Which drives are caching audio data?
norton
post Sep 1 2004, 14:35
EAC => What about the 'caching audio data'!?
I have read almost everything on this forum about this subject.
No doubt about it: If the Drive you are using to rip with EAC is caching audio data, the 'Drive caches audio data' Box (Drive options... / Extraction method) have to be checked (ticked).
But how can you know if your Drive is caching audio data?
Of what I have read on this forum, you should run 'Detect Read Features' (Drive options... / Extraction method / Detect Read Features). If the result is: Caching: No => You're OK! If the result is: Caching: Yes => You have to checked the 'Drive caches audio data' Box.
Well... The problem is, many people are saying that the 'Detect Read Features' is NOT accurate!!! (How do they know that??) That means even if you perform 'Detect Read Features', you are still not sure if your Drive is caching audio data, or not.
MY QUESTION IS: How can I know if my Drive is Caching audio data, or not?
Thanks for helping,
norton
This post has been edited by norton: Sep 1 2004, 16:21
Pio2001
post Sep 1 2004, 18:49
Moderator
The EAC detection feature is not accurate because sometimes it reports caching, sometimes not, for the same drive.
Sometimes, EAC reports no caching while Feurio does. We have 2 or 3 examples of this, but none of the opposite. It is too few to draw any conclusion of Feurio's detection accuracy against EAC.
To know if your drive caches :
Ask EAC. If it says yes, then it caches.
If it says no, try Feurio. If it says yes, then it caches. If it says no, try the following :
If your drive supports C2
Enable C2, uncheck cache, and find a CD lightly damaged, that triggers error correction (red lights), but still give you no errors on a range which triggers the first red bar at least 20 times.
Test and copy this range.
If the CRC are the same, your drive doesn't cache.
If the CRC are different,
Check cache and try again.
If you can't get "no error" anymore, it is likely that your drive caches. Whatever, leave it checked, since it obviously make the secure mode work properly.
If you still get no errors, but CRC are OK, your drive caches.
If you get no errors and CRC still mistmatch, find a less damaged CD, or try a shorter range.
If your drive doesn't support C2,
...But also valid if it supports C2.
Check cache, and try to find a CD lightly damaged, so that it reports no errors, but which the first red bar filled at least 20 times, and CRC are OK.
Uncheck cache. Test and copy.
If you get errors, find a less damaged CD or range.
If you get 100 % quality (no red bars) and CRC mismatch, your drive caches.
If you get 100% quality and CRC are OK, find a more damaged range or CD and try again.
If you still get red bars, but CRC mismatch, your drive caches.
If you still get red bars and CRC are OK, your drive doesn't cache.
liekloo
post Oct 17 2004, 18:39
QUOTE (Pio2001 @ Sep 1 2004, 06:49 PM)
I fully agree with the rest of your instructions, but here is a sentence that contradicts with what I have in mind: I don't see how a caching drive with cache unchecked, can cause any red bars.
Here is my reasoning: AFAIK the red bars are only triggered due to a difference in the 2 audio sector reads. However the caching drive with cache unchecked will always return the same cached data, without any differences and thus without triggering the red bars.
Am I overlooking something?
"E S S E N T I A L" Guide for E A C :
http://users.fulladsl.be/spb2267/
Pio2001
post Oct 23 2004, 03:02
Moderator
QUOTE (liekloo @ Oct 17 2004, 07:39 PM)
It is only true if the cache is bigger than 62 kB. If it is smaller, only a part of what EAC reads is cached (EAC reads by bursts of 62 kB).
rutra80
post Oct 23 2004, 04:57
Group: Members (Donating)
QUOTE (Pio2001 @ Oct 23 2004, 04:02 AM)
Does cache = drive's buffer? If my DVD writer has a 2MB buffer, and my DVD-ROM drive a 512KB buffer, then if they were caching, would they cache 2MB and 512KB of audio data?
This post has been edited by rutra80: Oct 23 2004, 05:03
- norton   Which drives are caching audio data?   Sep 1 2004, 14:35
- - Pio2001   The EAC detection feature is not accurate because ...   Sep 1 2004, 18:49
|- - liekloo   QUOTE (Pio2001 @ Sep 1 2004, 06:49 PM)Uncheck...   Oct 17 2004, 18:39
|- - Pio2001   QUOTE (liekloo @ Oct 17 2004, 07:39 PM)the re...   Oct 23 2004, 03:02
|- - rutra80   QUOTE (Pio2001 @ Oct 23 2004, 04:02 AM)It is ...   Oct 23 2004, 04:57
- - markanini   Pio2001, that's the best explaination I've...   Sep 1 2004, 18:59
- - norton   QUOTE To know if your drive caches : Ask EAC. If i...   Sep 1 2004, 22:04
|- - Pio2001   QUOTE (norton @ Sep 1 2004, 11:04 PM)I was wo...   Sep 1 2004, 23:06
|- - minix   QUOTE (norton @ Sep 1 2004, 11:04 PM)I was wo...   Sep 2 2004, 23:53
- - norton   Well... I QUIT!! I have spent the last 1...   Sep 1 2004, 23:00
- - dreamliner77   QUOTE (norton @ Sep 1 2004, 06:00 PM)Well......   Sep 2 2004, 00:03
|- - mai9   QUOTE (dreamliner77 @ Sep 2 2004, 12:03 AM)I...   Oct 24 2004, 01:51
- - norton   QUOTE I'd say be safe and just check "dri...   Sep 2 2004, 00:32
- - kwanbis   just listen to them ... or a random sample   Sep 2 2004, 03:20
- - norton   QUOTE just listen to them ... or a random sample ...   Sep 2 2004, 03:48
- - VolMax   Caching or not, it doesnt matter for me now. The ...   Sep 2 2004, 05:26
|- - Pio2001   Your results are interesting, but they are all abo...   Sep 2 2004, 12:05
- - VolMax   QUOTE Your results are interesting, but they are a...   Sep 2 2004, 15:54
|- - Never_Again   QUOTE (VolMax @ Sep 2 2004, 10:54 AM)What is ...   Sep 2 2004, 16:50
- - norton   About ASUS CD-S520/A4... On the ASUS website, in ...   Sep 2 2004, 16:07
- - norton   QUOTE Make sure DMA is enabled for your drive. Feu...   Sep 3 2004, 01:31
- - VolMax   QUOTE VolMax and Pio: what feature are you two tal...   Sep 3 2004, 04:58
|- - Never_Again   QUOTE (VolMax @ Sep 2 2004, 11:58 PM)Drive co...   Oct 19 2004, 08:34
- - Pio2001   No, the audio cache can be smaller than the data c...   Oct 24 2004, 00:11
|- - rutra80   QUOTE (Pio2001 @ Oct 24 2004, 01:11 AM)No, th...   Oct 24 2004, 05:17
|- - Triza   QUOTE (rutra80 @ Oct 23 2004, 08:17 PM)QUOTE ...   Oct 24 2004, 09:09
- - rutra80   If there is a 100% reliable method to determine ho...   Oct 26 2004, 10:48
RSS Lo-Fi Version Time is now: 30th March 2015 - 12:30
