foo_uie_trackinfo, now-playing/selected-item panel
Phi
post Nov 13 2004, 09:30
I figured it would be handy to have a sidebar panel that displayed some info (via TAGZ) about the currently playing or currently selected track. This will probably be a little redundant for people with complex/complete playlist displays, but for others that have limited info displayed in their playlist I hope this will be useful to you.
Check out a basic screenshot here.
The panel has two modes:
  • now-playing mode - displays info according to the currently playing track
  • follow cursor mode - displays info about the focused item in the current playlist
Switch between these modes by either double left-clicking or single middle-clicking on the panel. It also supports drag and drop in both directions: dragging a file over the panel will temporarily show the info for that track, and dropping will display that info until you left click.
You can configure the display for all modes using a single TAGZ formatting string in the preferences. It supports the regular TAGZ and special fields (%_isplaying%,%_ispaused%,%_time_total%,etc), plus a few specific to the panel:
  • %_trackinfo_mode%
    a string containing either "Dropped","Follow cursor", or "Now playing" according to the current display mode of the panel.
  • %_trackinfo_dropped%, %_trackinfo_followcursor%, %_trackinfo_nowplaying%
    one (and only one) of these strings will be "1" (the others will be an empty string), again depending on the current display mode of the panel (useful for $if functions)
  • %_trackinfo_notrack%
    set to "1" when the panel has no track to display (happens when starting up in now-playing mode)
To get a line-break use $char(10). You can also change the alignment of a single line by putting either $char(1)C or $char(1)R at the very start of the line, where the C and R stand for Centered and Right (left aligned is the default). Below I have included the script responsible for the above screenshot, so check that out if you are unsure. Obviously you'd want some technical info displayed, but that is just an example. Most of you guys are much better at this than I am anyway.
Latest version (0.1.1):
foo_uie_trackinfo.dll
foo_uie_trackinfo-src.zip
Note: Make sure you download foo_ui_columns v0.1.2 beta 4 (or newer) if you are expecting to add this panel to a sidebar (as seen in the screenshot).
Uses some code from kode54's foo_osd, and foosion's foo_history.
Formatting string used in screenshot:
$if(%_trackinfo_notrack%,
$char(10)$char(10)$char(1)CNo track playing,
$char(1)Ca0caf3%_trackinfo_mode% mode$char(10)
$char(1)C$if(%_isplaying%,$select($add(1,$mod(%_time_remaining_seconds%,4)), ,.,..,...),)$char(10)
dcab50Artist:$char(10)
$char(1)C4040ff%artist%$char(10)
dcab50Title:$char(10)
$char(1)C4040ff%title%$char(10)
dcab50Release:$char(10)
$char(1)C4040ff%album%)
You can stop reading now wink.gif.
This post has been edited by Phi: Dec 7 2004, 11:07
Phi
post Nov 14 2004, 08:18
QUOTE (anza @ Nov 13 2004, 11:12 PM)
Also, could you add a "word wrap" feature? This would be really useful for displaying lyrics, as the lines tend to get clipped. Also a vertical scrollbar would also be nice when the displayed info doesn't fit...
Word wrap is a possibility. Technically, you could do it with TAGZ, but the code required gets a bit repetitive. Scrollbar maybe, it would need a bit of a redesign to support that though.
QUOTE (upNorth @ Nov 14 2004, 04:10 AM)
Edit: Phi, could you please add support for $tab() ?
Edit2: And maybe make "dynamic info" optional? Display is flickering from time to time, and I suppose it's wasting some CPU cycles too when you don't have animations. Just a thought...
Btw: Thanks for making yet another plugin/panel  smile.gif
Yep. I'd planned $tab support for this release, but ran into a few problems. I'll see if I can fix it. And I'll add disabling dynamic info to my todo as well. There is also something I need to try to eliminate of the flickering (not sure if it will make a difference though).
QUOTE (jokull @ Nov 14 2004, 04:55 AM)
EDIT: Suggestion: Double clicking the information area brings up the special info tag editor.
Yes, thats planned (maybe not with double-click though). The executed command will be configurable.
