Columns UI, alternative user interface
musicmusic
post May 3 2003, 15:16
Columns UI developer
Columns UI homepage | Documentation | FAQs | #columnsui on chat.freenode.net
Useful forum topics
Columns UI gallery
Older Columns UI configurations
This post has been edited by Canar: Jan 26 2015, 02:16
musicmusic
post Jan 26 2004, 22:30
QUOTE (treech @ Jan 26 2004, 07:54 PM)
anyway, i did notice a few things, colors in scripts don't seem to work, i know there a little box there for adding colors, but it's not very flexible, i use different colors for bitrate and such....
like this:
//bitrate stuff
$if2($greater(0,$info(bitrate)),$get(RED))
$if2($greater(129,$info(bitrate)),$get(YELLOW))
$if2($greater(161,$info(bitrate)),$get(GREY))
$if2($greater(192,$info(bitrate)),$get(GREEN))
$if2($greater(256,$info(bitrate)),$get(BLUE))
$pad($info(bitrate),4)$char(9474)
Also, i'm not quite sure of the $pad_right(), $pad() and such features, are they working like they do in the normal iu ?
And what is the "use custom title spec for sorting by column" ? give an example on it plz smile.gif
EDIT: oh, and the sorting is kinda nuts on the lenght smile.gif (i guess we need natural sorting or something like that)
EDIT2: Also, the the dropdown thingy (playmode, default,shuffle, whatever...) does not show, it does not drop down....
rectangle & tri: thanks, both fixed (redownload, still marked alpha 5)
1. You can use colour codes in the string, its working fine here. You can also use tab char's the same way you would with standard ui.
2. pad stuff, If you use a fixed width font probably
3. custom sort spec is the spec to use for sorting when clicking on the columns, the box underneath is where you put the spec smile.gif so you could put $num() there and avoid natural sorting
4. working here but was giving me wierd problems before, will look into it
5. I will add import/export tools when things are a bit for finalised
- musicmusic   Columns UI   May 3 2003, 15:16
- - kikuzo   foo_ui_columns is UI to which I was waiting eagerl...   Jan 23 2004, 03:11
- - ssamadhi97   hmm plugin seems to have trouble with sorting/disp...   Jan 23 2004, 03:42
- - The Link   Under Win2kSP4 the GUI shows up as an empty grey w...   Jan 23 2004, 10:15
- - treech   indeed problems with SP4 + win2000, but keep worki...   Jan 23 2004, 11:09
- - Tri   It looks very good already but it needs some work,...   Jan 23 2004, 19:56
- - musicmusic   QUOTE (kikuzo @ Jan 23 2004, 02:11 AM)foo_ui_...   Jan 24 2004, 01:30
- - Sid59   nice UI .. - when i click on the 'time' o...   Jan 24 2004, 02:07
- - juglesh   i just get a grey window, also. dont get me wrong...   Jan 24 2004, 02:20
- - Speek   Alpha 2 is still just a grey form with a title bar...   Jan 24 2004, 09:46
- - musicmusic   QUOTE (Sid59 @ Jan 24 2004, 01:07 AM)nice UI ...   Jan 24 2004, 12:19
- - rage-   The latest version seems to have loaded up for me ...   Jan 24 2004, 12:29
- - Speek   From console: ERROR (foo_ui_columns) : wm_create E...   Jan 24 2004, 14:01
- - musicmusic   QUOTE (Speek @ Jan 24 2004, 01:01 PM)From con...   Jan 24 2004, 19:54
- - Speek   With the latest debug version: ERROR (foo_ui_colum...   Jan 24 2004, 21:27
- - juglesh   (win98se) am now getting the interface, when it lo...   Jan 24 2004, 21:59
- - rectangle   Love this UI but couple of problems I've found...   Jan 24 2004, 22:57
- - TurinsRevenge   Great Start! This is going to be really nice ...   Jan 25 2004, 03:35
- - kikuzo   Thanks for udating.Sometimes foobar2000 crash with...   Jan 25 2004, 10:47
