foo_playlist_tree, still very experimental (beta stage)
cwbowron
post Nov 15 2004, 23:23
foo_playlist_tree is a very customizable media library, with support for hierarchical playlists as well as dynamic playlists. Dynamic playlists can be generated using the same syntax as foo_playlistgen_ex. It can operate in its own window or as a column_ui panel.
More information and downloads are available at:
http://www.bazquux.com/wiki/Foobar2000:Playlist_Tree
This post has been edited by cwbowron: Jan 4 2008, 01:47
There used to be a link to my website here.
stroke
post Nov 26 2004, 19:05
the panel version of playlist tree is a great idea, but i have a problem, sort of ... well, drag & drop, when draging frorm playlist to the playlist tree, works OK for me ... with the right mouse button. while i'm drging folders within the playlist tree panel i have to use the left mouse button. a little confusing. is it intended?
when i save a collection, file extension is not saved, unless i enter the file name in the following format: name.col
and i also have an idea. what about including a possibility to display database content formated according to a set of rules, specified in formatting strings, just like album list panel, or database expolrer panel display. these folders would update automatically whenever database content changes. and one could use only one panel instead of two to organize one's music & stuff. it could look something like that:
the first 14 folders updating automatically, as they were created by inserting a certain formatting string in the plugin's preferences, and the Radiohead folder staying unchanged, as long as i want, since it was created by the drag & drop method
what do you think?
ps. move up/down feature would also be useful
I felt weak, perhaps I was.
cwbowron
post Nov 28 2004, 22:59
QUOTE (stroke @ Nov 26 2004, 01:05 PM)
I had never intended dragging items from the playlist to the playlist tree so any way in which that works is a by product of other stuff. My intent was just to be able to drag and drop files from explorer and to drag and drop items within the tree.
I have noted that it doest add the extension if one is not given and that will most likely be changed in the next release.
what do you think?
Not a bad idea, but it's not something I am likely to implement. If any one else want to take my code and run with it, they are free to do so.
Is there any advantage to this that could not be done using two panels, one to have your playlist tree and one to have your albumlist panel?
To give some background, I have a collection of over 700 cds... I dont want anything that automatically shows me my entire collection. I use explorer to nagivate that. What I use this for is generating categorized trees of small subsets of my collection so they are much more managable.
A move up/down feature is already in it... You can move songs up and down in their playlist using drag and drop, and you can use '[' and ']' to move songs and entire trees up and down.
As far as the renaming goes, that should already work, but apparently its not working for some people... its working for me... Renaming only works for folders, not for files.
As for the trees being expanded when dropping new ones, I dont know what thats all about, I might look into it... Could be a side effect of TreeView_EnsureVisible.
cwbowron
post Nov 29 2004, 01:18
QUOTE (cwbowron @ Nov 28 2004, 04:59 PM)
I fixed the extension issue. If you type in a name without an extension, .col will be added to it.
I also fixed the expansion issue. Now when you drag and drop files and folders, the expansion of other trees will not be affected.
the file, as always, can be found at http://www.bowron.us/foo_playlist_tree.zip
- cwbowron   foo_playlist_tree   Nov 15 2004, 23:23
- - foosion   QUOTE (cwbowron @ Nov 15 2004, 11:23 PM)If an...   Nov 16 2004, 01:30
- - cwbowron   I had not intended that the release I made be for ...   Nov 16 2004, 06:21
|- - NEMO7538   I would be very interested by such a plugin (once ...   Nov 16 2004, 07:00
