278 Pages V   1 2 3 > »
Columns UI, alternative user interface
musicmusic
post May 3 2003, 15:16
Columns UI developer
Columns UI homepage | Documentation | FAQs | #columnsui on chat.freenode.net
Useful forum topics
Columns UI gallery
Older Columns UI configurations
This post has been edited by Canar: Jan 26 2015, 02:16
kikuzo
post Jan 23 2004, 03:11
foo_ui_columns is UI to which I was waiting eagerly just for this.It's very cool.
But since it's alpha status.I have big problem with this.I can't add colomns.huh.gif
foobar will be crash.However It's very useful for me.
I wolud like to this component to become more perfect.
ssamadhi97
post Jan 23 2004, 03:42
Group: Developer (Donating)
hmm plugin seems to have trouble with sorting/displaying playlist with untagged tracks in it, gonna try to reproduce sometime soon (not now - bed!).. pretty neat otherwise
A riddle is a short sword attached to the next 2000 years.
The Link
post Jan 23 2004, 10:15
Under Win2kSP4 the GUI shows up as an empty grey window.
Nevertheless congratulations for this nice approach, it's highly regarded. smile.gif
Regards,
The Link
treech
post Jan 23 2004, 11:09
indeed problems with SP4 + win2000, but keep working on it, sounds promising smile.gif
Tri
post Jan 23 2004, 19:56
It looks very good already but it needs some work, e.g. trying to add a new column crashes it... The status bar font also should be separately configurable.
Always defragment your MP3s to avoid subtle lack in harmonics.
musicmusic
post Jan 24 2004, 01:30
QUOTE (kikuzo @ Jan 23 2004, 02:11 AM)
Im glad you find it useful, thanks for the report, fixed in alpha 2.
changes:
-fixed crash w/ new columns
-improved keyboard navigation of playlist (added home/end/pg up/page down/alt-up/alt-down/space actions & fixed up/down keys; also removed jerkyness/corruptions when scrolling past top/bottom of playlist area using up/down keys)
-fixed scrolling too far past end of playlist
-corrected font of playback order dropdown
QUOTE (ssamadhi97 @ Jan 23 2004, 02:42 AM)
The default strings are bad, probably that (?) Also for sorting when you click on columns it just sends the titleformatting spec to the sort playlist function, so things like %_is_playing% arent defined, leading to misleading results..
QUOTE (The Link @ Jan 23 2004, 09:15 AM)
Regards,
The Link
The entire window? At least its the right colour ph34r.gif Can you try with the new version? If its still broke i dont know whats causing it, i will look into it, thanks.
QUOTE (Tri @ Jan 23 2004, 06:56 PM)
yes there's many things still to be done, e.g. implement drag-droping of files, rename playlists, fix up mouse selections of playlist, shift/ctrl modifiers for selections etc. which is the only reason its is alpha. So yes i will make the status bar font configurable, it is just a matter of time.
Sid59
post Jan 24 2004, 02:07
nice UI ..
- when i click on the 'time' or any other column, it will only sort one way. not in reverse
- i can't add files to an existing tab
- gonna add the ability to delete some of the toolbars? - play order, vis, and so on.
opps .. didn't read the very last part of your post. hope it all comes together.
i think it can be a much cleaner interface than the default one.
This post has been edited by Sid59: Jan 24 2004, 02:08
juglesh
post Jan 24 2004, 02:20
i just get a grey window, also. dont get me wrong, its a nice box! tongue.gif
maybe its one of those things that dont work on win98? i have win98, fb2k7.7b, latest column.dll that you posted.
thanks for your time,
juglesh B>{)}
www.RadioKDUG.com
Speek
post Jan 24 2004, 09:46
Alpha 2 is still just a grey form with a title bar and a status bar in Win2k (SP4). Maybe a missing dll, but there's no error message. I hope this can be fixed.
musicmusic
post Jan 24 2004, 12:19
QUOTE (Sid59 @ Jan 24 2004, 01:07 AM)
nice UI ..
1. will be changed later
2. do you mean drag & drop? coming "soon"
3. there already should be a right click menu for that, does it not appear ?