- - Speek   QUOTE (kikuzo @ Jan 25 2004, 10:47 AM)I have ...   Jan 25 2004, 11:05
- - musicmusic   QUOTE (juglesh @ Jan 24 2004, 08:59 PM)(win98...   Jan 25 2004, 17:01
- - fantomex   am i the only one who gets this?   Jan 25 2004, 18:16
- - lightbulb   QUOTE (fantomex @ Jan 25 2004, 09:16 AM) am i...   Jan 25 2004, 18:45
- - Tri   While playing around I noticed that the 'Item ...   Jan 25 2004, 20:33
- - Mike Giacomelli   This looks great. keep up the good work.   Jan 25 2004, 22:33
- - Mike Giacomelli   QUOTE (Tri @ Jan 23 2004, 10:56 AM)It looks v...   Jan 25 2004, 22:36
- - Funkstar De Luxe   QUOTE (Mike Giacomelli @ Jan 25 2004, 01:36 P...   Jan 25 2004, 22:59
- - YinYang   Win98SE bug here. It seems that I cannot manually...   Jan 25 2004, 23:42
- - juglesh   QUOTE QUOTE (juglesh @ Jan 24 2004, 08:59 PM) whe...   Jan 25 2004, 23:42
- - Killmaster   Some thoughts and suggestions: -Setting custom st...   Jan 26 2004, 00:39
- - Tri   QUOTE (Mike Giacomelli @ Jan 25 2004, 10:36 P...   Jan 26 2004, 06:22
- - kerpondile   apparently taskbar balloon tip on song change is n...   Jan 26 2004, 18:11
- - The Link   QUOTE (kerpondile @ Jan 26 2004, 06:11 PM)app...   Jan 26 2004, 18:15
- - musicmusic   QUOTE (fantomex @ Jan 25 2004, 05:16 PM) am i...   Jan 26 2004, 19:56
- - treech   Very cool, works with w2k + sp4 now anyway, i did...   Jan 26 2004, 20:54
- - Tri   With alpha 5, the right-click menu doesn't wor...   Jan 26 2004, 21:09
- - rectangle   Right click context menu items now not working in ...   Jan 26 2004, 21:21
- - Haggis   QUOTE (musicmusic @ Jan 26 2004, 10:56 AM)Doe...   Jan 26 2004, 22:29
- - musicmusic   QUOTE (treech @ Jan 26 2004, 07:54 PM)Very co...   Jan 26 2004, 22:30
- - musicmusic   My post got cut off somehow Tri & rectangle...   Jan 26 2004, 22:36
- - treech   Also, ONE color property for all fields would be u...   Jan 26 2004, 23:36
- - juglesh   QUOTE Does anyone have any requests for columns. I...   Jan 27 2004, 04:43
- - Sid59   getting better and better .. good job. you change...   Jan 27 2004, 09:38
- - kerpondile   This is small feature, but is it possible statusba...   Jan 27 2004, 11:15
- - Speek   And another request: could you make the playlist 3...   Jan 27 2004, 14:42
- - ginipig1   Looking good   Jan 27 2004, 14:53
- - kalmark   I like it, I like it!!! Suggestions:...   Jan 27 2004, 16:33
- - foosion   QUOTE (juglesh @ Jan 27 2004, 04:43 AM)what a...   Jan 27 2004, 18:05
- - ginipig1   what do you mean foosion? Since this dll is still...   Jan 27 2004, 18:32
- - foosion   QUOTE (ginipig1 @ Jan 27 2004, 06:32 PM)Since...   Jan 27 2004, 19:41
- - ginipig1   bleh, i misread his post.. I thought he meant 1 ho...   Jan 27 2004, 21:46
- - juglesh   @ ginipig1 and foosion: guys...hello? foobar is su...   Jan 27 2004, 22:00
- - ginipig1   QUOTE (juglesh @ Jan 27 2004, 01:00 PM)@ gini...   Jan 27 2004, 22:16
- - foosion   QUOTE (juglesh @ Jan 27 2004, 10:00 PM)@ gini...   Jan 27 2004, 22:26
- - musicmusic   You misinterpreted me - i meant text alignment. Y...   Jan 28 2004, 22:18
- - fantomex   QUOTE (musicmusic @ Jan 26 2004, 07:56 PM)QUO...   Jan 28 2004, 22:43
- - fantomex   edit, something IS wrong with me   Jan 28 2004, 22:48
- - The Link   This is getting really cool! Even the defau...   Jan 28 2004, 23:03
- - BlueScreenJunky   wow, sweeeet ! I love your UI, maybe still a f...   Jan 28 2004, 23:08
- - kerpondile   Good job!! This component looks very good...   Jan 28 2004, 23:11
