Foo_uie_albumart, Very simple album art panel
rexy
post Nov 14 2004, 01:35
UPDATE: version updated to v0.045
UPDATE: source released
New since v0.01:
v.045
* Minimum height
* Cyclable sources
* Updated albumlist
* Bug fixes
* ...other stuff.
v0.044
* Fixed wildcard matching so it works with unicode
* Bug fixes
* Source released
v0.043
* If cover stays the same, no redrawing.
* Option to show the cover for the Album List selection if the list has focus (needs a sepcial version of the Album List panel, included in the release archive)
v0.042
* Cleaned up code
* Recompiled using the new SDK
* Changed source list defaults
v0.041
* Recoded the UIE implementation, which by itself fixed too many bugs to list here
v0.040
* Change code to GDI+ in order to improve resizing quality
* Mouse clicks user-selected functionality
* Fix sources list bug (changing precedence seldom messes up source display)
* Wildcards in cover sources
* Add png support
* Allow access to all possible click functionalities through context menu.
* Works with the new columns_ui (is it .012? something like that)
v0.034
* In initial sources, change "deafult.jpg" to "components\default.jpg" (click reset to get new defaults if you are updating to this version)
* Include a default.jpg with the DLL
* Refresh on source list change
* Option for auto-fit without maintaining aspect ratio
* When no track playing, follow cursor regardless of settings
* Load focued track's cover on start up (works with start playing on startup because
it plays the focused track anyway)
* Option for a black pixel border around cover art image--image, not panel (I wanted it this way... looks pretty)
* Fix host transfer
* Added an option that opens the preferences to the end of the standard ui_extension context menu.
v0.033
* Paths with special characters work.
* Better resource management.
v0.032
* Ability to set background color.
* Option to follow cursor.
* Some random fixes and changes.
v0.03a:
* Better resizing quality.
* Sources list (uses title formatting).
v0.02:
* Album cover not a control anymore and is now simply drawn using StretchBlt.
* Config window with options for auto-center, auto-expand, and auto-shrink.
Needs both MSVCP71.dll and MSVCR71.dll present in order to work, as well as GDI+ runtime installed (standard in Windows XP and newer). Please make sure these necessities are met before complainining about DLL load errors. Thanks.
Also, if you are upgrading from a previous version, it is recommended that you reset the source list by clicking Reset.
Download:
v0.045 Binary
v0.045 Source
This post has been edited by rexy: Feb 3 2005, 07:45
rexy
post Nov 15 2004, 02:27
Version 0.03a added.
@reardon: How exactly does it store the cover? Is it a tag that has the file's adress? If so, then it is now supported with the new version. Otherwise, is it simply binary data within a tag?... do you know where I may find specifications about the standart use of covers in tags? I may consider implementing this (I might not implement it though).
@TedFromAccounting:
1. Maybe. It's actually kinda easy so I just might.
2. Added to to-do.
3. Now possible.
Right now, I'm trying to fix the special characters thing. It seems that even with a literal with special characters, _tfopen fails. Anyone know of a practical alternative that would work with special characters and would just return a FILE*?
This post has been edited by rexy: Nov 15 2004, 03:17
- rexy   Foo_uie_albumart   Nov 14 2004, 01:35
- - Messer   What are the requirements? For now I'm getting...   Nov 14 2004, 01:57
- - rexy   Hmmm... Well, I compiled it with VS.NET 2003, but ...   Nov 14 2004, 02:05
- - musicmusic   QUOTE (rexy @ Nov 14 2004, 02:05 AM)Hmmm... W...   Nov 14 2004, 02:14
- - dano   yes it's MSVCP71.dll   Nov 14 2004, 02:16
|- - Messer   QUOTE (dano @ Nov 14 2004, 03:16 AM)yes it...   Nov 14 2004, 02:28
- - Tomacco_Boy   Great work rexy, working fine here and i was wonde...   Nov 14 2004, 02:24