QUOTE (Speek @ Jan 24 2004, 08:46 AM)
Thanks for the hint, there was a couple diff. things about the way the status bar was made so that's given me some ideas.
Can you or anyone else with affected os try this version and:
- tell me what parts show up
- paste messages from console (they're set as errors so console should pop-up)
rage-
post Jan 24 2004, 12:29
The latest version seems to have loaded up for me just fine, though it did output an error to the console.
ERROR (foo_ui_columns) : wm_create
ERROR (foo_ui_columns) : window handle: 852574 playlist window handle: 1114750 last error: 1400
ERROR (foo_ui_columns) : playlists window handle: 1180294 last error: 0
I also noticed that I can't set the column width for any columns; it just reverts back to the default.
This post has been edited by rage-: Jan 24 2004, 12:35
We're all just noise on the wires..
Speek
post Jan 24 2004, 14:01
From console:
ERROR (foo_ui_columns) : window handle: 1180340 playlist window handle: 1311470 last error: 1400
ERROR (foo_ui_columns) : playlists window handle: 918256 last error: 1400
And there's still just the title bar and status bar.
musicmusic
post Jan 24 2004, 19:54
QUOTE (Speek @ Jan 24 2004, 01:01 PM)
From console:
thanks for testing, but now i am confused..
i fixed the first error 1400 but i dont get where the second one you've got is coming from..
Can you try the new debug version? link It should have a bunch of console messages again, paste them here if you can.
whilst im at it, alpha 3
link
changes:
- mouse movements captured outside of playlist (i.e. scrolls when mouse below/above playlist area)
- more keyboard actions added (enter, shift/ctrl modifiers)
- fixed width of columns not saved from prefs
- added provisional drag & drop support
- added separate config for status bar font
- ensure visible focuses items in the centre of playlist
- playlist renamer
that's enough for now, i think i got most of the things raised above
Speek
post Jan 24 2004, 21:27
Post #15
With the latest debug version:
ERROR (foo_ui_columns) : main window handle: 1442118
ERROR (foo_ui_columns) : playlist window handle: 1311040 last error: 6
ERROR (foo_ui_columns) : header window handle: 1573194 last error: 6
ERROR (foo_ui_columns) : pl list wnd: 1442056 last error: 6
ERROR (foo_ui_columns) : main window rect: 0 0 504 356
ERROR (foo_ui_columns) : playlist window rect: 111 89 500 327
ERROR (foo_ui_columns) : status window rect: 111 89 500 327
ERROR (foo_ui_columns) : playlist window rect: 111 58 500 327
ERROR (foo_ui_columns) : status window rect: 111 58 500 327
ERROR (foo_ui_columns) : status wnd: 4981252 last error: 1400
ERROR (foo_ui_columns) : status window rect: 4 332 500 352
juglesh
post Jan 24 2004, 21:59
Post #16
(win98se) am now getting the interface, when it loads it gives the errors below, and when ever i resize the window it gives errors.
ERROR (foo_ui_columns) : main window handle: 1288
ERROR (foo_ui_columns) : playlist window handle: 1240 last error: 87
ERROR (foo_ui_columns) : header window handle: 1208 last error: 87
ERROR (foo_ui_columns) : pl list wnd: 1212 last error: 87
ERROR (foo_ui_columns) : status wnd: 1628 last error: 87
ERROR (foo_ui_columns) : main window rect: 131 16 785 541
ERROR (foo_ui_columns) : playlist window rect: 242 74 781 512
ERROR (foo_ui_columns) : status window rect: 135 517 781 537
INFO (CORE) : startup time: 10790 ms
ERROR (CORE) : Failed to load DLL: foo_delete.dll, reason: Unable to load dll.
