Foo_uie_albumart, Very simple album art panel
rexy
post Nov 14 2004, 01:35
UPDATE: version updated to v0.045
UPDATE: source released
New since v0.01:
v.045
* Minimum height
* Cyclable sources
* Updated albumlist
* Bug fixes
* ...other stuff.
v0.044
* Fixed wildcard matching so it works with unicode
* Bug fixes
* Source released
v0.043
* If cover stays the same, no redrawing.
* Option to show the cover for the Album List selection if the list has focus (needs a sepcial version of the Album List panel, included in the release archive)
v0.042
* Cleaned up code
* Recompiled using the new SDK
* Changed source list defaults
v0.041
* Recoded the UIE implementation, which by itself fixed too many bugs to list here
v0.040
* Change code to GDI+ in order to improve resizing quality
* Mouse clicks user-selected functionality
* Fix sources list bug (changing precedence seldom messes up source display)
* Wildcards in cover sources
* Add png support
* Allow access to all possible click functionalities through context menu.
* Works with the new columns_ui (is it .012? something like that)
v0.034
* In initial sources, change "deafult.jpg" to "components\default.jpg" (click reset to get new defaults if you are updating to this version)
* Include a default.jpg with the DLL
* Refresh on source list change
* Option for auto-fit without maintaining aspect ratio
* When no track playing, follow cursor regardless of settings
* Load focued track's cover on start up (works with start playing on startup because
it plays the focused track anyway)
* Option for a black pixel border around cover art image--image, not panel (I wanted it this way... looks pretty)
* Fix host transfer
* Added an option that opens the preferences to the end of the standard ui_extension context menu.
v0.033
* Paths with special characters work.
* Better resource management.
v0.032
* Ability to set background color.
* Option to follow cursor.
* Some random fixes and changes.
v0.03a:
* Better resizing quality.
* Sources list (uses title formatting).
v0.02:
* Album cover not a control anymore and is now simply drawn using StretchBlt.
* Config window with options for auto-center, auto-expand, and auto-shrink.
Needs both MSVCP71.dll and MSVCR71.dll present in order to work, as well as GDI+ runtime installed (standard in Windows XP and newer). Please make sure these necessities are met before complainining about DLL load errors. Thanks.
Also, if you are upgrading from a previous version, it is recommended that you reset the source list by clicking Reset.
Download:
v0.045 Binary
v0.045 Source
This post has been edited by rexy: Feb 3 2005, 07:45
EZ-man
post Nov 17 2004, 04:00
I have update to 0.34 ,but sometimes it shows the message when starting fb2k:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00E73A37h
Access violation, operation: read, address: 00000000h
Call path:
WinMain=>app_init
Code bytes (00E73A37h):
00E739F7h:  CC CC CC CC CC CC CC CC CC 56 57 E8 9A 0E 00 00
00E73A07h:  8B F0 8B 3E 8B CE FF 57 24 50 8B CE FF 57 1C 8B
00E73A17h:  F0 85 F6 74 1B 56 E8 4E F0 FF FF A1 28 81 E7 00
00E73A27h:  83 C4 04 6A 05 6A 00 6A 00 50 FF 15 18 61 E7 00
00E73A37h:  8B 16 5F 8B CE 5E FF 62 04 8B 15 04 67 E7 00 8B
00E73A47h:  C1 8D 48 08 89 11 8B 15 08 67 E7 00 89 51 04 8B
00E73A57h:  15 0C 67 E7 00 89 51 08 8B 15 10 67 E7 00 89 51
00E73A67h:  0C 8B 0D 80 83 E7 00 8B 54 24 04 89 48 04 8B 4C
Stack (0012FC14h):
0012FBF4h:  00F9F8C8 77FA88F0 77F521E0 00000058
0012FC04h:  00F9D238 C0000005 00F9D214 00F9D224
0012FC14h:  004442AC 00E780E4 004118E9 772A4187
0012FC24h:  0015233D 00000000 00000006 0012FC64
0012FC34h:  003B0000 77F944A8 00000003 003B0718
0012FC44h:  003B0000 00000000 0012FC3C 00000106
0012FC54h:  0012FE84 77FA88F0 003B67D0 00000103
0012FC64h:  77F58497 77F57F98 77F58A3A 772A4187
0012FC74h:  00000010 00000000 77F8E397 003B0608
0012FC84h:  77F8E3C3 00000000 003B4D08 00000400
0012FC94h:  02080000 0012FC9C 003B0178 003B0640