|- - Sandman2012   QUOTE (NEMO7538 @ Nov 15 2004, 10:00 PM)Have ...   Nov 16 2004, 07:47
- - ssamadhi97   duplicate "http://" in the url. I just f...   Nov 16 2004, 07:54
|- - Sandman2012   QUOTE (ssamadhi97 @ Nov 15 2004, 10:54 PM)dup...   Nov 16 2004, 07:59
- - jkwarras   QUOTE (cwbowron @ Nov 15 2004, 02:23 PM)I...   Nov 16 2004, 12:00
- - upNorth   I think he actually wants to make a new playlist, ...   Nov 16 2004, 14:00
- - cwbowron   I've updated my program and made it availabe a...   Nov 17 2004, 20:13
|- - NEMO7538   QUOTE (cwbowron @ Nov 17 2004, 11:13 AM)... ...   Nov 17 2004, 20:38
|- - jkwarras   QUOTE (cwbowron @ Nov 17 2004, 11:13 AM)... I...   Nov 17 2004, 22:12
- - cwbowron   Ok, so i figured out today why no one could see di...   Nov 18 2004, 22:15
- - Killmaster   Looks like it needs a certain MSVCRTD.dll, is this...   Nov 18 2004, 23:34
- - cwbowron   I updated the zip file to include the missing dll.   Nov 19 2004, 01:54
- - cwbowron   I've updated the file at http://www.bowron.us/...   Nov 19 2004, 23:00
- - jkwarras   Hi, I've finally understood what your plugin ...   Nov 20 2004, 00:35
- - Killmaster   This might be going past the focus of this plugin,...   Nov 20 2004, 08:31
- - spase   i VERY MUCH like this component idea, expecially b...   Nov 23 2004, 08:21
- - cwbowron   I'm glad some people are starting to understan...   Nov 23 2004, 20:46
- - spase   ok i opened playlist tree, right clicked on the ...   Nov 24 2004, 06:27
- - spase   also, i tried to add 333 tracks to the tree and it...   Nov 24 2004, 06:35
- - spase   i think this "freezing" was it just taki...   Nov 24 2004, 06:56
|- - cwbowron   QUOTE (spase @ Nov 24 2004, 12:56 AM)i think ...   Nov 24 2004, 18:58
|- - NEMO7538   Can you make it a panel?   Nov 24 2004, 21:30
- - cwbowron   I added a kludged version of scrolling... if you a...   Nov 24 2004, 23:59
- - anza   The zip file seems to be broken.   Nov 25 2004, 00:04
|- - cwbowron   QUOTE (anza @ Nov 24 2004, 06:04 PM)The zip f...   Nov 25 2004, 06:18
- - pIv   To cwbowron 1. When I try drag to playlist_tree_w...   Nov 25 2004, 13:23
- - cwbowron   playlist tree now works as a ui extension which me...   Nov 26 2004, 07:36
|- - Sperber   QUOTE (cwbowron @ Nov 26 2004, 08:36 AM)playl...   Nov 26 2004, 09:18
- - jkwarras   Ohoh! Thanks   Nov 26 2004, 09:20
- - stroke   the panel version of playlist tree is a great idea...   Nov 26 2004, 19:05
|- - jkwarras   QUOTE (stroke @ Nov 26 2004, 10:05 AM)what do...   Nov 27 2004, 11:39
|- - cwbowron   QUOTE (stroke @ Nov 26 2004, 01:05 PM)the pan...   Nov 28 2004, 22:59
|- - cwbowron   QUOTE (cwbowron @ Nov 28 2004, 04:59 PM)I hav...   Nov 29 2004, 01:18
- - spase   i like stroke's idea. also i have come across...   Nov 27 2004, 08:36
- - spase   also, in creating a new item or renaming an old on...   Nov 27 2004, 08:44
- - spase   looks good... i'm not sure if its possible, b...   Nov 29 2004, 23:18
- - spase   oh and also, do your ".col" files have t...   Nov 29 2004, 23:18
- - spase   hmm i got this crash one time when renaming an ite...   Nov 29 2004, 23:28
- - spase   hmm it also seems in this newest version that i ca...   Nov 29 2004, 23:33
|- - cwbowron   QUOTE (spase @ Nov 29 2004, 05:33 PM)hmm it a...   Nov 30 2004, 01:22
- - cwbowron   I've added folder and music file icons to the ...   Dec 1 2004, 20:05
- - cwbowron   I moved my files to http://foobar.bowron.us and I ...   Dec 1 2004, 22:51
- - Tomacco_Boy   Great work cwbowron, i have a question tho ? can y...   Dec 1 2004, 23:53
- - Genesis   execelent plugin this could be exactly what I...   Dec 2 2004, 01:30
|- - cwbowron   QUOTE (Genesis @ Dec 1 2004, 07:30 PM)in my f...   Dec 2 2004, 18:22
|- - cwbowron   QUOTE (cwbowron @ Dec 2 2004, 12:22 PM)Not Do...   Dec 2 2004, 19:49
|- - Genesis   QUOTE (cwbowron @ Dec 2 2004, 09:22 AM)QUOTE ...   Dec 2 2004, 19:51
- - jkwarras   Hey!, thanks a lot for this plugin and new bui...   Dec 2 2004, 20:10
|- - cwbowron   QUOTE (jkwarras @ Dec 2 2004, 02:10 PM)Hey...   Dec 2 2004, 20:30
||- - stroke   QUOTE (jkwarras @ Dec 2 2004, 02:10 PM)- I re...   Dec 2 2004, 21:38