- - longyan   High security alert!!! You are not per...   Nov 14 2004, 04:43
- - spaceships   any way to pop it up on the side if it has album a...   Nov 14 2004, 07:26
- - eliazu   hi man the plug don't work.. i had the proble...   Nov 14 2004, 10:52
|- - dano   QUOTE (eliazu @ Nov 14 2004, 10:52 AM)hi man ...   Nov 14 2004, 10:59
- - upNorth   Thanks for making such a plugin rexy Now the pr...   Nov 14 2004, 11:28
|- - NEMO7538   QUOTE (upNorth @ Nov 14 2004, 02:28 AM)Thanks...   Nov 14 2004, 11:59
|- - upNorth   QUOTE (NEMO7538 @ Nov 14 2004, 12:59 PM)QUOTE...   Nov 14 2004, 20:05
- - kalmark   QUOTE (NEMO7538 @ Nov 14 2004, 12:59 PM)I...   Nov 14 2004, 19:35
- - Skates   Any chance of adding support of reading album art ...   Nov 14 2004, 20:01
- - free   not worked for me MSVCP71.dll installed latest ver...   Nov 14 2004, 20:21
- - kalmark   The folder.jpg has to be called "folder.jpg...   Nov 14 2004, 20:34
- - rexy   Thanks for the compliments. Don't worry, this ...   Nov 14 2004, 20:51
- - spaceships   QUOTE Thanks for the compliments. Don't worry,...   Nov 14 2004, 21:03
- - rexy   Version updated. Look at first post.   Nov 14 2004, 21:20
- - TedFromAccounting   Working fine here so far. However... A few ideas...   Nov 14 2004, 21:20
- - The Link   Thanks for this update. Would it be possible to ma...   Nov 14 2004, 21:24
- - dano   rexy, i really hope for better resizing, currently...   Nov 14 2004, 21:40
- - free   his not work if filepath contained non-english cha...   Nov 14 2004, 21:42
- - upNorth   I think I found the cause of my problem. It's ...   Nov 14 2004, 21:56
- - NappyHead   The ability to use .jpg would be nive, since all m...   Nov 14 2004, 23:45
|- - Morgensonne   QUOTE (NappyHead @ Nov 14 2004, 02:45 PM)The ...   Nov 14 2004, 23:52
- - NappyHead   My bad, changed name of file to folder and it work...   Nov 14 2004, 23:55
- - nbv4   Awesome! You're making it harder and harde...   Nov 15 2004, 00:55
- - reardon   Have you thought about supporting the COVER tag if...   Nov 15 2004, 02:18
- - rexy   Version 0.03a added. @reardon: How exactly does i...   Nov 15 2004, 02:27
|- - foosion   QUOTE (rexy @ Nov 15 2004, 02:27 AM)Right now...   Nov 15 2004, 09:27
|- - reardon   QUOTE (rexy @ Nov 14 2004, 05:27 PM)Version 0...   Nov 15 2004, 18:05
- - badrad   Thanks! Just wanted to let you know this is ap...   Nov 15 2004, 03:57
- - hedge153   How about wildcard support in the 'Sources for...   Nov 15 2004, 05:34
- - nbv4   What would be cool is a way to have the plugin sea...   Nov 15 2004, 05:39
- - spaceships   hmm the download link doesn't seem to be worki...   Nov 15 2004, 05:45
- - rexy   Thanks, eveyone. Version updated. @nbv4: Already...   Nov 15 2004, 05:54
- - badrad   QUOTE (rexy @ Nov 14 2004, 08:54 PM)Version u...   Nov 15 2004, 06:10
- - Tomacco_Boy   Is there a possibility of adding a feature to scan...   Nov 15 2004, 06:51
- - free   not work if my path contain cyryllic(russian) char...   Nov 15 2004, 06:58
- - Klato   Absolutely no problems with this plugin. Awesome...   Nov 15 2004, 07:10
|- - Duble0Syx   Maybe I just need sleep or more skill, but if my c...   Nov 15 2004, 07:31
- - rexy   @Souble0Syx: If the cover art is in the track...   Nov 15 2004, 08:39
- - Tomacco_Boy   QUOTE @Tomacco_Boy: Probably won't get impleme...   Nov 15 2004, 08:51
- - badrad   Hey, recently I have been getting a dialog box wit...   Nov 15 2004, 08:58
|- - badrad   QUOTE (badrad @ Nov 14 2004, 11:58 PM)Hey, re...   Nov 15 2004, 22:48
- - syrek   I want to give in fixed with and hight and maybe a...   Nov 15 2004, 11:45
- - metal_termite   Yes, finally! Very nice! Pretty please ad...   Nov 15 2004, 11:51
- - upNorth   I really like the way the list of sources work. Bu...   Nov 15 2004, 12:10
- - Tomacco_Boy   Just thought this would compliment your work rexy....   Nov 15 2004, 12:44
|- - krazy   QUOTE (Tomacco_Boy @ Nov 15 2004, 07:44 PM)Ju...   Nov 15 2004, 18:50
|- - upNorth   QUOTE (krazy @ Nov 15 2004, 07:50 PM)I wasn...   Nov 15 2004, 19:06