0012FCA4h:  003B0178 77F5541D 003B0640 003B0640
0012FCB4h:  7FFDF000 003B3AE0 00150640 00156D90
0012FCC4h:  003B0640 003B0640 001503F0 003B0640
0012FCD4h:  00000000 003B0640 003B0640 003B0640
0012FCE4h:  003B0640 003B0640 003B0640 003B0640
0012FCF4h:  003B0640 003B0640 003B0640 003B5788
0012FD04h:  00150178 00150178 003B0640 77F59037
0012FD14h:  00150178 00156580 003B4C00 00150178
0012FD24h:  00150178 003B0178 003B0190 003B3FF0
Registers:
EAX: 00000000, EBX: 77BFAA6B, ECX: 0012FC04, EDX: 004458F8
ESI: 00000000, EDI: 0043B0D8, EBP: 0012FF0C, ESP: 0012FC14
Crash location: "foo_uie_albumart", loaded at 00E70000h - 00E7B000h
Loaded modules:
foobar2000                       loaded at 00400000h - 00452000h
ntdll                            loaded at 77F50000h - 77FF7000h
kernel32                         loaded at 77E40000h - 77F4F000h
USER32                           loaded at 77D10000h - 77D9A000h
GDI32                            loaded at 7F000000h - 7F041000h
ADVAPI32                         loaded at 77DA0000h - 77E39000h
RPCRT4                           loaded at 78000000h - 78087000h
ole32                            loaded at 7CD50000h - 7CE74000h
COMCTL32                         loaded at 78090000h - 78174000h
msvcrt                           loaded at 77BE0000h - 77C33000h
SHLWAPI                          loaded at 772A0000h - 77309000h
utf8api                          loaded at 10000000h - 1000D000h
comdlg32                         loaded at 76320000h - 76363000h
SHELL32                          loaded at 773A0000h - 77B8F000h
IMM32                            loaded at 76300000h - 7631C000h
LPK                              loaded at 621F0000h - 621F8000h
USP10                            loaded at 72F10000h - 72F6A000h
foo_ape                          loaded at 00940000h - 0095F000h
foo_cdda                         loaded at 003F0000h - 003FE000h
foo_convolve                     loaded at 00960000h - 009B3000h
foo_cue_ex                       loaded at 009C0000h - 009CB000h
foo_ddecontrol                   loaded at 009D0000h - 009EB000h
foo_dsp_extra                    loaded at 00A10000h - 00A25000h
foo_dsp_ssrc                     loaded at 00A30000h - 00A6F000h
foo_flac                         loaded at 00A80000h - 00A9C000h
foo_id3v2                        loaded at 00AA0000h - 00AD0000h
MSVCP60                          loaded at 75FF0000h - 76051000h
foo_input_std                    loaded at 00AD0000h - 00B72000h
MSACM32                          loaded at 77BB0000h - 77BC4000h
WINMM                            loaded at 76B10000h - 76B39000h
foo_midi                         loaded at 00C00000h - 00C8F000h
MFC42                            loaded at 73D30000h - 73E22000h
OLEAUT32                         loaded at 770F0000h - 7717B000h
MFC42LOC                         loaded at 611C0000h - 611C9000h
foo_mpg123                       loaded at 00C90000h - 00CEA000h
foo_output_std                   loaded at 00D10000h - 00D19000h
foo_out_ks                       loaded at 00D20000h - 00D2B000h
SETUPAPI                         loaded at 765E0000h - 7672A000h
foo_playcount                    loaded at 00D30000h - 00D3A000h
foo_playlistfind                 loaded at 00D40000h - 00D4B000h
foo_quicktag                     loaded at 00D50000h - 00D59000h
foo_read_http                    loaded at 00D60000h - 00D69000h
WS2_32                           loaded at 71A10000h - 71A24000h
WS2HELP                          loaded at 71A00000h - 71A08000h
foo_rgscan                       loaded at 00D70000h - 00D7D000h
foo_speex                        loaded at 00D80000h - 00D98000h
foo_tunes                        loaded at 00DA0000h - 00E14000h
MSCTF                            loaded at 74680000h - 746C4000h
foo_uie_albumart                 loaded at 00E70000h - 00E7B000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
MSVCR71                          loaded at 7C340000h - 7C396000h