- - kalmark   Stuff worth mentoning: 1) You can only en/disable...   Jan 28 2004, 23:30
- - foosion   QUOTE (kerpondile @ Jan 28 2004, 11:11 PM)The...   Jan 29 2004, 00:08
- - Speek   QUOTE (musicmusic @ Jan 28 2004, 10:18 PM)QUO...   Jan 29 2004, 00:14
- - BlueScreenJunky   err... in the default config the length string has...   Jan 29 2004, 00:43
- - kode54   QUOTE (BlueScreenJunky @ Jan 28 2004, 03:43 P...   Jan 29 2004, 01:33
- - juglesh   QUOTE when pressing a key in the playlist could ta...   Jan 29 2004, 01:44
- - meatsoup   I absolutely love this UI, but I have a problem wi...   Jan 29 2004, 01:51
- - BlueScreenJunky   QUOTE It shows the elapsed time on whichever file ...   Jan 29 2004, 02:37
- - treech   Gettingreally good, but there are a few more thing...   Jan 29 2004, 02:37
- - Haggis   QUOTE (BlueScreenJunky @ Jan 28 2004, 05:37 P...   Jan 29 2004, 02:45
- - slayerbeast   hey i think it would be cool if it could have a pa...   Jan 29 2004, 08:28
- - kerpondile   QUOTE (foosion @ Jan 28 2004, 03:08 PM)QUOTE ...   Jan 29 2004, 08:58
- - bisley   good job musicmusic, i like so much this ui but ...   Jan 29 2004, 12:32
- - bisley   and one thing more... i choose one of the playlis...   Jan 29 2004, 17:10
- - kerpondile   QUOTE (juglesh @ Jan 28 2004, 04:44 PM)when p...   Jan 29 2004, 17:46
- - Lyx   hi, my 2 cents about this promising alternate GUI...   Jan 29 2004, 18:07
- - Lyx   ok, here're some basic things which come to my...   Jan 29 2004, 19:20
- - Speek   Musicmusic, Thanks for the sunken effect option. ...   Jan 29 2004, 21:07
- - musicmusic   Do you mean pressing the wheel (autoscroll) or tu...   Jan 29 2004, 21:18
- - treech   musicmusic: thanks for the fixes, very cool   Jan 29 2004, 21:57
- - Lyx   QUOTE 1. then you cant set diff background colours...   Jan 29 2004, 22:03
- - kerpondile   QUOTE QUOTE (kerpondile @ Jan 28 2004, 10:11 PM) ...   Jan 29 2004, 22:36
- - musicmusic   QUOTE (treech @ Jan 29 2004, 08:57 PM)musicmu...   Jan 29 2004, 22:44
- - musicmusic   QUOTE (Lyx @ Jan 29 2004, 09:03 PM)QUOTE 1. t...   Jan 29 2004, 22:47
- - The Link   QUOTE Do you mean pressing the wheel (autoscroll) ...   Jan 29 2004, 22:57
- - treech   QUOTE EDIT: cropping ? wtf is that?  Ok that...   Jan 29 2004, 23:01
- - kode54   Reducing the color formatting of all columns to on...   Jan 30 2004, 00:17
- - rectangle   right click on playlist tab "Save Playlist...   Jan 30 2004, 00:30
- - genmu   Thanks for this great UI... ^^ One minor request:...   Jan 30 2004, 00:43
- - BlueScreenJunky   QUOTE 6. probably some bad calculations when resiz...   Jan 30 2004, 01:03
- - Fickle   I cant seem to remove the playback buttons when us...   Jan 30 2004, 15:42
- - treech   QUOTE Illegal operation: Code: C0000094h, flags: 0...   Jan 30 2004, 17:19
- - treech   Disturbing, just found all of my columns getting s...   Jan 30 2004, 19:03
- - kode54   QUOTE (treech @ Jan 30 2004, 10:03 AM)Disturb...   Jan 30 2004, 19:52
- - dewey1973   I feel like a dolt, but I can't get this to do...   Jan 30 2004, 19:55
- - kode54   QUOTE (musicmusic @ Jan 29 2004, 12:18 PM)- f...   Jan 31 2004, 05:28
- - musicmusic   QUOTE (Fickle @ Jan 30 2004, 02:42 PM)I cant ...   Feb 1 2004, 16:41
- - treech   QUOTE it also seems to remove a few of the new 0.8...   Feb 1 2004, 21:33
- - kode54   QUOTE (treech @ Feb 1 2004, 12:33 PM)QUOTE it...   Feb 1 2004, 21:40
- - kerpondile   Shortcutkeys doesn't appear to work when you h...   Feb 1 2004, 21:45
70 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 23rd May 2015 - 14:25