QUOTE (desigrid @ Nov 14 2004, 06:59 AM)
Request: Besides now playing and follow cursor modes, could you add an additional mode that automatically switches to now playing mode when a track is currently playing and back to follow cursor when no track is playing?
Yeah, I could do that. It'll probably take the form of an option in the preferences to "switch to follow cursor mode when no track is playing." Just to confirm, would you want changing playlist focus to never affect the currently displayed track while a song is playing? Or would you want the displayed track to change when a new song starts, but also allow a change in playlist focus to affect the displayed track?
EDIT: actually, you'd want to be able to switch to and from that mode without going into the prefs, right?
@messer:
This post has been edited by Phi: Nov 14 2004, 08:34
desigrid
post Nov 14 2004, 08:49
QUOTE (Phi @ Nov 13 2004, 11:18 PM)
- Phi   foo_uie_trackinfo   Nov 13 2004, 09:30
- - Saint   Great plugin! keep up the good work   Nov 13 2004, 11:02
- - Saint   This is just a quick thing i came up with, will fe...   Nov 13 2004, 11:54
- - jkwarras   Thanks! Playing with it right now....   Nov 13 2004, 12:25
- - Tomacco_Boy   Yeah great work, thanks been hoping for something ...   Nov 13 2004, 12:28
- - anza   Great work! Now get back on working with foo_...   Nov 13 2004, 13:12
|- - syrek   QUOTE (anza @ Nov 13 2004, 02:12 PM)Great wor...   Nov 13 2004, 13:22
- - kalmark   I was thinking about album art too, but right now ...   Nov 13 2004, 14:19
- - linus   for me to album art is real a must... edit: typo   Nov 13 2004, 16:42
- - free   Coool uie   Nov 13 2004, 16:46
- - eliazu   plz add option to see the album cover. it will be ...   Nov 13 2004, 17:28
- - Schinkentoni   Great plugin so far. But it would be even usefulle...   Nov 13 2004, 17:29
|- - upNorth   QUOTE (Schinkentoni @ Nov 13 2004, 06:29 PM)G...   Nov 13 2004, 18:10
- - jokull   Great. Anyone have a cool format string to post? ...   Nov 13 2004, 18:55
|- - stroke   QUOTE (jokull @ Nov 13 2004, 07:55 PM)Anyone ...   Nov 13 2004, 21:25
|- - tberman333   QUOTE (stroke @ Nov 13 2004, 04:25 PM)QUOTE (...   Nov 24 2004, 04:35
|- - rocketsauce   QUOTE (tberman333 @ Nov 23 2004, 07:35 PM)QUO...   Nov 24 2004, 04:50
|- - salmonmoose   I seem to have a problem with the information upda...   Nov 24 2004, 06:37
|- - Phi   QUOTE (salmonmoose @ Nov 24 2004, 04:37 PM)Pr...   Nov 24 2004, 12:42
- - desigrid   Phi, thanks for this great UIE! Been waiting f...   Nov 13 2004, 20:59
- - free   My fstring screenshot http://img103.exs.cx/my.php...   Nov 13 2004, 22:17
|- - Silverbolt   free: nice.   Nov 13 2004, 22:55
|- - Sandman2012   QUOTE (free @ Nov 13 2004, 01:17 PM)My  ...   Nov 14 2004, 05:01
|- - Killmaster   QUOTE (Sandman2012 @ Nov 13 2004, 08:01 PM)QU...   Nov 15 2004, 04:30
- - Messer   CODE$select($add(1,$mod...   Nov 13 2004, 23:35
|- - Silverbolt   Messer: best thing I've seen all day   Nov 14 2004, 01:09
|- - linus   @Phi: Thanks for this plugin (and, obviously, for...   Nov 14 2004, 22:27