foo_uie_albumlist                loaded at 00E90000h - 00E9E000h
foo_uie_simple_spectrum          loaded at 00EA0000h - 00EAB000h
foo_uie_tabs                     loaded at 00EB0000h - 00EB9000h
foo_uie_trackinfo                loaded at 00EC0000h - 00ECB000h
foo_uie_volume                   loaded at 00ED0000h - 00EDB000h
foo_ui_columns                   loaded at 00EE0000h - 00F16000h
foo_ui_std                       loaded at 00F20000h - 00F37000h
foo_vis_bacon                    loaded at 00F40000h - 00F58000h
foo_vis_manager                  loaded at 00F60000h - 00F68000h
foo_wavpack                      loaded at 00F70000h - 00F82000h
msctfime                         loaded at 010A0000h - 010CB000h
UxTheme                          loaded at 5A410000h - 5A443000h
Msimtf                           loaded at 74650000h - 74676000h
imagehlp                         loaded at 76C60000h - 76C82000h
DBGHELP                          loaded at 6D820000h - 6D89D000h
VERSION                          loaded at 77BD0000h - 77BD7000h
Stack dump analysis:
Address: 00E780E4h, location: "foo_uie_albumart", loaded at 00E70000h - 00E7B000h
Address: 004118E9h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 772A4187h, location: "SHLWAPI", loaded at 772A0000h - 77309000h
Symbol: "Ordinal125" (+0000002Dh)
Address: 77F944A8h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlRemoteCall" (+000001BEh)
Address: 77FA88F0h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "wcstombs" (+00003409h)
Address: 77F58497h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlAllocateHeap" (+000008E9h)
Address: 77F57F98h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlAllocateHeap" (+000003EAh)
Address: 77F58A3Ah, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlAllocateHeap" (+00000E8Ch)
Address: 77F8E397h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlReAllocateHeap" (+00000D4Fh)
Address: 77F8E3C3h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlReAllocateHeap" (+00000D7Bh)
Address: 77F5541Dh, location: "ntdll", loaded at 77F50000h - 77FF7000h
Address: 77F59037h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlFreeHeap" (+000005F9h)
Address: 0043946Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77C2CA98h, location: "msvcrt", loaded at 77BE0000h - 77C33000h
Symbol: "wpgmptr" (+000000A4h)
Address: 77F59BB3h, location: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlAcquirePebLock" (+00000031h)
Address: 0043A200h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043A1ECh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00410FD5h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438DB5h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438DE0h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043C320h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77E6141Ah, location: "kernel32", loaded at 77E40000h - 77F4F000h
Symbol: "GetCurrentDirectoryW" (+00000044h)
Address: 77E7B2E5h, location: "kernel32", loaded at 77E40000h - 77F4F000h
Symbol: "SetThreadExecutionState" (+00000097h)
Address: 77E77CE0h, location: "kernel32", loaded at 77E40000h - 77F4F000h
Symbol: "VerSetConditionMask" (+0000D764h)
Address: 00438C81h, location: "foobar2000", loaded at 00400000h - 00452000h
Version info:
foobar2000 v0.8.3
UNICODE
This post has been edited by EZ-man: Nov 17 2004, 06:35
- rexy   Foo_uie_albumart   Nov 14 2004, 01:35
- - Messer   What are the requirements? For now I'm getting...   Nov 14 2004, 01:57
- - rexy   Hmmm... Well, I compiled it with VS.NET 2003, but ...   Nov 14 2004, 02:05
- - musicmusic   QUOTE (rexy @ Nov 14 2004, 02:05 AM)Hmmm... W...   Nov 14 2004, 02:14
- - dano   yes it's MSVCP71.dll   Nov 14 2004, 02:16
|- - Messer   QUOTE (dano @ Nov 14 2004, 03:16 AM)yes it...   Nov 14 2004, 02:28
- - Tomacco_Boy   Great work rexy, working fine here and i was wonde...   Nov 14 2004, 02:24
- - longyan   High security alert!!! You are not per...   Nov 14 2004, 04:43
