foo_uie_trackinfo, now-playing/selected-item panel
Phi
post Nov 13 2004, 09:30
I figured it would be handy to have a sidebar panel that displayed some info (via TAGZ) about the currently playing or currently selected track. This will probably be a little redundant for people with complex/complete playlist displays, but for others that have limited info displayed in their playlist I hope this will be useful to you.
Check out a basic screenshot here.
The panel has two modes:
  • now-playing mode - displays info according to the currently playing track
  • follow cursor mode - displays info about the focused item in the current playlist
Switch between these modes by either double left-clicking or single middle-clicking on the panel. It also supports drag and drop in both directions: dragging a file over the panel will temporarily show the info for that track, and dropping will display that info until you left click.
You can configure the display for all modes using a single TAGZ formatting string in the preferences. It supports the regular TAGZ and special fields (%_isplaying%,%_ispaused%,%_time_total%,etc), plus a few specific to the panel:
  • %_trackinfo_mode%
    a string containing either "Dropped","Follow cursor", or "Now playing" according to the current display mode of the panel.
  • %_trackinfo_dropped%, %_trackinfo_followcursor%, %_trackinfo_nowplaying%
    one (and only one) of these strings will be "1" (the others will be an empty string), again depending on the current display mode of the panel (useful for $if functions)
  • %_trackinfo_notrack%
    set to "1" when the panel has no track to display (happens when starting up in now-playing mode)
To get a line-break use $char(10). You can also change the alignment of a single line by putting either $char(1)C or $char(1)R at the very start of the line, where the C and R stand for Centered and Right (left aligned is the default). Below I have included the script responsible for the above screenshot, so check that out if you are unsure. Obviously you'd want some technical info displayed, but that is just an example. Most of you guys are much better at this than I am anyway.
Latest version (0.1.1):
foo_uie_trackinfo.dll
foo_uie_trackinfo-src.zip
Note: Make sure you download foo_ui_columns v0.1.2 beta 4 (or newer) if you are expecting to add this panel to a sidebar (as seen in the screenshot).
Uses some code from kode54's foo_osd, and foosion's foo_history.
Formatting string used in screenshot:
$if(%_trackinfo_notrack%,
$char(10)$char(10)$char(1)CNo track playing,
$char(1)Ca0caf3%_trackinfo_mode% mode$char(10)
$char(1)C$if(%_isplaying%,$select($add(1,$mod(%_time_remaining_seconds%,4)), ,.,..,...),)$char(10)
dcab50Artist:$char(10)
$char(1)C4040ff%artist%$char(10)
dcab50Title:$char(10)
$char(1)C4040ff%title%$char(10)
dcab50Release:$char(10)
$char(1)C4040ff%album%)
You can stop reading now wink.gif.
This post has been edited by Phi: Dec 7 2004, 11:07
Phi
post Nov 16 2004, 12:34
Thanks for the comments guys.
QUOTE (juglesh @ Nov 16 2004, 09:46 AM)
QUOTE (Zurman @ Nov 15 2004, 12:31 PM)
Why doesnt scrolling work here?
i thought not as well, but you gotta scroll with yer mouse wheel, there is no scroll bar. seems like there should be... unsure.gif
if you use your scroll alot, like reading a very long comment, then click on a track with less info, the panel will remain scrolled up, you will have to scroll back down to see the second track info. although, you will only have to scroll down one click. hmm, you just have to move your scroll wheel one click either direction and the second track will be scrolled up to the top. uhh, unless the second track has a long comment also... blink.gif anyway, the thing is not resetting itself on track changes laugh.gif
another cool pluggin, thanks!
edit: could it made so that i could select and copy the info in the panel?
Scroll bar is coming, I just haven't coded it yet. Ditto for the reset on new track. I don't think you'll ever be able to select/copy text though, sorry.
QUOTE (mazy @ Nov 16 2004, 10:41 AM)
Phi: last version is great, but could you make that world-wrap configurable? i would like to have it disabled. and i have request, though i'm almost sure that it would be way too hard to implement - showing cut off text in hints, when you hower mouse over them. too hard and messy, right? ... anyway, great plugin, thanks!