- - upNorth   RE: foo_uie_trackinfo   Nov 14 2004, 01:03
- - spaceships   stroke mod CODE$char(1) Mode: ff...   Nov 14 2004, 08:09
|- - JEN   $char(1)CStatistics:$char(10) This song ...   Nov 14 2004, 13:57
|- - Phi   QUOTE (JEN @ Nov 14 2004, 11:57 PM)$char...   Nov 14 2004, 14:13
|- - Morgensonne   QUOTE (JEN @ Nov 14 2004, 11:57 PM)$char...   Nov 14 2004, 23:25
- - Phi   QUOTE (anza @ Nov 13 2004, 11:12 PM)Great wor...   Nov 14 2004, 08:18
|- - desigrid   QUOTE (Phi @ Nov 13 2004, 11:18 PM)Just to co...   Nov 14 2004, 08:49
- - mazy   great plugin, Phi! i've requested somethin...   Nov 14 2004, 12:07
|- - jkwarras   QUOTE (mazy @ Nov 14 2004, 03:07 AM)- it coul...   Nov 14 2004, 13:04
|- - upNorth   QUOTE (jkwarras @ Nov 14 2004, 02:04 PM)QUOTE...   Nov 14 2004, 13:16
- - Phi   QUOTE (mazy @ Nov 14 2004, 10:07 PM)great plu...   Nov 14 2004, 13:43
- - JEN   Thanks   Nov 14 2004, 14:29
- - free   Sandman2012 sure: http://pix.mail333.com/new_simpl...   Nov 14 2004, 20:26
|- - Sandman2012   QUOTE (free @ Nov 14 2004, 11:26 AM)Sandman20...   Nov 15 2004, 06:08
|- - badrad   QUOTE (Sandman2012 @ Nov 14 2004, 09:08 PM)ed...   Nov 15 2004, 06:16
|- - Sandman2012   QUOTE (badrad @ Nov 14 2004, 09:16 PM)QUOTE (...   Nov 15 2004, 18:50
- - Skates   Adding covert art support would be awesome, especi...   Nov 14 2004, 23:56
- - badrad   *deleted double post*   Nov 15 2004, 03:59
- - badrad   Very useful plugin, thanks. I am loving these foo_...   Nov 15 2004, 04:04
- - metal_termite   there is a plugin like this for winamp, however al...   Nov 15 2004, 13:20
|- - Phi   Updated. Changes: window should now be flicker-fr...   Nov 15 2004, 16:29
|- - Zurman   QUOTE (Phi @ Nov 15 2004, 07:29 AM)Updated. ...   Nov 15 2004, 21:31
||- - juglesh   QUOTE (Zurman @ Nov 15 2004, 12:31 PM)Why doe...   Nov 15 2004, 23:46
||- - Zurman   QUOTE (juglesh @ Nov 15 2004, 02:46 PM)QUOTE ...   Nov 16 2004, 12:08
|- - Phi   Updated for the new ui extension api. No other ne...   Nov 28 2004, 15:10
|- - nbv4   QUOTE (Phi @ Nov 28 2004, 06:10 AM)Updated fo...   Nov 29 2004, 00:52
|- - Phi   QUOTE (nbv4 @ Nov 29 2004, 10:52 AM)is there ...   Nov 29 2004, 05:56
- - metal_termite   thanks!   Nov 15 2004, 16:53
|- - mazy   QUOTE (metal_termite @ Nov 15 2004, 04:53 PM)...   Nov 16 2004, 00:41
- - anza   Scrolling works here almost perfectly. The only pr...   Nov 15 2004, 22:23
- - badrad   New version is working great.   Nov 15 2004, 22:55
- - Morgensonne   Great plugin so far... waiting for $tab() / ...   Nov 15 2004, 23:52
- - desigrid   Minor bug: panel does not display information of c...   Nov 16 2004, 06:57
- - rexy   This is a wonderful plugin if you want to remove t...   Nov 16 2004, 07:25
|- - Sandman2012   QUOTE (rexy @ Nov 15 2004, 10:25 PM)This is a...   Nov 16 2004, 07:42
- - Chairman85   QUOTE (mazy @ Nov 15 2004, 03:41 PM)Phi: last...   Nov 16 2004, 08:12
- - Phi   Thanks for the comments guys. QUOTE (juglesh ...   Nov 16 2004, 12:34
|- - Zurman   QUOTE (Phi @ Nov 16 2004, 03:34 AM)@Zurman: W...   Nov 16 2004, 12:58