- - spaceships   any way to pop it up on the side if it has album a...   Nov 14 2004, 07:26
- - eliazu   hi man the plug don't work.. i had the proble...   Nov 14 2004, 10:52
|- - dano   QUOTE (eliazu @ Nov 14 2004, 10:52 AM)hi man ...   Nov 14 2004, 10:59
- - upNorth   Thanks for making such a plugin rexy Now the pr...   Nov 14 2004, 11:28
|- - NEMO7538   QUOTE (upNorth @ Nov 14 2004, 02:28 AM)Thanks...   Nov 14 2004, 11:59
|- - upNorth   QUOTE (NEMO7538 @ Nov 14 2004, 12:59 PM)QUOTE...   Nov 14 2004, 20:05
- - kalmark   QUOTE (NEMO7538 @ Nov 14 2004, 12:59 PM)I...   Nov 14 2004, 19:35
- - Skates   Any chance of adding support of reading album art ...   Nov 14 2004, 20:01
- - free   not worked for me MSVCP71.dll installed latest ver...   Nov 14 2004, 20:21
- - kalmark   The folder.jpg has to be called "folder.jpg...   Nov 14 2004, 20:34
- - rexy   Thanks for the compliments. Don't worry, this ...   Nov 14 2004, 20:51
- - spaceships   QUOTE Thanks for the compliments. Don't worry,...   Nov 14 2004, 21:03
- - rexy   Version updated. Look at first post.   Nov 14 2004, 21:20
- - TedFromAccounting   Working fine here so far. However... A few ideas...   Nov 14 2004, 21:20
- - The Link   Thanks for this update. Would it be possible to ma...   Nov 14 2004, 21:24
- - dano   rexy, i really hope for better resizing, currently...   Nov 14 2004, 21:40
- - free   his not work if filepath contained non-english cha...   Nov 14 2004, 21:42
- - upNorth   I think I found the cause of my problem. It's ...   Nov 14 2004, 21:56
- - NappyHead   The ability to use .jpg would be nive, since all m...   Nov 14 2004, 23:45
|- - Morgensonne   QUOTE (NappyHead @ Nov 14 2004, 02:45 PM)The ...   Nov 14 2004, 23:52
- - NappyHead   My bad, changed name of file to folder and it work...   Nov 14 2004, 23:55
- - nbv4   Awesome! You're making it harder and harde...   Nov 15 2004, 00:55
- - reardon   Have you thought about supporting the COVER tag if...   Nov 15 2004, 02:18
- - rexy   Version 0.03a added. @reardon: How exactly does i...   Nov 15 2004, 02:27
|- - foosion   QUOTE (rexy @ Nov 15 2004, 02:27 AM)Right now...   Nov 15 2004, 09:27
|- - reardon   QUOTE (rexy @ Nov 14 2004, 05:27 PM)Version 0...   Nov 15 2004, 18:05
- - badrad   Thanks! Just wanted to let you know this is ap...   Nov 15 2004, 03:57
- - hedge153   How about wildcard support in the 'Sources for...   Nov 15 2004, 05:34
- - nbv4   What would be cool is a way to have the plugin sea...   Nov 15 2004, 05:39
- - spaceships   hmm the download link doesn't seem to be worki...   Nov 15 2004, 05:45
- - rexy   Thanks, eveyone. Version updated. @nbv4: Already...   Nov 15 2004, 05:54
- - badrad   QUOTE (rexy @ Nov 14 2004, 08:54 PM)Version u...   Nov 15 2004, 06:10
- - Tomacco_Boy   Is there a possibility of adding a feature to scan...   Nov 15 2004, 06:51
- - free   not work if my path contain cyryllic(russian) char...   Nov 15 2004, 06:58
- - Klato   Absolutely no problems with this plugin. Awesome...   Nov 15 2004, 07:10
|- - Duble0Syx   Maybe I just need sleep or more skill, but if my c...   Nov 15 2004, 07:31
- - rexy   @Souble0Syx: If the cover art is in the track...   Nov 15 2004, 08:39
- - Tomacco_Boy   QUOTE @Tomacco_Boy: Probably won't get impleme...   Nov 15 2004, 08:51
- - badrad   Hey, recently I have been getting a dialog box wit...   Nov 15 2004, 08:58
|- - badrad   QUOTE (badrad @ Nov 14 2004, 11:58 PM)Hey, re...   Nov 15 2004, 22:48
- - syrek   I want to give in fixed with and hight and maybe a...   Nov 15 2004, 11:45
- - metal_termite   Yes, finally! Very nice! Pretty please ad...   Nov 15 2004, 11:51
- - upNorth   I really like the way the list of sources work. Bu...   Nov 15 2004, 12:10
- - Tomacco_Boy   Just thought this would compliment your work rexy....   Nov 15 2004, 12:44
|- - krazy   QUOTE (Tomacco_Boy @ Nov 15 2004, 07:44 PM)Ju...   Nov 15 2004, 18:50
|- - upNorth   QUOTE (krazy @ Nov 15 2004, 07:50 PM)I wasn...   Nov 15 2004, 19:06
