02:54 PM)2. usin...   Dec 5 2004, 14:56
- - stroke   i'm using the following display formatting str...   Dec 5 2004, 19:57
- - jkwarras   After playing with this great extension here goes ...   Dec 6 2004, 16:43
|- - cwbowron   QUOTE (jkwarras @ Dec 6 2004, 10:43 AM)After ...   Dec 6 2004, 19:59
|- - witt   QUOTE (cwbowron @ Dec 7 2004, 03:59 AM)I...   Dec 6 2004, 20:45
||- - cwbowron   QUOTE (witt @ Dec 6 2004, 02:45 PM)QUOTE (cwb...   Dec 6 2004, 22:18
|- - jkwarras   First: thanks! you're really devoted Q...   Dec 6 2004, 20:58
||- - cwbowron   QUOTE (jkwarras @ Dec 6 2004, 02:58 PM)First:...   Dec 6 2004, 21:15
|- - foosion   QUOTE (cwbowron @ Dec 6 2004, 07:59 PM)I...   Dec 6 2004, 21:09
- - jkwarras   QUOTE (cwbowron @ Nov 15 2004, 02:23 PM)Spefi...   Dec 6 2004, 21:49
19 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 30th May 2015 - 14:52