ERROR (foo_ui_columns) : main window rect: 131 16 978 529
ERROR (foo_ui_columns) : playlist window rect: 242 74 974 500
ERROR (foo_ui_columns) : status window rect: 135 505 974 525
ERROR (foo_ui_columns) : main window rect: 131 16 779 556
ERROR (foo_ui_columns) : playlist window rect: 242 74 775 527
ERROR (foo_ui_columns) : status window rect: 135 532 775 552
ERROR (foo_ui_columns) : main window rect: 131 16 930 608
ERROR (foo_ui_columns) : playlist window rect: 242 74 926 579
ERROR (foo_ui_columns) : status window rect: 135 584 926 604
ERROR (foo_ui_columns) : main window rect: 218 10 811 614
ERROR (foo_ui_columns) : playlist window rect: 329 68 807 585
ERROR (foo_ui_columns) : status window rect: 222 590 807 610
ERROR (foo_ui_columns) : main window rect: 409 7 1021 732
ERROR (foo_ui_columns) : playlist window rect: 520 65 1017 703
ERROR (foo_ui_columns) : status window rect: 413 708 1017 728
here is a shot of the window (everything default)
when i resize the columns, the pl goes back to the top and the scroll handle sticks where it was until it click it, then it goes to the top. same if i sort the columns.
will it be possible to sort by artist, then album?
umm...where's the play buttons?
thanks again.
juglesh B>{)}
www.RadioKDUG.com
rectangle
post Jan 24 2004, 22:57
Post #17
Group: Members (Donating)
Love this UI but couple of problems I've found:
1) This:
& sometimes this:
is fixed by resizing window but then I get:
2) Playback Order toolbar does not work. Order can only be changed via Menu Toolbar - Playback/Order
TurinsRevenge
post Jan 25 2004, 03:35
Post #18
Great Start! This is going to be really nice when it's finished. Actually, its really cool already.
Master of Fate. By Fate Mastered
kikuzo
post Jan 25 2004, 10:47
Post #19
Thanks for udating.Sometimes foobar2000 crash with this UI.But I love this.
I wish This UI work perfect in near future.
I have another problem.I can change background color but background color never change inside the colums where color is still black.
Can I chanege color inside colomns?
Speek
post Jan 25 2004, 11:05
Post #20
QUOTE (kikuzo @ Jan 25 2004, 10:47 AM)
I have another problem.I can change background color but background color never change inside the colums where color is still black. Can I change color inside colomns?
Yes, in the "colour" (!) field. The order is "text | selected text | background | selected background".
musicmusic
post Jan 25 2004, 17:01
Post #21
QUOTE (juglesh @ Jan 24 2004, 08:59 PM)
Seems OK for me, can you explain more? When you sort, the playlist core will scroll to the item with focus. I fixed one bug with scrollbar which would occur when sorting, please tell me if its ok with current version. i also dont know what's up with your menu, i can probably fix it anyway.
Whilst unintendedly, you already can (click album column, then artist columns). Not to mention you can set custom strings for sorting already.
I think you're confused, those are in the standard ui. If you meant are you going to add buttons, yes, someday.
QUOTE (rectangle @ Jan 24 2004, 09:57 PM)
1) This:
& sometimes this:
Thanks, both should be fixed in alpha 4.
QUOTE (TurinsRevenge @ Jan 25 2004, 02:35 AM)
QUOTE (kikuzo @ Jan 25 2004, 09:47 AM)
I need more info because i dont get crashes. Can you post:
- what you where doing when it crashed
- how to reproduce (if known)
- crashlog
- operating system
Anyway, alpha 4 with all the above mentioned fixes.
changelog:
alpha 4
- fixed playback order drop down
- fixed scrollbar not redrawn on "ensure visible"
- fixed incorrect positioning of controls
- fixed systray menu not destroyed when click out of it
- added alternative playlist switcher using tabs
I think the tabs playlist switcher it looks a lot better/cleaner than the listbox, the rebar just needs a bit of sorting out.
fantomex
post Jan 25 2004, 18:16
Post #22
am i the only one who gets this?
lightbulb
post Jan 25 2004, 18:45
Post #23
QUOTE (fantomex @ Jan 25 2004, 09:16 AM)
No, you're not alone.
Tri
post Jan 25 2004, 20:33
Post #24
While playing around I noticed that the 'Item height' resets when you go to preferences.
This post has been edited by Tri: Jan 25 2004, 20:33
saratoga
post Jan 25 2004, 22:33
Post #25
This looks great. keep up the good work.
RSS Lo-Fi Version Time is now: 28th July 2015 - 12:00