|- - NEMO7538   Nice plugin ! Congratulations. Some users of ...   Nov 15 2004, 19:14
|- - Zurman   QUOTE (NEMO7538 @ Nov 15 2004, 10:14 AM)Nice ...   Nov 15 2004, 22:00
- - rexy   QUOTE (foosion @ Nov 15 2004, 12:27 AM)QUOTE ...   Nov 15 2004, 14:39
|- - foosion   QUOTE (rexy @ Nov 15 2004, 02:39 PM)As for au...   Nov 15 2004, 14:54
- - free   thx now it's correctly work for me   Nov 15 2004, 15:02
- - upNorth   @rexy: There is a bug in the sources list. From ti...   Nov 15 2004, 15:25
- - kalmark   QUOTE (upNorth @ Nov 15 2004, 04:25 PM)@rexy:...   Nov 15 2004, 15:45
- - EZ-man   I have put this plugin in components folder. When ...   Nov 15 2004, 15:45
|- - esa372   QUOTE (EZ-man @ Nov 15 2004, 07:45 AM)I ...   Nov 15 2004, 16:02
- - desigrid   Great UIE rexy! Though I've a similar re...   Nov 15 2004, 16:06
- - foosion   Problem 1 (crash): Transfering the album art panel...   Nov 15 2004, 16:07
- - koach   QUOTE (EZ-man @ Nov 15 2004, 11:45 PM)I ...   Nov 15 2004, 16:55
|- - sleepyboy   I found another method to solve this problem: pre...   Nov 15 2004, 17:07
- - upNorth   Feature request: Option to refresh image for the p...   Nov 15 2004, 17:18
- - EZ-man   Finally, I found a problem from component libaries...   Nov 15 2004, 17:58
- - EZ-man   Yeah! Finally I solve my problem! Now it w...   Nov 15 2004, 18:14
|- - Duble0Syx   I've run into a problem. If my covers are all...   Nov 15 2004, 18:34
- - EZ-man   Here's a wrong word in default setting. ...   Nov 15 2004, 20:24
- - TheGreekGeek   hi, I'm using foobar with columnsUI 1.2 beta ...   Nov 15 2004, 22:18
- - Moonwhaler   Hi! How about this crazy idea: Use some sort ...   Nov 15 2004, 22:19
|- - mazy   QUOTE (Moonwhaler @ Nov 15 2004, 10:19 PM)How...   Nov 16 2004, 00:37
- - kalmark   QUOTE (Moonwhaler @ Nov 15 2004, 11:19 PM)The...   Nov 15 2004, 22:36
|- - Duble0Syx   QUOTE (kalmark @ Nov 15 2004, 01:36 PM)(Sadly...   Nov 15 2004, 22:47
- - Saint   i haven't come across that error message yet.   Nov 15 2004, 23:36
- - rexy   The upcoming revision of the UI extension API will...   Nov 15 2004, 23:36
|- - TheGreekGeek   hei rexy, the panel isnt showing up. But as usual...   Nov 15 2004, 23:51
- - tourmalet   I am obviously being incredibly stupid, but I just...   Nov 16 2004, 00:33
- - foosion   rexy: http://www.stud.uni-karlsruhe.de/~uzbs/fb2k/...   Nov 16 2004, 00:34
- - rexy   Version updated. @foosion: thanks.   Nov 16 2004, 01:31
|- - badrad   QUOTE (rexy @ Nov 15 2004, 04:31 PM)Version u...   Nov 16 2004, 02:36
- - Olive   It keeps crashing at startup here QUOTE Illegal ...   Nov 16 2004, 02:52
|- - Duble0Syx   QUOTE (Olive @ Nov 15 2004, 05:52 PM)It keeps...   Nov 16 2004, 04:59
|- - Gemini   QUOTE (Duble0Syx @ Nov 15 2004, 07:59 PM)QUOT...   Nov 16 2004, 05:23
- - rexy   That's really weird... especially the blue scr...   Nov 16 2004, 05:37
|- - Duble0Syx   QUOTE (rexy @ Nov 15 2004, 08:37 PM)That...   Nov 16 2004, 06:08
- - EZ-man   when running with track info+quick tag+play counte...   Nov 16 2004, 08:08
|- - upNorth   QUOTE (EZ-man @ Nov 16 2004, 09:08 AM)wh...   Nov 16 2004, 08:42
- - EZ-man   But After I restart my computer, the problem was s...   Nov 16 2004, 10:27
- - free   add function: when double-click on cover open this...   Nov 16 2004, 23:13
|- - upNorth   QUOTE (free @ Nov 17 2004, 12:13 AM)add funct...   Nov 16 2004, 23:18
- - Overdo   ok having a problem with this plugin which i'm...   Nov 16 2004, 23:30
- - rexy   @EZ-man: Are you sure you have the latest build (I...   Nov 16 2004, 23:46
- - Overdo   haha thx! i wasn't right clicking at the c...   Nov 17 2004, 00:44
- - EZ-man   I have update to 0.34 ,but sometimes it shows the ...   Nov 17 2004, 04:00
- - rocketsauce   It seems that upgrading to the current version (v0...   Nov 17 2004, 05:38
- - Duble0Syx   It's always possible that it may use things wi...   Nov 17 2004, 06:10
8 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 25th January 2015 - 23:23