- - nIRV   some suggestions/requests - the word-wrap thing ...   Nov 16 2004, 12:44
|- - Phi   QUOTE (nIRV @ Nov 16 2004, 10:44 PM)some sugg...   Nov 16 2004, 13:00
|- - NEMO7538   Nice plugin indeed ! The behavior however for...   Nov 17 2004, 19:46
|- - jkwarras   QUOTE (NEMO7538 @ Nov 17 2004, 10:46 AM)The b...   Nov 17 2004, 22:17
|- - picmixer   QUOTE (jkwarras @ Nov 17 2004, 11:17 PM)QUOTE...   Nov 17 2004, 22:19
|- - jkwarras   QUOTE (picmixer @ Nov 17 2004, 01:19 PM)Hmh, ...   Nov 17 2004, 22:27
- - jkwarras   Phi: When I use %comment% or$meta(comment) th...   Nov 18 2004, 00:15
|- - Phi   QUOTE (jkwarras @ Nov 18 2004, 10:15 AM)Phi: ...   Nov 18 2004, 13:12
- - jokull   I wasn't sure where to ask this question but h...   Nov 18 2004, 16:20
- - juglesh   feature request: drag items from other panels, dia...   Nov 18 2004, 20:27
|- - foosion   QUOTE (juglesh @ Nov 18 2004, 08:27 PM)featur...   Nov 18 2004, 20:52
- - rexy   An alternative to word wrapping would be a scrolli...   Nov 21 2004, 01:30
- - l.s   The TrackInfo panel allways redraws the whole pane...   Nov 22 2004, 20:20
|- - Phi   QUOTE (l.s @ Nov 23 2004, 06:20 AM)The TrackI...   Nov 23 2004, 12:18
- - Phi   You can grab the old version from here.   Nov 29 2004, 12:43
|- - nbv4   QUOTE (Phi @ Nov 29 2004, 03:43 AM)You can gr...   Nov 29 2004, 16:37
- - multifate   phi: great job on the plugin in fact i'm lovin...   Nov 29 2004, 16:55
- - Phi   QUOTE (nbv4 @ Nov 30 2004, 02:37 AM)QUOTE (Ph...   Nov 29 2004, 17:43
|- - multifate   QUOTE (Phi @ Nov 29 2004, 08:43 AM)QUOTE (mul...   Nov 30 2004, 13:52
- - EZ-man   some suggestion Can latest version support "...   Nov 29 2004, 18:23
- - slayerbeast   hey when trackinfo is consuming a lot of CPU. when...   Nov 29 2004, 20:09
|- - jkwarras   QUOTE (slayerbeast @ Nov 29 2004, 11:09 AM)he...   Nov 29 2004, 20:37
|- - upNorth   QUOTE (slayerbeast @ Nov 29 2004, 09:09 PM)he...   Nov 29 2004, 20:44
|- - jkwarras   QUOTE (upNorth @ Nov 29 2004, 11:44 AM)Have y...   Nov 29 2004, 22:09
- - EZ-man   QUOTE Have you tried turning off "Update ever...   Nov 30 2004, 03:25
- - Phi   QUOTE (EZ-man @ Nov 30 2004, 04:23 AM)so...   Nov 30 2004, 06:08
- - slayerbeast   True, Had word wrap on, update every second on, an...   Nov 30 2004, 12:48
- - slayerbeast   Phi's right.... ! I came to a very fast co...   Nov 30 2004, 12:59
- - EZ-man   I'm wonder why it doesn't have scrollbar? ...   Dec 1 2004, 07:38
|- - jkwarras   QUOTE (EZ-man @ Nov 30 2004, 10:38 PM)I...   Dec 1 2004, 08:22
- - EZ-man   If I don't have a mouse-wheel how could I scro...   Dec 1 2004, 09:44
|- - jkwarras   QUOTE (EZ-man @ Dec 1 2004, 12:44 AM)If ...   Dec 1 2004, 11:11
|- - Phi   QUOTE (jkwarras @ Dec 1 2004, 09:11 PM)QUOTE ...   Dec 1 2004, 12:57
|- - EZ-man   QUOTE (jkwarras @ Dec 1 2004, 06:11 PM)QUOTE ...   Dec 1 2004, 14:38
- - EZ-man   Maybe add enable/disable vertical scroll bar is go...   Dec 1 2004, 14:42
11 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 1st February 2015 - 20:46