|- - NEMO7538   Nice plugin ! Congratulations. Some users of ...   Nov 15 2004, 19:14
|- - Zurman   QUOTE (NEMO7538 @ Nov 15 2004, 10:14 AM)Nice ...   Nov 15 2004, 22:00
- - rexy   QUOTE (foosion @ Nov 15 2004, 12:27 AM)QUOTE ...   Nov 15 2004, 14:39
|- - foosion   QUOTE (rexy @ Nov 15 2004, 02:39 PM)As for au...   Nov 15 2004, 14:54
- - free   thx now it's correctly work for me   Nov 15 2004, 15:02
- - upNorth   @rexy: There is a bug in the sources list. From ti...   Nov 15 2004, 15:25
- - kalmark   QUOTE (upNorth @ Nov 15 2004, 04:25 PM)@rexy:...   Nov 15 2004, 15:45
- - EZ-man   I have put this plugin in components folder. When ...   Nov 15 2004, 15:45
|- - esa372   QUOTE (EZ-man @ Nov 15 2004, 07:45 AM)I ...   Nov 15 2004, 16:02
- - desigrid   Great UIE rexy! Though I've a similar re...   Nov 15 2004, 16:06
- - foosion   Problem 1 (crash): Transfering the album art panel...   Nov 15 2004, 16:07
- - koach   QUOTE (EZ-man @ Nov 15 2004, 11:45 PM)I ...   Nov 15 2004, 16:55
|- - sleepyboy   I found another method to solve this problem: pre...   Nov 15 2004, 17:07
- - upNorth   Feature request: Option to refresh image for the p...   Nov 15 2004, 17:18
- - EZ-man   Finally, I found a problem from component libaries...   Nov 15 2004, 17:58
- - EZ-man   Yeah! Finally I solve my problem! Now it w...   Nov 15 2004, 18:14
|- - Duble0Syx   I've run into a problem. If my covers are all...   Nov 15 2004, 18:34
- - EZ-man   Here's a wrong word in default setting. ...   Nov 15 2004, 20:24
- - TheGreekGeek   hi, I'm using foobar with columnsUI 1.2 beta ...   Nov 15 2004, 22:18
- - Moonwhaler   Hi! How about this crazy idea: Use some sort ...   Nov 15 2004, 22:19
|- - mazy   QUOTE (Moonwhaler @ Nov 15 2004, 10:19 PM)How...   Nov 16 2004, 00:37
- - kalmark   QUOTE (Moonwhaler @ Nov 15 2004, 11:19 PM)The...   Nov 15 2004, 22:36
|- - Duble0Syx   QUOTE (kalmark @ Nov 15 2004, 01:36 PM)(Sadly...   Nov 15 2004, 22:47
- - Saint   i haven't come across that error message yet.   Nov 15 2004, 23:36
- - rexy   The upcoming revision of the UI extension API will...   Nov 15 2004, 23:36
|- - TheGreekGeek   hei rexy, the panel isnt showing up. But as usual...   Nov 15 2004, 23:51
- - tourmalet   I am obviously being incredibly stupid, but I just...   Nov 16 2004, 00:33
- - foosion   rexy: http://www.stud.uni-karlsruhe.de/~uzbs/fb2k/...   Nov 16 2004, 00:34
- - rexy   Version updated. @foosion: thanks.   Nov 16 2004, 01:31
|- - badrad   QUOTE (rexy @ Nov 15 2004, 04:31 PM)Version u...   Nov 16 2004, 02:36
- - Olive   It keeps crashing at startup here QUOTE Illegal ...   Nov 16 2004, 02:52
|- - Duble0Syx   QUOTE (Olive @ Nov 15 2004, 05:52 PM)It keeps...   Nov 16 2004, 04:59
|- - Gemini   QUOTE (Duble0Syx @ Nov 15 2004, 07:59 PM)QUOT...   Nov 16 2004, 05:23
- - rexy   That's really weird... especially the blue scr...   Nov 16 2004, 05:37
|- - Duble0Syx   QUOTE (rexy @ Nov 15 2004, 08:37 PM)That...   Nov 16 2004, 06:08
- - EZ-man   when running with track info+quick tag+play counte...   Nov 16 2004, 08:08
|- - upNorth   QUOTE (EZ-man @ Nov 16 2004, 09:08 AM)wh...   Nov 16 2004, 08:42
- - EZ-man   But After I restart my computer, the problem was s...   Nov 16 2004, 10:27
- - free   add function: when double-click on cover open this...   Nov 16 2004, 23:13
|- - upNorth   QUOTE (free @ Nov 17 2004, 12:13 AM)add funct...   Nov 16 2004, 23:18
- - Overdo   ok having a problem with this plugin which i'm...   Nov 16 2004, 23:30
- - rexy   @EZ-man: Are you sure you have the latest build (I...   Nov 16 2004, 23:46
- - Overdo   haha thx! i wasn't right clicking at the c...   Nov 17 2004, 00:44
- - EZ-man   I have update to 0.34 ,but sometimes it shows the ...   Nov 17 2004, 04:00
- - rocketsauce   It seems that upgrading to the current version (v0...   Nov 17 2004, 05:38
- - Duble0Syx   It's always possible that it may use things wi...   Nov 17 2004, 06:10
8 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd July 2015 - 10:58