I knew someone was going to ask to disable the word-wrap. tongue.gif Yeah I can do that.
Showing cut off text would be much trickier, but there are a couple of tricks I could try to make this easier. Not for a while though.
QUOTE (desigrid @ Nov 16 2004, 04:57 PM)
Minor bug: panel does not display information of currently focused track on fb2k's start-up (first playlist item is shown instead). Otherwise, new version works great here smile.gif.
Thanks. I'll have a look.
@Zurman:
What OS are you running? I'm not sure if mouse-wheel scrolling will work under Win98 or older. You'll have a scroll bar soon, anyway.
Zurman
post Nov 16 2004, 12:58
QUOTE (Phi @ Nov 16 2004, 03:34 AM)
@Zurman:
Windows XP (no SP)
- Phi   foo_uie_trackinfo   Nov 13 2004, 09:30
- - Saint   Great plugin! keep up the good work   Nov 13 2004, 11:02
- - Saint   This is just a quick thing i came up with, will fe...   Nov 13 2004, 11:54
- - jkwarras   Thanks! Playing with it right now....   Nov 13 2004, 12:25
- - Tomacco_Boy   Yeah great work, thanks been hoping for something ...   Nov 13 2004, 12:28
- - anza   Great work! Now get back on working with foo_...   Nov 13 2004, 13:12
|- - syrek   QUOTE (anza @ Nov 13 2004, 02:12 PM)Great wor...   Nov 13 2004, 13:22
- - kalmark   I was thinking about album art too, but right now ...   Nov 13 2004, 14:19
- - linus   for me to album art is real a must... edit: typo   Nov 13 2004, 16:42
- - free   Coool uie   Nov 13 2004, 16:46
- - eliazu   plz add option to see the album cover. it will be ...   Nov 13 2004, 17:28
- - Schinkentoni   Great plugin so far. But it would be even usefulle...   Nov 13 2004, 17:29
|- - upNorth   QUOTE (Schinkentoni @ Nov 13 2004, 06:29 PM)G...   Nov 13 2004, 18:10
- - jokull   Great. Anyone have a cool format string to post? ...   Nov 13 2004, 18:55
|- - stroke   QUOTE (jokull @ Nov 13 2004, 07:55 PM)Anyone ...   Nov 13 2004, 21:25
|- - tberman333   QUOTE (stroke @ Nov 13 2004, 04:25 PM)QUOTE (...   Nov 24 2004, 04:35
|- - rocketsauce   QUOTE (tberman333 @ Nov 23 2004, 07:35 PM)QUO...   Nov 24 2004, 04:50
|- - salmonmoose   I seem to have a problem with the information upda...   Nov 24 2004, 06:37
|- - Phi   QUOTE (salmonmoose @ Nov 24 2004, 04:37 PM)Pr...   Nov 24 2004, 12:42
- - desigrid   Phi, thanks for this great UIE! Been waiting f...   Nov 13 2004, 20:59
- - free   My fstring screenshot http://img103.exs.cx/my.php...   Nov 13 2004, 22:17
|- - Silverbolt   free: nice.   Nov 13 2004, 22:55
|- - Sandman2012   QUOTE (free @ Nov 13 2004, 01:17 PM)My  ...   Nov 14 2004, 05:01
|- - Killmaster   QUOTE (Sandman2012 @ Nov 13 2004, 08:01 PM)QU...   Nov 15 2004, 04:30
- - Messer   CODE$select($add(1,$mod...   Nov 13 2004, 23:35
|- - Silverbolt   Messer: best thing I've seen all day   Nov 14 2004, 01:09
|- - linus   @Phi: Thanks for this plugin (and, obviously, for...   Nov 14 2004, 22:27
- - upNorth   RE: foo_uie_trackinfo   Nov 14 2004, 01:03
- - spaceships   stroke mod CODE$char(1) Mode: ff...   Nov 14 2004, 08:09
