foo_dumb, experimental new modplugin, by Kode54
deus-ex
post Sep 9 2004, 22:54
Hello Kode54,
You introduced a new modplugin named foo_dumb. I gave it a test run against foo_mod right away (just downloaded latest version 9.9.2004).
In comparison its soundoutput is not as clear as foo_mod utilizing bass.dll. It sounds softer, as if there's some textile between the speakers and
your ears. Also i found the .it-format support not as "balls on accurate" like provided with the bass.dll. I uploaded a file named Chris35b.it to
demonstrate this. At start of the second order (after ~8 sec. playtime) you'll hear a ~hiss~ sound which is intended to be there but foo_dumb
puts it too much into the foreground so that it sounds anoyingly wrong. Please also check foo_dumb with uploaded 303.it. It loses so much quality
against replaying with foo_mod.
Second file in the upload named F0x-Test.xm fails to be loaded with foo_dumb. It features some weird special undocumented Fasttracker tricks.
It does sound very uncommon but it is a very good test file i guess. Once Xmplay had problems with this file too, until i send it to Ian (Xmplay author)
so he was able and kind enough to fix it.
Visiting DUMB's homepage and checking its CVS on sourceforge it seems that the project came to halt since a very long time. Is that correct?
If so i hope you can maintain and fix the code for your plugin if necessary.
Btw., everytime you update one of your plugins i wonder what has changed. Recently you updated foo_mod (my favorite plugin) and foo_dumb
quite often though their version number did'nt change. Maybe you can put a little file_id.diz or readme.txt along with the plugin mentioning the
changes if its not too much to ask for?
One suggestion/question please: (don't beat me for asking this) biggrin.gif
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
I don't know if bass.dll/dumb library provides necessary data but is it possible to have pattern view like in Xmplay?
Edited 18-10-2004: Downloadlink as a service for new threadvisitors.
Download latest version of Foo_Dumb
Regards, deus-ex.
This post has been edited by deus-ex: Oct 18 2004, 16:19
Best regards
deus-ex (MODLAND co-admin: ftp://ftp.modland.com)
deus-ex
post Sep 18 2004, 17:21
Trauma.okt wont load with v0.9.2.9. It's the only .okt file of my collection.
Algory.ptm: Effect "Porta to Note/Porta down" seems to sound wrong. Start from ~2.05 min or Order 1D, Channel 14 and 15, Porta to Note/Porta down sounds probably wrong in comparison to Open Cubic Player.
Sidenote: In_Mod handles the effect same way as foo_dumb.
Foo_Dumb Testfiles 4
deus-ex
Best regards
- deus-ex   foo_dumb   Sep 9 2004, 22:54
- - kode54   Chris35b.it doesn't sound much different from ...   Sep 9 2004, 23:46
|- - deus-ex   QUOTE (kode54 @ Sep 9 2004, 11:46 PM)Chris35b...   Sep 10 2004, 00:32
- - lll9p_1   Where can i download it?   Sep 10 2004, 05:48
|- - Silverbolt   QUOTE (lll9p_1 @ Sep 9 2004, 08:48 PM)Where c...   Sep 10 2004, 06:31
- - kode54   Uploaded v0.9.2.1.Fixed infinite running / load-ti...   Sep 10 2004, 10:23
|- - deus-ex   QUOTE (kode54 @ Sep 10 2004, 10:23 AM)Uploade...   Sep 10 2004, 11:56
- - kode54   Uploaded v0.9.2.2.Fixed panning slide/shift effect...   Sep 10 2004, 14:39
- - deus-ex   Checked updated foo_dumb v0.9.2.2. Cregaia.it issu...   Sep 10 2004, 21:53
|- - kode54   QUOTE (deus-ex @ Sep 10 2004, 01:53 PM)C...   Sep 11 2004, 10:12
|- - deus-ex   QUOTE (kode54 @ Sep 11 2004, 10:12 AM)...DUMB...   Sep 11 2004, 21:59
|- - kode54   DOSBox 0.61+ CVS build, dated 2004-Sep-07, from h...   Sep 12 2004, 04:29
- - deus-ex   QUOTE (kode54 @ Sep 12 2004, 04:29 AM)DOSBox ...   Sep 12 2004, 14:25