||- - jkwarras   QUOTE (stroke @ Dec 2 2004, 12:38 PM)not exac...   Dec 2 2004, 21:53
|||- - cwbowron   QUOTE (jkwarras @ Dec 2 2004, 03:53 PM)BTW, o...   Dec 2 2004, 23:06
|||- - jkwarras   QUOTE (cwbowron @ Dec 2 2004, 02:06 PM)QUOTE ...   Dec 2 2004, 23:26
|||- - Genesis   Do you have any idea why foobar justs exits when l...   Dec 3 2004, 10:34
||- - jkwarras   QUOTE (stroke @ Dec 2 2004, 12:38 PM)not exac...   Dec 3 2004, 12:35
||- - phwip   Thanks for a very useful component. QUOTE (jkwarr...   Dec 3 2004, 13:36
||- - jkwarras   QUOTE (phwip @ Dec 3 2004, 04:36 AM)And I am ...   Dec 3 2004, 13:54
||- - phwip   QUOTE (jkwarras @ Dec 3 2004, 12:54 PM)I thin...   Dec 3 2004, 14:07
|- - jkwarras   QUOTE (jkwarras @ Dec 2 2004, 11:10 AM)Just s...   Dec 5 2004, 19:39
- - jkwarras   @cwbowron: Maybe you can add the component in the ...   Dec 3 2004, 14:44
- - witt   foo_playlist_tree still lacks Unicode support...   Dec 3 2004, 15:14
- - cwbowron   Latest version uploaded this morning supports cust...   Dec 3 2004, 16:47
|- - jkwarras   QUOTE (cwbowron @ Dec 3 2004, 07:47 AM)Latest...   Dec 3 2004, 17:05
||- - cwbowron   QUOTE (jkwarras @ Dec 3 2004, 11:05 AM)hmmm.....   Dec 3 2004, 18:49
||- - jkwarras   QUOTE (cwbowron @ Dec 3 2004, 09:49 AM)Yes, y...   Dec 3 2004, 19:23
|- - Genesis   QUOTE (cwbowron @ Dec 3 2004, 07:47 AM)To Gen...   Dec 3 2004, 20:50
|- - cwbowron   QUOTE (Genesis @ Dec 3 2004, 02:50 PM)QUOTE (...   Dec 3 2004, 23:59
- - jkwarras   ops! Last version of your plugin: I'm gett...   Dec 3 2004, 17:11
- - spase   afaik it already has a "link to the database,...   Dec 3 2004, 17:35
- - cwbowron   Dynamic Playlists are in. The way I have implem...   Dec 4 2004, 00:04
|- - jkwarras   QUOTE (cwbowron @ Dec 3 2004, 03:04 PM)Dynami...   Dec 4 2004, 00:33
|- - stroke   QUOTE (cwbowron @ Dec 4 2004, 01:04 AM)Dynami...   Dec 4 2004, 00:59
- - spase   afaik it used to be a panel. maybe he hasn't ...   Dec 4 2004, 01:19
|- - NEMO7538   I support the idea of making it a panel. In aditi...   Dec 4 2004, 03:24
- - stroke   i've just recollected that some time ago i wro...   Dec 4 2004, 15:28
|- - cwbowron   QUOTE (stroke @ Dec 4 2004, 09:28 AM)i've...   Dec 4 2004, 17:06
|- - stroke   QUOTE (cwbowron @ Dec 4 2004, 06:06 PM)QUOTE ...   Dec 4 2004, 17:31
- - cwbowron   Updated current version to support the latest ui_c...   Dec 4 2004, 18:53
- - The Link   Since you updated to the latest ui_columns api I t...   Dec 4 2004, 19:47
- - spase   shouldnt i be able to just copy and paste any view...   Dec 5 2004, 01:05
- - spase   also how do i get it to sort the dynamic folders p...   Dec 5 2004, 01:18
- - spase   another thing i found, if you hide the window, the...   Dec 5 2004, 01:54
- - spase   found a reproducible crash: occurs when trying to...   Dec 5 2004, 02:11
- - cwbowron   I've updated the dynamic playlists to increase...   Dec 5 2004, 05:56
|- - spase   QUOTE (cwbowron @ Dec 4 2004, 11:56 PM)I...   Dec 5 2004, 17:52
- - The Link   The recursive sorting works great but it would be ...   Dec 5 2004, 12:47
|- - Genesis   Now it finally works to add my albums I have som...   Dec 5 2004, 14:54
|- - The Link   QUOTE (Genesis @ Dec 5 2004, 02:54 PM)2. usin...   Dec 5 2004, 14:56
- - stroke   i'm using the following display formatting str...   Dec 5 2004, 19:57
- - jkwarras   After playing with this great extension here goes ...   Dec 6 2004, 16:43
|- - cwbowron   QUOTE (jkwarras @ Dec 6 2004, 10:43 AM)After ...   Dec 6 2004, 19:59
|- - witt   QUOTE (cwbowron @ Dec 7 2004, 03:59 AM)I...   Dec 6 2004, 20:45
||- - cwbowron   QUOTE (witt @ Dec 6 2004, 02:45 PM)QUOTE (cwb...   Dec 6 2004, 22:18
|- - jkwarras   First: thanks! you're really devoted Q...   Dec 6 2004, 20:58
||- - cwbowron   QUOTE (jkwarras @ Dec 6 2004, 02:58 PM)First:...   Dec 6 2004, 21:15
|- - foosion   QUOTE (cwbowron @ Dec 6 2004, 07:59 PM)I...   Dec 6 2004, 21:09
- - jkwarras   QUOTE (cwbowron @ Nov 15 2004, 02:23 PM)Spefi...   Dec 6 2004, 21:49
19 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th January 2015 - 14:03