|- - JEN   $char(1)CStatistics:$char(10) This song ...   Nov 14 2004, 13:57
|- - Phi   QUOTE (JEN @ Nov 14 2004, 11:57 PM)$char...   Nov 14 2004, 14:13
|- - Morgensonne   QUOTE (JEN @ Nov 14 2004, 11:57 PM)$char...   Nov 14 2004, 23:25
- - Phi   QUOTE (anza @ Nov 13 2004, 11:12 PM)Great wor...   Nov 14 2004, 08:18
|- - desigrid   QUOTE (Phi @ Nov 13 2004, 11:18 PM)Just to co...   Nov 14 2004, 08:49
- - mazy   great plugin, Phi! i've requested somethin...   Nov 14 2004, 12:07
|- - jkwarras   QUOTE (mazy @ Nov 14 2004, 03:07 AM)- it coul...   Nov 14 2004, 13:04
|- - upNorth   QUOTE (jkwarras @ Nov 14 2004, 02:04 PM)QUOTE...   Nov 14 2004, 13:16
- - Phi   QUOTE (mazy @ Nov 14 2004, 10:07 PM)great plu...   Nov 14 2004, 13:43
- - JEN   Thanks   Nov 14 2004, 14:29
- - free   Sandman2012 sure: http://pix.mail333.com/new_simpl...   Nov 14 2004, 20:26
|- - Sandman2012   QUOTE (free @ Nov 14 2004, 11:26 AM)Sandman20...   Nov 15 2004, 06:08
|- - badrad   QUOTE (Sandman2012 @ Nov 14 2004, 09:08 PM)ed...   Nov 15 2004, 06:16
|- - Sandman2012   QUOTE (badrad @ Nov 14 2004, 09:16 PM)QUOTE (...   Nov 15 2004, 18:50
- - Skates   Adding covert art support would be awesome, especi...   Nov 14 2004, 23:56
- - badrad   *deleted double post*   Nov 15 2004, 03:59
- - badrad   Very useful plugin, thanks. I am loving these foo_...   Nov 15 2004, 04:04
- - metal_termite   there is a plugin like this for winamp, however al...   Nov 15 2004, 13:20
|- - Phi   Updated. Changes: window should now be flicker-fr...   Nov 15 2004, 16:29
|- - Zurman   QUOTE (Phi @ Nov 15 2004, 07:29 AM)Updated. ...   Nov 15 2004, 21:31
||- - juglesh   QUOTE (Zurman @ Nov 15 2004, 12:31 PM)Why doe...   Nov 15 2004, 23:46
||- - Zurman   QUOTE (juglesh @ Nov 15 2004, 02:46 PM)QUOTE ...   Nov 16 2004, 12:08
|- - Phi   Updated for the new ui extension api. No other ne...   Nov 28 2004, 15:10
|- - nbv4   QUOTE (Phi @ Nov 28 2004, 06:10 AM)Updated fo...   Nov 29 2004, 00:52
|- - Phi   QUOTE (nbv4 @ Nov 29 2004, 10:52 AM)is there ...   Nov 29 2004, 05:56
- - metal_termite   thanks!   Nov 15 2004, 16:53
|- - mazy   QUOTE (metal_termite @ Nov 15 2004, 04:53 PM)...   Nov 16 2004, 00:41
- - anza   Scrolling works here almost perfectly. The only pr...   Nov 15 2004, 22:23
- - badrad   New version is working great.   Nov 15 2004, 22:55
- - Morgensonne   Great plugin so far... waiting for $tab() / ...   Nov 15 2004, 23:52
- - desigrid   Minor bug: panel does not display information of c...   Nov 16 2004, 06:57
- - rexy   This is a wonderful plugin if you want to remove t...   Nov 16 2004, 07:25
|- - Sandman2012   QUOTE (rexy @ Nov 15 2004, 10:25 PM)This is a...   Nov 16 2004, 07:42
- - Chairman85   QUOTE (mazy @ Nov 15 2004, 03:41 PM)Phi: last...   Nov 16 2004, 08:12
- - Phi   Thanks for the comments guys. QUOTE (juglesh ...   Nov 16 2004, 12:34
|- - Zurman   QUOTE (Phi @ Nov 16 2004, 03:34 AM)@Zurman: W...   Nov 16 2004, 12:58