- - bleh   I might as well join the party and point out that ...   Sep 12 2004, 18:03
- - kode54   Not accessasble because of a 'two posting...   Sep 13 2004, 10:31
|- - deus-ex   QUOTE (kode54 @ Sep 13 2004, 10:31 AM)...now ...   Sep 13 2004, 13:34
|- - deus-ex   QUOTE (deus-ex @ Sep 13 2004, 01:34 PM)Q...   Sep 14 2004, 11:28
|- - kode54   QUOTE (deus-ex @ Sep 14 2004, 03:28 AM)-...   Sep 15 2004, 06:19
|- - deus-ex   QUOTE (kode54 @ Sep 15 2004, 06:19 AM)I can t...   Sep 15 2004, 13:35
|- - kode54   QUOTE (deus-ex @ Sep 15 2004, 05:35 AM)Q...   Sep 15 2004, 18:42
|- - deus-ex   QUOTE (kode54 @ Sep 15 2004, 06:42 PM)Which, ...   Sep 15 2004, 20:05
- - bleh   Okay, envelope carry is cool now in the quick exam...   Sep 13 2004, 13:48
|- - kode54   QUOTE (bleh @ Sep 13 2004, 05:48 AM)Okay, env...   Sep 13 2004, 17:49
- - deus-ex   Version 0.9.2.4 crashed on some .it-files here too...   Sep 13 2004, 20:24
- - bleh   1. Cool, the crash is fixed on my system as well....   Sep 13 2004, 21:17
|- - deus-ex   QUOTE (bleh @ Sep 13 2004, 09:17 PM)2.  The I...   Sep 13 2004, 23:00
- - bleh   Whoa, I'm sorry, I've been listening with ...   Sep 13 2004, 23:39
- - kode54   Uploaded v0.9.2.6.Corrected sample offset for PTM ...   Sep 14 2004, 03:00
- - holox   You can get Dosbox cvs compiles from CVS Compile w...   Sep 14 2004, 13:02
|- - deus-ex   QUOTE (holox @ Sep 14 2004, 01:02 PM)You can ...   Sep 14 2004, 13:36
- - deus-ex   Jos-Dr4k.xm fails to load both with foo_dumb and f...   Sep 15 2004, 17:51
- - kode54   QUOTE (deus-ex @ Sep 15 2004, 12:05 PM)Q...   Sep 16 2004, 09:27
|- - deus-ex   QUOTE (kode54 @ Sep 16 2004, 09:27 AM)I'v...   Sep 16 2004, 13:55
|- - kode54   QUOTE (deus-ex @ Sep 16 2004, 05:55 AM)Q...   Sep 16 2004, 16:36
|- - deus-ex   QUOTE (kode54 @ Sep 16 2004, 04:36 PM)Which q...   Sep 16 2004, 19:31
|- - kode54   QUOTE (deus-ex @ Sep 16 2004, 11:31 AM)1...   Sep 17 2004, 10:15
|- - deus-ex   QUOTE (kode54 @ Sep 17 2004, 10:15 AM)I was p...   Sep 17 2004, 12:27
- - bleh   QUOTE HAHA, the OKT format is just another MOD-lik...   Sep 17 2004, 13:42
|- - kode54   QUOTE (bleh @ Sep 17 2004, 05:42 AM)QUOTE HAH...   Sep 17 2004, 17:16
- - ep0ch   I don't suppose it will be possible to get the...   Sep 17 2004, 14:36
- - GenjuroXL   I think supporting DW would mean emulating an m68k...   Sep 17 2004, 16:55
- - deus-ex   Open Cubic Player 2.60pre6 sources also contain co...   Sep 17 2004, 17:33
- - kode54   QUOTE (ep0ch @ Sep 17 2004, 06:36 AM)I don...   Sep 17 2004, 17:34
- - jsheridan   Invalid behaviour with this   Sep 17 2004, 18:52
- - deus-ex   Rezipped DISCVRY.MOD for everyone who can't ac...   Sep 17 2004, 21:08
- - kode54   Uploaded v0.9.2.9.Implemented Xxx panning effect b...   Sep 18 2004, 02:11
- - jsheridan   Invalid playback starting from 1:01 (only one stri...   Sep 18 2004, 11:46
- - deus-ex   Trauma.okt wont load with v0.9.2.9. It's the o...   Sep 18 2004, 17:21
- - bleh   That's other, "other," OKT format I ...   Sep 18 2004, 18:43
- - deus-ex   Trauma.okt can be played with Winamp In_Mod and Op...   Sep 18 2004, 20:07
- - kode54   Uploaded v0.9.2.10.S3M reader now disposes of effe...   Sep 19 2004, 19:31
|- - jsheridan   QUOTE (kode54 @ Sep 19 2004, 10:31 AM)Uploade...   Sep 19 2004, 21:34
- - deus-ex   Acknowleged, Algory.ptm playback is better than wh...   Sep 20 2004, 22:29
- - kode54   Uploaded v0.9.2.10.1.Initializes channel sample nu...   Sep 21 2004, 04:06
- - deus-ex   Warswa.xm replay fixed, thank you. Found some prob...   Sep 21 2004, 17:56
- - kode54   Uploaded v0.9.2.11.Implemented PSM format reader. ...   Sep 22 2004, 02:46
- - deus-ex   All .mod-format problems fixed. The PSM format us...   Sep 22 2004, 16:43
- - T&L   Hi, there's a problem playing tense.s3m (music...   Sep 22 2004, 21:20
|- - foosion   QUOTE (T&L @ Sep 22 2004, 10:20 PM)It see...   Sep 22 2004, 21:57
|- - kode54   QUOTE (T&L @ Sep 22 2004, 01:20 PM)Hi, th...   Sep 22 2004, 23:49
|- - T&L   QUOTE (kode54 @ Sep 23 2004, 01:49 AM)If you ...   Sep 23 2004, 22:07
- - deus-ex   Output of PSM format sounds excellent, better than...   Sep 25 2004, 15:18
- - kode54   Just what I always wanted, a PSM with multiple SON...   Sep 26 2004, 04:00
- - deus-ex   Game "Silverball", 01-TITLE.S3M, a conve...   Sep 26 2004, 12:54
- - kode54   Uploaded v0.9.2.12.Extended PSM reader to support ...   Sep 27 2004, 15:20
- - deus-ex   All previously reported problems fixed. Subsong fe...   Sep 28 2004, 15:43
- - kode54   Subsong index is conveniently a core feature, so y...   Sep 29 2004, 08:21
- - T&L   Can't download the plugin from kode54's si...   Sep 29 2004, 17:15
- - deus-ex   Kode54's plugin site is temporarily unavailabl...   Sep 29 2004, 19:50
- - deus-ex   Thanks for hinting the %_subsong% variable. That...   Sep 30 2004, 13:23
- - kode54   Uploaded v0.9.2.12.2.Removed checkpoint list / len...   Sep 30 2004, 16:04
- - deus-ex   This Examples demonstrate several problems i found...   Oct 1 2004, 12:00
- - kode54   Uploaded v0.9.2.13.Changed subsong scanner to chec...   Oct 1 2004, 18:07
- - deus-ex   Here goes next round for v0.9.2.13: Providing down...   Oct 2 2004, 15:13
|- - kode54   Nonexisting Subsong:ninja philosophy.it - Silent p...   Oct 2 2004, 18:36
- - deus-ex   Allright, all v0.9.2.13 probs sorted. Regarding ...   Oct 2 2004, 19:57
|- - kode54   QUOTE (deus-ex @ Oct 2 2004, 11:57 AM)Al...   Oct 2 2004, 23:33
|- - deus-ex   QUOTE (kode54 @ Oct 2 2004, 11:33 PM)I've...   Oct 3 2004, 12:27
- - nIRV   could you indicate a place where I could download ...   Oct 3 2004, 13:10
|- - Case   QUOTE (nIRV @ Oct 3 2004, 03:10 PM)could you ...   Oct 3 2004, 13:15
- - kode54   Uploaded v0.9.3.Old PSM format support.MTM support...   Oct 4 2004, 07:32
- - deus-ex   Woah, you're updating faster than i can follow...   Oct 4 2004, 14:14
- - kode54   Uploaded v0.9.3.2.Removed part of my last NNA chan...   Oct 4 2004, 14:31
- - deus-ex   What the f...? You killed Lucky Luke. Pushed some...   Oct 4 2004, 14:56
- - kode54   Uploaded v0.9.3.3.Fixed glissando control, it was ...   Oct 4 2004, 16:14
- - deus-ex   Ok, .mtm crashes sorted. All the .mtm's of my ...   Oct 4 2004, 16:43
|- - kode54   QUOTE (deus-ex @ Oct 4 2004, 08:43 AM)Ad...   Oct 4 2004, 17:08
- - deus-ex   I recommend to use In_Adlib.dll along with the Win...   Oct 5 2004, 15:15
|- - deus-ex   QUOTE (deus-ex @ Oct 5 2004, 03:15 PM)Th...   Oct 7 2004, 19:50
- - bigboo   HI I just tested your new mod plug-in and it seem...   Oct 5 2004, 22:30
- - kode54   Uploaded v0.9.3.4.Fixed pitch pan separation for n...   Oct 6 2004, 03:44
|- - deus-ex   QUOTE (kode54 @ Oct 6 2004, 03:44 AM)QUOTE DS...   Oct 6 2004, 16:40
- - bigboo   Thanks for all those detailled infos and the quick...   Oct 6 2004, 13:22
- - kode54   My friend just checked 16th intro.mod, the first ...   Oct 6 2004, 15:00
|- - bigboo   QUOTE (kode54 @ Oct 6 2004, 04:00 PM)My frien...   Oct 6 2004, 15:19
- - kode54   Uploaded v0.9.3.6.Fixed volume swing, which is rel...   Oct 7 2004, 00:04
- - deus-ex   No need to investigate further, with v0.9.3.6 all ...   Oct 7 2004, 14:20
- - deus-ex   Hello (fading echo: hello... hello... hello...), a...   Oct 14 2004, 14:30
- - kode54   Uploaded v0.9.4.Implemented mostly dodgy volume ra...   Oct 14 2004, 23:13
- - deus-ex   First listening test with volume ramping enabled s...   Oct 15 2004, 16:42
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 26th January 2015 - 21:14