- - nIRV   some suggestions/requests - the word-wrap thing ...   Nov 16 2004, 12:44
|- - Phi   QUOTE (nIRV @ Nov 16 2004, 10:44 PM)some sugg...   Nov 16 2004, 13:00
|- - NEMO7538   Nice plugin indeed ! The behavior however for...   Nov 17 2004, 19:46
|- - jkwarras   QUOTE (NEMO7538 @ Nov 17 2004, 10:46 AM)The b...   Nov 17 2004, 22:17
|- - picmixer   QUOTE (jkwarras @ Nov 17 2004, 11:17 PM)QUOTE...   Nov 17 2004, 22:19
|- - jkwarras   QUOTE (picmixer @ Nov 17 2004, 01:19 PM)Hmh, ...   Nov 17 2004, 22:27
- - jkwarras   Phi: When I use %comment% or$meta(comment) th...   Nov 18 2004, 00:15
|- - Phi   QUOTE (jkwarras @ Nov 18 2004, 10:15 AM)Phi: ...   Nov 18 2004, 13:12
- - jokull   I wasn't sure where to ask this question but h...   Nov 18 2004, 16:20
- - juglesh   feature request: drag items from other panels, dia...   Nov 18 2004, 20:27
|- - foosion   QUOTE (juglesh @ Nov 18 2004, 08:27 PM)featur...   Nov 18 2004, 20:52
- - rexy   An alternative to word wrapping would be a scrolli...   Nov 21 2004, 01:30
- - l.s   The TrackInfo panel allways redraws the whole pane...   Nov 22 2004, 20:20
|- - Phi   QUOTE (l.s @ Nov 23 2004, 06:20 AM)The TrackI...   Nov 23 2004, 12:18
- - Phi   You can grab the old version from here.   Nov 29 2004, 12:43
|- - nbv4   QUOTE (Phi @ Nov 29 2004, 03:43 AM)You can gr...   Nov 29 2004, 16:37
- - multifate   phi: great job on the plugin in fact i'm lovin...   Nov 29 2004, 16:55
- - Phi   QUOTE (nbv4 @ Nov 30 2004, 02:37 AM)QUOTE (Ph...   Nov 29 2004, 17:43
|- - multifate   QUOTE (Phi @ Nov 29 2004, 08:43 AM)QUOTE (mul...   Nov 30 2004, 13:52
- - EZ-man   some suggestion Can latest version support "...   Nov 29 2004, 18:23
- - slayerbeast   hey when trackinfo is consuming a lot of CPU. when...   Nov 29 2004, 20:09
|- - jkwarras   QUOTE (slayerbeast @ Nov 29 2004, 11:09 AM)he...   Nov 29 2004, 20:37
|- - upNorth   QUOTE (slayerbeast @ Nov 29 2004, 09:09 PM)he...   Nov 29 2004, 20:44
|- - jkwarras   QUOTE (upNorth @ Nov 29 2004, 11:44 AM)Have y...   Nov 29 2004, 22:09
- - EZ-man   QUOTE Have you tried turning off "Update ever...   Nov 30 2004, 03:25
- - Phi   QUOTE (EZ-man @ Nov 30 2004, 04:23 AM)so...   Nov 30 2004, 06:08
- - slayerbeast   True, Had word wrap on, update every second on, an...   Nov 30 2004, 12:48
- - slayerbeast   Phi's right.... ! I came to a very fast co...   Nov 30 2004, 12:59
- - EZ-man   I'm wonder why it doesn't have scrollbar? ...   Dec 1 2004, 07:38
|- - jkwarras   QUOTE (EZ-man @ Nov 30 2004, 10:38 PM)I...   Dec 1 2004, 08:22
- - EZ-man   If I don't have a mouse-wheel how could I scro...   Dec 1 2004, 09:44
|- - jkwarras   QUOTE (EZ-man @ Dec 1 2004, 12:44 AM)If ...   Dec 1 2004, 11:11
|- - Phi   QUOTE (jkwarras @ Dec 1 2004, 09:11 PM)QUOTE ...   Dec 1 2004, 12:57
|- - EZ-man   QUOTE (jkwarras @ Dec 1 2004, 06:11 PM)QUOTE ...   Dec 1 2004, 14:38
- - EZ-man   Maybe add enable/disable vertical scroll bar is go...   Dec 1 2004, 14:42
11 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 28th April 2015 - 16:00
